Clio Rs Line+alt sandero+o motoretă
wolfin |
#841
![]() Haha Group: Members Posts: 8.937 Joined: 2 December 05 From: Bucuresti ![]() |
pegas
3120
CGB |
#842
![]() CGB Group: Members Posts: 2.455 Joined: 4 May 05 From: behind ![]() |
Ca sa pornesc masina? Cum se face asta?
Clio RS Line
2022 _______________
Raduchu |
#843
![]() Nu-mi arde becu' Group: Members Posts: 1.453 Joined: 21 April 09 ![]() |
Haidi bre ca sigur s-au gandit injinerii de la Reno ca bateria aia de la cheie se mai consuma si ea
![]() Poti sa faci o proba fara baterie in cartela, daca esti curios..imposibil sa nu porneasca. |
Renault 25 '86
2 x Volkswagen Passat
'08 Highline '10 R-Line There is a light somewhere, it may not be much, but it beats the darkness!
Rage, rage against the dying of the light! 500.000 km and counting. |
wolfin |
#844
Cheia..e ascunsa prin card. O folosesti sa descui masina. Daca e suficient de aproape de imobilizator.(cardul)..ar trebui sa porneasca din buton.
Amu...s ar putea sa porneasca alarma...daca e din fabrica...dar odata cu pornirea ar trebui sa se opreasca. Cum zicea @mucix.....read the fucking manual ![]() This post has been edited by wolfin: 9 Nov 2024, 20:42 |
pegas
3120
cj98czh |
#845
![]() Membru de la Cluj ... Group: Moderatori Posts: 23.376 Joined: 27 March 06 From: Cluj-Napoca ![]() |
scoti cheia din card, deschizi usa de la sofer dupa ce ai dat capacelul jos, bagi cartela in slotul de card si porneste ..
Mazda 3
Zoom-Zoom
2018
bgdrenault |
#846
![]() bgd Group: Members Posts: 3.569 Joined: 4 February 07 From: Piatra Neamt ![]() |
Probabil nu are slot de card, dar se apropie cartela de buton si se apasa, si porneste
Megane
Sedan 1,33 140 CP
2019 Intens
- XXX
wolfin |
#847
Sau cu comanda vocala.
pegas
3120
miki |
#848
![]() #Hırsızlargibigeceniniçine Group: Members Posts: 1.239 Joined: 30 July 02 From: Bucuresti ![]() |
Sedan 1.6 16V / Megane IV 1.33 TCE/Santa Fe
2004 / 2019/2008
bgdrenault |
#849
Megane
Sedan 1,33 140 CP
2019 Intens
- XXX
wolfin |
#850
Da.
Bine nu call ci ..Go baby go |
pegas
3120
cj98czh |
#851
Mazda 3
Zoom-Zoom
2018
harby ;)) |
#852
![]() Membru Group: Members Posts: 1.371 Joined: 3 July 12 From: Pitesti ![]() |
Renault 12 Gordini
Pontiac Firebird
1972, 1980
CGB |
#853
La ultimu drum cu masina nu afisa nimic. Asta acu aproape 2 luni. A aparut insa mesaju ala cu baterie slaba dupa ce am schimbat bateria si am pornit masina. Si aparea inainte de fiecare pornire, desi schimbasem bateria. Ca sa scap de el tre apasat de 4 ori un buton de pe cartela in timp ce esti langa masina. Asa scrie in carte. Apropo, bateria este un cr2032H. H vine de la high discharge rate. Plm nu stiam d-astea. Deci luati o baterie cr2032 cu cati mai multi mAh ca sa tina mai mult.
Asta era bateria originala din card si fisa ei, pentru care-i interesat This post has been edited by CGB: 11 Nov 2024, 08:23 Attached thumbnail(s) IMG_20241111_081927.jpg ( Size: 303.99k ) Number of downloads: 399 IMG_20241111_081810.jpg ( Size: 842.11k ) Number of downloads: 396 |
Clio RS Line
aqua |
#854
![]() Membru autentic Group: Members Posts: 2.251 Joined: 24 February 05 From: Bucuresti ![]() |
la kia a inceput cu cateva momente cand apasam pe buton din maner usa si nu se intampla nimic, m-am dat mai aproape mai departe si am stat vreo 5 minute pe langa ea, am uitat ca am cheia fizica in ea ca asa e cand nu o folosesti, in final a mai gasit ceva energie prin ea si mi-a deschis usa dar masina pornea ok
dupa care, a mers f bine merci inca cateva zile si am uitat de incident, apoi iar am stat pe langa ea pana s-a hotarat sa deschida, doar ca acum nu mai facea nimic la ponire motor, stiam ca tre sa apas cu cheia direct pe boton sa faca contact fizic, si chiar a pornit , niciun mesaj in bord de baterie slaba cumparat 2 baterii si schimbat la ambele chei, au tinut vreo 4 ani |
ex. megane dci,
ex. Sportage GDI
2017 Sportage 2020 AWD T-GDI
#855
![]() fan Dacia Group: Members Posts: 21.579 Joined: 12 November 05 From: Bucuresti ![]() |
QUOTE(CGB @ 9 Nov 2024, 16:34) Azi oleaca de panica de la clio. Ajung la masina, apuc maneru sa dășchid usa, canci. Scot cartela, apas botonu, canci. Scot cheia aia din cartela, dășchid usa, apas botonu canci. Mortus coptus. Scarpinat in cap, facut 100 m, mers la altex luat una bucata baterie ptr card, cr20232. Scimbat baterie. Totu ok. Bine ca nu eram in poola cu satelitu pîn vreun pustiu. Clio era nefolosit de vreo luna juma. Bine ca n-a fost bateria de pe masina. Battery life Make sure that the correct battery type is being used, and that the battery is in good condition and inserted correctly. Its service life is approximately two years: it should be replaced when the message “Keycard Battery Low” appears on the instrument panel CARD: battery. Special features of the unlocking system Under certain circumstances, approach unlocking is deactivated: - after eight days of no use of the vehicle; - if the card remains close to the 3 area of the vehicle for approximately five minutes after the vehicle has been locked; - after several passes in the vicinity of the 3 area of the vehicle and without the door being unlocked. Use the remote control card or, depending on the vehicle, press the 2 button on the door handle 1 to unlock the vehicle and reactivate the mode. Operating faults In certain cases, the hands-free card may not work: - card battery flat, etc.; - near to appliances operating on the same frequency as the card (monitor, mobile phone, video game, etc.); - vehicle located in a high electromagnetic radiation zone. The message “Place card on zone + START” appears on the instrument panel. Press the brake or clutch pedal, then place the card 5 (button side) on the placement area 4. Press the 2 button to start the vehicle. The message goes out. https://gb.e-guide.renault.com/eng/Clio-5/K...ut-your-vehicle |
- negru pe alb
CGB |
#856
Acu 2 saptamani au cazut usebeurile la clio. In mers. Nu mai citeau nimic, nu mai incarcau telefonu. Sucombate conplet. Verificat siguranta, totu ok. Oprit si repornit masina. Au revenit la viata.
Acu o saptamana am stat mai mult cu hayonu dășchis si a aparut pa bord ''baterie slaba porniti motorul''. Asta dupa un drum lung de 300 km. Asa ca bateria nu avea cum sa fie descarcata. In fine am pornit la drum si ptr inca 300 km am mers cu mesaju "bateria se incarca" in bord. La destinatie am oprit motorul apoi am repornit si mesajul a disparut. Concluzia: ceva bube in soft. Daca patiti ciudatenii d-astea, opriti si reporniti motorul inainte de-a va panica. Posibil sa se rezolve cu aceasta metoda de "restart". This post has been edited by CGB: 14 Jan 2025, 14:02 |
Clio RS Line
MyKe89 |
#857
![]() Membru RFG Group: Members Posts: 3.070 Joined: 16 December 07 From: Bucuresti ![]() |
Management prost al bateriei.
Să vezi când te rogi de ea să reînvie la semafor din S&S. |
'23 Honda
CR-V
e:HEV '02 BMW Z3 1.9i
'91 MB W124 230E |
cj98czh |
#858
eu nu stiu cum sa opresc SS si tu te rogi sa invie
Mazda 3
Zoom-Zoom
2018
wolfin |
#859
Sa reinvie masina..nu s&s
pegas
3120
cj98czh |
#860
priceput din prima .. dar daca al doilea buton dupa cel de strat este SS off, nu are de unde sa invie ..
stai ca am gasit si fara buton de SS deloc .. din fabrica .. la alti producatori .. |
Mazda 3
Zoom-Zoom
2018
#861
da, la Peugeot, unde intri in tableta sa opresti.....
This post has been edited by einstein1984: 14 Jan 2025, 17:11 |
- negru pe alb
Habba |
#862
![]() Vizionar Group: Members Posts: 571 Joined: 24 January 17 ![]() |
Și la Skoda tot din tabletă...la generațiile anterioare era buton fizic, s-a dus și ăla.
ex Dacia
2005, Laureate 1.4mpi-K7J Drugs are bad, mkay?
bgdrenault |
#863
Ca idee, de ce se mai lasa totusi optiunea de a anula start stopul?
Nu ca imi place, la megane e dezactivat permanent de la contact capota, dar daca esti ecologist, de ce sa mai lasi optiunea? |
Megane
Sedan 1,33 140 CP
2019 Intens
- XXX
wolfin |
#864
Daca esti ecologist mergi cu bicicleta sau transport in comun.
Iar Renault si oricare....corporatie ....incalcite sunt deciziile oricare ar fi alea This post has been edited by wolfin: 14 Jan 2025, 18:09 |
pegas
3120
axabrt |
#865
![]() Membru autentic Group: Members Posts: 4.139 Joined: 15 February 05 From: Ploiesti ![]() |
Nimic nu știți.
Daca tu ești ecologist și mergi cu biticleta pe lângă unul cu diesel care sta la semafor cu start stop dezactivat, se cheama dezavantaj pentru plămânii tai. Adicătelea 1-0 pentru diesel. Daca faci asta la vreo 20 de semafoarele zilnic timp de 300 de zile pe an, in câțiva ani nu prea multi cred că hmm nu prea vor arata bine plamanii ecologismului. |
Focus mk3.5
medelin |
#866
![]() Membru autentic Group: Members Posts: 573 Joined: 23 May 10 ![]() |
Da, confirm.
Sesizez in ultima perioada poluare din ce in ce mai putina cand trec pe langa coloanele de masini, si imi dau seama dupa sunet, e mai liniste. Deci noxe si galagie mai putina👍 Pe partea cealalta, in foarte putinele ocazii cand mai ies cu masina in oras, nu urc mai sus de 7% la diesel si datorita ss. Culmea e ca am buton. This post has been edited by medelin: 14 Jan 2025, 20:28 |
tractor u650, dacia
1971
- b 22 auz 7-B-798 Chiar existand tractorul,plugul il trag cu inima!
bgdrenault |
#867
Mai putina poluare? N o fi nasul infundat ?
Eu cu bicicleta, in Piatra Neamt, vara dupa ora 18, si e jale, cu J mare. O simti direct in plamani, si evit zonele aglomerate, ca nu am o tinta , fac doar miscare |
Megane
Sedan 1,33 140 CP
2019 Intens
- XXX
Bicicleta galbena |
#868
![]() Sunt nembru, domnule! Group: Members Posts: 2.204 Joined: 29 January 13 From: Bucuresti ![]() |
Nu e nici un nas infundat. Am scris si eu acum catva timp pe topicul cu biciclete: in Bucuresti, la semafor, se simte cand stai langa masini cu s&s activat si motorul oprit. De aia am si facut o mica rugaminte prieteneasca pentru colegii cu s&s sa-l lase activ - mai putina poluare e binevenita pentru toata lumea, evident biciclistii si pietonii sunt primii castigatori.
Peugeot
407 1.8 16v
meg2s |
#869
![]() Membru autentic Group: Members Posts: 1.162 Joined: 5 November 15 From: Bucuresti ![]() |
N-ai cu cine man...
Mie-mi spun multi ca-s prost ca mi-am luat phev ca sa merg exclusiv electric in oras; desi n-am panouri - deci nu vorbim despre rentabilitate financiara. Plus ca pe grupurile de Cupra sunt multi care-si fac cat-off ori teava goala de la un capat la altul - sunt convins ca un procentaj ne-neglijabil din trafic este la fel: masini noi cu poluare masiva. |
CUPRA
Formentor
(2023) e-Hybrid++ 204CP (Ex) Megane Sedan Privilege (2008) 1.5 dCi 78kW && Megane 4 GT (2018) 1.6 dCi 163CP EDC
(Ex) Skoda Octavia 4 Style++ (2022) 2.0 TDI 150 DSG |
medelin |
#870
QUOTE(bgdrenault @ 15 Jan 2025, 09:56) Eu cu bicicleta, in Piatra Neamt, vara dupa ora 18, si e jale, cu J mare. Ai dreptate, vara e oribil, caldura accentueaza orice. Acum e iarna, bate vantul aproape constant, e mai bine putin. |
tractor u650, dacia
1971
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 13th July 2025 - 01:50 |
