Project Spring restotarion in Bulgaria, I get one totaled spring and i will try to restore
chiMol |
Membru incepator Group: Members Posts: 27 Joined: 20 January 23 ![]() |
Spring
- still no
2022
![]() fan Dacia Group: Members Posts: 21.864 Joined: 12 November 05 From: Bucuresti ![]() |
Good luck with that!
You have expereince/training working on high voltage equipment? This post has been edited by einstein1984: 20 Jan 2023, 12:15 |
- negru pe alb
chiMol |
I don't have Experience with high voltage battery , but i hope that i can use my knowledge about EVs.
Spring
- still no
2022
Make sure you have a mega ohm metter and insulated gloves then.
This post has been edited by einstein1984: 20 Jan 2023, 14:20 |
- negru pe alb
chiMol |
Really i am not sure of fixing wiring 100% there are many stretched and torn 12v electric installation. This is the reason that i am looking for electrical scheme, but i can not found it...maybe the model is too new.
I hope that the car will be loaded soon and it come this month ![]() ![]() |
Spring
- still no
2022
chiMol |
Challange accepted
Car is delivered.... Have no charger ![]() This post has been edited by chiMol: 1 Feb 2023, 19:22 Attached thumbnail(s) IMG_20230201_174744_122_copy_800x600_1.jpg ( Size: 171.21k ) Number of downloads: 706 IMG_20230201_174801_279_copy_800x600.jpg ( Size: 169.17k ) Number of downloads: 718 IMG_20230201_174751_613_copy_800x600.jpg ( Size: 151.53k ) Number of downloads: 719 |
Spring
- still no
2022
sorin1983 |
![]() Membru autentic Group: Members Posts: 5.649 Joined: 3 July 06 From: Bucuresti-Rahova ![]() |
good luck! you will need it
Megane1-
chiMol |
I will need it - true
I still need electric installation scheme, because of too much cured wires.. if someone know from where I can get it it will be super. Airbag questions? Is the airbag module resettable or need change the same one is in sandero 2 and duster. Where is posisioned front crash sensor - after this crash I can not see it at all Body Can someone to measure in millimeters some control points that I will need for body rebuild I will mark points ot pictures. Thanks all for collaboration. ![]() |
Spring
- still no
2022
You need acces to Dialogys app, it has all of those
- negru pe alb
chiMol |
least Dialogys that i found is 2020 version but there is no spring
![]() there must be update i hope that i will find it soon ![]() This post has been edited by chiMol: 2 Feb 2023, 11:03 Attached thumbnail(s) dacia_spring_electric_38.jpg ( Size: 473.02k ) Number of downloads: 683 |
Spring
- still no
2022
punktnet |
![]() Tehnic Group: Members Posts: 90 Joined: 27 September 09 ![]() |
QUOTE(chiMol @ 1 Feb 2023, 22:21) I will need it - true I still need electric installation scheme, because of too much cured wires.. if someone know from where I can get it it will be super. Airbag questions? Is the airbag module resettable or need change the same one is in sandero 2 and duster. Where is posisioned front crash sensor - after this crash I can not see it at all Body Can someone to measure in millimeters some control points that I will need for body rebuild I will mark points ot pictures. Thanks all for collaboration. ![]() Hello, i don`t want to dissapoint you, but attached it`s a part of the repair manual related to crash data from the airbag ECU and the traction battery. It`s in romanian but you can use google translator to read the quote in the center. I suggest you to consider it because there is a lot of traffic on the CAN network between all the ECU`s on the vehicle. Good luck and best regards. 2 Feb 2023, 14:39: And being a good guy, here is the control point list for Spring 2 Feb 2023, 14:42: And the crash diagnose points This post has been edited by punktnet: 2 Feb 2023, 14:42 Attached thumbnail(s) airbag.jpg ( Size: 251.38k ) Number of downloads: 680 Attached File(s) ![]() ![]() |
Power
2022 Diesel Power
chiMol |
Really thank you for this info
![]() Is there some kind of lock the car motor , controller or in case of accident ? I see pictures of spring with deployed airbags but with green OK in dashboard for moving(may be). CHARGE QUESTIONS I order this charger type 2 https://www.aliexpress.com/item/10050032467....8e0b1802FjiauW I will try it because the car come without any charger or cables. |
Spring
- still no
2022
chiMol |
I am trying to remove for rebuild some parts.
![]() Vacuum pump - it works at all. Broken inlet pipe. This post has been edited by chiMol: 4 Feb 2023, 22:14 Attached thumbnail(s) IMG_20230203_155358_921_copy_800x600.jpg ( Size: 153.92k ) Number of downloads: 121 IMG_20230203_155432_628_copy_800x600.jpg ( Size: 201.83k ) Number of downloads: 106 IMG_20230203_160311_682_copy_450x600.jpg ( Size: 242.66k ) Number of downloads: 93 IMG_20230203_163952_905_copy_800x600.jpg ( Size: 150.45k ) Number of downloads: 102 IMG_20230203_152550_449_copy_800x600.jpg ( Size: 166.6k ) Number of downloads: 92 |
Spring
- still no
2022
chiMol |
Work in progress
PLASTIC WORK I hope that I will save some parts of these. Front grill have potential to be repaired Left ark is repaired Left under wing is 50% repaired just Some photos Attached thumbnail(s) IMG_20230211_162235_853_copy_800x600.jpg ( Size: 175.79k ) Number of downloads: 114 IMG_20230211_160208_584_copy_800x600.jpg ( Size: 133.08k ) Number of downloads: 101 IMG_20230211_155440_539_copy_450x600.jpg ( Size: 224.82k ) Number of downloads: 98 IMG_20230211_154940_802_copy_450x600.jpg ( Size: 247.3k ) Number of downloads: 95 IMG_20230211_150321_378_copy_800x600.jpg ( Size: 150.26k ) Number of downloads: 94 IMG_20230211_150317_965_copy_800x600.jpg ( Size: 150.91k ) Number of downloads: 95 |
Spring
- still no
2022
chiMol |
Did someone test renolink to Dacia spring. What is available as options to check.
Spring
- still no
2022
chiMol |
All in line.....
Attached thumbnail(s) IMG_20230225_114031_313_copy_800x600.jpg ( Size: 217.95k ) Number of downloads: 95 IMG_20230225_130229_852_copy_800x600.jpg ( Size: 202.92k ) Number of downloads: 90 IMG_20230225_143344_673_copy_800x600.jpg ( Size: 188.49k ) Number of downloads: 85 |
Spring
- still no
2022
chiMol |
Work in progress. Test/measurement bumper and hood are redy
Attached thumbnail(s) IMG_20230304_165616_894_copy_800x600.jpg ( Size: 207.73k ) Number of downloads: 101 IMG_20230304_144756_403_copy_450x600.jpg ( Size: 256.11k ) Number of downloads: 98 IMG_20230304_141019_262_copy_800x600.jpg ( Size: 216.61k ) Number of downloads: 90 IMG_20230304_140955_802_copy_800x600.jpg ( Size: 214.72k ) Number of downloads: 88 IMG_20230303_230146_208_copy_800x600.jpg ( Size: 104.29k ) Number of downloads: 85 |
Spring
- still no
2022
![]() - Group: Members Posts: 22.893 Joined: 19 April 05 From: Romania ![]() |
![]() ps. Best wishes to the people of Bulgaria! Happy Liberation Day!!! This post has been edited by IRONICK: 4 Mar 2023, 23:54 |
Albalux 11 (©SanGiorgio)
chiMol |
Thank you .
And some more content about safety belts https://youtu.be/mhyUkQv0UTM 6 Mar 2023, 19:57: Front frame update All in sizes. All welds rewelded. Paint . Waiting for anticirosion film. This post has been edited by chiMol: 6 Mar 2023, 19:57 Attached thumbnail(s) IMG_20230305_123427_610_copy_600x450.jpg ( Size: 273.49k ) Number of downloads: 101 IMG_20230305_123429_924_copy_600x800.jpg ( Size: 186.79k ) Number of downloads: 88 IMG_20230306_182257_060_copy_600x450.jpg ( Size: 232.45k ) Number of downloads: 91 IMG_20230306_182305_959_copy_600x800.jpg ( Size: 181.97k ) Number of downloads: 88 |
Spring
- still no
2022
chiMol |
Temporarily/rebuild front bumper and hood installed for measuring gapes.
All inside frames not welded just scrolled for fine adjustment. Software and cable renolink is here from AliExpress shipped from France. All going well. Attached thumbnail(s) IMG_20230307_174433_157_copy_800x600.jpg ( Size: 206.85k ) Number of downloads: 103 IMG_20230307_174509_176_copy_800x600.jpg ( Size: 131.61k ) Number of downloads: 100 |
Spring
- still no
2022
welding a plate on top of that broken frame would have been a better fix tough.
- negru pe alb
chiMol |
May be you are right. Till now is just alined and assembled for tests and test run .... Till now I won in CAN system problems and all run. In final I will install additional support of frame where were damage. The bendet material is both bad chacharteristiks than original. I hope that soon will be on the road again.
First run https://youtu.be/bafIJ1WcUK0 This post has been edited by chiMol: 9 Mar 2023, 15:51 |
Spring
- still no
2022
torquemada |
![]() torquemada Group: Members Posts: 1.904 Joined: 17 January 05 From: Bucuresti ![]() |
Hey look it's a ... LADA Granta
Logan II
- B-xxx-xxx
2012 / 0.9 TCe Laureate Există două feluri de oameni:
QUOTE(chiMol @ 9 Mar 2023, 15:51) May be you are right. Till now is just alined and assembled for tests and test run .... Till now I won in CAN system problems and all run. In final I will install additional support of frame where were damage. The bendet material is both bad chacharteristiks than original. I hope that soon will be on the road again. First run https://youtu.be/bafIJ1WcUK0 Good job! |
chiMol |
Thanks for support. I still have so much to do.
Yes Granta ( this is my car ![]() |
Spring
- still no
2022
chiMol |
Last week I was in Romania to get some used parts -hood, grill with charge door, bumper , LH drl , front windshield, charge extension cable and other small stuffs .
I assembly with new hood, gaps are almost ok , and other parts are fitting good. Pictures are with old bumper because new do not have down grill jet. I hope that will come soon. Overall just need to adjust wheel chambers and toe and front frame position now is 10mm in left and 11 mm in back at left side. It is correctable via wholes in frame i hope. Next step filer + paint ...... May be in next week's Attached thumbnail(s) IMG_20230323_184000_473_copy_800x600.jpg ( Size: 225.73k ) Number of downloads: 103 IMG_20230323_182122_900_copy_800x600.jpg ( Size: 222.25k ) Number of downloads: 90 IMG_20230323_182134_653_copy_450x600.jpg ( Size: 254.62k ) Number of downloads: 88 IMG_20230323_182139_736_copy_450x600.jpg ( Size: 253.45k ) Number of downloads: 80 IMG_20230323_182147_311_copy_800x600.jpg ( Size: 157.45k ) Number of downloads: 84 IMG_20230323_182210_409_copy_800x600.jpg ( Size: 241.68k ) Number of downloads: 91 |
Spring
- still no
2022
stolniceanulucian |
Membru autentic Group: Members Posts: 391 Joined: 31 March 11 ![]() |
Tough job. Good luck |
Logan 1.4 GPL Landi Renzo
- BT-03-YPY
2008 Preferance berlina 1.4 mpi GPL Landi Renzo
caravan 1.4 twinport GPL Tomaseto QBox orlando 1.8 twinport |
GIC |
![]() Doar membru Group: Members Posts: 930 Joined: 13 January 04 From: Oradea ![]() |
alexis |
![]() daciot Group: Members Posts: 204 Joined: 30 June 05 From: Bucuresti ![]() |
Spring
- B XX HXX
2021
chiMol |
I do not have much time to work on it, but I am trying
![]() Overall I have one big issue with abs system - it gives error when driving over 10 km /h, but I can not read the error I don know why. I thing to check abs rings and sensors may the readings are not correct because of dropped metal parts or other. Other to check must be steering wheel sensor I think it is not calibrated correct. It says +15 when is straits.... Just wait for clear non snow weather and start again ![]() Attached thumbnail(s) IMG_20230401_155841_728_copy_600x800.jpg ( Size: 198.92k ) Number of downloads: 77 IMG_20230401_155846_391_copy_600x800.jpg ( Size: 139.36k ) Number of downloads: 61 IMG_20230401_155851_023_copy_600x800.jpg ( Size: 168.2k ) Number of downloads: 58 |
Spring
- still no
2022
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 9th September 2025 - 16:40 |
