Prepare Logan for "winter season"?, To be ready for bad and cold weather
MoneyTalks |
#61
Lexus
ES300H
Boris |
#62
![]() Croatian member Group: Members Posts: 497 Joined: 20 October 04 From: Zagreb, Croatia ![]() |
Logan Laureate 1.6
2005 + LPG Landi Renzo sequent Reliability of machines is inversely proportional to the number and importance of people watching it
mcv_rulez |
#63
![]() Mai mult spațiu. Mai multe posibilități. Group: Members Posts: 222 Joined: 14 November 06 From: Zenica, Bosnia ![]() |
Use CONTINENTAL winter tires (the best),
Change antifreeze liquid, Check battery status, Buy new wipers (must).... CYA |
Going to buy Dacia
Logan MCV
1.6 16V Laureate (5 seats) MCV really rules!!!
martin245 |
#64
![]() EX PAT Group: Members Posts: 913 Joined: 1 April 06 From: Karlsbad Germany (again) ![]() |
I use firestone
I Controll my antifreeze (no need to Change it every year) Check battery terminals for corrosion and not to forget wiper washer water is also filled with a wiper antifreeze and not to forget lubricate your boot lid lock Stu |
logan 14 mpi Simply RED
- GB 1 Bessy Regs
mcv_rulez |
#65
Firestone's good too,
I use Michelin Pilot Alpin 2 PA2 |
Going to buy Dacia
Logan MCV
jocker |
#66
![]() Membru incepator Group: Members Posts: 20 Joined: 23 July 05 ![]() |
QUOTE(martin245 @ 15 Nov 2006, 18:12) Level of my antifreeze is very close to MIN mark. I have checked and it is at -40 C. With what kind of antifeeze should I top it up. Because some people says that if you mix to diferent based antifreezes it will start to make foam. Please if you can answer what kind of antifreeze should I use, or which one you have used? |
logan laureate 1.4 MPI
- Makedonija
mcv_rulez |
#67
better use same antifreeze. If u don't know wich one was it, It's better to change it whole......
It's on you, my friend..... I use INA antifreeze liquid. (Only availible in Croatia and Bosnia) |
Going to buy Dacia
Logan MCV
zorpetus |
#68
Membru Group: Members Posts: 120 Joined: 17 April 06 ![]() |
QUOTE(mcv_rulez @ 21 Nov 2006, 11:33) better use same antifreeze. If u don't know wich one was it, It's better to change it whole...... It's on you, my friend..... I use INA antifreeze liquid. (Only availible in Croatia and Bosnia) Here is what Dacia says about that: ------ We thank you for your message and for the trust you put in us by appealling to our services. As regards the aspects you presented we inform you that for the cooling system of the Logan vehicle, Dacia recommends the use of " Glaceol RX type D ", according to the Warranty Book. Since Dacia does not recommend a coolant made by Total ( France ), we are not aware of its properties. We are kindly asking you to keep contact with our local representative for all information, as you could find in them the best partner for understanding your needs. --------------- But, using GLACELF SUPRA coolant (made by Total, France) should be OK. |
None
None
- None
mcv_rulez |
#69
O.K.
Going to buy Dacia
Logan MCV
mcv_rulez |
#70
Hey, people.
Do not forget to clean your headlights and taillights every morning, because your lights are going to blind other drivers if they are dirty, because light is "blowing" in the air, just like in fog!!! CYA |
Going to buy Dacia
Logan MCV
martin245 |
#71
Well the big storm has passed over us leaving a trail of destruction ....BUT I can say this I was Driving My Logan in this storm (having to return home from work) and I was suprised how well it took the sidewinds .I have driven a lot worse cars in winds than My logan so full points for Wind resistance
Stu Attached thumbnail(s) wind_fan.jpg ( Size: 13.35k ) Number of downloads: 51 |
- GB 1 Bessy Regs
Uri |
#72
Membru incepator Group: Members Posts: 16 Joined: 9 March 07 ![]() |
I was a bit afraid of how the Logan is going to take the side wind, being so high and not so streamlined. But it was a pleasant surprise, really, and quite the contrary to the Peugeot 307. With Peugeot, there was almost no noise in it but it would just turn its nose now and then, quite unexpectedly. With Logan, the noise is awful but the car is very steady.
By the way, the noise is not always bad. Whit temperature jumping up and below zero, there is always the danger of ice, and it happens that on ice, tires are making a different, somehow "drier" noise than on the wet asphalt. So it is a good warning. And more. Logan is a warm car, and its engine starts well even at -22 C (the lowest temperature in Estonia this winter). I say that because I've heard much complaining here in Estonia about French engines "dying" in cold, just like the soldiers of Napoleon did in Russia. About Barum Polaris 2 tires (no spikes). I can say they are not at all bad - on everything except the solid ice. On the solid ice, I do not not know, for we did not have it this winter. But again, I'm a 50/70/90 type of a driver (e.g. keeping the speed limit), so a guy who loves to drive with his foot flat may be of different oppinion. This post has been edited by Uri: 12 Mar 2007, 12:12 |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 19th July 2025 - 07:18 |
