26 Pages « < 18 19 20 21 22 > »
> Eleron Logan
tgmpupy
post 8 Aug 2006, 15:32
Post #571
este facut in belgia de CARSTAYLING.
http://www.carstyling.be/dacia/index.htm
dacia logan 2004 - b77 xxx
VeNoM386
post 8 Aug 2006, 15:36
Post #572
Arata mai bine decat alte eleroane prezentate aici, dar tot cel de la Zender ramane cel mai dragut, parerea mea.
This post has been edited by VeNoM386: 8 Aug 2006, 15:40
Citroen C4 Champion 2007
nickvio
post 9 Aug 2006, 12:11
Post #573
Pentru tgmpupy....poti te rog sa-mi spui cum ai rezolvat problema celor aproximativ 3 mm ce depasesc lungimea portbagajului? Si daca a mai fost nevoie de alte finisaje inainte de vopsit. Intreb toate astea, pentru ca am gasit la dilerul din oras eleroane in stoc, la acelas pret cu al tau si ma cam bate gandul sa-mi montez. Pentru ceilalti doritori, pot sa va spun ca vopsitul=50 ron, montatul 30 ron....normal la negru. Multumesc
dacia logan ambition 2005
post 9 Aug 2006, 17:14
Post #574
Se vede ca nu a mai intrat IRONICK pe forum. Eleronul ala a aparut la dealer in jur de 20 iulie.
nickvio
post 12 Aug 2006, 18:58
Post #575
Buna!!! Speram ca tgmpupy sa-mi dea un semn in ceea ce priveste montarea eleronului, pentru ca marti sunt programat la service excl.gif
tgmpupy
post 14 Aug 2006, 09:48
Post #576
am fost in vacanta,cei 3 mm raman asa ,azi il iau de la vopsit.
post 15 Aug 2006, 12:05
Post #577
Asa doar de info . . . date extrase din pdf-urile respective
Permissible maximum speed 192Km/h
The vehicle was driven up to a maximum speed by 174km/h.
An increase of the maximum speed by the cultivation of the tail spoiler could not be determined. Negative "Auswirkkungen" was determined on the handling by the "Anbrigung" of the spoiler
PS. Cine stie sa traduca mai bine ar putea sa faca gestul . .
http://www.carstyling.be/dacia/TUV6001998191.pdf
This post has been edited by IRONICK: 15 Aug 2006, 12:08
alexis
post 15 Aug 2006, 13:34
Post #578
daciot
QUOTE(IRONICK @ 15 Aug 2006, 13:05)
An increase of the maximum speed by the cultivation of the tail spoiler could not be determined. No negative effect was determined on the handling by mounting of the spoiler.
Cu alte cuvinte - vorba lui nea Iancu - e de bine mon cher.
Dacia Spring 2021 - B XX HXX
post 15 Aug 2006, 14:05
Post #579
Pai atunci continua cu restul pdf-ului, vad ca te pricepi . . .
nickvio
post 18 Aug 2006, 19:11
Post #580
Buna!!! Poate vreun coleg forumist sa-mi spuna cu precizie ce fel de silicon sa folosesc pentru lipirea eleronului. Mentionez ca am achizitionay de la diler, un eleron belgian, care l-am vopsit la o vopsitorie, si doresc sa fac montajul singur. Multumesc ! excl.gif excl.gif
DragosPopa
post 1 Sep 2006, 19:25
Post #581
Am fost azi 01.09.2006 la ADRAS pe Oltenitei....Preturi super mari la eleroane..cel cu lampa 360 ron, cel fara 200 ron si asta fara manopera, vopsit, montat..Astia sunt nebuni!!!!
This post has been edited by DragosPopa: 1 Sep 2006, 19:25
Dacia Logan Preference DCI 2006 - gr 80 pdg
ga!nusha
post 2 Sep 2006, 08:49
Post #582
Still here
eleron cu lampa facut de dacia??? o poza ceva?
Mazda 3 MPS ex: Logan Preference+AC 1.6 2oo8
DragosPopa
post 3 Sep 2006, 10:30
Post #583
QUOTE(ga!nusha @ 2 Sep 2006, 09:49)
Doar am intrebat....nu stiu mai multe amanunte ca de aia m-am mirat si eu....(sa nu intelegeti altceva cu "lampa"..a se citi stop)...
This post has been edited by DragosPopa: 3 Sep 2006, 10:30
wiorelus
post 26 Sep 2006, 14:15
Post #584
Salutare!!!!
Am si eu o intrebare pentru cei care si-au montat acest eleron aplicat, daca se simte vreo diferenta referitor la stabilitatea masinii, adica imbunatateste cu ceva stabilitatea la viteze mari?
Multumesc!!!!!
Logan Ambition 1.6 MPI 2005
post 26 Sep 2006, 14:19
Post #585
Mai, tu nu poti sa citesti mai sus ?
wiorelus
post 26 Sep 2006, 14:30
Post #586
QUOTE(IRONICK @ 26 Sep 2006, 11:19)
Se putea cu un "NU" sau cu un "DA"
Merci!!
post 26 Sep 2006, 14:33
Post #587
Nu trebuie sa te superi, dar nu erau de rasfoit multe pagini. Erau doar cateva posturi mai sus. Si zic ca mai bine citesti parerea producatorului. Ei testeaza "altfel" un produs, decat un user de pe forum.
This post has been edited by IRONICK: 26 Sep 2006, 14:38
wiorelus
post 26 Sep 2006, 14:52
Post #588
QUOTE(IRONICK @ 26 Sep 2006, 11:33)
Am invatat sa ma iau numai dupa ceea ce vad sau ating cu mana mea. In comert ca sa-ti vinzi produsul ai fi in stare sa spui ca ajuta si la zbor. De asta vreau fapte nu pareri sau fise tehnice de la fz. Ca poate pe logan acel eleron nu ar putea avea nici un efect, decat cel vizual si poate nu ma intereseaza doar efectul vizual. De asta intreb pe cei care si-au pus si INTRADEVAR simt daca este vreo diferenta.
O zi buna ironickule smile.gif !!!!!!
post 26 Sep 2006, 15:07
Post #589
Eu ti-as recomanda parerea ziaristilor despre eleron:
QUOTE(Libertatea)
Fata de modelele precedente, Logan Prestige este in mod evident mai stabil, asezandu-se bine pe sosea, odata cu cresterea vitezei de croaziera. Contributia este adusa poate de eleronul incorporat, disponibil insa numai pe versiunile superioare.
http://www.libertatea.ro/index.php?section...hiva&sid=163118
This post has been edited by IRONICK: 26 Sep 2006, 15:11
wiorelus
post 26 Sep 2006, 15:56
Post #590
QUOTE(IRONICK @ 26 Sep 2006, 12:07)
QUOTE(Libertatea)
Nu-mi strica ziua cu toti ziaristii de apa dulce iar tu nu ma ajuta sa-mi schimb parea despre tine!!!
Cred ca nu trebuie sa-ti explic ce este ala eleron, ce caracteristici trebuie sa aiba un eleron pentru a fi si functional, adica sa imbunatateasca aerodinamica masinii.
Iar acel ELERON de care spune meseriasul de ziarist, este doar o umflatura pe partea din spate a capacului portbagajului, care intradevar imbunatateste , doar vizual loganul privit din spate.
Multumesc pentru efort totusi!!!!!
post 26 Sep 2006, 16:03
Post #591
Teste reale cu acel eleron se pot face numai intr-un tunel aerodinamic si cu aparatura speciala. Nu cred ca in utilizarea de zi cu zi a autovehicului se poate stabili eficacitatea eleronului. Sunt n factori care poate sa influenteze tragerea unei concluzii. Din cauza asta am recomandat testele producatorului.
O zi buna si tie in continuare
This post has been edited by IRONICK: 26 Sep 2006, 16:06
wiorelus
post 26 Sep 2006, 16:32
Post #592
QUOTE(IRONICK @ 26 Sep 2006, 13:03)
Pai de asta intram pe acest forum pentru ca nu prea se gaseste pe oriunde profesionisti care sa-ti testeze tie ceea ce te intereseaza si atunci incercam sa invatam, sa ne informam unul de la altul poate din greseala in greseala dar pana la urma iese si ceva bun ca atunci sigur nu ne-am pierde timpul pe aici. Crezi ca s-a dus cineva la nu stiu ce experti sa le testeze daca alubandul izoleaza eficient loganul pe plafon. Au incercat unii nu a mers, sau poate a mers si este ok adica izoleaza termic si uite asa ajungem si la ceva bun.
-Scorpio-
post 27 Sep 2006, 07:35
Post #593
membru jucator
si tu-ti inchipui ca ai nostri colegi forumisti iti vor putea da mai mult decat o parere subiectiva?
Honda Civic 140HP 2010 - SV-XX-XXX
Nota: nu lasati cheia in portbagaj deoarece este necesara la deschidere. (instructiuni de utilizare Logan, pag 3.17)
post 27 Sep 2006, 11:38
Post #594
Eeeee, cu aluband-ul este alta mancare de peste. Nu cred ca o sa stea cineva pe forum sa testeze eleronul.
PS. Poate doar marius80_eugen, ca sa mai castige ceva cai putere . . . biggrin.gif
wiorelus
post 27 Sep 2006, 13:35
Post #595
QUOTE(IRONICK @ 27 Sep 2006, 08:38)
Offfffff omule, nu vreau sa testeze nimeni acest eleron, vreau doar impresii de la cei care l-au montat.
mirceateodorescu683
post 11 Oct 2006, 18:38
Post #596
MD
Dintre toate eleroanele, cel mai mult mi-a placut cel de Logan vandut de reteaua Dacia (270 RON). Mi l-am cumparat. In cartea tehnica sunt niste figuri, pe care eu, total in afara domeniului, nu le pricep. Intrebarea este: o sugestie unde l-as putea vopsi si monta si cu cat in Bucuresti? Multumesc anticipat!
PS: la service-ul de unde l-am luat problema vopsirii oficiale se pune dupa 15 nov., costa 150 RON (!!!), si apoi ne gandim la montat. Deci nu-mi convine.
Da dom'le, am Passat cu motor TDI!
DragosPopa
post 15 Oct 2006, 12:03
Post #597
Nu fac reclama..doar am gasit unele gen cele de fabrica aici....http://www.tuning-logan.ro/index.php?template=produse&grupa=1&categorie=9
dragos_alx
post 16 Oct 2006, 11:06
Post #598
QUOTE(mirceateodorescu683 @ 11 Oct 2006, 19:38)
mircea eu il am vopsit deja, e modelul soft de la dacia cel de 70 Euro.
ai idee unde il montam? din cate am vazut eu trebuie gaurita tabla de la portbagaj si dat cu silicon inainte de aplicare. si mai trebuie pus si ceva pe la suruburi ca sa nu intre apa.
ceva idei si solutii?
stie si altcineva? recoamnadari?
help pls!
ms!
Megane 2 CC Privilege 1,5Dci/Logan Ambition/Kia Sportage CRDI 2009 / 2006 / 2011 - B 727 X D X
Megane cu Car Pc si Internet inside :) GPS IGO 2014, harta 3D in relief cu ecran de 7"
cristi_xp
post 16 Oct 2006, 12:28
Post #599
QUOTE(nickvio @ 18 Aug 2006, 20:11)
Eu zic sa incerci cu silicon sanitar de ala transparent,asa mi-am lipit eu pleoapele pe faruri,le am de mai bine de un an ...
Dacia Logan Ambition 1,6 MPI 2005 - Neinmatriculata
Vand axa cu came sport de logan /solenza / supernova .
juristul2000
post 16 Oct 2006, 20:11
Post #600
"Membru 20 cm record"
Eu am montat eleronul de la PIlot doar cu silicon si de aproape un an nu am nici o problema.Eu zic sa nu dai gaura ca dupa aia poate rugineste tabla in acea zonasau mai rau daca te saturi de eleron ce faci?Chituiesti?Matuieste bine tabla in zona eleronului si pune silicon.Bafta
Referitor la silicon eu am folosit Bizon
This post has been edited by juristul2000: 16 Oct 2006, 20:13
logan dacia Laurate 2005 - AR-07-RZV
20% warn permanent!!!
decat sa...... mai bine nu!!!!
NU, da spaga!!!
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 17th May 2025 - 23:48
