Despre PC-uri, Orice "probleme"
C@talin |
#1591
Range Rover
V8 5.0
Vogue SE
koldun |
#1592
![]() un om Group: Members Posts: 763 Joined: 1 November 07 From: CT ![]() |
Treaba aia cu master si slave...
Captur
TCe 0.9 2016 Oh, I’m in no condition to drive! Wait a minute... I don’t have to listen to myself, I’m drunk...!
Homer Simpson |
SiloS |
#1593
![]() Gangester Group: Members Posts: 4.298 Joined: 23 February 04 From: Buzau ![]() |
Pai sunt puse bine. HDD initial este "primary master" iar HDD secundar este "primary slave" .
BMW
E30 325i 2003 BMW Z4
logan1.5dci |
#1594
Nu Există Informații Group: Members Posts: 881 Joined: 29 September 05 From: Dobrogea ![]() |
Gata m-am conectat si prin Wireless-G ADSL Gateway.
![]() Ma asteptam sa fie mai greu, dar a mers ca uns. In afara de setari de securitate normale oricarui router wireless, am mai facut doar doua setari: - am selectat PPPoE - VPI= 0 /VCI=35 (oricum la astea are detectare automata) -am bagat userul/parola si gata, merge. This post has been edited by logan1.5dci: 8 Mar 2009, 14:43 |
- Nu Există Informații
sorin1983 |
#1595
![]() Membru autentic Group: Members Posts: 5.636 Joined: 3 July 06 From: Bucuresti-Rahova ![]() |
Megane1-
marksman |
#1596
Post mortem nihil est Group: Members Posts: 7.732 Joined: 1 November 04 From: sat ![]() |
Cable select nu functioneaza cu un cablu IDE obisnuit.
QUOTE(pcguide.com) To use cable select, both devices on the channel are set to the "cable select" (CS) setting, usually by a special jumper. Then, a special cable is used. This cable is very similar in most respects to the regular IDE/ATA cable, except for the CSEL signal. CSEL is carried on wire #28 of the standard IDE/ATA cable, and is grounded at the host's connector (the one that attaches to the motherboard or controller). On a cable select cable, one of the connectors (the "master connector") has pin #28 connected through to the cable, but the other (the "slave connector") has an open circuit on that pin (no connection). When both drives on the channel are set cable select, here's what happens: * Master: The device that is attached to the "master connector" sees the CSEL signal as grounded, because its connector has pin #28 attached to the cable, and the host's connector has that signal grounded. Seeing the "zero value" (grounded), the device sets itself to operate as master (device 0). * Slave: The drive that is attached to the "slave connector" does not see the CSEL signal as grounded, because its connector is not attached to the CSEL signal on the cable. Seeing this "no connection", the device configures itself as a slave (device 1). This post has been edited by Illusi0n: 8 Mar 2009, 16:30 |
Opel / Mazda
Crossland X / CX-30
2019 / 2020 Nick Ușor
#1597
ce parere aveti despre produsele Sweex?
logan1.5dci |
#1598
Au multe produse, parca ar fi de rebranding .
marksman |
#1599
Multe chestii de la Sweex si de la Edimax sunt tot alea: routere, AP-uri, switch-uri...
Eu am un rack 2.5" (ide to usb) si e OK. |
Opel / Mazda
Crossland X / CX-30
ady85btz |
#1600
Trebuie sa fac o traducere din ceha in romana si caut un dictionar online sau un traducator mai exact (gugal translate o cam zbarceste) .Are careva idee?
Kia
Cee'd ~the BEST~
ilciov |
#1601
![]() Membru incepator Group: Members Posts: 87 Joined: 4 February 06 From: Bucuresti ![]() |
Poti incerca Linguatec Personal Translator v2008.
Este destul de interesant. |
AMBITION 1.6 MPI, 2006 / megane 1.6 16v 2008
ady85btz |
#1602
cum pot lasa si eu subtitrarea mai jos in bs player?
Kia
Cee'd ~the BEST~
sonycu |
#1603
![]() Alpinist de weekend !! Group: Members Posts: 612 Joined: 3 July 07 From: Bucuresti ![]() |
So..
1) Click dreapta pe film/Subtitles/Subtitles Properties/Custom Position si apoi muti subtitrarea unde vrei tu 2) Click dreapta pe film/Subtitles/Subtitles Properties/Move up OR Move down Sigur, asta se mai poate face si cu ajutorul tastelor SHIFT + UP/SHIFT + DOWN |
Ex Dacia
Solenza, Echiparea Scala,
An 2004 Nicht, woher ihr kommt, mache euch fu rderhin eure Ehre, sonders wohin ihr geht !
ady85btz |
#1604
Mersi,a mers
Kia
Cee'd ~the BEST~
sonycu |
#1605
![]() Cu placere |
Ex Dacia
sorin1983 |
#1606
Megane1-
fullfit46 |
#1607
![]() Membru autentic Group: Members Posts: 244 Joined: 8 June 08 From: Vaslui ![]() |
Poate stie cineva ...de ce mi se blocheaza calculatorul ?....se innegreste deodata monitorul, nici macar nu se restarteaza....trebuie sa ii dau eu restart, iar monitorul clipeste dupa aia de parca ii numai el deschis , fara unitate. Jaful ii un pentium 4 de 40 Gb...cu 1G de rami
2007 Benzina Albrecht AE 6110 / Midland ML 145
kog |
#1608
posibil sa fie placa video pe duca...
1989 TLX
marksman |
#1609
Si al meu tot asa s-a comportat. Cauza: condensatorii de pe placa video.
Opel / Mazda
Crossland X / CX-30
kog |
#1610
se inlocuiesc destul de usor, dar daca ai ceva bani mai bine cumperi alta
1989 TLX
marksman |
#1611
Eu i-am inlocuit pentru ca la momentul ala eram lefter si condensatorii au costat 5 lei. Nu pot sa zic ca mi-a fost usor, pentru ca scoaterea cositorului din gaurile in cablajul multistrat a fost o munca de chinez batran.
Opel / Mazda
Crossland X / CX-30
kog |
#1612
lefter sunt si eu dar pe mine m-au costat condensatorii doar 1.4 ron
1989 TLX
Merced |
#1613
Ideala ar fi o statie de lipit cu aer cald. Au aia de repara telefoane, si pentru 10-20 de lei cat ti-ar lua manopera, nu e mult.
Merge si cu un letcon, dar trebuie musai sa fie de putere mare 90W acolo sa aiba, ca altfel cu un pistolas d-ala mic de 20-30W faci varza cablajul ala. Si o pompa de fludor, schimbi la ei intr-o veselie. Un coleg de servici se ocupa cu asta frecvent, si are un letcon de zeci de ani si o pompa de fludor. In rest "skill" si obisnuinta. Bine, e si prea zgarcit sa ia o statie d-aia de lipit cat de cat, cati bani si-a scos din reparatii de placi de baza, video sau surse, isi lua 30 de statii pana acum lejer. |
Ka
fullfit46 |
#1614
Merci mult...o sa ma uit maine la ea...sa vad ce-i de facut
ady85btz |
#1615
cum pot muta si eu subtitrarea la un film din bsplayer pe banda neagra din josul ecranului? am dat cu shift + sageata jos dar nu vrea sa mi-o mute pe banda neagra;ramane tot deasupra
Kia
Cee'd ~the BEST~
ady85btz |
#1616
Mi-am luat azi un gamepad Logitech Precision si nu reusesc sa-i configurez toate butoanele la Fifa 2009 . La unele pe care vreau sa le setez imi zice EMPTY si nu vrea ca sa le puna,si nici macar sageata dreapta nu vrea sa-o vada in joc.Cum il fac si eu?Are careva idee?
Kia
Cee'd ~the BEST~
koldun |
#1617
QUOTE(ady85btz @ 19 Mar 2009, 20:51) cum pot muta si eu subtitrarea la un film din bsplayer pe banda neagra din josul ecranului? am dat cu shift + sageata jos dar nu vrea sa mi-o mute pe banda neagra;ramane tot deasupra Nu mai folosesc de foarte mult timp BS Playerul dar, daca nu gresesc, trebuie sa fie ceva legat de setari pentru a afisa subtitrarile pe overlay. Sper sa te ajute. Succese! |
Captur
Homer Simpson |
ady85btz |
#1618
vreau sa-mi iau si eu o multifunctionala pana in 300 ron maxim.O folosesc mai mult pentru imprimare si scanat. ce parere aveti de asta? astepft si eu un sfat.mersi
Kia
Cee'd ~the BEST~
logan1.5dci |
#1619
Nu stiu daca e sfat, poate o observatie:
Eu dupa ce am folosit laser, mi-am luat numai laser. Primul avantaj, tine mult mai mult cartusul, apoi nu se murdareste(cand cineva vorbeste cu precipitatii). Ma intrebi de color? Am una (trei) pentru text(negru) si una pentru imagini (color, CLP 500) This post has been edited by logan1.5dci: 24 Mar 2009, 14:36 |
ady85btz |
#1620
una color sare de 600...eu dispun de maxim 300
Kia
Cee'd ~the BEST~
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 17th July 2025 - 23:26 |
