releu semnalizare
releu semnalizare
vik007 |
![]() Membru incepator Group: Members Posts: 4 Joined: 15 October 07 From: Bucuresti ![]() |
Break
2003 injectie
CAPTUR E-Tech full hybrid 145
2024
alinushy |
![]() modeLator Group: Members Posts: 2.622 Joined: 9 January 07 From: Pitesti - Mioveni ![]() |
@ vik007: e buton basculant (ca in schema lui bygy007 ) sau e din ala ca pe papuc (push buton)?
http://www.daciaclub.ro/Butonul-de-avarie-t58014.html This post has been edited by alinushy: 19 Oct 2007, 07:43 |
Audi
A4
ydaniel |
NU cumparati relee de metaplast bucuresti.cautati de EP sacele;)mai scumpe dar muuuuuuuuult mai bune;)
Oriunde,
oricand...
Cand esti rau ,nu te uita! |
De malvina sunt foarte bune.
Alexu7 |
eu am urmatoarea configuratie.
4 papuci pe mufa alea cu rosu. aia albastra e un "loc" liber pe mufa insa releul n-are lamela si pt ala. deci sa inteleg ca e tipul electronic? merge montat releu cu "piu-piu" fara adaptari? ![]() ![]() This post has been edited by Alexu7: 28 Oct 2007, 09:35 |
DACIA POPnituita
1310 L
1998
maryus_83 |
![]() Membru autentic Group: Members Posts: 1.067 Joined: 14 April 05 From: Brasov ![]() |
Am pus si eu de Malvina aseara dupa ce la cel vechi a aparut un zgomot puternic si am ramas fara semnalizari.
![]() This post has been edited by maryus_83: 28 May 2008, 07:59 |
Dacia/Reno
Logan Ambition 1.5 dci 70cp/ Kangoo 1.5dci
'08/'12 Don't forget kids... the more you post the bigger your penis is.
cezar_23@ |
![]() Membru incepator Group: Members Posts: 35 Joined: 17 May 08 ![]() |
vand releu de semnalizare 10 lei nou
29 May 2008, 22:03: cine e interesat la id vand_dacie1310 This post has been edited by cezar_23@: 29 May 2008, 22:03 |
dacie 1410
berlina
1995
- TR-04-EDF
Rafi |
![]() e doua bleu!! Group: Members Posts: 1.204 Joined: 27 November 07 From: ™Bucharest™ ![]() |
Salutare am si eu o mica intreabare
Dacia™
1310----CN----
--1996-- Daewoo™ Nubira II --CDX-- --2006--
trage cu incredere de soclu, ala in ce intra firele.
Rafi |
Dacia™
1310----CN----
mishujkl |
![]() posts: 0,25 Group: Members Posts: 231 Joined: 25 June 07 From: sv ![]() |
nu-mi mai merge releul de semnalizare si nu am inteles, pana la urma merge pus unul nou de papuc
cris06 |
![]() Mester Group: Members Posts: 597 Joined: 7 October 08 From: Iasi ![]() |
Fal, fal! Nu. Monteaza un releu electronic cu electromagnet si rezolvi problema.
Daewoo
- IS.06.---
mishujkl |
Daca nu face piu piu il las pe asta, nu ma deranjeaza ca nu mai clipeste semnalizarea(sta aprinsa continuu). Am vrut unul de papuc, se aude mai... modern.
![]() This post has been edited by mishujkl: 22 Nov 2008, 20:08 |
v_razvan_c |
![]() Membru autentic Group: Members Posts: 665 Joined: 11 March 07 ![]() |
Baieti, ajutati-ma si pe mine sa nu fac vreo prostie la instalatia electrica, nu prea am chef de complicatii
![]() Dacia tatei, din `73, nu a fost prevazuta cu sistem de avarie si i-ar cam fi de folos... Am inteles ce trebuie sa fac din schema, dar la partea cu ,,+ RELEU" si ,,IESIRE RELEU SEMNALIZARE" nu ma descurc; si n-as vrea sa le iau la nimereala. Deci, care sunt acele 2 picioruse de pe releu, care trebuie sa le aduc catre buton. Este releu comun, negru, cu carcasa din plastic. Si ,,BEC AVARIE BORD", are ceva daca nu il pun, presupun ca ala ar fi martor si nu ma intereseaza... ![]() Attached thumbnail(s) saptew.JPG ( Size: 36.52k ) Number of downloads: 1079 |
la buton e un singur piciorus , nu stiu cum este la dacia veche (nu stiu daca are cele 2 reglete sub bord ) vii cu 2 fire (unul de la + prin contact , si celalalt direct ) la buton apoi cel comun la alimentarea cu + a releului separat tragi 2 fire de la maneta semnalizare la iesire (stinga si dreapta la buton) martorul nu conteaza nu il poti pune
2024
cris06 |
@ razvan: de la borna comutatorului de avarie "+ releu" pleci cu un fir catre releul de semnalizare si-l conectezi la borna + sau 49 (desi la astea romanesti nu e notatia asta decat la cele termice). Firul care venea la releu la + il poti anula sau mai bine il conectezi (prelungit) la comutatorul de avarie la borna "+ contact". De la borna "iesire releu" pleci cu un fir la releu la borna C sau 49a ori la firul verde de la comutatorul de semnalizare (maneta).
This post has been edited by cris06: 2 Mar 2009, 21:56 |
Daewoo
- IS.06.---
v_razvan_c |
OK, am inteles, va multumesc. Daca intervine ceva la fata locului, revin
![]() Cred ca sunt 2 riglete sub bord... |
v_razvan_c |
Hm, am respectat schema, dar totusi a refuzat sa functioneze corect...
Merg avariile, dar cu contactul pus doar. Am pus pe buton un +permanent, +din contact, am tras firele pentru becuri(stanga-dreapta), ,,IESIRE RELEU SEMNALIZARE" l-am conectat la piciorusul notat cu litera ,,C" pe releu, iar ,,+RELEU" l-am pus pe ,,RS" , asa cum scrie pe releu. Bine asa? Sau trebuia sa pun ,, + RELEU" la plus-ul care este deja pe releu? Plus ca la mine a venit invers butonul, fata de schema de mai sus... am gresit eu ? This post has been edited by v_razvan_c: 4 Mar 2009, 22:09 Attached thumbnail(s) butn_avarie.JPG ( Size: 31.96k ) Number of downloads: 865 |
la buton ai 2 sectiuni , una cea din dreapta (in cazul nostru) care la apasarea butonului fac toate 4 contact , si cea de-a doua sectiune care face are 3 pini , cind este apasat pe avarie fac contact 2 pini din a doua sectiune , iar cind nu , unul din cele 2 , care este si comunul care se duce la plus releu si al 3-lea care se duce la + contact
vezi care scheme le intelegi This post has been edited by bygy007: 5 Mar 2009, 01:08 Attached thumbnail(s) Buton_avarie_dacia.JPG ( Size: 58.26k ) Number of downloads: 904 Buton_avarii_2.jpg ( Size: 71.15k ) Number of downloads: 381 BUTON_SEMNALIZARE.JPG ( Size: 38.66k ) Number of downloads: 769 |
2024
v_razvan_c |
Multumesc, bygy007, am inteles din prima ce e de facut, este destul de simplu, insa nu stiu unde totusi am gresit... Mai incerc
v_razvan_c |
OK, deci chiar am inteles si am respectat schema, nu sunt sucker, ce naiba, merge intr-adevar, dar cand pun avariile, se aprin si becurile de la ulei, deci daca imping masina ar porni fara chei
Merced |
#53
Ia incearca tu si cu alt buton, ca nu e bine ce zici tu. Cand pui avariile practic tu pui si contactul, daca se aprind becurile de ulei. Nici eu nu mai am avarii de cand mi-a improvizat un individ in service semnalizarile, stiu ca a umblat pe la butonu' de avarii, ca nu avea timp sa gaseasca "cauza" pentru care ramasesem fara semnalizari, a inversat niste fire p-acolo si acum am semnalizari, dar pe direct, si avarii ioc. O sa ma uit si eu maine sa vad ce e p-acolo, poate si la mine butonul era vinovat, ca mi-au picat semnalizarile chiar cand am incercat intr-o zi sa vad daca am avarii, poate le pun si eu la punct. Nu mai sunt in functiune de prin 2007, da' nu prea am avut nevoie de ele, daca opresc aiurea o las cu semnal pe partea respectiva si noaptea cu pozitii. Da' ar fi bune de avut, cine stie.
Ka
v_razvan_c |
#54
Butonul este nou nout... L-am avut pe 1300, dar era instalatia improvizata de mine, adica tot nu era alimentat butonul cu + deloc; deci nu pot spune 100% ca e bun. Poate incerc candva cu altul, va multumesc oricum, dar e bine si asa
v_razvan_c |
#55
Dar daca alimentez releul cu + permanent, se poate intampla ceva cu el? Stiu ca vor merge si semnalizarile stanga-dreapta indiferent de pozitia cheii in contact daca fac asta..
This post has been edited by v_razvan_c: 9 Mar 2009, 01:00 |
v_razvan_c |
#56
Pff, l-am facut. Nu mi-ati spus, sau nu am fost pe faza sa scot plusul pus la releu. Tarziu mi-am dat seama ca releul trebuie alimentat din buton. Va multumesc
Marcel_K |
#57
Membru incepator Group: Members Posts: 45 Joined: 11 March 09 ![]() |
Releul electronic se poate regla?
Cum se numeste aceasta piesa? Am reusit sa rup una. This post has been edited by Marcel_K: 11 Mar 2010, 19:45 Attached thumbnail(s) IMG_0703.JPG ( Size: 558.46k ) Number of downloads: 275 IMG_0704.JPG ( Size: 572.34k ) Number of downloads: 230 |
1998
#58
ala e un condesator incearca sa vezi daca merge fara
2024
davidut5 |
#59
![]() Membru Group: Members Posts: 143 Joined: 9 July 09 From: Alexandria ![]() |
Se poate modifica un releu electromecanic ca sa nu simta lipsa becului? De ce?
Pentru ca vreau sa pun leduri, si nu vreau sa pun rezistenta din cauza consumului |
Volkswagen
Jetta
1991 wolfburg, 19e
- TR-01-LOW
#60
da dar nu este indicat
2024
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 12th July 2025 - 22:15 |
