Alarma UCH, ce piese lipsesc, functionalitate
djcristi |
#151
Membru autentic Group: Members Posts: 3.944 Joined: 5 October 09 From: Bucuresti / Pitesti ![]() |
Attached thumbnail(s) out_alb.png ( Size: 148.2k ) Number of downloads: 1533 lipituri.png ( Size: 764.36k ) Number of downloads: 1653 lipituri_glue.png ( Size: 1.08mb ) Number of downloads: 1606 |
Megane 2.2
- DJC
03/2008 Estate 1.5dci euro4 76kW FAP business Dacia Logan euro4 1.5dci 50kW(68ps) ambition (fab oct-2007)
user2000 |
#152
![]() Membru incepator Group: Members Posts: 88 Joined: 1 January 12 From: BARLAD ![]() |
nu gasesc tranzistorul ala
- VS-03-DHW
2005 PREFERANCE
raduhoria |
#153
Membru incepator Group: Members Posts: 65 Joined: 12 January 08 ![]() |
Tranzistorul e unul banal, poate il gasesti si pe la vreun aparat stricat care-l ai prin casa sau la orice magazin de piese electronice. Alarma va suna doar cand sunt deschise usile, daca deschiderea lor nu s-a facut din inchiderea centralizata. Se pot inseria cu contactele de la usi senzori de perimetru si de soc.
- bv 78 dac
romeo-alex |
#154
![]() Membru incepator Group: Members Posts: 36 Joined: 3 April 11 From: BARLAD ![]() |
user2000 |
#155
multumesc de informatii
- VS-03-DHW
2005 PREFERANCE
Danny_bb |
#156
![]() Membru autentic Group: Members Posts: 605 Joined: 17 February 07 From: Brasov/Slobozia ![]() |
Ce fel de semnal comanda releul ? Continuu sau intermitent ?
Break 1.6TD
1988, Logan 1.5 dci 2006
raduhoria |
#157
De la uch semnalul de alarma vine intermitent din 2 in 2 secunde. Bobina releului e actionata intermitent din 2 in 2 secunde inchizand si deschizand circuitul claxonului care e alimentat continuu.
This post has been edited by raduhoria: 27 Feb 2012, 22:29 |
- bv 78 dac
adutu23 |
#158
Membru incepator Group: Members Posts: 19 Joined: 25 January 09 ![]() |
imi spune si mie va rog cineva unde se leaga releul (mura in gura) la ce pini si cum (eventual foto ca la gradinita).
in UCH am inteles cum se pun piesele (am foto lui djcristi, #144) dar cu releul nu inteleg. plsssss ![]() |
renault
megane 1.5 dci.
adutu23 |
#159
renault
megane 1.5 dci.
ostilu84 |
#160
![]() Membru Group: Members Posts: 188 Joined: 16 December 07 From: Dragasani , Valcea , Romania ![]() |
Functia este activata din soft? Nu sunt necesare doar piesele....
- VL-43-***
2004 Sa te fereasca Dumnezeu de cei care au doar convingeri si nici o indoiala! (Tudor Octavian)
adutu23 |
#161
da am acivat-o din soft. palpaie avariile cand deschid usile. ce am facut gresit oare daca zici ca functioneaza?
26 Nov 2012, 19:12: Adevarul e ca nu am gasit releu de 15A, am pus de 10 dar nu cred ca este o problema asta ,deoarece am probat cu o sirena de alarma in loc de claxon si nu nu functioneaza. dupa cat am citit eu am inteles ca la sirena nu e nevoie de releu This post has been edited by adutu23: 26 Nov 2012, 19:12 |
renault
megane 1.5 dci.
adutu23 |
#162
chiar nu mai e nimeni amabil sa imi dea o alta metoda de a activa alarma asta interna???
renault
megane 1.5 dci.
zetog |
#163
![]() Membru incepator Group: Members Posts: 16 Joined: 15 March 09 ![]() |
Alarma este activata doar trebuie sa montezi corespunzator piesele si sa faci legaturile corect, nu te risca aiurea daca nu te pricepi.
2008 F2 LAUREATE
X@by |
#164
![]() Membru autentic Group: Members Posts: 249 Joined: 8 June 08 From: Tg Mures ![]() |
LOGAN/SOLENZA
2008,Preference 1.5DCI 90CP/2003,Clima 1.4MPI GOD IS MY CO-PILOT!
adutu23 |
#165
oau am km pana la tine. sunt din Bacau. pe mes poate imi poti explica dak esti amabil. ms
renault
megane 1.5 dci.
X@by |
#166
Cum ai legat releul (ai pus numai un releu)? Ai pus rezistenta in uch? Explica ce ai facut sa te putem ajuta. Daca nu ne scrii ce ai facut, noi de unde sa stim ce ai facut tu acolo.
LOGAN/SOLENZA
adutu23 |
#167
am facut exact ca in foto djcristi Post #144 si un releu extern la care am tras fir din uch din pinul b35 la pinul 86. la pinul 86 i-am pus o dioda (1n4007) la pinul 85.de la pinul 87 al releului am tras fir ma mufa de la lumini(clacxon) la pinul b6, iar de la pinul 30 al releului am dus fir la pinu a4 ai aceleasi mufe de la lumini(clacxon).releu am incercat cu unul de 10a si unul de 30/40a ambele de 12 v.
am activat din dtt functia alarmei. (nu pot pune fotografii) Va multumesc celor care vor sa ajute. |
renault
megane 1.5 dci.
X@by |
#168
Leaga-l asa. fi atent ca difera numerotarea releului tau. Ar trebui sa ai o schema si pe releul tau.
LOGAN/SOLENZA
adutu23 |
#169
am incercat si varianta ta. de la b6 la 30 si de la a4 la 87. . am incercat sa pun b6 sau a4 pe pinul 87a al releului (pinul di mijloc) si porneste claxonul cand pun releul. am incercat sincer toate variantele.dioda conteaza sensul?am puso si asa si asa.
Posibil sa nu mearga la toate variantele de logan????mss 30 Nov 2012, 22:00: am vazut ca eu am 2goarne la claxon ,asa sunt la toate modelele? intreb deoarece gandesc sa nu fie releul mic ,de 30/40a. sau gresesc???? This post has been edited by adutu23: 30 Nov 2012, 22:00 |
renault
megane 1.5 dci.
#170
![]() Membru autentic Group: Members Posts: 8.184 Joined: 12 May 06 From: BUCURESTI ![]() |
ai ars tranzistoru punind dioda invers
CAPTUR E-Tech full hybrid 145
- B 07 BGY
adutu23 |
#171
aaaa daa? asta sa fire problema crezi? cum pun dioda corect? am vazut ca dioda are un cerc la un capat.la care pin al releului pun "cercul"?rezistenta de 1k de pe placa are sens?(pe placa am pus exact ca in foto) msss mult
30 Nov 2012, 22:25: scuze de intrebarile mele jalnice care pentru unii sunt ceva f.banale dar as vrea sa imi fac eu singur la masina. multumesc pt intelegere This post has been edited by adutu23: 30 Nov 2012, 22:25 |
renault
megane 1.5 dci.
#172
rezistentele nu au polaritate , dar tranzistoarele , diodele su unnele condesatoare , alea electrolitice
Attached thumbnail(s) G16730B.jpg ( Size: 17.74k ) Number of downloads: 844 |
- B 07 BGY
adutu23 |
#173
ok multumesc pentru raspuns.am sa cumpar alte piese sa incerc din nou.
pe placa lipesc sensul pieselor exact ca in foto djcrisi post#144,nu???iar la releu ca in scema luiX@by Post #168 ??? corect? si ince ceva, releul care l-am folosit de 30/40a e bun?? multumesc 1 Dec 2012, 08:46: mai am o problema pe care as vrea sa o rezolv. mi-am activat si deschiderea portbagajului din cheia masinii sa se deschida la a doua apasare de buton.toate bune pana aici. din interior portbagajul se deschide la prima apasare a butonului deschidere usi de pe consola centrala. as vrea sa fac sa se deschida tot din a doua apasare la fel ca din cheie. cum reusesc acest lucru? e aiurea asa ca ma pot trezi cu toate bagajele pe sosea in mers daca am gresit butonul,sau actionat din greseala,mai ales ca mi-am montat telescoape sa se ridice singur, mai ales ca trebuie sa renunt la functia de inchidere automata a usilor la o anumita viteza. Multumesc mult This post has been edited by adutu23: 1 Dec 2012, 08:46 |
renault
megane 1.5 dci.
X@by |
#174
Nu din rautate iti zic dar cu electronica esti paralel, mai bine dute la cineva care se pricepe inainte sa-ti strici UCH-ul.
LOGAN/SOLENZA
adutu23 |
#175
paralel poti sa fii sigur.nu ma supar dar o puteai zice mai frumos
![]() daca esti dispus sa ma ajuti fa-o ca nimeni nu a stiut din prima tot. |
renault
megane 1.5 dci.
X@by |
#176
Nu din rautate am spus. Poti sa-ti prajesti processorul din uch. Intai invata ce este, cum functioneaza: dioda, releul, tranzistorul si dupa aia mai vorbim. Pe google gasesti tot.
LOGAN/SOLENZA
Dsign |
#177
Ie grele la scoala, bre! Cand iti spune profu de fizica de a6a (sau in ce clasa s-o mai face electricitatea) sa inveti macar ce si cum intr-un circuit simplu, ca nu se stie cum ai nevoie, tu te gandesti cum sa pleci mai repede pe maidan la batut besica ... Incepe sa-mi fie din ce in ce mai greu sa gasesc o informatie pe forumul asta din cauza celor ca adutu.
Mergi fratioare la cineva care se pricepe, nu mai umple paginile cu prostii. Daca te pricepi un pic, informatia din acest topic, spre exemplu, este absolut suficienta. |
D
- B 48 CUP
2004 Preference 1.6MPI Egee http://youtu.be/OQ-ukXOBfI4
marian_ariciuc |
#178
![]() User Group: Members Posts: 322 Joined: 6 May 10 From: de obicei, acasa ![]() |
s-a gasit solutie eleganta(cum e cea din postul #96), pentru activarea alarmei interne UCH?
n-arata profi cele prezentate pe aici... |
1.6 16V E5 Vand modul inteligent de geam pentru logan 1 si 2 si alte...
kti |
#179
![]() ,,hobyst,, Group: Members Posts: 123 Joined: 20 May 08 From: CRAIOVA ![]() |
QUOTE(adutu23 @ 1 Dec 2012, 13:54) paralel poti sa fii sigur.nu ma supar dar o puteai zice mai frumos ![]() daca esti dispus sa ma ajuti fa-o ca nimeni nu a stiut din prima tot. vad , deja te-ai suparat de la o banala jonctiune acolo ai tranzistori,polaritate , n-p-n, p-n-p..........vorba colegului lasa supararea si apeleaza la ,,cunoscatori,, pt ca vei face mai mult rau decat bine. daca vrei probe atunci stai fara grija suntem multi pe aici care stim cu ce se mananca un UCH si alte ,,centraline,, ... spor si bafta ![]() |
1.4/gpl/stag200-4 ,1,5 diesel
- xx-70-xxx
ostilu84 |
#180
Salutare!
Un echivalent mai usor de gasit pentru BC 337 stie cineva? Am montat initial in locul acestuia un BD 135 si nu misca nimic releul, dupa aceea am pus un BC 547B, se aude releul putin, dar nu are putere sa anclanseze, se aude un tiuit usor ascultat de aproape. Am testat montajul releu-tranzistor pe o sursa de 12v aplicand o tensiune de 5v in baza lui BC 547B si functioneaza, doar ca pe masina nu vrea. Am verificat comanda de la UCH si exista, am 4,73v in cele doua secunde de comanda. Ceva idei? Releul este de 20 Amperi, deci duce claxonul care este simplu fara probleme, iar consumul bobinei acestuia este de 130 mA. |
- VL-43-***
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 9th September 2025 - 17:40 |
