carburator dublucorp, pt dacia 1300
ksi_id |
22 Apr 2006, 11:28
Membru autentic Group: Members Posts: 218 Joined: 16 April 05 From: timisoara |
vw jetta
1800cmc 90hp
1992
- TM 18 KSI
marius-gabriel |
22 Apr 2006, 11:50
Membru autentic Group: Members Posts: 1.006 Joined: 14 November 03 From: CALARASI |
ii poti pune cam orice carburator gasesti provenind de la o masina care sa aiba cat de cat aceasi capacitate cilindrica.
cel dublu corp de dacie(olcit) e cam pacatos si se regleaza extrem de greu. galerie trebuie neaparat alta+flansa pt tipul de carb care il alegi. |
HONDA CIVIC EX
HONDA ACCORD
- MARIUS
ksi_id |
22 Apr 2006, 12:13
QUOTE(marius-gabriel @ 22 Apr 2006, 12:50) ii poti pune cam orice carburator gasesti provenind de la o masina care sa aiba cat de cat aceasi capacitate cilindrica. cel dublu corp de dacie(olcit) e cam pacatos si se regleaza extrem de greu. galerie trebuie neaparat alta+flansa pt tipul de carb care il alegi. Imi trebuie doar flansa cu galeria mea sau si flansa si galerie(de ce model imi trebuie?) |
vw jetta
1800cmc 90hp
1992
- TM 18 KSI
danS22 |
22 Apr 2006, 13:00
Membru autentic Group: Members Posts: 623 Joined: 14 February 06 |
da iti tre o flansa la galeria ta , pt alt carburator
dacia,vw scirocco
gt,kr,Li
1984,1988,2001
- bh... Dacia1300('82),Vw Scirocco Gli MK1 ('79),Vw Scirocco Gt MK2 ('84)Dacia 1410 ('01)
marianrec |
22 Apr 2006, 13:49
membru drept Group: Members Posts: 330 Joined: 30 March 04 From: Galati |
Trebuie sa schimbi si galeria. De 1600...
1990, 1994
- GL03WWT & GL07NAT bau
amc |
22 Apr 2006, 14:11
2 trancane Group: Members Posts: 603 Joined: 28 November 05 From: Bucuresti |
pe galeria de 1600 pui doua weber DCOE 40 cu flanse si jicloare aferente unei capacitati de 1300! This post has been edited by amc: 22 Apr 2006, 14:12 |
YUGO
Zavzta
2007/prestige
- 1-B-NU-IS--chhh
marianrec |
22 Apr 2006, 14:13
This post has been edited by marianrec: 22 Apr 2006, 14:14 |
1990, 1994
ksi_id |
22 Apr 2006, 14:41
Doar galerie imi trebuie de 1600 sau si esapamentul complet?
Si apropo eu am GPL si vreau sa-l tin si in continuare. La carb meu am o gaura unde este bagat furtunul de GPL, pot si la un carb dublucorp sa fac acelasi lucru? Si cam cat voi avea consumul? Pe benzina nu ma intereseaza poate sa consume si 16% dar pe gaz nu vreau sa sara de 11, max 12%. |
vw jetta
1800cmc 90hp
1992
- TM 18 KSI
marius-gabriel |
22 Apr 2006, 16:05
neaparat trebuie alta galerie(de 1600, renault 18, etc) ca sa te poti bucura de noul carburator daca ai sa pui dublucorp.
nu trebuie sa schimbi si restul esapamentului! flansa se face in functie de tipul de carburator ales. poate nici nu e cazul de flansa, depinde ce carb alegi! |
HONDA CIVIC EX
HONDA ACCORD
- MARIUS
danS22 |
22 Apr 2006, 18:01
AMC , smechere carburatoare , cunosc un tip care are un unchi cu un motor de r12 g pe dacia ,dar carburatoarele nu le are montate din cauza consumului foarte mare,poate ca le vinde ,cam ce pret ii pot oferii pe ele? aproximativ?(cam de 10 ani nu au fost folosite dar sunt complete)
dacia,vw scirocco
gt,kr,Li
1984,1988,2001
payty |
22 Apr 2006, 18:30
QUOTE(ksi_id @ 22 Apr 2006, 12:28) ceau Ce carburator(de preferinta dublucorp) se potriveste pe dacia cu motor de 1300 si daca trebuie si galerie? P.S:Am cautat in alte topicuri dar nu am priceput exact cum sta treaba. Poti pune de renault 18. Ar trebui sa mearga pe dacie. Pui galerie de 1600 cu flansa. Daca ai gpl cu stut din ala in carburator, o sa fie nasol pentru ca atunci cand se deschide treapta 2 a carburatorului o sa iti moara motorul. This post has been edited by payty: 22 Apr 2006, 18:36 |
1996 1.6/2002 1.4
payty |
22 Apr 2006, 18:33
QUOTE(ksi_id @ 22 Apr 2006, 15:41) Doar galerie imi trebuie de 1600 sau si esapamentul complet? Si apropo eu am GPL si vreau sa-l tin si in continuare. La carb meu am o gaura unde este bagat furtunul de GPL, pot si la un carb dublucorp sa fac acelasi lucru? Si cam cat voi avea consumul? Pe benzina nu ma intereseaza poate sa consume si 16% dar pe gaz nu vreau sa sara de 11, max 12%. la un motor de 1.3 ar trebui si acum sa iti ia mai putin de 12% pe gaz. Daca vrei sa mergi doar pe gaz, eu zic ca e inutil sa investesti intr-un carburator. |
1996 1.6/2002 1.4
amc |
22 Apr 2006, 20:47
QUOTE(danS22 @ 22 Apr 2006, 19:01) AMC , smechere carburatoare , cunosc un tip care are un unchi cu un motor de r12 g pe dacia ,dar carburatoarele nu le are montate din cauza consumului foarte mare,poate ca le vinde ,cam ce pret ii pot oferii pe ele? aproximativ?(cam de 10 ani nu au fost folosite dar sunt complete) maxim 100euro! referitor la subiect: Omu vrea performante pe gaz mai bine lasa! This post has been edited by amc: 22 Apr 2006, 20:49 |
YUGO
Zavzta
2007/prestige
- 1-B-NU-IS--chhh
cristigeo69 |
22 Apr 2006, 21:15
1.6i m40 Group: Members Posts: 755 Joined: 20 September 05 From: Bucuresti |
amc nu ai inteles...vrea sa mearga si el la economie(gaz) cand se duce la scoala...etc unde nu necesita forja...si cand vrea sa simta si el ceva acolo sa o dea pe benzina...sper sa am dreptate
si ca sa nu fiu off topic galerie de papuc si carb.de oltcit(dus la reglat pe banc)daca vrei sa faci ceva...daca nu consuma mult si degeaba... era sa uit...PASTEti FERICITi This post has been edited by cristigeo69: 22 Apr 2006, 21:21 |
ex Dacia
1980 LS
- B 70 W R C MASINA SI FEMEIA NU SE IMPRUMUTA,mai ales masina...ca femeia se imprumuta singura :D
payty |
23 Apr 2006, 11:18
pe gaz, carburatorul nu are utilitate decat prin clapeta de acceleratie. Nu mai este folosit la absolut nimic altceva( pompa de sprit, circuit de relanti, etc, etc) .Amestecul se regleaza din vaporizator si robinetul de pe furtunul care vine de la vaporizator la carburator. Deci daca vrei sa mergi pe gaz, nu prea mai conteaza ce carburator ai.
1996 1.6/2002 1.4
Siconi |
24 Apr 2006, 20:32
Sofer americanizat! V6 Rules!!! Group: Members Posts: 2.906 Joined: 13 November 05 From: Houston, TX |
payty, ai dreptate. stiu asta de la un amic care si-a montat el singur GPL pe berlina lui... carbul il mai are doar pentru clapeta de la acceleratie, ca sa dozeze nivelul de gas in admisie. In rest sta degeaba.
Mercury
Mariner Premier 3.0L V6 4WD
ksi_id |
24 Apr 2006, 21:56
QUOTE(cristigeo69 @ 22 Apr 2006, 22:15) amc nu ai inteles...vrea sa mearga si el la economie(gaz) cand se duce la scoala...etc unde nu necesita forja...si cand vrea sa simta si el ceva acolo sa o dea pe benzina...sper sa am dreptate si ca sa nu fiu off topic galerie de papuc si carb.de oltcit(dus la reglat pe banc)daca vrei sa faci ceva...daca nu consuma mult si degeaba... era sa uit...PASTEti FERICITi Omu' are dreptate. pe gaz vreau economie(acuma am 8,5 consum dar chiar si 11 nu ma deranjeaza daca noul carb va influenta consumu') si tocmai de aia am spus ca nu ma intereseaza consumu' pe benzina ca vreau doar sa ma pot si eu incorda din cand in cand(sau chiar mai des ). Furtunul de la GPL ii bagat undeva in partea de jos a carb. Si chiar, am citit ca sunt doua tipuri de carb dublucorp unul pt demaraj si altu mai slab la demaraj dar viteza max mai mare, e adevarat? Pe mine ma intereseaza ala pt demaraj ca de viteza max sunt multumit Paste fericit! tuturor, |
vw jetta
1800cmc 90hp
1992
- TM 18 KSI
tonicelli |
24 Apr 2006, 22:50
Membru autentic Group: Members Posts: 374 Joined: 26 March 06 From: Valea Jiului |
Am vazut eu la cineva un carburator dublucorp si vreau sa spun ca masina merge super . Am inteles ca e de la Ford si consumul este relativ la fel
Sper sa-mi dea voie sa fac niste poze |
Laureate plus
- HD-XX-XXX România ... frumoasă țară ... păcat că e locuită
payty |
25 Apr 2006, 09:19
QUOTE(ksi_id @ 24 Apr 2006, 22:56) Omu' are dreptate. pe gaz vreau economie(acuma am 8,5 consum dar chiar si 11 nu ma deranjeaza daca noul carb va influenta consumu') si tocmai de aia am spus ca nu ma intereseaza consumu' pe benzina ca vreau doar sa ma pot si eu incorda din cand in cand(sau chiar mai des ). Furtunul de la GPL ii bagat undeva in partea de jos a carb. Si chiar, am citit ca sunt doua tipuri de carb dublucorp unul pt demaraj si altu mai slab la demaraj dar viteza max mai mare, e adevarat? Pe mine ma intereseaza ala pt demaraj ca de viteza max sunt multumit Paste fericit! tuturor, exista carburatoare sincrone, la care ambele trepte ale carburatorului se deschid simultan si carburatorare progresive la care intai se deschide prima treapta si apoi a doua, la turatie mai mare. Norma, cel sincron iti asigura un demaraj mai puternic decat cel progresiv, dar si un consum ceva mai mare. |
1996 1.6/2002 1.4
anndi |
27 Apr 2006, 11:31
Membru autentic Group: Members Posts: 932 Joined: 13 December 04 From: Timisoara |
Si la cele progresive se deschid amandoua corpurile daca ii dai talpa! Daca corpul 2 se deschide pe vacuum numai atunci are influenta turatia. Asa am eu pe nova si oricat as apasa de tare accel corpul 2 nu se deschide decat de la 3250-3400 rpm in sus. Pe loc la fel, numai in sarcina functioneaza.
Megane GT220
GrandTour 2014
mc_maxx |
29 Apr 2006, 23:28
ACHIZITI DE EPAVE Group: Members Posts: 55 Joined: 29 April 06 From: BUCHAREST |
eu zic daca ai pune un carburator de renault 12 ar fi okey si consum si putere am mers cu cineva care avea astefel de carburator si consuma in oras 6l
Attached thumbnail(s) break_20douziste4.jpg ( Size: 62.91k ) Number of downloads: 10468 fuiorescu_dacia_mot.jpg ( Size: 63.55k ) Number of downloads: 11199 |
1,5DCI
- b-87-HCI -
StefanT |
30 Apr 2006, 00:00
STF - Special Tactical Force Group: Members Posts: 3.413 Joined: 19 April 04 From: Bucuresti |
Suzuki
GSX-1300-R
- B'100'HAY Fan Reno 53379
cristigeo69 |
30 Apr 2006, 00:18
ex Dacia
1980 LS
ksi_id |
30 Apr 2006, 11:57
Faza e ca eu vreau sa scot cat mai multa putere, la demaraj doar, indiferent de consumul de benzina, ca eu deobicei merg pe gpl
vw jetta
1800cmc 90hp
1992
- TM 18 KSI
mc_maxx |
30 Apr 2006, 21:55
pe bune... asta era consumul..
1,5DCI
- b-87-HCI -
cristigeo69 |
1 May 2006, 14:16
hai mosuleeee ai pus carbelitorul ??? ca am gasit si eu o galerie pentru dublu corp de nova si as vrea sa-ti citesc parerea despre demaraj etc...ca as vrea sa-mi iau si eu.
bafta! This post has been edited by cristigeo69: 1 May 2006, 14:17 |
ex Dacia
1980 LS
ksi_id |
1 May 2006, 19:02
vw jetta
1800cmc 90hp
1992
- TM 18 KSI
ydaniel |
1 May 2006, 20:21
e faine pozele:))vad ca se poarta teava cu termocupla
Oriunde,
oricand...
Cand esti rau ,nu te uita! |
ksi_id |
1 May 2006, 21:25
A chiar si in afara de solex si weber ce alte "firme" mai sunt bune si de care sa ma feresc?
vw jetta
1800cmc 90hp
1992
- TM 18 KSI
ksi_id |
3 May 2006, 10:37
Daca un dublucorp deschide a doua clapeta la 3250 de ture ce pot sa-i fac ca sa deschida pe la 2500 de ex?
vw jetta
1800cmc 90hp
1992
- TM 18 KSI
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 11th May 2024 - 00:20 |
