Datele din calculatorul de bord se auto-reseteaza, (masa insuficienta la tabloul de bord)
mitzu02 |
#301
Membru incepator Group: Members Posts: 3 Joined: 21 September 06 ![]() |
2006 LAUREATE
powerx |
#302
![]() Membru Group: Members Posts: 192 Joined: 2 March 04 From: Iasi sau Vaslui ![]() |
Mda, electricianul din service-ul in care am fost eu, zicea ca ar fi 2 EEPROM-uri, unul pt kilometraj partial, si celalalt pt restul chestiilor ce le memoreaza pe acolo(benzina consumata, etc). Si explicatia data de fabrica ar fi ca daca se umple memoria la primul eeprom, cam incearca sa scrie in al doilea, si le reseteaza pe ambele. Bug-uri de soft dupa ei. Dar, electricianul zicea de o valoare ceva de genul 5000 km la primul, ceea ce cred ca nu a fost cazul la majoritatea celor cu aceasta problema. A mai zis ca imi va schimba bordul pe garantie, data viitoare cand mai face asa.
Logan Ambition
Verde cameleon
- VS-23-XYZ
2005 Mic si rau, mai mult mic decat rau.
#303
Ma intrebam si eu . . al-3-lea eprom pentru kilometrajul general unde este ?
PS. Multa imaginatie mai au electricienii astia in service-uri. This post has been edited by IRONICK: 26 Sep 2006, 13:23 |
powerx |
#304
http://en.wikipedia.org/wiki/Eprom
http://en.wikipedia.org/wiki/EEprom mai pe scurt: Comparison with EPROM EPROM has two significant limitations: * it has to be taken out of the circuit and put under an ultraviolet light source to erase it * higher (non-TTL) voltages are generally required to program it. These voltages are normally not available in regular computer circuit boards. EEPROM can be programmed and erased electrically. The difference between EPROM and EEPROM lies in the thickness of the insulating layer — in an EPROM it is about 3 nanometres thick whereas in an EEPROM it is much thinner — typically around 1 nanometre. This thinner insulating layer allows for lower voltages to be used for programming. din schema respectiva ar parea sa fie 2 eepromuri. Ma rog, exprimarea tipului a fost "unul pt kilometraj zilnic, si unul pentru restul". PS: nu ai o poza la o rezolutie mai mare a respectivei placi? Mersi This post has been edited by powerx: 26 Sep 2006, 16:29 |
Logan Ambition
Verde cameleon
- VS-23-XYZ
#305
Stiu care este diferenta intre ele. Nu mi-a batut tastatura bine e-urile.
EL. Nu am. Poza este din topicul lui Klaus cu schimbare culoare bord . .. This post has been edited by IRONICK: 26 Sep 2006, 16:33 |
tedy |
#306
![]() Membru Indoctrinat Loganist Group: Members Posts: 580 Joined: 7 July 05 From: Bucuresti ![]() |
QUOTE(powerx @ 26 Sep 2006, 17:23) http://en.wikipedia.org/wiki/Eprom http://en.wikipedia.org/wiki/EEprom mai pe scurt: Comparison with EPROM EPROM has two significant limitations: * it has to be taken out of the circuit and put under an ultraviolet light source to erase it * higher (non-TTL) voltages are generally required to program it. These voltages are normally not available in regular computer circuit boards. EEPROM can be programmed and erased electrically. The difference between EPROM and EEPROM lies in the thickness of the insulating layer — in an EPROM it is about 3 nanometres thick whereas in an EEPROM it is much thinner — typically around 1 nanometre. This thinner insulating layer allows for lower voltages to be used for programming. din schema respectiva ar parea sa fie 2 eepromuri. Ma rog, exprimarea tipului a fost "unul pt kilometraj zilnic, si unul pentru restul". PS: nu ai o poza la o rezolutie mai mare a respectivei placi? Mersi Domnu',nu va suparati,dar in romaneste nu se poate?Ca unii mai fara scoala ca mine se uita ca curca-n lemne la textul asta...Multumesc |
VW
bettle
- xxx
1.9 tdi
DragosP |
#307
![]() eprom: memorie care se scrie electric, și se șterge (dacă are fereastră) cu ultraviolete (tipic). eeprom: memorie care se scrie electric și se șterge tot electric. Asta despre definiție, că restul nu merită tradus. |
Ceva de plastic
- BRRC
. Scuze celor pe care i-am supărat!
Cu noi este Dumnezeu! |
#308
Cred ca aici se punea la indoiala informatia cetateanului din service care zicea de 2 eeprom-uri - 1 km partial, 1 pentru celalalte chestii.
QUOTE(powerx @ 26 Sep 2006, 14:00) Mda, electricianul din service-ul in care am fost eu, zicea ca ar fi 2 EEPROM-uri, unul pt kilometraj partial, si celalalt pt restul chestiilor ce le memoreaza pe acolo(benzina consumata, etc). Si explicatia data de fabrica ar fi ca daca se umple memoria la primul eeprom, cam incearca sa scrie in al doilea, si le reseteaza pe ambele. Si lumea isi punea intrebarea, daca sunt 2 eepromuri pentru aceste functii, pentru functia aia de km general ar trebui sa fie un al treilea eeprom, care nu se defecteza. Deci 3 eepromuri... care sunt pe placa...aaa...aaa... unde? Si cum de unele loganuri (cum e al meu care nu s-a resetat niciodata) merg bine-mersi, si altele nu? Pai daca e acelasi soft, si aceleasi eepromuri, nu ar trebui sa se comporte toate la fel? As putea sa pun pariu ca de fapt e un contact imperfect, cel mai probabil cel de masa de pe traversa bordului. |
LC_TM |
#309
Membru autentic Group: Members Posts: 269 Joined: 27 September 06 ![]() |
Hi,
Stiu ca este primul meu post,dar citesc acest forum de mai bine de 1 an de zile,in consecinta am achizitionat un logan in oct 2005 si am constat aceeasi resetare a computerlui de bord. Ceea ce am observat este ca daca eu stau cu cd-player-ul pornit timp de 3-4 ore la un nivel de 18-20 computerul mi se reseteaza.Fara sa fie problema cu depasirea memoriei sau chestii de genul asta,de ce spun asta?Simplu ptr ca aveam 110km facuti de la ultima alimentare cand eu resetez valorile computerului de bord.Tind sa cred ca este o problema de alimentare,in momentul in care scade tensiunea pe bornele bateriei computer-ul se reseteaza. Cam asta ar fi ce am constatat,chestia cu player-ul pornit se intampla aproape in fiecare weekend ![]() |
Nissan/ex. Dacia
Terrano II 2.7TDi/Logan
- TM-XX-XXX
2004/2005 Ambition 1.6MPI
roland |
#310
LC_TM, ti s-a resetat si ceasul sau nu? Si eu am stat cu CD-ul pornit si apoi am observat resetarea, dar totodata depasisem si capacitatea kilometrajului partial. Dar nu mi s-a resetat ceasul si nici CD-ul nu mi-a cerut cod.
LC_TM |
#311
Hi,
Ceasul nu s-a resetat niciodata,palyer-ul la fel,doar valorile compului de bord ![]() Cam astea sunt experientele mele cu compu de bord ![]() This post has been edited by LC_TM: 27 Sep 2006, 19:41 |
Nissan/ex. Dacia
- TM-XX-XXX
caeindru |
#312
Membru incepator Group: Members Posts: 2 Joined: 7 October 06 ![]() |
Nu am citit tot threadul.
Am patit-o in vara asta, o singura data. S-a resetat compul, iar cand am refacut contactul, revenise integral, mai putin consumul de benzina. Adica arata zero! Cand am alimentat, si-a revenit si acesta. Am analizat ce s-a intamplat si am ajuns la o concluzie: probabil ca a sarit borna de la baterie sau ceva asemanator, la alimentarea electrica, pentru ca nu am mai avut de atunci (si nici pana atunci) vreo problema asemanatoare (nu e vorba de depasirea memoriei compului). Ma bazez pe asta pentru ca, inainte de a se intampla pocinogul, am facut o curba foarte stransa si am simtit cum se misca bateria. Apropo, de ce bateria nu are vreun sistem de fixare si sta asa, pe inertie? Sau imi lipseste mie? |
dacia logan
ambition 1.6 mpi
bobo77 |
#313
Adica o luase "la trap bateria"? nu prea cred, o fii mai saltareate a ta,nu este asta motivul pt care s-a resetat cb., citeste topicul si o sa pricepi...
Laureate 1,6 mpi
- CT _ _ _ _
2008 ph 2 Multa lume,putini oameni...
prody |
#314
![]() membru iradiat Group: Members Posts: 1.365 Joined: 26 November 05 From: Cetatea Banilor ![]() |
Fiti atenti ce am facut io : am oprit motorul intr-o mica vale, cam cu vreo 10 m inainte de a parca masina, asa, de curiozitate, ca nu mai facusem niciodata cu asta ( desi nu e recomandat, pentru servofrana). Am parcat, am rezolvat ce aveam de facut, dupa 30 min. cand ma urc in masina, pornesc si caut sa selectez consumul instant... surpriza , se resetase consumul mediu si km. parcursi de la ultima alimentare, cred ca atat, la altele nu m-am mai uitat.
Mazda
3
2011 TX
Alma |
#315
Membru incepator Group: Members Posts: 7 Joined: 28 February 06 ![]() |
sunt curios daca noul computer (fara consum instant) mai are problema asta, poate asta a fost motivul schimbarii.
6000rpm |
#316
![]() Membru incepator Group: Members Posts: 46 Joined: 8 February 06 ![]() |
salutare! (hai ca dezgrop cadavrele)
![]() problema asta cu auto-resetarea o am si eu de ceva vreme. sincer sa fiu, s-a resetat de 3-4 ori din arpilie 2005 de cand am masina (abition). nu e mult dar e deranjant. ![]() se reseteaza cand pornesti motorul, fara explicatie. ![]() a fost cineva in service sa rezolve aceasta problema? vreau sa ma duc si eu si sa stiu la ce sa ma astept! ![]() ps. ![]() ![]() This post has been edited by 6000rpm: 16 Nov 2006, 20:15 |
Logan 1.5 DCI
2007, Ambition
DFA |
#317
![]() moderator://DC/Logan Group: Moderatori Posts: 3.562 Joined: 30 September 05 From: Buzău, RO ![]() |
Mergi în service și vezi dacă poți să-i convingi pe electricieni să-ți tragă o masă mai bună la tabloul de bord. Sau o faci tu...
Asta e singura soluție. Masa o poți lua de pe coloana de direcție sau direct de la baterie. Masa existentă nu trebuie deconectată, ci adăugată la ea una pe care să nu mai "pice" nici o tensiune. |
Logan III Comfort
ECO-G 100cp
- 27 Iul 2021
2021 sedan Logan III Comfort ECO-G 100, Bleu Iron, 16" Amaris, MediaNav, P. sc. încălz.+Climă, P. Comfort, P. Park. 2, volan piele, geam. el. sp.
ex Logan I 1.5 |
david79 |
#318
![]() Membru autentic Group: Members Posts: 888 Joined: 19 March 05 ![]() |
sa inteleg ca ar exista o legatura intre resetarea comp de bord si afisarea liniilor de la temperetura apa ( alt numar decat 4 )..... , si anume acea masa.
Toyota
2008 / 2011
cataline |
#319
Membru autentic Group: Members Posts: 332 Joined: 9 February 06 From: Bucuresti ![]() |
QUOTE(DFA @ 16 Nov 2006, 21:48) Mergi în service și vezi dacă poți să-i convingi pe electricieni să-ți tragă o masă mai bună la tabloul de bord. Sau o faci tu... Asta e singura soluție. Masa o poți lua de pe coloana de direcție sau direct de la baterie. Masa existentă nu trebuie deconectată, ci adăugată la ea una pe care să nu mai "pice" nici o tensiune. Nu prea vad eu service dacia sa faca asa ceva atat timp cat masina este in garantie. Si eu am avut resetari de computer si mai apoi (cei drept cam jumatate de an nu a mai facut) a aparut faza cu temperatura. Legatura dintre cele doua nu exista dupa mine dar cine mai stie ce caz ascuns mai exista. |
Ambition 1.6
- B-xx-XXX
2005 Logan 1.6 Ambition, dec 2005
DFA |
#320
QUOTE(david79 @ 16 Nov 2006, 22:15) sa inteleg ca ar exista o legatura intre resetarea comp de bord si afisarea liniilor de la temperetura apa alt numar decat 4 Da, ambele probleme au o cauză comună, masa care ajunge la tabloul de bord, pe ea apar tensiuni parazite și nu mai are potențialul corect (-12V), care provoacă resetarea CB și afișarea unei temperaturi mai ridicate decât cea reală. Nu e obligatoriu ca cele 2 defecte să se manifeste simultan. QUOTE(cataline @ 17 Nov 2006, 11:22) Poate reușești să-i convingi că schimbarea TdB nu rezolvă problema, doar "întărirea" masei o rezolvă. Unele service-uri care au mai citit pe aici pe forum aplică această rezolvare cu succes. |
Logan III Comfort
ECO-G 100cp
- 27 Iul 2021
ex Logan I 1.5 |
l@u |
#321
Salut-Laureate+2006 fara CI acum 15 min s-a resetat ptr a 2-a oara in 2000 Km.Cum termin de scris direct in service ma opresc-cand ma intorc am sa va tin la curent cu explicatiile celor de acolo.Mentionez ca se reseteaza din senin consumul mediu si cantitatea de combustibil consumata de la ultima resetare
Land Rover
Freelander
Td4, HSE
DFA |
#322
De fapt se resetează doar cantitatea de combustibil consumată. Consumul mediu se pierde doar ca o consecință.
Logan III Comfort
ECO-G 100cp
- 27 Iul 2021
ex Logan I 1.5 |
powerx |
#323
schimbat azi tablou bord pe acest motiv, auto-resetare in service. Am incercat sa ii explic la om ca degeaba schimb, a zis ca el e electrician, nu eu
![]() Oricum, e bine ca am bord nou, am 98 km la bord ![]() |
Logan Ambition
Verde cameleon
- VS-23-XYZ
l@u |
#324
Revin cu explicatiile promise si culese de la 3 service-uri:
-primul service...ASA FACE TOATE...no problem it"s no sugar -al 2-lea service...baiatul cu IT-ul plecat in concediu -al 3-lea service...verificat CB;s-a gasit o eroare care s-a resetat in rest,,no problem it's no sugar''.Drept urmare am cerut o verificare a CB pe tester dar am fost instiintat ca aceasta treaba nu face obiectul garantiei si trebuie platita de mine~70RON.Am renuntat la verificare dar am cerut sa mi se mentioneze in carnetul de garantie defectul solicitat si am primit un carnet de control in care se mentioneaza ca am sesizat defectiunea iar cei de la service au controlat+resetat CB si nu au gasit nici o defectiune.Deocamdata prestatia celor din service nesperat de buna.Astept evolutia CB in continuare iar la urmatorul reset am sa ma prezint in service asa cum am fost sfatuit de cel care s-a ocupat de cazul meu. |
Land Rover
Freelander
Td4, HSE
cataline |
#325
QUOTE(DFA @ 17 Nov 2006, 13:32) Poate reușești să-i convingi că schimbarea TdB nu rezolvă problema, doar "întărirea" masei o rezolvă. Unele service-uri care au mai citit pe aici pe forum aplică această rezolvare cu succes. Eu cand am fost cu masina la Cobalcescu in legatura cu temperatura afisata in bord gresit (care btw este tot nerezolvata, sta Uzina sa gandeasca inca solutie) mi s-a zis ca ei nu trag fire aiurea de masa fara sa vorbeasca la Uzina intai. Poate unele service-uri o fac, dar Cobalcescu nu. La AMG solutia era schimbare TdB si nu aduceau vorba de masa si alte d-astea (prea avansat pentru ei). |
Ambition 1.6
- B-xx-XXX
6000rpm |
#326
sunt niste nemernici! de ce nu vor sa inteleaga ca trebuie un cablu mai gros la minus si scapa si de mii de vizite la service ale oamenilor nemultumiti. vad ca nu s-a mai resetat in ultima vreme. sa vad si cat il tine. azi am facut plinul si l-am resetat eu. sa vedem...
Logan 1.5 DCI
2007, Ambition
driverx |
#327
Exista un loc (poate chiar acest topic) unde se descrie cat de cat pasii pentru a pune o masa sanatoasa? Am 1222 km cu masina si ieri cred ca 5-a sau a 6-a oara s-a resetat. M-am saturat sincer sa fiu....
Mitsubishi
Lancer
l@u |
#328
[quote=driverx,19 Nov 2006, 07:27]
Exista un loc (poate chiar acest topic) unde se descrie cat de cat pasii pentru a pune o masa sanatoasa? Daca gasesti link-ul mai repede posteaza-l te rog ![]() This post has been edited by lau0678: 19 Nov 2006, 10:09 |
Land Rover
Freelander
Td4, HSE
l@u |
#329
Astazi am fost sunat de la service-ul la care lipsea baiatu' cu calculatoarele si sunt invitat ptr. a se lamuri problema cu autoresetarea.Dupa investigatiile de rigoare s-a ajuns la concluzia ca....
![]() ![]() This post has been edited by lau0678: 20 Nov 2006, 13:31 |
Land Rover
Freelander
Td4, HSE
DFA |
#330
Simpla înlocuire a TdB nu va rezolva resetarea datelor memorate de CB.
Oricum, așteptăm cu interes să ne spui după cât timp de la schimbare ți-au dispărut datele din CB... ![]() (sau poate ai noroc tu și odată cu schimbarea TdB îți "întărește" și masa lui...) |
Logan III Comfort
ECO-G 100cp
- 27 Iul 2021
ex Logan I 1.5 |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 4th August 2025 - 12:59 |
