Lumina colorata, lumina desenata, Imagini: "asa" si "altfel"
#241
![]() fan Dacia Group: Members Posts: 21.592 Joined: 12 November 05 From: Bucuresti ![]() |
- negru pe alb
Ov |
#242
un inceput ar fi sa citesti lectiile de aici: http://www.morguefile.com/archive/classroom.php
in cateva ore n-ai ce face si crede-ma ca-s chiar utile |
ArtVandelay |
#243
![]() Anytown, USA.. Group: Members Posts: 2.662 Joined: 5 January 08 From: Craiova ![]() |
focus
2001 He wondered why the boomerang kept getting bigger. Then, it hit him.
I got 99 cookiez cause a bitch ate one. |
Ov |
#244
un close-up reusit, dar cred ca i-ar fi placut mai mult sa-i faci poza din fata
![]() This post has been edited by Ov: 7 Jan 2009, 13:21 |
miki |
#245
![]() #Hırsızlargibigeceniniçine Group: Members Posts: 1.242 Joined: 30 July 02 From: Bucuresti ![]() |
Mie mi se pare mai interesant asa!
Din fata, parca nu ar mai fi fost umbrele interesante, mai ales ca banui eu, omul nu are macro-ring sau alt flash de macro! ![]() Oricum are un dof acceptabil, desi un pic mai blur pe background n-ar fi stricat! |
Sedan 1.6 16V / Megane IV 1.33 TCE/Santa Fe
2004 / 2019/2008
logan1.5dci |
#246
Nu Există Informații Group: Members Posts: 881 Joined: 29 September 05 From: Dobrogea ![]() |
E prima data cand pozez cratere.
![]() Poza nu-i nimic de capul ei, chiar mai am de invatat la butonat. Facuta cu distanta focala 200, apoi zoom digital, decupat , de aia a ajuns asa mica. Oricum planuiesc un obiectiv cu distanta de 400, da mai stau, poate improvizez un telescop(sa faca poze,stiu ca exista da costa), ma mai gandesc. Pun cearceaful asta si intreb, ce date ar fi bine sa pun la viitoarele fotografii? Make - NIKON CORPORATION Model - NIKON D60 Orientation - Top left XResolution - 300 YResolution - 300 ResolutionUnit - Inch Software - ViewNX 1.0 W DateTime - 2009:01:07 00:25:51 YCbCrPositioning - Centered ExifOffset - 212 ExposureTime - 1/400 seconds FNumber - 6.30 ExposureProgram - Aperture priority ISOSpeedRatings - 1600 ExifVersion - 0221 DateTimeOriginal - 2009:01:07 00:12:06 DateTimeDigitized - 2009:01:07 00:12:06 ComponentsConfiguration - YCbCr ExposureBiasValue - -4.00 MaxApertureValue - F 5.66 MeteringMode - Multi-segment LightSource - Auto Flash - Not fired FocalLength - 200 mm UserComment - SubsecTime - 40 SubsecTimeOriginal - 40 SubsecTimeDigitized - 40 FlashPixVersion - 0100 ColorSpace - sRGB ExifImageWidth - 3872 ExifImageHeight - 2592 InteroperabilityOffset - 826 SensingMethod - One-chip color area sensor FileSource - Other SceneType - Other CustomRendered - Normal process ExposureMode - Auto White Balance - Auto DigitalZoomRatio - 1 x FocalLengthIn35mmFilm - 300 mm SceneCaptureType - Standard GainControl - High gain up Contrast - Normal Saturation - Normal Sharpness - Normal SubjectDistanceRange - Unknown Maker Note (Vendor): - Data version - 0210 (808595760) ISO Setting - 1600 Color Mode - COLOR Image Quality - NORMAL White Balance - AUTO Image Sharpening - AUTO Focus Mode - MANUAL White Balance Adjustment - 0 White Balance RB - 670 Exposure Adjustment - 68608 Thumbnail IFD offset - 2854 ISO 2 - 1600 Tone Compensation - AUTO Lens type - 234881024 Lens - 764 Flash Used - Not fired Bracketing - 0 Color Mode - MODE3a Light Type - NATURAL Hue Adjustment - 0 Noise Reduction - OFF Total pictures - 325 Optimization - NORMAL Thumbnail: - Compression - 6 (JPG) XResolution - 72 YResolution - 72 ResolutionUnit - Inch JpegIFOffset - 3914 JpegIFByteCount - 4870 Si mai intreb ceva pe... meseriasi. Ce am gresit ? This post has been edited by logan1.5dci: 7 Jan 2009, 11:25 |
- Nu Există Informații
os |
#247
Nu ca as fi eu mare expert, dar am pozat Luna de mai multe ori si uite ce opinii am despre poza de mai sus:
1. pare supraexpusa. Luna e un pietroi gri (deschis), iluminat direct de Soare. Cum ai fotografia obiectul un pietroi etc. aflat linga tine, cam asa e si Luna: eu am obtinut rezultate bune cu ceva de genul ISO 100; F8; 1/125 (sau chiar 1/250). 2. Poza e (foarte) "soft", o sa-mi permit sa sugerez citeva lucruri: 2.1: daca e facuta de pe trepied/suport: stabilizatorul (VR) trebuie sa fie oprit. 2.2. De verificat focalizarea: AF? Care senzor? MF? La obiectivele care stiu si AF (adica aproape toate), opritorul de "infinit" pe inel e un pic dincolo de pozitia optica "infinit". 2.3. Nu stiu daca aparatul tau suporta asa ceva; daca da, ar fi de folosit: predeclansare oglinda. Acest regim de lucru lasa camerei un mic timp (la mine: 2 sec) ca sa se stinga oscilatiile produse de mecanismul oglinzii. Daca mu, poti folosi declansatorul automat. 2.4. Prelucrarea imaginii: poate ar fi mers un "unsharp mask". Daca imaginea e facuta din RAW (NEF) un pic de "unsharp mask" e necesar. In rest, mult succes! Apropos: pentru Luna/cer poti sa incerci un teleconvertor, ori un obiectiv rusesc cu oglinda (exista de exemplu Rubinar 500mm si Rubinar 1000mm). Au ele ceva dezavantaje, dar sunt imbatabile la pret (pentru distantele alea focale). rubinar 1000/10: http://www.rugift.com/photocameras/rubinar_1000_lens.htm rubinar 500/8: http://www.rugift.com/photocameras/rubinar_8_500_lens.htm rubinar 500/5,6: http://www.rugift.com/photocameras/rubinar_500_lens.htm Am dat link-urile ca sa vezi despre ce e vorba; poate reusesti un autoimport de prin Ucraina, la pret mai bun? Nota: iti mai trebuie un adaptor M42/Nikon. -------- Edit: Intre timp au aparut informatiile din EXIF, dar nu mai stau sa corectez textul de mai sus. Doar citeva comentarii "de ce": - diafragma: de cele mai multe ori obiectivele dau imagini mai bune cu diafragma (usor) inchisa. Cit de inchisa e variabil de la obiectiv la obiectiv; cu valori in jurul lui 8 esti in siguranta. - sensibilitatea: ISO mai mic -> zgomot mai mic. Luna e de fapt destul de luminoasa, vezi ce am scris mai inainte. Timpul de expunere rezulta. - Automatul de expunere: in functie de setare, acesta (poate sa) incearca/incerce sa obtina vestitul gri de 18% pe o portiune mai mare a cadrului (sau pe tot cadrul). In cazul Lunii insa, ai ceva mic, luminos si interesant in mijlocul a ceva negru, mare si de care nu-ti pasa. Asa ca vrei sa expui corect Luna; restul de cer n-are decit sa iasa negru. - vad ca ai folosit MF - cum zic, obiectivele trec dincolo de infinit (pentru ca AF sa poata gasi infinitul). Daca inelul a fost rotit pina in opritor-> out of focus, trebuie sa rotesti "un pic" inapoi. Poti foarte bine sa incerci AF. |
. Muschii mei minte nu are.
ArtVandelay |
#248
poza cu fluturele nu ar fi iesit bine din fata, pentru ca era lumina in spate iar poza e cu telefonul (nu aveam camera atunci). singurele editari sunt auto levels si resize
poate daca il convingeam sa se roteasca ![]() This post has been edited by ArtVandelay: 7 Jan 2009, 12:59 |
focus
Ov |
#249
#250
Sunt foarte curios ce model de telefon e. K850i cumva?
Ov |
#251
ceva de genu', ca alea-s singurele telefoane capabile sa produca imagini decente
ArtVandelay |
#252
k750i
focus
#253
Uite si argumentul de care aveam nevoie mai devreme. Trebuia sa spui de la inceput.
Os, referitor la pozele cu luna, sunt diferente notabile de claritate intre cele facute in Bucuresti si cele facte de exemplu la munte? Eu ma astept la un raspuns pozitiv gandindu-ma la poluarea aerului si cea luminoasa. Are rost sa ma chinui sa obtin un cadru la urmatoarea luna plina profitand putin de o noapte geroasa prin bucuresti? |
- negru pe alb
jcdenton |
#254
![]() Membru Group: Members Posts: 131 Joined: 1 November 07 From: Bucuresti ![]() |
Logan Laureate
2010
os |
#255
@einstein1984, despre Luna:
Nu stiu, ca n-am facut niciodata din Bucuresti. Cred ca in cazul Lunii mai degraba sunt limitative obiectivele, dar inca o data: nu stiu. Poate altcineva sa spuna mai multe? (Ov? Liviu?) |
logan1.5dci |
#256
Multumesc os pentru sfaturi.
Am sa mai incerc curand, poate la noapte. Am totusi o obsevatie/intrebare. Daca ma uit atent partea de jos a lunii este supraexpusa, dar daca o expun corect jos se va mai vedea partea de sus, care e cam intunecata? Unde se vad denivelarile alea N-Vsi unde se vede craterul ala mare S-E. This post has been edited by logan1.5dci: 7 Jan 2009, 16:52 |
os |
#257
Se vede cum trebuie - adica atit cit se poate.
Ceea ce se intimpla este asa: partea intunecata a Lunii oricum nu se vede(*) fiindca in absenta atmosferei si a particulelor (praf, cristale de gheata etc) din aceasta pe Luna nu este lumina difuza. Cu alte cuvinte lumiona solara e luminoasa, iar umbra e neagra. La "margini" se vede la fel. (*) exceptii in anumite configuratii aparte, in care pe Luna mai soseste ceva lumina reflectata de Pamint ori refractata de atmosfera Pamintului ca in cazul eclipselor. |
Ov |
#258
QUOTE(einstein1984 @ 7 Jan 2009, 16:28) sunt diferente notabile de claritate intre cele facute in Bucuresti si cele facte de exemplu la munte? http://ideograme.blogspot.com/2006/09/fara-text.html ultima poza e facuta din drumul taberei, vara, din casa scarii, pe geamul dintre etajul 1 si 2, fara trepied, un obiectiv de 350mm, f5.6, iso vre-o 200 si cam 1/350 timpul de expunere. Nu mai stiu exact, dar valorile sunt pe acolo. |
logan1.5dci |
#259
OOOAAAAA ce misto, am sa fac si eu.
![]() Abia astept sa-mi vina convertorul x3 pe care l-am comandat ieri. |
Ov |
#260
greseala clasica la foto de luna e ca (la fel cum s-a spus deja mai sus) folositi timp prea lung de expunere sau iso prea mare. Luna este FOARTE luminosa, d'aia merge chiar sa faci pozele din mana fara trepied. E o "lege" empirica ce zice ca daca vrei sa nu-ti iasa poza miscata timpul de expunere trebuie sa fie ceva de genul 1/focala, adica la un obiectiv tele de 200mm, ca sa nu iasa poza miscata tb folosit minim 1/200s si la un wide de 18mm ar merge 1/18s
![]() ![]() This post has been edited by Ov: 8 Jan 2009, 15:02 |
os |
#261
*crop_factor...
Ov |
#262
logan1.5dci |
#263
Revin cu o mentiune, am sa incerc sa fac, chiar daca tehnologic pot, mai am de invatat sa folosesc aparatul.
Multumesc os si Ov pentru indicatii. ![]() Mentiune: poate as fi incercat mai multe setari, poza am facut-o de acasa de la geam, si a trebuit sa deschid geamul , asa ca m-am cam grabit (ca e ger), nu zic ca stiam, dar as fi facut mai multe probe si o postam pe cea mai buna. Oricum am facut 3, cea postata aratand cel mai bine. Pe trepied. This post has been edited by logan1.5dci: 8 Jan 2009, 15:48 |
os |
#264
@logan1.5dci: cel mai bine - experimenteaza. Desigur, sunt chestiuni deja testate de altii, pe care n-are rost sa le redescoperi - dar pin ala urma tot trebuie sa capeti reflexele adecvate. Eu de exemplu uit (prea des) sa dezactivez stabilizatorul cind lucrez de pe trepied. Asta vara cind cu eclipsa de luna am facut cred 50 de RAW-uri cu eclipsa de pe trepied (eram afara pe o terasa, aveam camera linga mine pe trepied si cam la 5 minute trageam una-doua imagini. Ghinion, uitasem stabilizatorul activ - toate pozele au fost numai bune de aruncat
![]() @Ov: da, despre timpul de expunere estimat spuneam, in chestiunea cu crop-factor. E asa, regula aia provine de pe vremea camerelor cu film si se refera la fullformat. Cropfactor intervine prin unghiul de cimp (caci ceea ce provoaca pozele "miscate" sunt mai ales oscilatii unghiulare). Dar "regula" nu e decit EXTREM de orientativa, dapinde ce lucruri cum ar fi pozitia in care stai (una favorita pentru mine este in genunchi, uneori mai sprijin si un cot pe genunchiul flexat), de cit esti de obosit si inca atitia alti factori. Poza su tobosarii de aici: http://www.daciaclub.ro/index.php?showtopi...dpost&p=1428766 am facut-o din mina la 55mm cu 1/15 sec. Fara stabilizator, dar cu cotul sprijinit pe genunchi. Luasem si ceva calmante(*), care cred ca mi-au stabilizat imaginea. (*) cam 200cl de lichide, din alea facute din apa, malt si hamei. |
Ov |
#265
QUOTE(logan1.5dci @ 8 Jan 2009, 15:13) io am facut vre-o 200 pana am scos-o p'aia. Bine, nu erau toate proaste, dar prinzi tu ideea ![]() QUOTE(os @ 8 Jan 2009, 15:43) @Ov: da, despre timpul de expunere estimat spuneam, in chestiunea cu crop-factor. E asa, regula aia provine de pe vremea camerelor cu film si se refera la fullformat. Cropfactor intervine prin unghiul de cimp (caci ceea ce provoaca pozele "miscate" sunt mai ales oscilatii unghiulare). am si zis ca regula e mega empirica, e doar asa, sa-ti dea o idee generala cam prin ce zona trebuie sa te invarti, dar voiam sa-ti subliniez ca marimea senzorului n-are nici o legatura aici ![]() ![]() QUOTE(os @ 8 Jan 2009, 15:43) daca nu erau "fierte" nu se pune ![]() ![]() This post has been edited by Ov: 8 Jan 2009, 16:22 |
os |
#266
Crezi ca-o sa ma las? Nici gind!
Sigur ca ai dreptate in relatia dintre marimea senzorului si distanta focala. Totusi (ca si in alt caz controversat - cel al calculului DOF) smecheria e asa, ca nu te uiti la poze la marimea senzorului ci le maresti (ca-i analog sau digital nu conteaza) pina la marimea "ceruta". Fiindca pentru aceeasi marime finala (ca-i ea pe hirtie, sau pe ecran) maresti mai mult imaginea(*) facuta de un senzor mai mic, maresti si imperfectiunile acestei imagini - in acest caz "tremuraturile". Asa intervine crop_factor. (*) aici prin imagine se intelege proiectia (optica) prin obiectiv a obiectului real pe suprafata sensibila, indiferent de natura acestei suprafete. ------ Pai - dac'ar fi fost fara alcool, nu mai era calmant hi hi... Crede-ma ca se pune. Si inca ce se pune... cu alt aocazie (dar cu substanta asemanatoare) am avut surpriza ca constat a doua zi, cind am vizionat pozele pe care le facusem, ca la un moment dat cineva mi-a luat camera si a pozat cu ea: nu se poate sa fi fost eu, caci nu-mi aminteam de loc sa fi facut pozele alea. |
Serpico |
#267
Membru autentic Group: Members Posts: 511 Joined: 10 April 03 From: Timisoara ![]() |
Si eu zic ca nu are importanta "crop factor"-ul cand se aplica regula (orientativa) ce zice ca timpul de expunere sa fie de cel putin 1/focala la fotografierea din mana pentru ca poza sa nu iasa miscata.
Sa zicem ca fotografiem cu un aparat cu film 35mm (cadru 24mm x 36mm). Sa presupunem ca am facut poza cu regula "timp=1/focala" si nu a iesit miscata. Acum iau negativul si decupez partea centrala a cadrului la 16mm x 24mm (Nikon DX; crop factor 1,5). Brusc poza (ce a mai ramas din ea) devine miscata? Un alt aspect: un obiectiv cu distanta focala de 100 mm (de exemplu) da aceeasi perspectiva si acelasi DOF (la aceeasi diafragma) indiferent ca e folosit pe un Full Frame sau pe un DX/APS-C. Nu se obtine pe DX/APS-C perspectiva data de un obiectiv de 150mm/160mm (in aceleasi conditii, respectiv aceeasi distanta aparat-subiect). Singurul parametru influentat de "crop factor" este unghiul de cuprindere. Adica exact ceea ce spune si numele: se face un crop (nu se mareste distanta focala). |
Laureate Plus 1.4MPI 2007
os |
#268
Serpico: ai dreptate, si n-ai.
Pentru ca nu degeaba am scris "aduci imaginea la marimea ceruta": dupa ce decupezi poza, o mai maresti ca s-o aduci la aceeasi marime (sau o privesti mai de aproape, ca sa revii la aceeasi impresie vizuala - adica la acelasi unghi de cimp). In acest fel incepi sa observi detalii si/sau imperfectiuni pe care inainte nu le vedeai. Spre exemplu, presupune ca limita la care un detaliu este perceput de observator ca "miscat" este 0.1 mm. Mai presupune ca imaginea initiala FF are un detaliu cu margini "graduale" late de de 0.08mm -> acest detaliu va fi perceput ca fiind "clar", caci limita de 0.1 mm nu e depasita. Dupa ce imaginea e decupata si marita (pentru aceeasi impresie vizuala, in exemplul tau de 1.5 ori) detaliul are margini de 0.08*1.5=0.12mm - dincolo de limita de "nemiscare". Sigur, limitele sunt fluente; prezentarea mea de aici numai o simplificare. Cum poti sa te convingi: cauta o super-zoom, seteaz-o pe manual la cea mai mare distanta focala a ei, aia la care marketingu' zice "optical zoom 10x" Probabil ca o sa ajungi pe la 30-50mm (distant afocala reala, nu "equiv 35mm"). Stabilizatorul oprit (daca exista). Fa o poza din mina la 1/30, sau la 1/50 - sau la cit iese. Mareste rezultatul la o dimensiune rezonabila. Vorbeste cu mine, sa-mi spui ce a iesit. Unghul de cimp nu-i chiar neimportant - ci dimpotriva, el determina major ceea ce "se vede". Acest fapt corespunde de altfel si vederii naturale. In rest suntem de acord. In exemplul tau legat de obiective: ca sa putem compara lucrurile, ar trebui sa modificam distanta fata de obiect pentru a obtine acelasi unghi de cimp. |
logan1.5dci |
#269
Ho ho ho , ce am gasit http://www.daciaclub.ro/Lumina-colorata-lu...-p1428766.html#
Mai sunt si altii care nu au somn, vad ca si domnu' Liviu a pozat luna ![]() Si ce-i misto ca zip-ul pastreaza EXIF-ul. Make - PENTAX Corporation Model - PENTAX *ist DL2 Orientation - Top left XResolution - 72 YResolution - 72 ResolutionUnit - Inch Software - *ist DL2 Ver 1.00 DateTime - 2008:05:15 00:36:23 YCbCrPositioning - Co-Sited ExifOffset - 602 ExposureTime - 1/125 seconds FNumber - 8.00 ExposureProgram - Aperture priority ISOSpeedRatings - 200 ExifVersion - 0221 DateTimeOriginal - 2008:05:15 00:36:23 DateTimeDigitized - 2008:05:15 00:36:23 ComponentsConfiguration - YCbCr ExposureBiasValue - 0.00 MeteringMode - Spot Flash - Flash not fired, compulsory flash mode FocalLength - 300 mm FlashPixVersion - 0100 ColorSpace - sRGB ExifImageWidth - 3008 ExifImageHeight - 2000 InteroperabilityOffset - 56338 SensingMethod - One-chip color area sensor FileSource - Other SceneType - Other CustomRendered - Normal process ExposureMode - Auto White Balance - Auto FocalLengthIn35mmFilm - 450 mm SceneCaptureType - Standard Contrast - Hard Saturation - High Sharpness - Hard SubjectDistanceRange - Distant view Maker Note (Vendor): - Mode - Auto Quality - Best ISO - 200 White Balance - Auto Thumbnail: - Compression - 6 (JPG) XResolution - 72 YResolution - 72 ResolutionUnit - Inch JpegIFOffset - 56464 JpegIFByteCount - 1162 |
Serpico |
#270
Sunt de acord ca imperfectiunile ies cu atat mai mult in evidenta cu cat marim mai mult imaginea.
Nu sunt insa asa de sigur ca se impune totusi o scurtare de 1,5 ori a timpului la un aparat cu crop factor de 1,5. Poate se impune un timp mai scurt, dar nu neaparat de 1,5 ori mai scurt. E greu de determinat (daca nu imposibil) si oricum regula timp=1/focala nu e decat o formula orientativa, stabilita empiric, cum deja s-a spus si aici. Depinde mult mai mult de fotograf decat de crop factor. Fotografia ta cu tobosarii (focala 55 mm si timp de expunere 1/15 sec) este un bun exemplu in acest sens. QUOTE(os @ 8 Jan 2009, 17:41) In exemplul tau legat de obiective: ca sa putem compara lucrurile, ar trebui sa modificam distanta fata de obiect pentru a obtine acelasi unghi de cimp. Depinde din ce punct de vedere privesti lucrurile: te intereseaza sa ai acelasi unghi de cuprindere sau te intereseaza sa ai aceeasi perspectiva si acelasi DOF. This post has been edited by Serpico: 8 Jan 2009, 17:28 |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 14th July 2025 - 12:48 |
