29 Pages « < 15 16 17 18 19 > »
> [VAND]piese DACIA noi-REDUCERE DE PRETURI
valy051
post 20 May 2012, 17:45
Post #481
Aveti poza,,Aparatoare roata noroi(1buc fata+1buc spate)'':
x x x - x
valy051
post 29 May 2012, 17:41
Post #482
Alternator Dacia(Cod 1114)------------------------------170ron
Antifurt capace roti Dacia---------------------------------12ron
Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron
Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc
Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc.
Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron
Bascula spate Dacia------------------------------------------25ron
Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron
Bec 21W/5W(dublu filament) ---------------------------1ron/buc
Bieleta antiruliu Prems ---------------------------------------7ron
Bloc diode 50A/12V-Dacia-----------------------------------30ron
Bloc diode(mici) ----------------------------------------------15ron
Borne acumulator(bronz) ----------------------------------7ron/set
Brida radiator -------------------------------------------------2ron
Bucsa ax volan----------------------------------------------2.5ron
Bucsa bascula superioara(Franta)--------------------------10ron
Bucsa caseta directie(teflon) ----------------------------1ron/buc
Bucsa bascula spate --------------------------------------3.5ron
Bucsa cuplaj volan(Fartec)-----------------------------------6ron
Bucsa tirant--------------- ----------------------------------16ron/4buc
Bucsi electromotor Dacia--------------------------------------6ron/set
Burduf planetara(mare) --------------------------------------5ron
Burduf planetara(mic) ----------------------------------------4ron
Buson baie ulei -----------------------------------------------3ron
Buson radiator ------------------------------------------------2ron
Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron
Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron
Cablu frana mana -------------------------------------------25ron
Cala carburator textolit -------------------------------------0.8ron
Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set
Camere Victoria 175/185/195-14 ----------------------------8ron
Camera Victoria 145-13---------------------------------------7ron
Capac delcou Dacia -------------------------------------------4ron
Carbuni electromotor Dacia-Oltcit ----------------------------6ron
Carburator Dacia 1400(27)(S.H.)-----------------------------55ron
Ceas presiune ulei--------------------------------------------10ron
Cheie combinata buson ulei baie+c.v. Dacia---------------15ron
Chiulasa neechipata 1310/1410 ---------------------------280ron
Cleste dezizolator multifunctional----------------------------2,5ron
Cleste dezizolator cablu(profesional)-------------------------27ron
Comutator semnal. directie 1310/1410 ----------------------10ron
Cui pontou Carfil---------------------------------------------12ron
Culbutori(2 buc)----------------------------------------------10/buc
Curea trapez.dintata GATES6213MC AVX10x825La---------13ron
Curea trapez.SUPER 9.5x950 -------------------------------11ron
Curea ventilator Fartec 10x6x1000 --------------------------5ron
Curea ventilator Fartec 10x8x1218 --------------------------9ron
Cutie sigurante 10 cai ----------------------------------------10ron
Cuzineti palier R1 Dacia1310/1410 -----------------------25ron
Disc ambreiaj Fi 180mm Dacia 1310/1410(original)--------55 ron
Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron
Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron
Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron
Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron
Garnituri cilindrii receptori spate ----------------------------3ron
Garnituri motor 1410(set)-----------------------------------25ron
Intrerupator lampa martor frana mana--------------------2.5ron
Inele sincron C.V.--------------------------------------------25ron
Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc
Motor stergator parbriz ARO 10------------------------------35ron
Oala planetara(dinspre roata) -------------------------------35ron
Patent 200mm-------------------------------------------------5ron
Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron
Pivot inf. -----------------------------------------------------15ron
Pivot Superior------------------------------------------------15ron
Presa pivoti Dacia--------------------------------------------45ron
Platina --------------------------------------------------------4ron
Releu far(4pic.) ---------------------------------------------2.5ron
Releu protectie halogene 30A(Italy) -------------------------8ron
Releu semnalizare Sacele -----------------------------------10ron
Releu tensiune mecanic Sacele pt.Dacia--------------------35ron
Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron
Rotor electromotor D.Sacele --------------------------------90ron
Rotor alternator D.Sacele------------------------------------60ron
Rulment ambreiaj Fi180(39060) ---------------------------12ron
Rulment biconic Mare(35305)C.V---------------------------25ron
Rulment biconic Mic(35405)C.V.----------------------------16ron
Rulment conic302/37 -----------------------------------------7ron
Rulment roata fata 6207 -------------------------------------9ron/buc
Rulmenti spate Dacia----------------------------------------15 ron/set/roata
Rulmenti cutie viteza(5tr) -------------------------------80ron/set
Saboti frana 1310----------------------------------------40ron/set roata
Semeringuri FARTEC-----110x130x13(arbore Tractor U650)--12ron
-------------------------50x70x10(butuc roata ARO)------------7ron
--------------------------35x50x8(distributie)--------------- ---5ron
--------------------------26x42x10(planetara Dacia 1310)-----5ron
Set sigurante(8A-16A)---------------------------------------2ron
Set Yalle usi+portbagaj1310 --------------------------------40ron
Set capse ferodouri saboti spate-----------------------------3ron
Simering priza C.V. 17x28x7/13F ----------------------------3ron
Sonda litrometrica 5726 (Aro)-------------------------------20ron
Sonda ulei ceas ----------------------------------------------22ron
Stator alternator ---------------------------------------------55ron
Stergatoare SACA 400mm/16''(set) ------------------------10ron
Supapa servomecanism frana--------------------------------2.5ron
Suporti motor Dacia----------------------------------------25ron
Stifturi planetara--------------------------------------------6ron/set
Termostat Dacia ---------------------------------------------10ron
Triunghi reflectorizant ---------------------------------------20ron
Valve tubeles -------------------------------------------------1ron
telef.0763012130
x x x - x
valy051
post 1 Jun 2012, 11:26
Post #483
Chiulasa neechipata 1310/1410 ---------------------------230ron
telef.0763012130
x x x - x
valy051
post 14 Jun 2012, 11:37
Post #484
telef.0763012130
x x x - x
valy051
post 24 Jun 2012, 16:05
Post #485
telef.0763012130
x x x - x
valy051
post 1 Jul 2012, 10:58
Post #486
telef.0763012130
x x x - x
address
post 3 Jul 2012, 03:23
Post #487
..... Dacia 13OO (1972) .....
Buna ziua.
Chiulasa de 1310 din ce an este, va rog?
Este compatibila cu benzina fara plumb?
Scaunele supapelor de admisie sunt pentru 33,5mm sau pentru 34,6mm?
Este modelul cu sau fara semeringuri la supape?
Eventual, inaltimea chiulasei?
Multumesc anticipat.
This post has been edited by address: 3 Jul 2012, 19:05
Dacia 1300 1972 - B01XYZ
valy051
post 4 Jul 2012, 18:51
Post #488
Aveti PM dle.address.
x x x - x
address
post 4 Jul 2012, 23:02
Post #489
Buna ziua.
Va multumesc pentru raspuns.
Care din dimensiunile de chiulase
(ca inaltime) vi se pare cea mai apropiata ?
Chiulase compatibile cu benzina fara plumb -
ma refeream la cele cu scaune de supape tratate,
montate (montabile) pe motoare cu injectie.
Va multumesc anticipat.
valy051
post 5 Jul 2012, 10:35
Post #490
Chiulasa este 102-13.Acest cod(102-13) se afla poansonat pe chiulasa.Specificatiile sunt cele cf.tabelului postat de dumneavoastra.Inaltimea chiulasei este de 73.75mm.
This post has been edited by valy051: 5 Jul 2012, 10:36
x x x - x
valy051
post 19 Jul 2012, 14:54
Post #491
telef.0763012130
x x x - x
valy051
post 28 Jul 2012, 09:23
Post #492
telef.0763012130
x x x - x
payty
post 28 Jul 2012, 22:00
Post #493
yalele pt usi si portbagaj mai exista?
daca da se poate pune o poza? sunt originale, sau turcesti?
valy051
post 8 Aug 2012, 12:18
Post #494
telef.0763012130
x x x - x
valy051
post 21 Aug 2012, 13:44
Post #495
telef.0763012130
x x x - x
valy051
post 27 Aug 2012, 09:43
Post #496
Vand:
telef.0763012130
x x x - x
valy051
post 30 Aug 2012, 15:23
Post #497
Vand:
telef.0763012130
x x x - x
florin iulian
post 30 Aug 2012, 20:22
Post #498
rulmentii pt roata fata si setul pt spate de cine sunt produsi ?
Dacia, Nissan 1300,1310,1310,Note 1980,1984,2002,2006
valy051
post 4 Sep 2012, 10:52
Post #499
Vand:
telef.0763012130
x x x - x
valy051
post 8 Sep 2012, 13:03
Post #500
Vand:
telef.0763012130
x x x - x
valy051
post 17 Sep 2012, 13:27
Post #501
Alternator Dacia(Cod 1114)--------------------------170 lei
Antifurt capace roti Dacia---------------------------15 lei
Anvelopa Hankook-185/65/R14 86T,1buc-NOUA--100 lei
Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm---100 lei/2buc.
Ax pompa apa Dacia(INOXIDABIL) ------------------------10 lei
Bascula spate Dacia----------------------------------------25 lei
Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35 lei
Bec 21W/5W(dublu filament) ---------------------------1 lei/buc
Bieleta directie(tip vechi)Dacia(Topoloveni)------------40 lei
Bieleta antiruliu Prems ---------------------------------------7 lei
Bloc diode(mari) --------------------------------------------25 lei
Borne acumulator(bronz) --------------------------------7 lei/set
Brida radiator -------------------------------------------------2 lei
Bucsa ax volan----------------------------------------------2.5 lei
Bucsa bascula sup.(Franta)) ------------------------------------10 lei
Bucsa bascula superioara,,Fartec''--------------------------------7 lei
Bucsa caseta directie(teflon) ----------------------------1,5-lei/buc
Bucsa cauciuc bascula spate -------------------------------3.5-lei
Bucsa cuplaj volan(Fartec)-----------------------------------7-lei
Bucsa tirant----------- ----------------------------------16-lei/4buc
Burduf planetara(mare) --------------------------------------5-lei
Burduf planetara(mic) ----------------------------------------4-lei
Buson baie ulei -----------------------------------------------4-lei
Buson radiator ------------------------------------------------2-lei
Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)--------55-lei
Butuc roata fata Dacia(3 prezoane)---------------------------50 lei
Cablu frana mana ------------------------------------------------25 lei
Cala carburator textolit ------------------------------------------1,5 lei
Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)8buc--150 lei/set 4buc
Camere Victoria 175/185/195-14 ----------------------------6 ron
Capac pompa apa Dacia(Pulsor - Scornicesti)--------------100 lei
Capac delcou Dacia -------------------------------------------5 lei
Carbuni alternator Urziceni ------------------------------------5 lei
Carbuni electromotor Dacia-Oltcit -----------------------------6 lei
Carburator Dacia 1400(27)(S.H.)------------------------------65 lei
Ceas presiune ulei-----------------------------------------------10 lei
Cheie combinata buson ulei baie+c.v. Dacia------------------15 lei
Chiulasa neechipata 1310/1410 -----------------------------250 lei
Cleste dezizolator multifunctional----------------------------2,5lei
Cleste dezizolator cablu(profesional)-------------------------25 lei
Comutator semnal. directie 1310/1410 ----------------------10 lei
Cui pontou Carfil--------------------------------------------------14 lei
Culbutori (2 buc.)-------------------------------------------------10 lei/buc
Curea trapez.dintata GATES6213MC AVX10x825La--------13 lei
Curea trapez.SUPER 9.5x950 -------------------------------11 lei
Curea ventilator Fartec 10x6x1000 --------------------------5 lei
Curea ventilator Fartec 10x8x1218 --------------------------9 lei
Cutie sigurante 10 cai ----------------------------------------8 lei
Cuzineti ST R1 Dacia1310/1410 ----------------------------25 lei
Disc ambreiaj Dacia 1310/1410(Fi 180)original------------55 lei
Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)---12 lei
Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20lei
Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10 lei
Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 lei
Garnituri cilindrii receptori spate Dacia-----------------------1,5lei
Garnituri motor 1410(set)-------------------------------------25 lei
Inele sincron C.V.-----------------------------------------------25 lei
Jicloare 1300/1400 Carfil(diferite)---------------------------3lei/buc
Motor stergator parbriz ARO 10------------------------------35 lei
Oala planetara(dinspre roata) ------------------------------35 lei
Patent 200mm---------------------------------------------------5 lei
Pistol aer cu manometru(0,5-10bar)(Italia) -------------30 lei
Pivot inf. --------------------------------------------------------17 lei
Pivot superior--------------------------------------------------15 lei
Presa pivoti Dacia----------------------------------------------45 lei
Releu far(4pic.) -------------------------------------------------3 lei
Releu protectie halogene 30A(Italy) -----------------------10 lei
Releu semnalizare Sacele ------------------------------------10 lei
Releu tensiune mecanic Bulgaria-12V ----------------------30 lei
Releu tensiune Sacele 12 V----------------------------------38 lei
Rotor electromotor D.Sacele --------------------------------90 lei
Rotor alternator D.Sacele------------------------------------60 lei
Rulment ambreiaj Fi180(39060) ---------------------------12 lei
Rulment biconic Mare(35305)C.V---------------------------25 lei
Rulment biconic Mic(35405)C.V.----------------------------16 lei
Rulment conic302/37 -----------------------------------------7 lei
Rulment roata fata 6207 -------------------------------------9 lei
Rulmenti cutie viteza(5tr) -------------------------------100 lei/set
Saboti frana 1310 (Fermit-Rm.Sarat)-----------------------80/set 4 buc
Semeringuri FARTEC-----110x130x13(arbore Tractor U 650)-------12lei
-------------------------80x100x10-----------------------------8 lei
-------------------------50x70x10(butuc roata ARO)-------------7 lei
--------------------------35x50x8(distributie Dacia)-------------5 lei
--------------------------26x42x10(planetara Dacia 1310)-------4 lei
Simering priza C.V. 17x28x7/13F ---------------------------------4 lei
Set sigurante(8A-16A)----------------------------------------------2 lei
Set Yalle usi+portbagaj1310 -------------------------------------40 lei
Sonda litrometrica 5726(ARO?)-----------------------------------20 lei
Sonda ulei ceas -----------------------------------------------------22 lei
Stator alternator ----------------------------------------------------55 lei
Stergatoare SACA 400mm/16''(set) -----------------------------10 lei
Suporti motor Dacia-------------------------------------------------25 lei
Termostat Dacia -----------------------------------------------------10 lei
Triunghi reflectorizant ----------------------------------------------20 lei
Valve tubeles ----------------------------------------------------------1 lei
Telef.0763012130
x x x - x
valy051
post 20 Sep 2012, 18:01
Post #502
Telef.0763012130
x x x - x
valy051
post 23 Sep 2012, 20:13
Post #503
Vand:
Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----40 lei/set
Telef.0763012130
x x x - x
valy051
post 29 Sep 2012, 01:17
Post #504
Vand:
Telef.0763012130
x x x - x
post 2 Oct 2012, 22:14
Post #505
Salut,
Motoras de aruncat lichidul pe parbriz ai?
Stima.
DACIA 1400 Dacia 1400 1997
valy051
post 4 Oct 2012, 09:00
Post #506
Vand:
Telef.0763012130
x x x - x
valy051
post 11 Oct 2012, 16:56
Post #507
Vand:
Telef.0763012130
x x x - x
valy051
post 17 Oct 2012, 19:50
Post #508
Vand:
Telef.0763012130
x x x - x
valy051
post 26 Oct 2012, 10:19
Post #509
Vand:
Telef.0763012130
x x x - x
deceneu32
post 29 Oct 2012, 22:16
Post #510
Pivotii ce marca sunt?
Dacia 1300 1970 - DJ 70 ABC
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 15th July 2025 - 05:05
