29 Pages « < 17 18 19 20 21 > »
> [VAND]piese DACIA noi-REDUCERE DE PRETURI
valy051
post 10 May 2013, 11:52
Post #541
Vand:
Alternator Dacia(Cod 1114)--------------------------170 lei
Anvelopa Hankook-185/65/R14 86T,1buc-NOUA--100 lei
Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm---100 lei/2buc.
Ax pompa apa Dacia(INOXIDABIL) ------------------------10 lei
Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35 lei
Bec 21W/5W(dublu filament) ---------------------------1 lei/buc
Bieleta directie(tip vechi)Dacia(Topoloveni)------------40 lei
Bieleta antiruliu Prems ---------------------------------------7 lei
Bloc diode(mari) --------------------------------------------25 lei
Borne acumulator(bronz) --------------------------------7 lei/set
Brida radiator -------------------------------------------------2 lei
Bucsa ax volan----------------------------------------------2.5 lei
Bucsa bascula sup.(Franta)) ------------------------------------10 lei
Bucsa bascula superioara,,Fartec''--------------------------------7 lei
Bucsa caseta directie(teflon) ----------------------------1,5-lei/buc
Bucsa cauciuc bascula spate -------------------------------3.5-lei
Bucsa cuplaj volan(Fartec)-----------------------------------7-lei
Bucsa tirant----------- ----------------------------------16-lei/4buc
Burduf planetara(mare) --------------------------------------5-lei
Burduf planetara(mic) ----------------------------------------4-lei
Buson baie ulei -----------------------------------------------4-lei
Buson radiator ------------------------------------------------2-lei
Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)--------55-lei
Butuc roata fata Dacia(3 prezoane)---------------------------50 lei
Cablu frana mana ------------------------------------------------25 lei
Cala carburator textolit ------------------------------------------1,5 lei
Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)8buc--150 lei/set 4buc
Camere Victoria 175/185/195-14 ----------------------------6 ron
Capac pompa apa Dacia(Pulsor - Scornicesti)--------------100 lei
Capac delcou Dacia -------------------------------------------5 lei
Carbuni alternator Urziceni ------------------------------------5 lei
Carbuni electromotor Dacia-Oltcit -----------------------------6 lei
Carburator Dacia 1400(27)(S.H.)------------------------------65 lei
Ceas presiune ulei-----------------------------------------------10 lei
Cheie combinata buson ulei baie+c.v. Dacia------------------15 lei
Chiulasa neechipata 1310/1410 -----------------------------250 lei
Cleste dezizolator multifunctional----------------------------2,5lei
Cleste dezizolator cablu(profesional)-------------------------25 lei
Comutator semnal. directie 1310/1410 ----------------------10 lei
Cui pontou Carfil--------------------------------------------------14 lei
Culbutori (2 buc.)-------------------------------------------------10 lei/buc
Curea trapez.dintata GATES6213MC AVX10x825La--------13 lei
Curea trapez.SUPER 9.5x950 -------------------------------11 lei
Curea ventilator Fartec 10x6x1000 --------------------------5 lei
Curea ventilator Fartec 10x8x1218 --------------------------9 lei
Cutie sigurante 10 cai ----------------------------------------8 lei
Cuzineti ST R1 Dacia1310/1410 ----------------------------25 lei
Disc ambreiaj Dacia 1310/1410(Fi 180)original------------55 lei
Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)---12 lei
Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20lei
Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10 lei
Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 lei
Garnituri cilindrii receptori spate Dacia-----------------------1,5lei
Garnituri motor 1410(set)-------------------------------------25 lei
Inele sincron C.V.-----------------------------------------------25 lei
Jicloare 1300/1400 Carfil(diferite)---------------------------3lei/buc
Motor stergator parbriz ARO 10------------------------------35 lei
Oala planetara(dinspre roata) ------------------------------35 lei
Patent 200mm---------------------------------------------------5 lei
Pistol aer cu manometru(0,5-10bar)(Italia) -------------30 lei
Pivot inf. --------------------------------------------------------17 lei
Pivot superior--------------------------------------------------15 lei
Presa pivoti Dacia----------------------------------------------45 lei
Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----40 lei/set
Releu far(4pic.) -------------------------------------------------3 lei
Releu protectie halogene 30A(Italy) -----------------------10 lei
Releu semnalizare Sacele ------------------------------------10 lei
Releu tensiune mecanic Bulgaria-12V ----------------------30 lei
Releu tensiune Sacele 12 V----------------------------------38 lei
Rotor electromotor D.Sacele --------------------------------90 lei
Rotor alternator D.Sacele------------------------------------60 lei
Rulment ambreiaj Fi180(39060) ---------------------------12 lei
Rulment biconic Mare(35305)C.V---------------------------25 lei
Rulment biconic Mic(35405)C.V.----------------------------16 lei
Rulment conic302/37 -----------------------------------------7 lei
Rulment roata fata 6207 -------------------------------------9 lei
Rulmenti cutie viteza(5tr) -------------------------------100 lei/set
Saboti frana 1310 (Fermit-Rm.Sarat)-----------------------80/set 4 buc
Semeringuri FARTEC-----110x130x13(arbore Tractor U 650)-------12lei
-------------------------80x100x10-----------------------------8 lei
-------------------------50x70x10(butuc roata ARO)-------------7 lei
--------------------------35x50x8(distributie Dacia)-------------5 lei
--------------------------26x42x10(planetara Dacia 1310)-------4 lei
Simering priza C.V. 17x28x7/13F ---------------------------------4 lei
Set sigurante(8A-16A)----------------------------------------------2 lei
Set Yalle usi+portbagaj1310 -------------------------------------40 lei
Sonda litrometrica 5726(ARO?)-----------------------------------20 lei
Sonda ulei ceas -----------------------------------------------------22 lei
Stator alternator ----------------------------------------------------55 lei
Stergatoare SACA 400mm/16''(set) -----------------------------10 lei
Suporti motor Dacia-------------------------------------------------25 lei
Termostat Dacia -----------------------------------------------------10 lei
Triunghi reflectorizant ----------------------------------------------20 lei
Valve tubeles ----------------------------------------------------------1 lei
Telef.0763012130
x x x - x
valy051
post 19 May 2013, 20:55
Post #542
Vand:
Telef.0763012130
x x x - x
valy051
post 22 May 2013, 17:30
Post #543
Vand:
Telef.0763012130
x x x - x
valy051
post 29 May 2013, 18:54
Post #544
Vand:
Telef.0763012130
x x x - x
valy051
post 10 Jun 2013, 20:19
Post #545
Vand:
Telef.0763012130
x x x - x
valy051
post 19 Jun 2013, 19:39
Post #546
Vand:
Telef.0763012130
x x x - x
valy051
post 26 Jun 2013, 14:40
Post #547
Vand:
Telef.0763012130
x x x - x
valy051
post 30 Jun 2013, 21:47
Post #548
Vand:
Telef.0763012130
x x x - x
valy051
post 8 Jul 2013, 13:09
Post #549
Vand:
Telef.0763012130
x x x - x
valy051
post 12 Jul 2013, 10:10
Post #550
Vand:
Bieleta directie(tabla ambutisata)Dacia(Topoloveni)------------40 lei
Bucsa bascula sup.(Fartec)) ------------------------------------10 lei
Bucsa caseta directie(teflon) ---------------------------------5-lei/buc
Bucsa cauciuc bascula spate -------------------------------4-lei
Bucsa cuplaj volan(Fartec)-----------------------------------10-lei
Carburator Dacia 1400(27)(S.H.)------------------------------55 lei
Pivot superior--------------------------------------------------20 lei
Telef.0763012130
x x x - x
valy051
post 18 Jul 2013, 09:41
Post #551
Vand:
Telef.0763012130
x x x - x
valy051
post 21 Jul 2013, 08:56
Post #552
Vand:
Telef.0763012130
x x x - x
valy051
post 29 Jul 2013, 15:46
Post #553
Vand:
Telef.0763012130
x x x - x
valy051
post 2 Aug 2013, 19:28
Post #554
Vand:
Rulment biconic Mare(35305)C.V---------------------------45 lei
Rulment conic302/37 -----------------------------------------10 lei
Telef.0763012130
x x x - x
valy051
post 15 Aug 2013, 08:46
Post #555
Vand:
Telef.0763012130
x x x - x
valy051
post 23 Aug 2013, 16:58
Post #556
Vand:
Telef.0763012130
x x x - x
valy051
post 25 Aug 2013, 10:05
Post #557
Vand:
Telef.0763012130
x x x - x
valy051
post 30 Aug 2013, 16:26
Post #558
Vand:
Telef.0763012130
x x x - x
valy051
post 10 Sep 2013, 17:28
Post #559
Vand:
Telef.0763012130
x x x - x
valy051
post 21 Sep 2013, 08:27
Post #560
Vand:
Telef.0763012130
x x x - x
valy051
post 30 Sep 2013, 19:35
Post #561
Vand:
Telef.0763012130
x x x - x
valy051
post 9 Oct 2013, 11:55
Post #562
Vand:
Telef.0763012130
x x x - x
valy051
post 17 Oct 2013, 21:48
Post #563
Vand:
Telef.0763012130
x x x - x
valy051
post 26 Oct 2013, 14:49
Post #564
Vand:
Telef.0763012130
x x x - x
valy051
post 6 Nov 2013, 15:35
Post #565
Vand:
Telef.0763012130
x x x - x
valy051
post 16 Nov 2013, 14:20
Post #566
Vand:
Telef.0763012130
x x x - x
cmandrei
post 9 Dec 2013, 03:29
Post #567
NEWSMAN
Redeschis la cerere.
ex. Renault Clio Symbol 2001 Dynamique (1.4 8V 75 cp K7J-A7) - RO
33.722 km - 12.2004
178.691 km - 03.2013
Andrei
valy051
post 9 Dec 2013, 15:21
Post #568
Vand:
Telef.0763012130
x x x - x
razvan1985
post 10 Dec 2013, 18:28
Post #569
membru...unic
suporti motor Dacia,25lei,se poate poza?
Dacia/Delta 1410/1310/L/MLS 1996/1988 - B 91 RZN/B 191 RZN
decat una proasta,mai bine mai multe bune...(masina)
valy051
post 24 Dec 2013, 09:18
Post #570
Vand:
Telef.0763012130
x x x - x
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 15th July 2025 - 01:16
