[VAND]piese DACIA noi-REDUCERE DE PRETURI
sandor406 |
#571
Membru incepator Group: Members Posts: 15 Joined: 11 July 09 ![]() |
1310 li
2000
- hd-08-gpu
valy051 |
#572
Membru autentic Group: Members Posts: 2.667 Joined: 9 April 09 From: Bucuresti ![]() |
Vand:
Alternator Dacia(Cod 1114)--------------------------170 lei Anvelopa Hankook-185/65/R14 86T,1buc-NOUA--100 lei Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm---100 lei/2buc. Ax pompa apa Dacia(INOXIDABIL) ------------------------10 lei Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35 lei Bec 21W/5W(dublu filament) ---------------------------1 lei/buc Bieleta directie(tabla ambutisata)Dacia(Topoloveni)------------40 lei Bloc diode(mari) --------------------------------------------25 lei Borne acumulator(bronz) --------------------------------7 lei/set Brida radiator -------------------------------------------------2 lei Bucsa ax volan----------------------------------------------2.5 lei Bucsa bascula sup.(Fartec)) ------------------------------------10 lei Bucsa caseta directie(teflon) ---------------------------------5-lei/buc Bucsa cauciuc bascula spate -------------------------------4-lei Bucsa cuplaj volan(Fartec)-----------------------------------10-lei Bucsa tirant----------- ----------------------------------16-lei/4buc Burduf planetara(mare) --------------------------------------5-lei Burduf planetara(mic) ----------------------------------------4-lei Buson baie ulei -----------------------------------------------4-lei Buson radiator ------------------------------------------------2-lei Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)--------55-lei Butuc roata fata Dacia(3 prezoane)---------------------------50 lei Cablu frana mana ------------------------------------------------25 lei Cala carburator textolit ------------------------------------------1,5 lei Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)8buc--150 lei/set 4buc Camere Victoria 175/185/195-14 ----------------------------6 ron Capac pompa apa Dacia(Pulsor - Scornicesti)--------------100 lei Capac delcou Dacia -------------------------------------------5 lei Carbuni alternator Urziceni ------------------------------------5 lei Carbuni electromotor Dacia-Oltcit -----------------------------6 lei Carburator Dacia 1400(27)(S.H.)------------------------------55 lei Ceas presiune ulei-----------------------------------------------10 lei Cheie combinata buson ulei baie+c.v. Dacia------------------15 lei Chiulasa neechipata 1310/1410 -----------------------------250 lei Cleste dezizolator multifunctional----------------------------2,5lei Cleste dezizolator cablu(profesional)-------------------------25 lei Comutator semnal. directie 1310/1410 ----------------------10 lei Cui pontou Carfil--------------------------------------------------14 lei Culbutori (2 buc.)-------------------------------------------------10 lei/buc Curea trapez.dintata GATES6213MC AVX10x825La--------13 lei Curea trapez.SUPER 9.5x950 -------------------------------11 lei Curea ventilator Fartec 10x6x1000 --------------------------5 lei Curea ventilator Fartec 10x8x1218 --------------------------9 lei Cutie sigurante 10 cai ----------------------------------------8 lei Cuzineti ST R1 Dacia1310/1410 ----------------------------25 lei Disc ambreiaj Dacia 1310/1410(Fi 180)original------------55 lei Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)---12 lei Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20lei Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10 lei Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 lei Garnituri cilindrii receptori spate Dacia-----------------------1,5lei Garnituri motor 1410(set)-------------------------------------25 lei Inele sincron C.V.-----------------------------------------------25 lei Jicloare 1300/1400 Carfil(diferite)---------------------------3lei/buc Motor stergator parbriz ARO 10------------------------------35 lei Oala planetara(dinspre roata) ------------------------------35 lei Patent 200mm---------------------------------------------------5 lei Pistol aer cu manometru(0,5-10bar)(Italia) -------------30 lei Pivot superior--------------------------------------------------20 lei Presa pivoti Dacia----------------------------------------------45 lei Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----40 lei/set Releu far(4pic.) -------------------------------------------------3 lei Releu protectie halogene 30A(Italy) -----------------------10 lei Releu semnalizare Sacele ------------------------------------10 lei Releu tensiune mecanic Bulgaria-12V ----------------------30 lei Releu tensiune Sacele 12 V----------------------------------38 lei Rotor electromotor D.Sacele --------------------------------90 lei Rotor alternator D.Sacele------------------------------------60 lei Rulment ambreiaj Fi180(39060) ---------------------------12 lei Rulment biconic Mare(35305)C.V---------------------------45 lei Rulment conic302/37 -----------------------------------------10 lei Rulment roata fata 6207 -------------------------------------9 lei Rulmenti cutie viteza(5tr) -------------------------------100 lei/set Saboti frana 1310 (Fermit-Rm.Sarat)-----------------------80/set 4 buc Semeringuri FARTEC-----110x130x13(arbore Tractor U 650)-------12lei -------------------------80x100x10-----------------------------8 lei -------------------------50x70x10(butuc roata ARO)-------------7 lei --------------------------35x50x8(distributie Dacia)-------------5 lei --------------------------26x42x10(planetara Dacia 1310)-------4 lei Simering priza C.V. 17x28x7/13F ---------------------------------4 lei Set sigurante(8A-16A)----------------------------------------------2 lei Set Yalle usi+portbagaj1310 -------------------------------------40 lei Sonda litrometrica 5726(ARO?)-----------------------------------20 lei Sonda ulei ceas -----------------------------------------------------22 lei Stator alternator ----------------------------------------------------55 lei Stergatoare SACA 400mm/16''(set) -----------------------------10 lei Suporti motor Dacia-------------------------------------------------25 lei Termostat Dacia -----------------------------------------------------10 lei Triunghi reflectorizant ----------------------------------------------20 lei Valve tubeles ----------------------------------------------------------1 lei Telef.0763012130 |
x
x
x
- x
valy051 |
#573
Vand:
x
x
x
- x
valy051 |
#574
Vand:
x
x
x
- x
valy051 |
#575
Vand:
x
x
x
- x
Albert Einstein |
#576
![]() Pasionat Group: Members Posts: 2.140 Joined: 22 May 06 From: Bucuresti ![]() |
QUOTE(valy051 @ 12 Feb 2014, 23:14) Ceas presiune ulei-----------------------------------------------10 lei Se poate o poza va rog? |
- "I fear the day when the technology overlaps with our humanity. The world will only have a generation of idiots" - Albert Einstein
valy051 |
#577
Aveti foto dle.Albert Einstein:
x
x
x
- x
valy051 |
#578
Vand:
x
x
x
- x
valy051 |
#579
Vand:
x
x
x
- x
val2011 |
#580
Alternatorul este de Sacele?
dacie
- bz..
valy051 |
#581
Vand:
x
x
x
- x
DACIOTUL_97 |
#582
![]() Ne plac femeile,dar iubim masinile ! Group: Members Posts: 1.649 Joined: 8 July 13 From: Bd-ul Dacia ![]() |
Poze se poate ? Multumesc. |
1310/Logan/
MLS 1986/MLS 1985/1.6 16v Prestige 2008 "Voi lupta pana la ultima mea picatura de sange,ca sa ai dreptul,sa nu fi de acord cu mine"
#Pasionat de fiare vechi# Ex.Dacia 1310-CN3 & 1310-ph1 |
valy051 |
#583
x
x
x
- x
valy051 |
#584
Vand:
Alternator Dacia(Cod 1114)--------------------------170 lei Anvelopa Hankook-185/65/R14 86T,1buc-NOUA--100 lei Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm---100 lei/2buc. Ax pompa apa Dacia(INOXIDABIL) ------------------------10 lei Bascula sup.cu pivot(rebucsata Fartec)DACIA-Papuc------------35 lei Bec 21W/5W(dublu filament) ---------------------------1 lei/buc Bieleta directie(tabla ambutisata)Dacia(Topoloveni)------------40 lei Bloc diode(mari) --------------------------------------------25 lei Borne acumulator(bronz) --------------------------------7 lei/set Brida radiator -------------------------------------------------2 lei Bucsa ax volan----------------------------------------------2.5 lei Bucsa bascula sup.(Fartec)) ------------------------------------10 lei Bucsa caseta directie(teflon) ---------------------------------5-lei/buc Bucsa cauciuc bascula spate -------------------------------4-lei Bucsa cuplaj volan(Fartec)-----------------------------------10-lei Bucsa tirant----------- ----------------------------------16-lei/4buc Burduf planetara(mare) --------------------------------------5-lei Burduf planetara(mic) ----------------------------------------4-lei Buson baie ulei -----------------------------------------------4-lei Buson radiator ------------------------------------------------2-lei Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)--------55-lei Butuc roata fata Dacia(3 prezoane)---------------------------50 lei Cablu frana mana ------------------------------------------------25 lei Cala carburator textolit ------------------------------------------1,5 lei Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)8buc--150 lei/set 4buc Camere Victoria 175/185/195-14 ----------------------------6 ron Capac pompa apa Dacia(Pulsor - Scornicesti)--------------100 lei Capac delcou Dacia -------------------------------------------5 lei Carbuni alternator Urziceni ------------------------------------5 lei Carbuni electromotor Dacia-Oltcit -----------------------------6 lei Carburator Dacia 1400(27)(S.H.)------------------------------55 lei Ceas presiune ulei-----------------------------------------------10 lei Cheie combinata buson ulei baie+c.v. Dacia------------------15 lei Chiulasa neechipata 1310/1410 -----------------------------250 lei Cleste dezizolator multifunctional----------------------------2,5lei Cleste dezizolator cablu(profesional)-------------------------25 lei Comutator semnal. directie 1310/1410 ----------------------10 lei Cui pontou Carfil--------------------------------------------------14 lei Culbutori (2 buc.)-------------------------------------------------10 lei/buc Curea trapez.dintata GATES6213MC AVX10x825La--------13 lei Curea trapez.SUPER 9.5x950 -------------------------------11 lei Curea ventilator Fartec 10x6x1000 --------------------------5 lei Curea ventilator Fartec 10x8x1218 --------------------------9 lei Cutie sigurante 10 cai ----------------------------------------8 lei Cuzineti ST R1 Dacia1310/1410 ----------------------------25 lei Disc ambreiaj Dacia 1310/1410(Fi 180)original------------55 lei Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)---12 lei Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20lei Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10 lei Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 lei Garnituri cilindrii receptori spate Dacia-----------------------1,5lei Garnituri motor 1410(set)-------------------------------------25 lei Inele sincron C.V.-----------------------------------------------25 lei Jicloare 1300/1400 Carfil(diferite)---------------------------3lei/buc Motor stergator parbriz ARO 10------------------------------35 lei Oala planetara(dinspre roata) ------------------------------35 lei Patent 200mm---------------------------------------------------5 lei Pistol aer cu manometru(0,5-10bar)(Italia) -------------30 lei Pivot superior--------------------------------------------------20 lei Presa pivoti Dacia----------------------------------------------45 lei Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----40 lei/set Releu far(4pic.) -------------------------------------------------3 lei Releu protectie halogene 30A(Italy) -----------------------10 lei Releu semnalizare Sacele ------------------------------------10 lei Releu tensiune mecanic Bulgaria-12V ----------------------30 lei Releu tensiune Sacele 12 V----------------------------------38 lei Rotor electromotor D.Sacele --------------------------------90 lei Rotor alternator D.Sacele------------------------------------60 lei Rulment ambreiaj Fi180(39060) ---------------------------12 lei Rulment biconic Mare(35305)C.V---------------------------45 lei Rulment conic302/37 -----------------------------------------10 lei Rulment roata fata 6207 -------------------------------------10 lei Rulmenti cutie viteza(5tr) -------------------------------100 lei/set Saboti frana 1310 (Fermit-Rm.Sarat)-----------------------80/set 4 buc Semeringuri FARTEC-----110x130x13(arbore Tractor U 650)-------12lei -------------------------80x100x10-----------------------------8 lei -------------------------50x70x10(butuc roata ARO)-------------7 lei --------------------------35x50x8(distributie Dacia)-------------5 lei --------------------------26x42x10(planetara Dacia 1310)-------4 lei Simering priza C.V. 17x28x7/13F ---------------------------------4 lei Set sigurante(8A-16A)----------------------------------------------2 lei Set Yalle usi+portbagaj1310 -------------------------------------40 lei Sonda litrometrica 5726(ARO?)-----------------------------------20 lei Sonda ulei ceas -----------------------------------------------------22 lei Stator alternator ----------------------------------------------------55 lei Stergatoare SACA 400mm/16''(set) -----------------------------10 lei Suporti motor Dacia-------------------------------------------------25 lei Termostat Dacia -----------------------------------------------------10 lei Triunghi reflectorizant ----------------------------------------------20 lei Valve tubeles ----------------------------------------------------------1 lei Telef.0763012130 |
x
x
x
- x
valy051 |
#585
Vand piese NOI Dacia:
x
x
x
- x
valy051 |
#586
x
x
x
- x
valy051 |
#587
x
x
x
- x
cmandrei |
#588
![]() NEWSMAN Group: Moderatori Posts: 10.439 Joined: 9 March 05 From: Bucuresti/Targu Mures ![]() |
Redeschis la cerere.
ex. Renault
Clio Symbol
2001 Dynamique (1.4 8V 75 cp K7J-A7)
- RO 33.722 km - 12.2004
178.691 km - 03.2013 Andrei |
valy051 |
#589
x
x
x
- x
valy051 |
#590
x
x
x
- x
valy051 |
#591
x
x
x
- x
valy051 |
#592
x
x
x
- x
valy051 |
#593
x
x
x
- x
valy051 |
#594
x
x
x
- x
valy051 |
#595
x
x
x
- x
cmandrei |
#596
ex. Renault
Clio Symbol
valy051 |
#597
x
x
x
- x
harby ;)) |
#598
![]() Membru Group: Members Posts: 1.371 Joined: 3 July 12 From: Pitesti ![]() |
Set Yalle usi+portbagaj1310 -------------------------------------40 lei\
+presa pivoti . puteti pune niste poze? |
Renault 12 Gordini
Pontiac Firebird
1972, 1980
DACIOTUL_97 |
#599
QUOTE(DACIOTUL_97 @ 19 Mar 2014, 23:52) QUOTE(valy051 @ 20 Mar 2014, 11:15) 08032013_001_.jpg ( Size: 162.33k )
Number of downloads: 261 08032013.jpg ( Size: 162.54k ) Number of downloads: 273 ![]() QUOTE(harby ![]() Set Yalle usi+portbagaj1310 -------------------------------------40 lei\ +presa pivoti . puteti pune niste poze? |
1310/Logan/
valy051 |
#600
Alternator Dacia(Cod 1114)--------------------------170 lei Antifurt buson rezervor benzina-----------------------25 lei Anvelopa Hankook-185/65/R14 86T,1buc-NOUA--100 lei Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm---100 lei/2buc. Ax pompa apa Dacia(INOXIDABIL) ------------------------10 lei Bascula sup.cu pivot(rebucsata Fartec)DACIA-Papuc------------35 lei Bec 21W/5W(dublu filament) ---------------------------1 lei/buc Bieleta directie(tabla ambutisata)Dacia(Topoloveni)------------40 lei Bloc diode(mari) --------------------------------------------25 lei Borne acumulator(bronz) --------------------------------7 lei/set Brida radiator -------------------------------------------------2 lei Bucsa ax volan----------------------------------------------2.5 lei Bucsa bascula sup.(Fartec)) ------------------------------------10 lei Bucsa caseta directie(teflon) ---------------------------------5-lei/buc Bucsa cauciuc bascula spate -------------------------------4-lei Bucsa cuplaj volan(Fartec)-----------------------------------10-lei Bucsa tirant----------- ----------------------------------16-lei/4buc Burduf planetara(mare) --------------------------------------5-lei Burduf planetara(mic) ----------------------------------------4-lei Buson baie ulei -----------------------------------------------4-lei Buson radiator ------------------------------------------------2-lei Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)--------55-lei Butuc roata fata Dacia(3 prezoane)---------------------------50 lei Cablu frana mana ------------------------------------------------25 lei Cala carburator textolit ------------------------------------------1,5 lei Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)8buc--150 lei/set 4buc Camere Victoria 175/185/195-14 ----------------------------6 ron Capac pompa apa Dacia(Pulsor - Scornicesti)--------------100 lei Capac delcou Dacia -------------------------------------------5 lei Carbuni alternator Urziceni ------------------------------------5 lei Carbuni electromotor Dacia-Oltcit -----------------------------6 lei Carburator Dacia 1400(27)(S.H.)------------------------------55 lei Ceas presiune ulei-----------------------------------------------10 lei Cheie combinata buson ulei baie+c.v. Dacia------------------15 lei Chiulasa neechipata 1310/1410 -----------------------------250 lei Cleste dezizolator multifunctional----------------------------2,5lei Cleste dezizolator cablu(profesional)-------------------------25 lei Comutator semnal. directie 1310/1410 ----------------------10 lei Culbutori (2 buc.)-------------------------------------------------10 lei/buc Curea trapez.dintata GATES6213MC AVX10x825La--------13 lei Curea trapez.SUPER 9.5x950 -------------------------------11 lei Curea ventilator Fartec 10x6x1000 --------------------------5 lei Curea ventilator Fartec 10x8x1218 --------------------------9 lei Cutie sigurante 10 cai ----------------------------------------8 lei Cuzineti ST R1 Dacia1310/1410 ----------------------------25 lei Disc ambreiaj Dacia 1310/1410(Fi 180)original------------55 lei Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)---12 lei Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20lei Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10 lei Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 lei Garnituri cilindrii receptori spate Dacia-----------------------1,5lei Garnituri motor 1410(set)-------------------------------------25 lei Inele sincron C.V.-----------------------------------------------25 lei Jicloare 1300/1400 Carfil(diferite)---------------------------3lei/buc Motor stergator parbriz ARO 10------------------------------35 lei Oala planetara(dinspre roata) ------------------------------35 lei Patent 200mm---------------------------------------------------5 lei Pistol aer cu manometru(0,5-10bar)(Italia) -------------30 lei Pivot superior--------------------------------------------------20 lei Presa pivoti Dacia----------------------------------------------45 lei Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----40 lei/set Releu far(4pic.) -------------------------------------------------3 lei Releu protectie halogene 30A(Italy) -----------------------10 lei Releu semnalizare Sacele ------------------------------------10 lei Releu tensiune mecanic Bulgaria-12V ----------------------30 lei Releu tensiune Sacele 12 V----------------------------------38 lei Rotor electromotor D.Sacele --------------------------------90 lei Rotor alternator D.Sacele------------------------------------60 lei Rulment ambreiaj Fi180(39060) ---------------------------12 lei Rulment biconic Mare(35305)C.V---------------------------45 lei Rulment conic302/37 -----------------------------------------10 lei Rulment roata fata 6207 -------------------------------------10 lei Rulmenti cutie viteza(5tr) -------------------------------100 lei/set Saboti frana 1310 (Fermit-Rm.Sarat)-----------------------80/set 4 buc Semeringuri FARTEC-----110x130x13(arbore Tractor U 650)-------12lei -------------------------80x100x10-----------------------------8 lei -------------------------50x70x10(butuc roata ARO)-------------7 lei --------------------------35x50x8(distributie Dacia)-------------5 lei --------------------------26x42x10(planetara Dacia 1310)-------4 lei Simering priza C.V. 17x28x7/13F ---------------------------------4 lei Set sigurante(8A-16A)----------------------------------------------2 lei Set Yalle usi+portbagaj1310 -------------------------------------40 lei Sonda litrometrica 5726(ARO?)-----------------------------------20 lei Sonda ulei ceas -----------------------------------------------------22 lei Stator alternator ----------------------------------------------------55 lei Stergatoare SACA 400mm/16''(set) -----------------------------10 lei Suporti motor Dacia-------------------------------------------------25 lei Termostat Dacia -----------------------------------------------------10 lei Triunghi reflectorizant ----------------------------------------------20 lei Valve tubeles ----------------------------------------------------------1 lei Telef.0763012130 |
x
x
x
- x
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 15th July 2025 - 01:05 |
