reparat caldura la bordul scoica de 1310
iordache ionut lucian |
Membru incepator Group: Members Posts: 69 Joined: 30 November 10 ![]() |
Dacia si Audi
Dacia 1410 BREAK Audi 80 1,6td
1999 break 1990 80 1,6 td
- IF 28 JSM
Alex4u |
![]() Ultima scursura' umana Group: Members Posts: 2.131 Joined: 19 March 10 From: Scursureștii de Campie ![]() |
la ce te referi..la cauciucul ala care acopera caloriferul de caldura?? am auzit ca multi acolo au pus musama..de bucatarie si apoi a etansat foarte bine..e real?
EX:DACIA
BERLINA TX
1987 Ex Bmw e36 318i
Ex Opel Astra G 1.6 - Vand piese Ex Audi A4 1.6 105 HP Ex Peugeot 206 Ford Focus II 2009. Opel Astra G 1.6 16v |
NU LA ALA MA REFEREAM CI LA ACELA CARE ACOPERA PRIZELE DINSPRE AFARA SPRE CALORIFER
7 Dec 2010, 13:18: suze de majuscule This post has been edited by iordache ionut lucian: 7 Dec 2010, 12:18 |
Dacia si Audi
- IF 28 JSM
rodi |
![]() Membru autentic Group: Members Posts: 648 Joined: 2 November 10 ![]() |
Asta duce la eliminarea tirajului cand circuli cu peste 40 la ora...
- --- E PUR SI MUOVE (it. - cit.)
Alex4u |
la asta ma gandeam si eu...tu il izolezi si aerul pe unde mai intra :-? hmm
EX:DACIA
BERLINA TX
Kiraly |
![]() Membru autentic Group: Members Posts: 921 Joined: 21 May 10 ![]() |
daca nu intra aerul nu mai ai dezaburire...
1310 Li
- BH 90 PUP sufli in jigler pui o sarma si gata!!!
IntensBurnE |
![]() low-ride member Group: Members Posts: 228 Joined: 12 April 10 From: Oradea ![]() |
si eu am bord tip scoica,eu am facut "unpik de loc" la cauciucul ala de sub grila sa intre mai mult aer, si m`am pus grile de plastic ce baga aerul fortat inauntru.deci si daca merg cu 40 parbrizul nu se mai abureste asa rapid ca inainte.
berlina **1310
1984
bashtalu |
![]() Membru autentic Group: Members Posts: 2.051 Joined: 9 September 06 From: Bucuresti ![]() |
poze daca se poate, va rog frumos
Audi
A4
salut
eu nu am izolat nimic din ceeace tine de intarea aerului in masina ci e de izolat partea unde vine caloriferul sunt 2 locuri separate locasul caloriferului si cel de unde trage aer daca locasul de la calorifer nu e bine izolat nu baga aer cald in masina si ii da afara pe la grila de la capota |
Dacia si Audi
- IF 28 JSM
inginer_ar |
Membru incepator Group: Members Posts: 4 Joined: 7 December 10 ![]() |
Domnilor, cea mai bună metodă de încălzire este cea originală. Pe scurt, avem două compartimente: cel primar (de sub grilă) și cel secundar (unde este radiatorul de încălzire), compartiment situat sub cel primar. Compartimentul secundar trebuie izolat perfect pentru a forța trecerea aerului numai prin radiatorul de încălzire. Radiatorul de încălzire trebuie izolat cu burete (gen Purfix) pe tot perimetrul pentru a nu permite trecerea aerului pe lângă el. Vor trebui eliminați voleții din material textil ("mușama") ce fac legătura dintre cele două compartimente și orice altă deschidere spre exterior din acel compartiment. În partea superioară a compartimentului secundar se poate folosi o folie de plastic ce va fi lipită pe tot perimetrul acestuia cu mastic. Pentru o distribuție optimă a aerului în habitaclu nu trebuie uitat paravanul ce dirijează aerul suflat de ventilatorul de încălzire ("aerotermă"). La viteze relativ mici va fi folosit ventilatorul pentru încălzire și dezaburire (ca la orice autoturism modern), la viteze mari aerul va trece din compartimentul primar în cel secundar prin rotorul ventilatorului chiar dacă acesta este oprit. Evident, motorul trebuie să atingă temperatura optimă de funcționare (termostat funcțional, recomandat este montajul unui electroventilator ), iar robinetul și voleții de dirijare (parbriz-pedalier) să fie funcționali. Cu scuzele de rigoare pentru mesajul meu cam lung, vă urez o iarnă ușoară.
none
none
none
asta am incercat sa spun si eu dar suba alta forma
eu nu stiam cum se numesc compartimentele alea 2 cel de sub grila si cel unde e montat caloriferu pt treaba asta am optat si eu si mam chinuit sa fac caldura in masina mai am si eu sa rezolv treaba de la comanda sa pot comanda din bord sa nu mai trag de cabluri si nu vreau sa modific nimic de sub bord ced ca o sa cumpat o comanda de climatizare noua sau una de la sh da sa fie buna ca amea e sparta si nu stau cablurile pe ia astazi am facut cu masina 100 km si nu sau aburit geamurile si am si caldura in masina bfta la toata lumea si iarna usoar si fara zapezi pe sosele |
Dacia si Audi
- IF 28 JSM
musamalele alea sint ca niste supape pasa aerul sa treaca de afara in calorifer , cind motorul merge creeaza o presiune pe musamale si se inchid aerul trecind prin ventilator , eu zic ca este cu dus si intors , elemini musamalele (astupi gaurile alea) faci caldura numai cu ventilatorul , trebuiesc etansate si marginile de la cele 2 compartimente cu burete
This post has been edited by bygy007: 7 Dec 2010, 22:31 |
CAPTUR E-Tech full hybrid 145
2024
recinalcol |
![]() Membru : Amputat Group: Members Posts: 686 Joined: 19 November 09 ![]() |
Nu are oare nimeni nici o poza sa inteleaga toata lumea.
![]() Eu stiu despre ce e vorba,dar poate sant altii care nu prea inteleg despre ce vorbiti. Se stie ca bordul scoica are probleme de caldura (daca nu este totul pus la punct) Si din cauza asta multi se chinuie cu alte metode . |
1310 Li
- VS-22-REC
panzerjager |
![]() Membru Group: Members Posts: 108 Joined: 6 November 09 ![]() |
am si eu o intrebare, ca m-am ocupat de incalzire.
daca se obtureaza total gaurile de legatura dintre comparimentul superior si cel inferior(gaurile inchise teoretic de voleti) aerul intra pe la ventilator....bun; dar cantitatea de aer ce intra pe la ventilator nu este mai mica? mai "sufla" cu aceeasi putere in interiorul masinii? |
1979
krapcarasu |
ba cam da, trebuie puse si captatoare sau cum se cheama alea care baga fortat aer in grila
Megane 1.4 16 v
- sv
inginer_ar |
La circulatia cu viteze relativ reduse (de ex. in oras) va fi folosit ventilatorul, iar la viteze mai mari debitul de aer este suficient, datorita circulatiei naturale a aerului in habitaclu (presiune mare in fata si presiune mai scazuta in zona de evacuare a aerului din stalpul C). Desigur, debitul de aer este mai mic, dar diferenta nu este asa de mare cum se crede, voletii dintre cele doua compartimente opun si ei o rezistenta apreciabila la trecerea aerului. Folosirea ventilatiei fortate este recomandabila, este necesara la majoritatea autoturismelor moderne, nu este "un rau necesar".
none
none
none
payty |
si la mine e tot cu musamale, doar ca am vazut ca nu prea sunt etanse si le-am lipit de ele niste fasii de tabla, la partea de jos, iar pe cealalta parte am pus niste magneti din aceia din neodimium care sunt suficient de puternici ca sa apropie de tot musamaua de gura aia pe care trebuie sa o astupe cand masina sta pe loc, dar se deschid atunci cand masina merge.
la mine dezaburirea merge aproape la fel de bine ca cea de la bordul de CN, dar trebuie foarte bine izolat capacul care vine peste cele doua compartimente. In special in laterale sunt probleme. Pentru a vedea asta porniti aeroterma si apoi puneti mana pe langa capacul de tabla. daca iese pe undeva aer inseamna ca nu e bine. incerc acuma sa pun un motor de turatie mai mare in locul celui care e acum la aeroterma care oricum caraie si cred ca asta ar imbunatati si mai mult dezaburirea. |
1996 1.6/2002 1.4
salut la toata lumea
azi am sa repar si directionarea aerului sa pot da din comanda catre parbriz si catre picioare aseara am facut cu masina 150 de km si nu sau aburit ceamurile si am observat ca nu baga aer pe jos spre picioare si vreau sa vad ce ii pot face sa dea si pe la picioare o sa revin cu detalii despre cum se poate rezolva si cu ceva poze si un filmulet |
Dacia si Audi
- IF 28 JSM
bashtalu |
ceva noutati? poze?
Audi
A4
drooopy |
Membru incepator Group: Members Posts: 36 Joined: 27 June 05 From: iasi ![]() |
Stie cineva la ce folosesc cele 2 gauri din compartimentul caloriferului ce dau in compartimentul motor? Cineva mi-a spus ca sunt pentru scurgerea apei dar ciudat ca una este pozitionata peste servofrana.
moto_0171.jpg ( Size: 341.22k ) Number of downloads: 2258 moto_0172.jpg ( Size: 130.48k ) Number of downloads: 2505 moto_0173.jpg ( Size: 157.59k ) Number of downloads: 2459 |
1996 L
- IS-XX-CMV
nikuniku |
drooopy pentru asa ceva sunt gaurile alea doua,de scurgerea apei,daca le astupi apa va intra in masina,asa ca ai grija sa fie tot timpu destupate
opel zafira
f75
1.6-16valve
bv-08-fgm |
Sunt pentru scurgerea apei,partea buna este ca cineva a scos acele "moturi" din cauciuc care de obicei au boala de a se infunda si sa nu mai permita scurgerea apei.
This post has been edited by bv-08-fgm: 3 Mar 2011, 23:11 |
1996
mihai7575 |
![]() Membru autentic Group: Members Posts: 744 Joined: 1 December 10 From: SLATINA ![]() |
De acord cu colegii mei de mai sus ,nu le astupa ,lasa-le exact asa cum se vad in poze,si totul va fi bine.
Dacia 1300,
dacia solenza,
1981,2004 |
drooopy |
Mdaaaa.... chestia e ca eu deja le acoperisem cu niste banda izolir dupa care am dat niste gauri cu o surubelnita pana sa intreb pe forum
![]() This post has been edited by drooopy: 4 Mar 2011, 18:35 |
1996 L
- IS-XX-CMV
BILIXON |
Membru incepator Group: Members Posts: 70 Joined: 22 March 09 ![]() |
Bună seara la toată lumea!
Știe cineva, sau a reparat cumva voleții de dirijare al aerului (la parbriz și picioare) din interiorul mașinii? Nu din comanda ci aceia de sub bord? Cam cum sta treaba cu ei, am băgat mâna sub bord atât cât am putut și am ajuns la ei.Par niște aripioare de plastic care dirijează aerul dar din nefericire la mine unul s-a blocat de curând. Se pot ajunge și repara dacă scot caloriferul și astfel bănuiesc că e mai comod, sau e musai pe sub bord, cabluri și fire? Am bord ,,scoică" am uitat să menționez... Mulțumesc tuturor!! |
Sandero Prestige
- TL 02 LPO
alumicu |
![]() Membru Group: Members Posts: 133 Joined: 4 March 11 ![]() |
@drooopy: izoleaza bide de jur-imprejur caloriferul cu ceva carpe; sfatul meu ar fi sa cauti in comert si sa montezi cele doua trompe unisens la scurgerea de la calorifer
@BILIXON: vezi ca la acele aripioare trebuie sa izolezi cu niste burete de usi This post has been edited by alumicu: 5 Mar 2011, 22:18 |
(OO-
x
-OO)
- DJ
BILIXON |
Bine, am simțit la mână și niște burete dar cum ajung acolo?
Sandero Prestige
- TL 02 LPO
ATM |
![]() 1948 Tucker Torpedo Group: Members Posts: 596 Joined: 28 December 05 From: Bucuresti ![]() |
Nu pe la calorifer, asta-i sigur. Cred ca daca dai tot cartonul de pe la pedale jos, cu polita de sub bord cu tot, s-ar putea sa ajungi, dar e munca cat nu face. Iar polita, mai ales daca are infiltratii sau condens o sa ti se dezmembreze la demontaj. Mai degraba chinuie-te sa misti voletul cu mana pe pozitia deschis si lasa-l asa.
MITSUBISHI
COLT
Z30-2005 Inchiriez fiare de calcat, geamuri termopan, betisoare de urechi, aparate de ras. Rog seriozitate.
BILIXON |
Aia e treaba, ca este destul de vechi si umflat de la apa, condens, si blocat pe închis, adica tot aerul e dirijat spre parbriz, bine acum poate fi și un avantaj că parbrizul este important în siguranța conducerii dar mă gândeam poate pe la la calorifer dacă îl scot...de aceea dac a mai făcut cineva și mă sfătuiește e bine dacă nu așa stă până la REMAT.
Sandero Prestige
- TL 02 LPO
BILIXON |
Vă salut !
Azi înarmat cu multă ambiție am reparat cum vă ceream sfatul mai sus, voleții de dirijare al aerului în habitaclul mașinii. Deci am demontat caloriferul, comanda de climatizare și polița de sub bord. După câteva ore am reușit tot ce mi-am propus. Să știți că se ajunge cel mai bine pe sub bord, dar este bine și pe sus pe la calorifer atunci cănd lipești pentru etanșare cu purfix orificiile. Colegul ATM avea dreptate: muncă cât nu face și julituri pe măine până la vară. Rămâi cu satisfacția că ți-a reușit, căldură din plin și directionată unde dorești. Efectiv acum am dezaburire și căldură de se usucă preșurile. ![]() Tuturor numai bine! |
Sandero Prestige
- TL 02 LPO
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 23rd July 2025 - 01:24 |
