DACIA 1990, o masina buna
razvan32 |
#271
![]() superdaciuta Group: Members Posts: 842 Joined: 12 January 08 From: Ploiesti ![]() |
Attached thumbnail(s) 1__2_.jpg ( Size: 579.96k ) Number of downloads: 1092 2__2_.jpg ( Size: 749.62k ) Number of downloads: 1082 |
1990 TX BERLINA
- 6-PH-7008
razvan32 |
#272
in poza am desenat pe unde imi vine apa in podul pedalier. nu am reusit sa-mi dau seama pe unde vine apa.
Attached thumbnail(s) DSCF7595.JPG ( Size: 1.52mb ) Number of downloads: 1014 |
1990 TX BERLINA
- 6-PH-7008
Raul90 |
#273
![]() Membru Group: Members Posts: 175 Joined: 27 November 11 ![]() |
mie imi intra apa pe la chederul de la parbriz. Pune 2 furtune in canalele de scurgere de sub cheder si poate scapi de problema.
Surubul ala de pe punte strange-l in asa fel incat sa nu curga pe acolo lichid ![]() |
Clio 2
razvan32 |
#274
1990 TX BERLINA
- 6-PH-7008
R12G |
#275
![]() Membru incepator Group: Members Posts: 48 Joined: 18 April 12 From: Slatina ![]() |
Da jos parbrizul fata si vezi sa nu ai mancata de rugina rama parbrizului
Dacia 1300
berlina
72
- 6B-7476
razvan32 |
#276
La ce perioada se schimba uleiul la motor?
Am pus anul trecut Aral 20w50. |
1990 TX BERLINA
- 6-PH-7008
maho |
#277
![]() Membru rigido-flexibil Group: Members Posts: 5.232 Joined: 7 April 10 From: Brașov, orașul olimpic ![]() |
1-2 ani, 7-8000 km...
bucatzel |
#278
![]() Membru plictisit Group: Moderatori Posts: 6.488 Joined: 19 May 08 From: Timisoara ![]() |
1981
maho |
#279
Corect, mi-a scapat ca-i mineral.
razvan32 |
#280
de ce in timp ce am faza scurta aprinsa, sigurantele pe faza scurta se incalzesc bine? normal trebuie sa nu se incalzeasca.
1990 TX BERLINA
- 6-PH-7008
adipopescu |
#281
![]() Membru incepator Group: Members Posts: 66 Joined: 9 October 10 ![]() |
Megane 3 Grandtour
2010 -
razvan32 |
#282
Unde se pune magnetul?
1990 TX BERLINA
- 6-PH-7008
oldtimercraiova |
#283
![]() Membru Group: Members Posts: 394 Joined: 8 March 15 ![]() |
Foarte frumoasa , sa te bucuri de ea in continuare!
razvan32 |
#284
1990 TX BERLINA
- 6-PH-7008
DACIOTUL_97 |
#285
![]() Ne plac femeile,dar iubim masinile ! Group: Members Posts: 1.649 Joined: 8 July 13 From: Bd-ul Dacia ![]() |
QUOTE(razvan32 @ 9 Aug 2015, 09:46) Aceeasi problema am avut-o si eu...iti recomand sa schimbi tabloul de sigurante cu unul pe leduri.E posibil sa mai fie si unele probleme la instalatia electrica (aici nu cunosc prea multe asa ca nu intru in detalii).Bafta ! |
1310/Logan/
MLS 1986/MLS 1985/1.6 16v Prestige 2008 "Voi lupta pana la ultima mea picatura de sange,ca sa ai dreptul,sa nu fi de acord cu mine"
#Pasionat de fiare vechi# Ex.Dacia 1310-CN3 & 1310-ph1 |
razvan32 |
#286
si unde se gaseste?
1990 TX BERLINA
- 6-PH-7008
razvan32 |
#287
releul care-l am acum luat de la cineva imi face o figura ciudata. m-i se incalzeste sarma infasurata ( prima dinspre parbriz din cele 3 bucati) care se afla dedesubt. frige foarte tare dar incarca foarte bine.
cat trebuie sa fie incarcarea? 1 Sep 2015, 21:24: trebuie sa-l schimb? This post has been edited by razvan32: 1 Sep 2015, 21:24 |
1990 TX BERLINA
- 6-PH-7008
razvan32 |
#288
deci?
1990 TX BERLINA
- 6-PH-7008
YellowStar |
#289
![]() Membru incepator Group: Members Posts: 5 Joined: 3 September 15 ![]() |
Foarte frumoasa !
razvan32 |
#290
QUOTE(YellowStar @ 4 Sep 2015, 02:10) merci 25 Sep 2015, 21:57: am schimbat releul de tensiune mecanic cu unul electronic cu fir de referinta. imi incarca 14.1 V. este superbine. 25 Sep 2015, 21:58: de asemenea am schimbat si cutia de sogurante ( era cu lamele din aluminiu) cu una din cupru. This post has been edited by razvan32: 25 Sep 2015, 21:58 |
1990 TX BERLINA
- 6-PH-7008
razvan32 |
#291
ieri mi-am schimbat temporizatorul de stergatoare pentru ca cel vechi imi clantanea continuu si nu mai mergea.
1990 TX BERLINA
- 6-PH-7008
razvan32 |
#292
cum se poate regla distanta dintre capota si grila? in atasament aveti desenul ca sa va dati seama.
Attached File(s) ![]() |
1990 TX BERLINA
- 6-PH-7008
razvan32 |
#293
am fost la masina si imi intra apa in masina : stanga fata, dreapta fata si stanga spate.
mereu gasesc apa si trebuie sa tin presul ridicat sus. este enervant. am marcat in poze traseul de apa pe unde vine. de unde poate sa vina? 1 Dec 2015, 10:26: nu stiu ce sa mai fac. This post has been edited by razvan32: 1 Dec 2015, 10:26 Attached thumbnail(s) IMG_20151129_124839.jpg ( Size: 1.84mb ) Number of downloads: 293 IMG_20151129_124807.jpg ( Size: 995.59k ) Number of downloads: 142 IMG_20151129_124300.jpg ( Size: 1.39mb ) Number of downloads: 118 |
1990 TX BERLINA
- 6-PH-7008
maho |
#294
Daca nu ziceai de stanga spate (pasager, nu portbagaj - dupa poza), te-as fi intrebat daca SI in stationare, sau doar in mers. Macar poti elimina varianta cu apa aruncata de roti.
In spate poate proveni (in zona aia) de la aerisire, sau (mai putin probabil, dar poti verifica) din usa, provenind de la geam. In fata: pe la cheder, pe la axul stergatoarelor, pe langa aeroterma (in dr.) - aici ar trebui sa dai grila exterioara jos, si sa verifici de fisuri bordurile alea lunguiete, de deasupra canalului de scurgere; verifica si cele doua gauri de scurgere, cu tuburile aferente, daca nu-s infundate. |
Daciaa97 |
#295
![]() Membru incepator Group: Members Posts: 53 Joined: 11 September 15 ![]() |
Poate sa fie de la cheder.. eu i-am pus silicon transparent si de atunci nu am mai avut treaba cu apa in masina..
1998
- dacia
sobolan |
#296
in fata iti intra pe la ventola in dreapta(da-o jos,arunca masticul,pune silicon si remonteaz-o),pe la cablurile instalatiei in stanga(pune un cordon de silicon de motor in jurul manunchiului inconjurat de burelele ala infect de dacia)....scenarii pot fi multe,se poate scurge pe langa grila sau aripa la colt si curge pe gascan apoi pe langa serva si intra prin gaurile tehnologice de la tabla peretelui despartitor(peretele de foc) etc......pe la cheder cand intra se prelinge de sub bord.....tot in fata intra pe la calorifer(ai acolo in spatele lui niste gratare din tabla) ,daca masina e cu botul in sus intra(e dacie) daca scurgerile alea doua de sub tavita is infundate...furtunele alea de kko in strivite din fabrica,pune furtun de gradina de juma de tol siliconic pe stuturile alea doua din plastic,nu scoate de tot furtunele,o sa fie posibil sa ai probleme mai mari....pe spate iti intra pe la portbagaj,incearca sa-l reasezi pe balama sau pune alt cheder....nu umbla nicaieri cu silicon sanitar,mai mult de un an nu tine, fii optimist,se rezolva
![]() Aral 20w50.....tine 5000km fara probleme sau un an ![]() usa...ce e cu ea de se potriveste asa "bine" ? ![]() This post has been edited by sobolan: 2 Dec 2015, 01:32 |
Logan-1.5dci-2017--
Golf mk5 - syncro - 2007--
maho |
#297
QUOTE(Daciaa97 @ 1 Dec 2015, 23:48) Poate sa fie de la cheder.. eu i-am pus silicon transparent si de atunci nu am mai avut treaba cu apa in masina.. Siliconul transparent e din ala "sanitar" (pt. baie), deci pe baza de acid acetic; nu-i recomandat, ataca tabla... QUOTE(sobolan @ 2 Dec 2015, 01:03) ...pe spate iti intra pe la portbagaj,incearca sa-l reasezi pe balama sau pune alt cheder.... Tu te-ai uitat la poza, sa vezi de care "spate" e vorba ? Din portbagaj nu va intra niciodata apa la pasageri... |
sobolan |
#298
QUOTE(maho @ 2 Dec 2015, 12:56) Tu te-ai uitat la poza, sa vezi de care "spate" e vorba ? Din portbagaj nu va intra niciodata apa la pasageri... ce monotona ar fi viata pe aici daca eu as spune ceva si nimeni n-ar "contra" ce spun eu...ma bucur ca-mi analizezi postarile......pui pariu ca intra cand masina e mai "rea" asa ??? ![]() This post has been edited by sobolan: 2 Dec 2015, 12:09 |
Logan-1.5dci-2017--
maho |
#299
Ce monotona ar fi viata, daca n-ai vorbi permanent vrute si nevrute...
Chiar sunt curios cum poti "explica" intrarea ipotetica a apei, din portbagaj in habitaclu. Mai ales ca in portbagaj e si o gaura tehnologica de scurgere, sub roata de rezerva. |
sobolan |
#300
QUOTE(maho @ 2 Dec 2015, 13:19) man,eu ajut...si altii de aici m-au ajutat enorm.....eu am impresia ca te-ai nervozat de la treaba cu volanul(stii tu,atunci cand aberai la infinit) si faci "split" de la chestia asta peste tot unde "ma prinzi" .....poate ne-om gasi personal vreodata sa mai discutam una alta.....despre dacii evident ![]() ![]() |
Logan-1.5dci-2017--
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 17th June 2025 - 02:59 |
