[VAND] Piese Noi LOGAN si RENO, suntem un magazin nou, avem preturi mici
RadulescuRomulus |
#91
![]() Sunt cu ochii pe voi! Group: Members Posts: 1.780 Joined: 7 December 10 From: naufragiat ![]() |
VW Passat berlina
2.0 Tdi CR + DSG
04.2009 - diesel, 140cp
- B 69 COI EX: megane 2.1, 1.5dci, 101 magari - B 314 ZDA
danyos |
#92
![]() Membru autentic Group: Members Posts: 275 Joined: 30 June 09 From: focsani /vrancea ![]() |
buna ziua , am un scenic 2 aveti pentru manerul portierei din fata stanga , acel capacel ..... a disparut intro noapte
![]() Attached thumbnail(s) fata.JPG ( Size: 17.18k ) Number of downloads: 409 |
scenic 2
renault
2005 dynamique 1.5 dci
- VN 10 XTX danios
RadulescuRomulus |
#93
Imi pare rau. Din 2 motive:
1. ca ti-a disparut, in toiul noptii 2. ca nu pot sa te ajut ![]() |
VW Passat berlina
2.0 Tdi CR + DSG
RadulescuRomulus |
#94
CASTROL MAGNATEC DIESEL 5W40 4L- 120 RON
CASTROL MAGNATEC DIESEL 10W40 4L - 100 RON CASTROL EDGE 5W30 1L 45 RON CASTROL EDGE 5W30 5L 200 RON CASTROL EDGE 5W40 TURBO DIESEL 1L 35 RON CASTROL EDGE 5W40 TURBO DIESEL 5L 140 RON CASTROL EDGE TURBO DIESEL 5W40 4L 125 RON CASTROL MAGNATEC DIESEL 5W40 B4 1L 30 RON CASTROL MAGNATEC DIESEL 5W40 B4 5L 130 RON CASTROL MAGNATEC DIESEL B4 - 10W40 - 1L 30 RON CASTROL MAGNATEC DIESEL B4 - 10W40 - 5L 105 RON Ulei VAT, facut in Polonia: Vat SynGold 5W-40 1L 25 RON Vat SynGold 5W-40 4L 92 RON LOGAN ------------------piese marca Starline, garantie 3 ani! Descriere ------------------------------------- Pret vanzare Elemente de directie---------------------------- 31.04 Cap Bara Dreapta-------------------------------- 41.96 Cap Bara Stanga---------------------------------- 41.98 Bieleta directie----------------------------------- 44.05 Bieleta directie----------------------------------- 44.65 Amortizoare spate------------------------------- 154.01 Amortizoare fata--------------------------------- 138.23 Pivot------------------------------------------------ 33.83 Kit-uri rulmenti roata fata fara ABS----------- 38.08 Kit-uri rulmenti roata spate--------------------- 32.25 Bascula dreapta---------------------------------- 106.18 Bascula stanga------------------------------------ 106.18 Bucsa bascula------------------------------------- 14.11 Bieleta antiruliu---------------------------------- 13.46 Discurii frana 260 ventilat--------------------- 147.63 / set 2 buc Discurii frana 238 plin-------------------------- 95.19 / set 2 buc Saboti frana fara ABS--------------------------- 66.64 Saboti frana cu ABS----------------------------- 108.46 Filtru ulei------------------------------------------- 15.74 Filtre aer DCI-------------------------------------- 16.39 Filtre habitaclu----------------------------------- 19.24 SAU orice alta marca doriti. Toate reperele de mai sus sunt marca Starline. Avem la vanzare si alte marci, mai cunoscute pe piata, pt care oferim pret la solicitare expresa. Mai mult, garantia este de 3 ani la reperele Starline! REPERE UNIVERSALE: antigel G12 13,19 RON antigel G12 38,93 RON lichid spalat parbriz -20 grade 5,40 RON lichid spalat parbriz -20 grade 15,35 RON acumulator 44 amperi 196,83 RON acumulator 54 amperi 232,82 RON acumulator 66 amperi 275,16 RON acumulator 74 amperi 305,03 RON acumulator 97 amperi 393,86 RON Bec Megalight Ultra H7 - 55w 38,03 RON Bec incandescent H7 GE 13,57 RON |
VW Passat berlina
2.0 Tdi CR + DSG
cosmin_angh3l |
#95
![]() Membru autentic Group: Members Posts: 443 Joined: 20 July 10 From: Bucuresti ![]() |
sal. ma intereseaza si pe mine urmatoarele piese pentru un Clio Symbol,an 2007,1.4 8V 75CP: Kit complet ambreiaj,rulment roata fata(masina are ABS). Multumesc.O zi buna
Megane 2.2,2007/1.6 16V Megane 3 1.5dci 110
Dacia Logan,2017/1.5
RadulescuRomulus |
#96
Placa + disc + rulment LUK STOC 180 mm = 290 RON
Placa + disc + rulment LUK STOC 200 mm = 340 RON Placa + disc + rulment STARLINE STOC 180 mm = 235 RON Kit-uri rulmenti roata FAG [nemtesti] = 77 RON In general, Renault echipeaza masinile fie cu Valeo, fie cu LUK / SWAG. This post has been edited by RadulescuRomulus: 31 Oct 2011, 17:07 |
VW Passat berlina
2.0 Tdi CR + DSG
ciumiki |
#97
Membru Group: Members Posts: 198 Joined: 17 March 11 ![]() |
Am ridicat piesele de la Posta si le-am montat. Ms. fain !
P.S. Recomand pe dl Radulescu. |
Megane
2007, 1.5 dci megane 2.2, 1.5 dci, 63 kw, an 2007
RadulescuRomulus |
#98
Multumesc domnu' Ciumiki.
VW Passat berlina
2.0 Tdi CR + DSG
Victorine |
#99
Suport motor la cutie sau bieleta anti ruliu Logan 1,6 MPi motor K7M la ce bani se gaseste si ce producator? Multumesc!
Toyota
Auris Touring Sports HSD
2014
RadulescuRomulus |
#100
Salve,
Din cate stiu, suportul motor e una [i se mai spune tampon/bieleta antirasturnare in limbajul de service], bieleta antiruliu e alta. Din pacate, nu pot accesa [acum] catalogul producatorilor pt o oferta detaliata. Revin maine, aici pe topic, cu un raspuns concret. Acum, la indemana, am doar pret la bieleta antiruliu a celor de la Starline = 13.50 ron. |
VW Passat berlina
2.0 Tdi CR + DSG
lag_ph |
#101
![]() miles away... Group: Members Posts: 2.253 Joined: 12 September 07 From: Bucuresti // Ploiesti ![]() |
Salut.
Pentru masina din semnatura, VF1B5640518914247, cu ABS si pachet de drumuri neprietenoase, o oferta pentru urmatoarele: - rulment roata (drepta) fata - bieleta antiruliu (drepta) - burduf planetara (dreapta, spre CV) - bucsi punte spate Producatori/preturi? De preferat PM sau mail - maister_dm@yahoo.CO.UK Merci. |
Laguna 1.8 16v
- 05.10.1998
- de PH _________________________________________________
Nothing's impossible |
Victorine |
#102
Corect, ai dreptate, ma intereseaza suportul motor de la cutie, cred ca i se mai zice bieleta anti-rostogolire sau anti-cuplu, nu antiruliu (alea-s la bara de torsiune). Astept o cotatie, multumesc!
Toyota
2014
danyos |
#103
RadulescuRomulus merci totusi pentru raspuns . spor .............
scenic 2
renault
- VN 10 XTX danios
sorin_pan |
#104
![]() Membru autentic Group: Members Posts: 412 Joined: 12 July 09 From: Bucuresti ![]() |
oplanetara dreapta de solenza la ce pret ?
Confort 2004
- B -xx-xxx
RadulescuRomulus |
#105
Buna seara Domnilor,
@maister_dm: rulment roata (drepta) fata - 271,50 RON pe FAG [nemtesc] bieleta antiruliu (drepta) - 74,27 RON pe RTS bieleta antiruliu (drepta) -104,87 RON pe SWAG - burduf planetara (dreapta, spre CV) - indisponibil - bucsi punte spate – indisponibil Ultimele 2 repere le-am cautat de mi s-au inrosit ochii. Daca maine aflu ceva accesibil, iti scriu. Sa-mi spui intai daca esti cat de cat interesat. Eu, de principiu, caut repere f bune sub raport calitate/marca/pret @Victorine: imi pare rau, insa ce am eu de oferit, acum, e mult mai scump decat in magazine ![]() @sorin_pan: general ricambi: 360 ron [sunt italienesti]. M-am dat peste cap sa aflu ceva swag, febi sau chiar romanesti. insa pauza. Multumesc, Romulus @danyos: multumesc! spor si tie si nu fi trist. ![]() This post has been edited by RadulescuRomulus: 1 Nov 2011, 21:55 |
VW Passat berlina
2.0 Tdi CR + DSG
lag_ph |
#106
* SNR/SKF? bieleta antiruliu (drepta) - 74,27 RON pe RTS * nu... bieleta antiruliu (drepta) -104,87 RON pe SWAG * nu, avand in vedere ca dupa 25k km a crapat.. Meyle/Lemforder? - burduf planetara (dreapta, spre CV) - indisponibil * nu e, nu e ![]() - bucsi punte spate – indisponibil * idem.. Acum strang oferte, nu de dragul de a pierde timp la tastatura, ci ca trebuie rezolvate problemele.. ![]() |
Laguna 1.8 16v
- 05.10.1998
RadulescuRomulus |
#107
Acestea sunt singurele alternative:
- rulment roata (drepta) fata - 271,50 RON pe FAG [nemtesc] * SNR/SKF? - niente / nada / nimic. ATENTIE: vezi ca FAG este ambalator pt SKF. deci, sa nu fii surprins cand cumperi fag sa descoperi skf [sau la producator numele sters]. - bieleta antiruliu (drepta) 104,87 RON pe SWAG 24 Ron pe STARLINE 74 Ron pe RTS 171 Ron pe LEMFORDER - burduf planetara (dreapta, spre CV) - Disponibil acum ![]() 101 Ron pe SPIDAN 106 Ron pe AUTOFREN SEINSA - bucsi punte spate – Disponibil acum ![]() 165 Ron/2 buc, doar pe SWAG Favoare: daca nu vei lua de la mine, am rugamintea sa imi scrii motivul refuzului. In speta, ma intereseaza daca e pretul sau marcile care le-am cotat. E ca o favoare doar... ![]() This post has been edited by RadulescuRomulus: 2 Nov 2011, 13:23 |
VW Passat berlina
2.0 Tdi CR + DSG
ursu_gl |
#108
Membru incepator Group: Members Posts: 26 Joined: 6 August 08 ![]() |
salut
incalzire scaune? sau butoanele ? multumesc |
Laguna II
2003 / 4+1 usi
- GL 83 FRA
RadulescuRomulus |
#109
domnu' urs,
nu te pot ajuta. P.S. poti apela cu incredere la userul DanCVA: e priceput, dibace si are pret decent! This post has been edited by RadulescuRomulus: 2 Nov 2011, 15:52 |
VW Passat berlina
2.0 Tdi CR + DSG
ciumiki |
#110
Pentru Logan 1.6 mpi din 2006 as dori un pret pt bucse punte spate.
Ms anticipat ! |
Megane
lag_ph |
#111
@RadulescuRomulus : ok, notat.
Laguna 1.8 16v
- 05.10.1998
RadulescuRomulus |
#112
@ciumiki: am nevoie de VIN-ul masinii.
VW Passat berlina
2.0 Tdi CR + DSG
ciumiki |
#113
VIN Dacia Logan: UU1LSDAFH38461676 - BUCSE PUNTE SPATE si SABOTI FRANA SPATE CU ABS.
Ms anticipat ! P.S. Am impresia ca e din 2007, nu e masina mea. This post has been edited by ciumiki: 3 Nov 2011, 16:58 |
Megane
hathazy |
#114
![]() Ex. Daciot---iubesc Dacia si prima finta purtatoare de vagin din Group: Members Posts: 209 Joined: 20 March 09 ![]() |
o bieleta antibascula pt megane 1 1.9d 47 kw cod motor f8q624?
Renault Megane 1
miros a motorina mereu
1997, inmatricula t99
- SJ 89 TOM
beberazvan_n |
#115
![]() Membru autentic Group: Members Posts: 587 Joined: 30 June 09 From: Bucuresti ; Branesti Ilfov ![]() |
Salut, in legatura cu amortizoarele spate pentru Dacia Solenza benzina, 1.4 , nr identificare : UU1R5A71543411397, 55 KW , an 2004.
Si oglinda retrovizoare dreapta ( doar oglinda fara senzor temperatura ) . Mersi mult. This post has been edited by beberazvan_n: 3 Nov 2011, 21:20 |
Megane 2, 1.5 dci...
- IF-03-VZL
RadulescuRomulus |
#116
@ciumiki: cautarile continua! iti dau PM si iti scriu si aici cand am un raspuns.
@hathazy: TAMPON MOTOR SWAG 150 ron [aveti poza atasata]. @beberazvan_n: Pentru Solenza: amortizor VECTOR, pe ulei = 102 Ron/buc amortizor AL-KO, pe ulei = 137 Ron/buc Oglinda, nu pot aduce decat pe origine, insa iti pot da contacte/forumisti care vand din dezmembrari. E... mai avantajos, parerea mea. Noua, doar sticla, sare lejer peste 70Ron... 4 Nov 2011, 17:48: QUOTE(ciumiki @ 3 Nov 2011, 16:55) VIN Dacia Logan: UU1LSDAFH38461676 - BUCSE PUNTE SPATE si SABOTI FRANA SPATE CU ABS. Ms anticipat ! P.S. Am impresia ca e din 2007, nu e masina mea. BUCSE PUNTE SPATE - 44.50 - MOOG SABOTI FRANA SPATE CU ABS. - 80 FEBI This post has been edited by RadulescuRomulus: 4 Nov 2011, 17:48 Attached thumbnail(s) tampon_swag.jpg ( Size: 8.22k ) Number of downloads: 263 |
VW Passat berlina
2.0 Tdi CR + DSG
ciumiki |
#117
pot cumpara piesele pe societate?
daca se poate pe marti o sa fac si comanda. Si as mai fi interesat de bucsa bara stabilizatoare megane 2 de origine renault.Alea SVAG deja scartaie tare. This post has been edited by ciumiki: 6 Nov 2011, 15:21 |
Megane
RadulescuRomulus |
#118
@ciumiki: ai PM
VW Passat berlina
2.0 Tdi CR + DSG
ursu_gl |
#119
carenaje pentru prinderea butoanelor de incalzire pe scaune ai ? sau cu tot cu butoane?
Laguna II
2003 / 4+1 usi
- GL 83 FRA
RadulescuRomulus |
#120
domnu' urs,
din pacate, nu vand accesorii, ci doar piese... prin urmare, nu am nimic care sa tina de incalzire / ambient in masina. Dar, nu ai vorbit cu userul DanCVA? stiu ca are preturi bune. 7 Nov 2011, 16:23: @ciumiki: pe origine, bucsa bara stabilizatoare = 171 ron/buc Cred ca iesi cam cu 9-10 lei mai ieftin decat la magazin/reprezentanta. Daca nu e graba, ne [mai] auzim pe PM... This post has been edited by RadulescuRomulus: 7 Nov 2011, 16:23 |
VW Passat berlina
2.0 Tdi CR + DSG
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 22nd July 2025 - 20:40 |
