6 Pages < 1 2 3 4 > »
> ECU mysteries - split, (o disputa aprinsa dintr-un topic facut varza))
marksman
post 27 Feb 2012, 13:03
Post mortem nihil est
QUOTE(IRONICK @ 27 Feb 2012, 13:00)
La Reno nu se calculeaza distanta dupa timpii de injectie ca la VW.
Si Reno asta, e varf de tehnologie?
Poftim, ca sa nu crapi de ras:
QUOTE(mail de la Ross Tech)
> So you read a value that's already in the ECU and you are confident
> that the ECU does an integration of speed over time?
Yes, that is also what the spec sheet for these control modules say.
If your friends work in an area like that I do believe the should have
access to such documents or need to talk to their supplier (i.e. Bosch)
It's not really a big discussion anymore from our perspective, the
knowledge around this has been around for the better part of 10 years so
I do believe that it is well understood by now and the error rate (in
terms of tools reading proper values) is quite small.
Sebastian Stange
Technical Support & Applications
Ross-Tech, LLC
881 Sumneytown Pike
Lansdale PA 19446, USA
Tel (US): +1.267.638.2300
Fax (US): +1.215.893.3816
Nick Ușor
post 27 Feb 2012, 14:17
Zice si de integrala din timpii de injectie si sursele multiple?
Extra:
viteza afisata = viteza reala (CAN) + 1,5% + 4Km/h
viteza afisata = viteza reala (CAN) + 1,5% + 5Km/h
viteza afisata = viteza reala (CAN) + 1,5% + 6Km/h
viteza afisata = viteza reala (CAN) + 6,5%
Care sunt palierele de viteza pentru care sunt aplicate respectivele formule si cine transmite pe can viteza?
This post has been edited by IRONICK: 27 Feb 2012, 14:23
marksman
post 27 Feb 2012, 14:28
QUOTE(IRONICK @ 27 Feb 2012, 14:17)
Alea-s glumele voastre de autobaza. Ia sa citam din ce au dat altii quote:
QUOTE(post sters de-al meu @ citat de alt "specialist")
Kilometrii din ECU sunt estimati pe baza timpilor de deschidere ai injectoarelor si alte variabile
Unde scrie "integrala din timpii de injectie"? Aia ai inventat-o tu. In rest, "surse multiple"?
QUOTE(IRONICK @ 27 Feb 2012, 12:00)
Iti amintesti intr-un post mai vechi ca am spus ca sunt doua surse?
Da, gasim kilometrajul in calculatorul de ABS, in cluster (km sunt stocati in 3 zone diferite), in ECU si probabil mai sunt si altele.
<span class='edit'>27 Feb 2012, 14:33:</span>
Imi pare rau, eu n-am acces la documentatia Renault.
Bottom line, kilometrajul stocat in ECU-urile EDC-15/16/17 de la VW este obtinut prin integrarea vitezei functie de timp. De unde vine viteza aia? Irelevant, este un parametru (as in "si alte variabile") pe care ECU il foloseste.
This post has been edited by marksman: 27 Feb 2012, 14:35
Nick Ușor
post 27 Feb 2012, 14:37
QUOTE(marksman @ 27 Feb 2012, 14:28)
Si normal ca o ramas ala cu 7 biti disponibili, daca la vag se face asemenea irosire a resurselor.
yhattori
pina una alta lamuriti-ma si pe mine de ce toate motoarele benzinare de la PSA au senzor de turatie pe volanta + senzor de pozitie axa cu came pentru referinta si numai TU5JP4 are un singur senzor turatie/referinta pe volanta?
This post has been edited by yhattori: 27 Feb 2012, 14:38
post 27 Feb 2012, 14:38
Cine ofera 5 impulsuri pe metru? Sau la viteza de 1.75km/h ce se intampla? De la cate roti calculeaza viteza (nu se calculeaza de la toate 4)?
marksman
@bucatzel: 3 zone numai in cluster. Mai sunt si chestii de gen "din 2 in 2 km, valoare para sau impara".
Nick Ușor
post 27 Feb 2012, 14:40
Nici eu nu am access, dar daca cauti pe net gasesti multe. Iar astea sunt norme generale.
Inca unu'. De ce nu incercati si pe topicul cu basescu? Sau pe ala de fotbal, sa va egzplice tonies cum e la maibah.
Io unu' deja ma improsc de ras, sincer... Ma gandesc ca urmeaza sa puneti bancuri la probleme tehnice, bule la imbunatiri, samd.
This post has been edited by bucatzel: 27 Feb 2012, 14:42
ArtVandelay
post 27 Feb 2012, 14:56
Anytown, USA..
QUOTE(yhattori @ 27 Feb 2012, 15:37)
cu un singur senzor pe volanta la pornire da scanteie la intamplare practic pana porneste, cu inca un senzor de pozitie pe axa cu came stie exact la care cilindru trebuie data. eu asa stiu
Ford focus 2001
yhattori
post 27 Feb 2012, 14:58
hai ca am aflat, ECU de pe tu5jp4 e mai destept, foloseste o smecherie la care-i zice DEPHIA = "Détection de Phase Intégrée à l'Allumage", afla daca cilindrul 1 e in compresie sau nu functie de tensiunea necesara pentru arc la bujie (e mai mare daca cilindrul e in compresie) si de aia nu mai are nevoie de senzor de pozitie.
partea nasoala e ca atunci s-ar putea sa nu scap doar cu senzor volanta ci sa schimb si modulul de aprindere.
da' oricum, chizdofrenica gaselnita, chiar ma gindeam azi cum dracu'-si sincronizeaza asta aprinderea fara senzor de pozitie.
Attached File(s)
post 27 Feb 2012, 15:20
QUOTE(bucatzel @ 27 Feb 2012, 14:40)
Sper. Poate asa se mai racoresc si ei cateva zile, sa se-mpace la un martisor, o maslina, ceva...
dr_mKe
post 27 Feb 2012, 16:31
Membru cu stetoscop
Informatia lu' nenea marksman este foarte corecta.
Asa ca musiu IRONICK, Catalin, Markos care or mai fi pe langa, rahat cu cumparat, bani pe al au dat, iar amu' trebuie mancat ! tongue.gif
post 27 Feb 2012, 16:34
QUOTE(dr_mKe @ 27 Feb 2012, 16:31)
A venit si catelusul grupului.
post 27 Feb 2012, 16:36
Dr. Auspuff?
dr_mKe
post 27 Feb 2012, 16:38
Membru cu stetoscop
Ce sa-i faci musiu IRONICK, mai ajungi si la bula cand debitezi asemenea minuni.
Rusine sa le fie inginerilor de la FauVe ca nu s-or consultat cu asemenea autoritate in materie precum dumneata ! Rusinica !
post 27 Feb 2012, 16:44
Intradevar, rusinica ca nu s-au gandit sa foloseasca timpii de injectie. La valoarea lor.
dr_mKe
post 27 Feb 2012, 17:00
Membru cu stetoscop
post 27 Feb 2012, 17:03
Daca purtati aceeasi discutie intr-un bar, acum erati la a X-a bere, si fie va spargeati berile in cap, fie va urati iubire eterna.
post 27 Feb 2012, 17:17
Nu stiu nici eu ce s-a intamplat de s-a intors doctor auspuff de pe forumul ala de piloti de liniute.
dr_mKe
post 27 Feb 2012, 17:34
Membru cu stetoscop
Stiam eu ca-i ceva necurat cu musiu IRONICK ! Puteam sa bag mana-n foc !
post 27 Feb 2012, 17:41
Ai ramas dator, eu te-am sunat.
dr_mKe
post 27 Feb 2012, 17:48
Membru cu stetoscop
Las'ca te sun cand oi fi la Bucale 3 luni la supraspecializare (in auspuff-uri) tongue.gif
post 27 Feb 2012, 17:55
Bine ca si-au adus aminte ca aproape se cunosc radmasa.gif radmasa.gif radmasa.gif
dr_mKe
post 27 Feb 2012, 17:57
Membru cu stetoscop
C a t a l i n
post 27 Feb 2012, 19:22
______________________
E o pla corectă. A uitat că sustinea ineptii cu distanță parcursă functie de timpii de injectie, iar acum o dă la întors cu senzorii de abs...
Doctore, până una alta, hai să facem listă cu ăia care se cred piloti dar dau cu masina in sant...
post 27 Feb 2012, 19:24
kum
post 27 Feb 2012, 19:36
Banat
Laguna 2.0T 2006 - GL-15-...
Tui mama ei de bula.
Amu' mi s-o rupt pana acum de faza, da' deja pesemne ca m-ati exasperat, de ajung sa-mi dau cu parerea.
Din timpii de injectie ar trebui sa stii turatia, nu?. Nenorocitul ala de vag mai are si prostul obicei sa stie si-n ce treapta esti (si sa-ti dea tot felul de sugestii tampe, cum ar fi sa bagi a 5-a la 60 km/h, dar sa nu divagam), deci din astea doua cred ca ar trebui sa poti afla si km parcursi, ca doar ii o amarata de inmultire. Amu' exact-exact cum intra in calcul perioada cat masina sta la punctul mort nu stiu, da' nu mi se pare deloc de necrezut ca s-o gandit cineva la asa ceva.
Parca vad ca vreun desteptovici care cand i s-o spus de punctul mort, el o auzit doar "division by zero" tongue.gif
@ kum. Discutia aiasta o inceput pe la jurnal de bord. posesorul jurnalului o facut curat, asa ca s-au mutat la ... tin-te bine, la "un banc". Intre timp, au ajuns aici. In continuare, io astept sa faca o vizita discutia asta si pe la topicul de fotbal, sau pe ala cu basescu, sa duca la maxim confuzia.
This post has been edited by bucatzel: 27 Feb 2012, 19:39
kum
post 27 Feb 2012, 19:38
Banat
Bine ma ca sunteti voi destepti...
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 23rd July 2025 - 08:02
