Un topic pentru off topic
wolfin |
#14161
![]() Haha Group: Members Posts: 8.940 Joined: 2 December 05 From: Bucuresti ![]() |
pegas
3120
Bicicleta galbena |
#14162
![]() Sunt nembru, domnule! Group: Members Posts: 2.206 Joined: 29 January 13 From: Bucuresti ![]() |
Nici eu. 1l ecoboost... pas.
Peugeot
407 1.8 16v
#14163
![]() fan Dacia Group: Members Posts: 21.581 Joined: 12 November 05 From: Bucuresti ![]() |
QUOTE(wolfin @ 22 Nov 2024, 19:39) avgas 100ll e benzina cu plumb , pentru motoare cu piston, kerosen (JP7 sau JET A1) e pentru turbine, e un soi de motorina. Deci faptul ca esti tu profan nu insemana ca sunt interschimbabile. axa, daca a ta nu are climatronic si doar aer manual si nu are cruise control, da schimba. This post has been edited by einstein1984: 26 Nov 2024, 14:42 |
- negru pe alb
YRX |
#14164
![]() Membru autentic Group: Members Posts: 5.095 Joined: 6 July 06 From: Bucuresti ![]() |
Foarte multi fac confuzia kerosen - aerogas.
Kerosenul este petrol lampant, gazul ala din lampile cu fitil. |
2005 Ambition 1.6 MPI
maho |
#14165
![]() Membru rigido-flexibil Group: Members Posts: 5.234 Joined: 7 April 10 From: Brașov, orașul olimpic ![]() |
Nu-s chiar acelasi lucru.
YRX |
#14166
Combustibilul de tip P nu se mai produce demult. Ala era o fractie distilata o idee mai grea. Lampile de camping, aprinzatoarele de gratar, sobele de incalzire etc. folosesc actualmente kerosen.
wolfin |
#14167
Inclusiv m1a abrams
This post has been edited by wolfin: 26 Nov 2024, 17:00 |
pegas
3120
#14168
M1A si toate masinile armatelor nato merg cu JP8 nu cu JET A1, JP8 are si aditivi lubrifianti si anticoroziune, kerosenul de lampa mai putin....
- negru pe alb
wolfin |
#14169
avem si noi goolge
That would seem to confirm that alternative types of fuel might not be a problem for the M1. In fact, Girona added, "Gasoline of any grade?: Check – Diesel of any grade?: Check – Any percentage of Ethanol fuel to include Pure Ethanol?: Check (it will run on Bacardi 151 all day)." He explained that during his service his tank was fueled up with anything they could find, including "questionable heating oil" found in the back of a broken-down truck. Whatever was sufficient to get the platoon back to friendly lines, "Been there done that, the tank didn't even hesitate." Of course, the issue is still how much JP-8, gasoline, kerosene, or even Barcardi 151 can be found. That's because the Abrams is estimated to use between 1.5 to 3 gallons per mile – and not the more common "miles per gallon." That makes even the most gas-guzzling muscle car look downright fuel-efficient. |
pegas
3120
dizzy |
#14170
![]() Work smart not hard! Group: Members Posts: 5.111 Joined: 11 February 04 ![]() |
Exact JP8!
Merge si pe JP4 si pe Diesel, ulei de gatit, pacura.. dar haleste mult This post has been edited by dizzy: 27 Nov 2024, 10:01 |
Whirpool
ex Dacia Logan
wolfin |
#14171
Honeywell AGT1500 multi-fuel turbine engine
batman batman |
pegas
3120
axabrt |
#14172
![]() Membru autentic Group: Members Posts: 4.150 Joined: 15 February 05 From: Ploiesti ![]() |
QUOTE(einstein1984 @ 26 Nov 2024, 14:39) Da asta ? https://www.rulate-proleasing.ro/detalii-au...1542/ford-kuga/ E full cred. As rămâne fără bani da macar știu o treabă. Totuși n as lua fara un drive test , trebuie sa vad cum mă împac cu cutia aia cvt că n am condus niciodată așa ceva. |
Focus mk3.5
#14173
Lasa, mai bine sa mai ai niste bani, gumele la suv sunt scumpe
- negru pe alb
wolfin |
#14174
Se gasesc all sezon la 250 lei bucata.
pegas
3120
medelin |
#14175
![]() Membru autentic Group: Members Posts: 573 Joined: 23 May 10 ![]() |
Dati 30k pe o masina, dupa care incepeti sa taiati din banii de caiciucuri…
Logica e plecata de mult… |
tractor u650, dacia
1971
- b 22 auz 7-B-798 Chiar existand tractorul,plugul il trag cu inima!
wolfin |
#14176
Si anvelopa sh care nu e ajunsa la martori e la fel de buna ca una noua.
pegas
3120
medelin |
#14177
Wow, misto. Inseamna ca graficele alea cu distanta de franare invers proportionala cu profilul anvelopelor sunt fake…
Sau alea cu evacuarea apei. This post has been edited by medelin: 29 Nov 2024, 17:19 |
tractor u650, dacia
1971
wolfin |
#14178
Pui sensul invers
pegas
3120
medelin |
#14179
Deci le montezi si incorect.
Tu asa faci, sau doar recomanzi? |
tractor u650, dacia
1971
wolfin |
#14180
Glumesc cu Axa.
This post has been edited by wolfin: 29 Nov 2024, 17:32 |
pegas
3120
psychoo |
#14181
![]() Membru Group: Members Posts: 3.721 Joined: 23 August 07 From: Timisoara ![]() |
Am gasi in sfarsit sa cumpar un service pack cu ecran si rama originale pentru telefonul S8 la 750 lei
Pus si o baterie noua originala Am scapat de burn-in si crapatura + diverse zgarieturi, e nou din nou telefonul, ma declar incantat |
Focus
wolfin |
#14182
Pai cum te impaci cu android 9. Mai merge waze? De ex?
Eu cu greu am renuntat la A5...dupa 5 ani...din cauza asta. AA functiona...dar waze pas....si se bloca pe interfata masinii...lipsa update. This post has been edited by wolfin: 1 Feb 2025, 22:44 |
pegas
3120
psychoo |
#14183
Android 8.0 - cel mai bun dpmdv
Da, merge tot perfect This post has been edited by psychoo: 1 Feb 2025, 23:06 Attached thumbnail(s) Screenshot_20250201_230618_Waze.jpg ( Size: 1.28mb ) Number of downloads: 216 |
Focus
dizzy |
#14184
https://b365.ro/video-cursa-nebuna-prin-buc...sOmH8KhjzZMaSfA
Trei tineri au făcut un experiment în trafic la ora de vârf, când pe străzile din București se circulă îngrozitor. Au plecat de la Casa Presei către Piața Muncii: unul cu mașina, unul cu metroul și unul… pe jos. Au vrut să vadă cum e mai rapid să te deplasezi prin Capitală, când toată lumea pleacă de la serviciu. Cât timp scutești cu metroul sau pe jos, când în București e haos în trafic Punctul de plecare a fost Piața Presei Libere, iar destinația, gura de metrou de la Piața Muncii (Bulevardul Decebal). Geo, autointitulat „alergător de performanță relativ mediocră”, a luat-o inițial la fugă, dar a fost deturnat de o patiserie. A intrat să-și ia o merdenea cu telemea și ceapă roșie. A fost avertizat că e cam sărată, dar a spus că nu-i problemă – și-a luat și o sticlă de apă la temperatura camerei și a plecat la pas să-și savureze gustarea. Deși inițial era absolut convins că are avantaj și o să câștige, când a văzut că nu-i chiar așa de aglomerat pe șosele, s-a panicat nițel și a început să alerge cu merdeneaua-n mână. George a luat metroul. A trebuit însă să meargă pe jos de la Casa Presei până la stația Aviatorilor, deci a pierdut ceva timp. A schimbat magistrala la Piața Victoriei spre Dristor 2. Alex a luat mașina: un autovehicul electric, cu 18 cai putere, pentru mobilitate sustenabilă. Primele 7 minute au fost un coșmar: n-a reușit să înainteze nici câteva sute de metri. A sperat totuși că pe Geo o să-l apuce un cârcel, întrucât avea de parcurs aproape 10 km. Rezultate strânse între concurenți George a ajuns primul, cu metroul, în 58 de minute. Alex a făcut o oră și 5 minute cu mașina, iar Geo a ajuns după o oră și 10 minute, cu tot cu pauza de gustărică și toate trecerile de pietoni la care a trebuit să aștepte. Spune că în total s-au adunat cam 25 de minute de așteptare ca să traverseze străzile. |
Whirpool
ex Dacia Logan
wolfin |
#14185
la aviatorilor la orele 17..18..e macel.
dimineata e doar crima. la victoriei ....bine ca nu mai cazi pe sine pe la capete...cand se imping „BUCURESTENII„ |
pegas
3120
dizzy |
#14186
In linie dreapta, vreo 7 km, dar nu mergi in linie dreapta
Asta zice ca nu il faci asa repede https://brouter.de/brouter-web/#map=14/44.4...rofile=shortest vreo 8 km pe sosea nu ii poti face pe jos intr-o ora, poate in o ora jumate - doua; |
Whirpool
ex Dacia Logan
wolfin |
#14187
Am luat prima amenda in 25 ani de
![]() 71 km/h in limitare de 60. ![]() |
pegas
3120
medelin |
#14188
Cat trebuie sa decartezi?
tractor u650, dacia
1971
wolfin |
#14189
90 lei
pegas
3120
miki |
#14190
![]() #Hırsızlargibigeceniniçine Group: Members Posts: 1.239 Joined: 30 July 02 From: Bucuresti ![]() |
Ghiseul inca nu merge...
Sedan 1.6 16V / Megane IV 1.33 TCE/Santa Fe
2004 / 2019/2008
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 13th July 2025 - 21:58 |
