11 Pages « < 4 5 6 7 8 > »
> Logan MCV Stepway Techroad 0.9 tce, MCV Stepway
Disturber
post 22 Apr 2020, 09:35
Post #151
QUOTE(bgdrenault @ 22 Apr 2020, 07:32)
Foarte faina si brun vision
Mai rau cu praful.
Vom vedea cand ajunge.
Intrebare: Are cineva idee ce capacitate maxima a stickului suporta navigatia?
Dacia MCV Stepway 2020 TCE 100 GPL
silvanu96
post 22 Apr 2020, 10:59
Post #152
in poza aia (sau o captura...) as fi bagat mana in foc ca e un Duster...
Renault Megane 3 2009 Hatch 1.5 dCI 78kw - PH__CSR
Duster Laureate 2016, 1.5dci 4wd.
gcorneille
post 22 Apr 2020, 11:45
Post #153
QUOTE(Disturber @ 22 Apr 2020, 00:35)
Am pe bonul de comanda Cod VIN. Acesta sa fie? Mie asa imi pare...Termen de livrare initial era 25 mai. Acum nu stiu in ce stadiu mai este.
Da, despre VIN este vorba (Vehicle Identification Number) si ar trebui sa inceapa cu UU1K52...
22 Apr 2020, 11:53:
QUOTE(Disturber @ 22 Apr 2020, 09:35)
In manual scrie 32 Gb.
22 Apr 2020, 11:56:
QUOTE(silvanu96 @ 22 Apr 2020, 10:59)
This post has been edited by gcorneille: 22 Apr 2020, 11:56
Dacia Logan MCV Stepway 0.9 Tce 2019/SL Techroad - B-104-RYZ
Disturber
post 22 Apr 2020, 14:01
Post #154
QUOTE(gcorneille @ 22 Apr 2020, 11:45)
<span class='edit'>22 Apr 2020, 11:53:</span>
Revin pe privat cu VIN-ul. Bine ca mi-ai zis, ca ma uitam dupa un stick fit de 64. Acum ma voi uita dupa 32 gb. biggrin.gif
This post has been edited by Disturber: 22 Apr 2020, 14:13
gcorneille
post 22 Apr 2020, 14:16
Post #155
De stick mai scrie in carte sa fie formatat FAT32.
Disturber
post 22 Apr 2020, 14:21
Post #156
QUOTE(gcorneille @ 22 Apr 2020, 14:16)
Asta n-ar fi o problema, mai ales ca il folosesc doar pentru muzica. Daca foloseam fisiere mari, atunci da. biggrin.gif
gcorneille
post 22 Apr 2020, 14:23
Post #157
marksman
post 22 Apr 2020, 14:38
Post #158
Post mortem nihil est
32GB sunt limitele partitiei pentru FAT32. Teoretic poti lua un stick mai mare, faci prima partitie FAT32 de max 32 GB si restul ce format vrei tu. Nu mai stiu daca merge si pe Windows chestia asta.
LE: probabil unitatea foloseste vreo versiune de WinCE, de unde si cererea de FAT32
This post has been edited by marksman: 22 Apr 2020, 14:39
Charlie Foxtrot: Massively vote Charlie Golf for President!
Andy_ACS
post 22 Apr 2020, 14:45
Post #159
Yes, I'm not!
WinCE a fost folosit la versiunile vechi de MediaNav.
La asta actuala care suporta AndroidAuto si AppleCarplay se foloseste Linux..
axabrt
post 22 Apr 2020, 15:06
Post #160
Mda la cat e de înaltă seamănă a Duster. De fapt dusterul e mai mic cred cel putin la lungime
De fapt chiar, de ce și ar lua cineva Duster 2wd in loc de asta ?
Ford Focus mk3.5 Ecob00st
psychoo
post 22 Apr 2020, 15:10
Post #161
pt ca e "gip"
Si de afara nu se vede ca are 2wd
Chiar si cele 4wd sunt foarte putine cele care fac offroad (fie si mild)
MyKe89
post 22 Apr 2020, 15:12
Post #162
Membru RFG
Pentru că roți cu diametru mai mare, gardă la sol mai bună, poziție mai înaltă de condus. Dar și preț cu 50% mai mare (echipări echivalente).
'23 Honda CR-V e:HEV
'02 BMW Z3 1.9i
'91 MB W124 230E
axabrt
post 22 Apr 2020, 15:44
Post #163
Sa facem praf și acest topic.
Cum sa nu se vadă de afara care i 4x4. Diferențialul ăla e și foarte bine ascuns sub spoilerul spate .
Înțeleg că nu se vede la passat sau audi dara la Duster se vede Intr o clipă.
Am mers eu la o schela pe niste dealuri la Mădulari , cu un Duster 4wd de OMV Petrom. Respectivul inginer mergea cam tare că întârziasem fata de ora la care trebuia să ajungem.
Deci incredibil cum putea să mearga dusterul cu 60 la ora prin ce hal de drum de pământ. Era off-road spre mediu asa eu făcusem drumul ăla de mai multe ori cu un Seat Leon fr dar cu mai mult de 30 km nu mergea că atingeam cu burta și în plus zgâlțâia mașina foarte rău.
Dusteru la viteze dubla n avea nimica te simteai că plutesti . Nespus de confortabil.
psychoo
post 22 Apr 2020, 16:06
Post #164
Cei care epateaza cu duster 2wd nu se lauda celor care stiu ce e ala un diferential si cum arata.
Cei care iau un duster 2wd ca se incadreaza in buget si criteriile (auzite de mine) sunt "siguranta" ca e mai sus si in caz de accident scapa (am auzit formularea "sa fiu huidu nu amaratii ceilalti") si garda inalta ca sa urce borduri. Preocuparile lor erau daca are GPL sau daca se poate pune.
Acele masini nu merg pe alt offroad decat jungla urbana. Parerea mea
Iar legat de nenea ala de gonea pe coclauri, daca tu crezi ca intr-un logan nu ar fi gonit exact la fel (sau ma rog, cu viteza cu care se simteau in siguranta) esti naiv.
Masinile de firma sunt birjarite si daca pica ceva se inlocuieste.
La un fost loc de munca au spart baia de ulei la un seat cand au tras pe marginea strazii sa se usureze. In ce conditii a oprit omul ala te las pe tine sa iti imaginezi
Andy_ACS
post 22 Apr 2020, 18:32
Post #165
Yes, I'm not!
QUOTE(MyKe89 @ 22 Apr 2020, 16:12)
Exact. In plus poate unii doresc un motor mai mare si dotari mai multe (gen scaune incalzite). Motorul cel mai puternic de la Logan e motorul cel mai slab de la Duster. De asemenea Duster pare facut mai calitativ decat Logan.
Nu cred ca ia nimeni Dacia "sa se dea mare" indiferent de ce model sau echipare.
post 22 Apr 2020, 18:54
Post #166
dusteru are roti mai amri si e mai confortabil pe drumuri proaste ca loganul. sandero stepway are syspesie naspa rau, mai naspa ca cel normal
gcorneille
post 22 Apr 2020, 21:58
Post #167
- MCV Stepway e mai lung decat Duster cu vreo 20 de cm, avantaj portbagaj MCV
- Duster este mai lat si are anvelope mai mari - avantaj stabilitate Duster
- Duster are 3 cm in plus la garda la sol - avantaj incalecari de borduri/bolovani Duster
- Duster are scaune mai bine profilate in fata, bancheta e mai comoda la MCV
- plasticul interior e cam la fel, un mic plus pentru Duster e orientarea consolei centrale
- usile la MCV Stepway se inchid mai soft decat la Duster
- MCV consuma ceva mai putin, totusi nu semnificativ
- MCV este mai ieftin
- personal, imi place mai mult aspectul lui MCV Stepway decat al lui Duster, dar asta este strict legat de gusturile mele
Avand in vedere ca nici eu nu cred ca isi ia cineva Dacia ca sa epateze, alegerea tine strict de nevoile/dorintele fiecaruia. Dupa cum spuneam anterior, daca imi luam Duster costa 19000 de eur, pentru ca eu nu as lua SUV 4x2. Si nu pentru off-road ci pur si simplu pentru stabilitate si control pe suprafete cu probleme.
post 22 Apr 2020, 22:09
Post #168
La masini e o problema cu caracteristicile scrise pe tot felul de pliante.
Se poate (destul de des de altfel) ca "feelingul" de contact direct cu masina sa rastoarne la 180 de grade zicerile din pliante.
Si la stabilitate, si la spatiu, si la profilare etc.
gcorneille
post 22 Apr 2020, 23:20
Post #169
QUOTE(Disturber @ 21 Apr 2020, 23:16)
Culoarea brun vision arata foarte bine, cel putin cand e curata, dupa cum spuneam am vazut doua pregatite de vanzare si arata foarte bine. Chiar si in trafic cred ca arata altfel decat majoritatea gri-negru-alb, dar dupa ce iti soseste si tie poate dam o tura de cartier si iti spun si eu cum se vede in trafic.
O sa ai aceeasi problema ca si mine, imediat se vede praful pe ea.
Eu am avut albastru marin inainte (albastrul inchis de la Logan, de care aveau o multime la MAI cu ceva ani in urma) si clar era mult mai rezistenta la mizerie.
22 Apr 2020, 23:27:
QUOTE(klaus @ 22 Apr 2020, 22:09)
Absolut de acord, daca iti cumperi masina dupa pliant s-ar putea sa ai surprize mari ulterior. Eu sunt de parere ca inainte de a cumpara o masina trebuie sa o conduci, preferabil intr-o echipare asemanatoare cu ce vrei sa cumperi. Degeaba conduci varful de gama de la dealer daca iti comanzi o echipare medie sau mai putin de atat, dezamagirea va fi mare.
Inainte de a cumpara masina, pe linga testarea Fabia Break, Clio Break si Duster am cochetat si cu Megane Sedan, ca era la dealer unul care ma atragea maxim. Dar in echiparea expusa costa 20500, iar intre ala si varianta de 15000 vazuta ulterior erau niste diferente uriase la feeling interior.
This post has been edited by gcorneille: 22 Apr 2020, 23:27
myreno4me
post 23 Apr 2020, 06:30
Post #170
Ca sa iti faci o idee despre masina ai nevoie de cativa zeci de km, in TD nu iti dai seama de nimic. Cu ce m-a ajutat ca m-am dat cateva minute cu o masina in echipare diesel, ca nu aveau benzina ? Eu am luat masina fara TD, dupa review-uri si filmulete de pe youtube. Si da, varianta business la megane e sinistra !
This post has been edited by myreno4me: 23 Apr 2020, 06:31
Megane IV 1.2 TCE 2018
Disturber
post 23 Apr 2020, 09:12
Post #171
QUOTE(gcorneille @ 22 Apr 2020, 21:58)
Duster are 3 cm in plus la garda si este mai scurt. Probabil asta face MCV-ul un pic mai stabil? Sau ma insel? biggrin.gif
QUOTE(gcorneille @ 22 Apr 2020, 23:20)
Momentan am Clio galben si am avut o Nubira gri...toti spuneau ca pe culoarea gri ar fi mai ok cu praful, dar nu este adevarat. A doua zi dupa ce o spalam, se vedea imediat praful pe ea...de multe ori chiar dupa ce plecam de la spalatorie. smile.gif) Galbenul mi s-a parut parca mai rezistent.
gcorneille
post 23 Apr 2020, 10:47
Post #172
QUOTE(Disturber @ 23 Apr 2020, 09:12)
Duster are si ampatamentul (distanta intre axe) si ecartamentul (distanta dintre roti) mai mari deci ar trebui sa fie mai stabila. E o diferenta de 4 cm la ampatament si 6-7 cm la ecartament.
23 Apr 2020, 10:50:
La noi marea problema este ca nu se spala strazile. Daca s-ar spala strazile zilnic in maxim o luna ar fi cu totul altceva, nu s-ar mai prafui masinile in 1-2 zile ca acum, ar sta curate 2 saptamani cel putin.
This post has been edited by gcorneille: 23 Apr 2020, 10:50
silvanu96
post 23 Apr 2020, 11:56
Post #173
... si arata mult mai bine Duster-ul decat MCV-ul. Mie asa mi se pare, ca s-au grabit sa-l scoata in piata iar designerii erau in concediu. In comparatie cu MCVul anterior , acesta mai trebuia ... bagat in sedinte... la Titu.
Disturber
post 23 Apr 2020, 13:50
Post #174
QUOTE(silvanu96 @ 23 Apr 2020, 11:56)
De exemplu imi place mult mai mult MCV-ul decat berlina sau Sandero si cu atat mai mult fata de MCV-ul anterior...personal il consider mult mai frumos. Acela era o combinatie intre o masina break de familie si Doker, dar nu foarte reusita. De fapt avea un plus interesant...2 locuri in plus.
MCV-ul actual arata a o masina break cu un desing mai normal, precum alte modele de la producatori consacrati. smile.gif
Si mai este ceva...cand ai nevoie de spatiu, nu te mai uiti la aspect 100%. M-am lovit de prea multe ori de nevoia spatiului incat sa ma mai frig cu o masina mica. Mai ales ca este pe drum si un bebe...numa' caruciorul lui cat este. smile.gif)
Dar una peste alta si eu recunosc, Duster pare mai fain creionat fata de MCV, insa ma lovesc de problema suprema...portbagajul sad.gif
This post has been edited by Disturber: 23 Apr 2020, 13:52
axabrt
post 23 Apr 2020, 13:54
Post #175
La dusterul asta nou nu mi place spatele.
Stopurile alea is naspa.
Cu siguranță puteau pune ceva mai drăguț , gen kadjar dar cine ar mai fi cumpărat atunci Renault ?
torquemada
post 23 Apr 2020, 15:42
Post #176
torquemada
Apropo de Renaut Duster ph3 (e și garda la sol trecută), prețuri de la 71790reali (12250euro) cu H4M și MT
P.S. inițiatorul topicului e și administrator pe acest topic, poate sterge orice dacă nu vrea topicul "poluat"
This post has been edited by torquemada: 23 Apr 2020, 15:42
Attached File(s)
Attached File  catalogo_final_duster_2020.pdf ( 5.69mb ) Number of downloads: 56
DACIA Logan II 2012 / 0.9 TCe Laureate - B-xxx-xxx
Există două feluri de oameni:
1 - Cei care pot extrapola din date incomplete
gcorneille
post 23 Apr 2020, 17:10
Post #177
Pina la urma, totul tine de perceptia fiecaruia. De exemplu mie vechiul MCV mi se pare o simpla utilitara, fara vreo pretentie de autoturism, in timp ce noul MCV este un break normal care arata destul de bine (am mai spus anterior ca nu-mi place spatele, acolo cred eu ca se mai putea lucra).
23 Apr 2020, 17:19:
QUOTE(torquemada @ 23 Apr 2020, 15:42)
Imi place mult mai mult interiorul la acest Renault Duster decat la Dacia Duster, dar as lua varianta Iconic, care sigur se duce spre 20k de eur. Iar motorul de 1.6 ca unica varianta...
This post has been edited by gcorneille: 23 Apr 2020, 17:19
torquemada
post 23 Apr 2020, 18:56
Post #178
torquemada
Paradoxal Renault Logan Stepway e tot cu H4M(1,6SCe) și CVT la vreo aprox 12400euro fără tva.
- senzor de ploaie și lumină
https://www.renault.com.br/veiculos/conheca...gama/logan.html
O motorizare interesantă e 1,5 benzină H4K, prezentă pe Duster ph2,5 de la Indieni
This post has been edited by torquemada: 23 Apr 2020, 18:58
miki
post 23 Apr 2020, 19:19
Post #179
#Hırsızlargibigeceniniçine
QUOTE(klaus @ 22 Apr 2020, 23:09)
Io-te d-aia am plecat eu sa cumpar Duster si m-am intors cu Megane...
Renault Sedan 1.6 16V / Megane IV 1.33 TCE 2004 / 2019 - XX-B-XXX
Funken Kurbelwelle
Uzun Araç!
Değer Așılırsa
Disturber
post 23 Apr 2020, 19:50
Post #180
QUOTE(torquemada @ 23 Apr 2020, 18:56)
Interesant este ca modelul Sandero difera fata de cel din Romania. Duce foarte mult cu spatele de Megane. smile.gif)
This post has been edited by Disturber: 23 Apr 2020, 19:51
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 8th May 2025 - 11:25
