SISTEME DE NAVIGATIE, PDA, GPS
sorin |
#211
pilot de renault Group: Members Posts: 883 Joined: 15 November 04 From: Lebbeke,Belgia ![]() |
MEGANE 2 1,9dCi
--ESTATE
--octombrie 2004
tektronix |
#212
Membru incepator Group: Members Posts: 4 Joined: 3 March 06 ![]() |
Am si eu un Pocket PC Mio 168 cu Mio Map pe el instalat doar cu harta Italiei mai precis decat orasul Roma. Am luat de la cineva un SD cu iGO Romania. Cand il bag pleaca automat auto-runul imi aleg limba apoi vocea dupa care imi da o ereoare " SD Card ID mismatch, please re-run setup. Chestia e ca nu stiu ce sa-i fac. Am cumparat cardul si acum nu merge . De la cine l-am luat mi-la probat pe un Pochet PC Medion si a mers fara probleme. Poate cineva sa ma ajute . Multumesc . |
Matei |
#213
![]() --M!-- Group: Members Posts: 328 Joined: 21 May 05 From: Bucharest ![]() |
vezi ca sunt mai multe compatibile:
Dispozitive PDA compatibile Mitac Mio 169, 168RS, 168, 336, 558, 339 Fujitsu-Siemens PocketLOOX 720, N520 Asus MyPal A632, A636, A730W Acer n35 AnexTek SP230 Dell Axim x30, x50v, x51v Garmin iQue M5 Hewlett-Packard iPAQ 1940, hx2110, h2210, rx 3115, rx3700, rx3715, h4150, h5550, hx4700 i-Mate PDA2, JAM HTC Universal/Qtek 9000/iMate Jasjar Qtek (HTC) 2020i, 9090, S100 Yakumo alpha GPS, delta 300 GPS 2L, deltaX GPS Toshiba e800 Dispozitive PDA incompatibile HP iPaq 6515, 6500 Compaq iPAQ h3970 Asus MyPal A620, 716 Fujitsu Siemens PocketLoox 610 HP iPaq 38xx, 37xx, 36xx, 65xx Dell Axim x3, x5 Toshiba e800 Bluetooth astea sunt luate de pe situl iGO : http://www.i-go.ro/products/iGO_Romania_2005_SD/ @TEKTRONIX : pe al tau nu-l vad nicaieri in lista... |
Megane Sedan II
2005, 1398 cmc Fericit sau roman ?
imagecam |
#214
Membru Group: Members Posts: 169 Joined: 25 November 05 From: Cluj ![]() |
Omul ti-a dat o versiune care trebuie crack-uita...
Imi imaginez ca stiai ca nu cumperi un soft legal, cu licenta. |
Megane Cabrio 1.6 16v + Peugeot 308 1.6HDI
2008 imagine motor-sport
127.0.0.1 |
#215
![]() no saint Group: Members Posts: 155 Joined: 24 November 04 From: Bucuresti ![]() |
QUOTE(Matei @ Mar 3 2006, 01:03 AM) vezi ca sunt mai multe compatibile: Dispozitive PDA compatibile Mitac Mio 169, 168RS, 168, 336, 558, 339 [...] astea sunt luate de pe situl iGO : http://www.i-go.ro/products/iGO_Romania_2005_SD/ @TEKTRONIX : pe al tau nu-l vad nicaieri in lista... Acum il vezi? Problema pare sa fie ca nu e rulat de pe SD-ul original si are o protectie la copiere. Daca e 100% sigur cumparat pe un canal autorizat suna la producator si fa scandal sa iti inlocuiasca SD-ul. |
Megane e-Tech
2023, EV60 Techno+ Megane e-Tech EV60
C-HR 2.0 Hybrid Ex: Kadjar, Captur, Kuga, Pathfinder, Focus, Clio Symbol |
tektronix |
#216
Omul nu il cunosc . Anuntul l-am luat dupa net m-am intalnit cu el si am cumparat SD-ul. La 100 Euro cat am dat pe el nu prea imi convine da asta e. Altceva pot sa-i mai fac in afara sa-l arunc
fanelul |
#217
Membru incepator Group: Members Posts: 15 Joined: 12 May 04 ![]() |
Sistem de navigatie!
Vroiam sa cumpar si eu un PDA cu GPS dar afland de parbrizul atermic de Megane m-am cam lasat pagubash. Ochisem Fujitsu nx20 sau Asus 632 (deh, dupa buget). Chiar nu "vede" antena incorporata prin parbriz? E viabila solutzia gps BT? |
Matei |
#218
@TEKTRONIX : da. nu aveam ochelarii de soare. mai bine dadeai 3 RON pe o ora de net si ti-l luai singur de pe dc
![]() @fanelul : vezi ca sunt si PDAuri care au mufa pt antena externa si poti sa iti cumperi una si sa o scoti prin bord sa o pui afara. gasesti multe pe ebay.co.uk. am avut eu BT GPS si merge foarte bine. dar trebuie sa incarci doua aparate. |
Megane Sedan II
sandman_ |
#219
![]() software engineer Group: Members Posts: 2.416 Joined: 20 June 05 From: Viena, Austria ![]() |
tektronix: ti-am scris un pm referitor la problema ta.
Megane 2(.1) C-C
Dinamique, 2.0 16v 136cp, 2005
- GJ-01-SSP Renault Laguna 3 2.0dCi, 150CP, 2008
and the best is still to come... |
flotl |
#220
Membru autentic Group: Members Posts: 525 Joined: 1 December 04 From: Tulcea ![]() |
MIO 168 mi-a venit cu antena exterioara care se prinde cu magnet.
Megane Sedan
1.5 dci 100 CP
2004 CP
alphonso |
#221
![]() Membru incepator Group: Members Posts: 3 Joined: 7 August 05 From: Vaslui-Romania ![]() |
Pe mine m-ar tenta un Asus A632 sau A636. Sa inteleg de la voi ca ar fi probleme din cauza parbrizului atermic si nu "citeste" suficienti sateliti? Pentru toate modelele de Megane cu parbriz atermic e obligatorie o antena exterioara sau care sa fie montata in dreptul oglinzii?
Megane Bicorp
2005 Renault Megane II Bicorp - Confort Dynamique
1.6 16V 115cp -2005 |
#222
![]() *** Big Daddy *** Group: Members Posts: 755 Joined: 5 February 05 From: ...pe aici, pe dincolo, pe peste tot... ![]() |
Un MIO 169, cu antena incorporata, functioneaza foarte bine pe un Passat tot cu parbriz atermic, singurul luncru care trebuie avut in vedere este ca antena sa fie in plan orizontal.
Clio Bicorp
2005-dCi/80cp Clio Bicorp Dynamique 1,5dCi/80CP, Bleu Odissee, Full Options (15.06.05)
VW Polo 1,4 TDI PD/105CP, Attractive, chiptuning by TCM Turbo (24.10.05) |
Alex04 |
#223
![]() zzzzzzzzz... Group: Members Posts: 122 Joined: 4 January 05 From: Tineretului, Bucuresti ![]() |
alphonso
Daca ai posibilitatea fa o proba cu un PDA cu antena interna si vezi daca iti merge. Eu am antena montata pe bord si merge perfect. GPS-ul este SysOnChip serial. |
Megane Sedan 2.1
2004 1.6 16V - 115cp
Confort Privilege Clima - Gri Boreal |
tektronix |
#224
Salut .
Am rezolvat problema cu Igo. ![]() Acum am o problema tehnica cu PDA-ul. Nu se mai opreste . Daca incerc sa-l opresc de la power off se inchide si se deschide instantaneu. Mai are un butonasi cu on , off dar daca il inchid de acolo sa pierdut tot ce am instalat pe el. Ma poate ajuta cineva cu vreo sugestie ceva . Eventual un centru de depanare .. ![]() |
sandman_ |
#225
Incearca sa iesi din toate aplicatiile inainte sa-l opresti
Megane 2(.1) C-C
richie |
#226
The Right Member Group: Members Posts: 661 Joined: 17 January 06 ![]() |
Eu am un QTEK S110...cu GSM incorporat, GPS pe Bluetooth SysOn Chip.
Merge fara probleme si prin parbrizul atermic si prin tot. Am pus receptorul inclusiv sub cotiera si tot mi-a mers cu o gramada de sateliti si semnal foarte bun. Referitor la cei 100 Euro pe care i-a dat tektronix pe SD-ul cu IGO...daca acesta este pretul SD-ului chior...e ok. Daca nu (ceea ce e foarte probabil, pentru ca banuiesc ca ti-a dat un SD de 512MB care e cam 50 USD) omul -si toti cei care iau bani pe softuri piratate pe care le descarca gratis de pe net sunt niste nesimtiti, magari, profitori pe care daca as pune mana (si n-ar avea o statura impresionanta ![]() |
Honda Accord /
Nissan Pathfinder 2.5dCI, LE Plus A/T
tektronix |
#227
Am incercat tot .............si tot nu merge. Dar mai face o chestie interesanta si acum am observat. Atunci cand este pus la incarcat daca ii dau eu power off nu mai face nimic , in schimb dupa 5 minute daca nu lucrez cu el se inchide. Problema cred ca e de la soft si cred ca tre scris din nou. Daca ma poate ajuta cineva as fi recunoscator.
sandman_ |
#228
uita-te prin configuratie. Eu am setat la al meu ca dupa 2 sau 5 minute de inactivitate sa se inchida, pentru a economisi energia.
Megane 2(.1) C-C
TheAlphonso |
#229
![]() Membru autentic Group: Members Posts: 251 Joined: 11 March 06 From: Bucuresti ![]() |
Salutare.
Ma poate ajuta cineva cu un soft de navigatie pentru modulul de GPS Carminat pe care il am pe Laguna mea? |
Laguna II 1.9dCi 88kW
2002 Privilege
- B-XX-LIF
richie |
#230
Nu am auzit sa existe deocamdata vreun program de navigatie pentru Romania, care sa functioneze pe sistemele de navigatie integrate....
Am vazut la TV ca s-ar putea face ceva, dar se adaugau ceva componente (sau se inlocuiau, nu mi-am dat seama bine). E un sistem nou...din pacate nu am reusit sa retin prea multe amanunte pentru ca nu am fost atent de la inceput la stirea respectiva (era la stiri) Cauta pe net...poate gasesti ceva informatii. |
Honda Accord /
pablo |
#231
![]() Membru autentic Group: Members Posts: 1.015 Joined: 10 December 04 From: ORADEA ![]() |
Uite aici:http://www.gpsmore.ro/
Mio DigiWalker A201 + iGO Mio DigiWalker 169 + iGO Mio DigiWalker 180 + iGO |
-------------------- Renault Megane II Sedan Confort Expresion 1,6 16V (dec 2004,clima,jenti AL,ESP,etc)
Renault Clio Extreme 1,5 dCi 80 CP (iul 2005,tempomat) |
richie |
#232
Da, intr-adevar...astia sunt.
Dar, cred ca solutia de care ziceam pentru implementat pe sistemul de navigatie al masinii este acesta: http://www.gpsmore.ro/limousine.html Din pacate, nu dau detalii pe site.... |
Honda Accord /
127.0.0.1 |
#233
Megane e-Tech
reno-cstavaru |
#234
Membru incepator Group: Members Posts: 46 Joined: 26 March 06 ![]() |
La www.emag.ro au un Asus A632 cu 13.700.000 care ofera toate accesoriile pentru a-l folosi la masina ca navigator. In plus, ca PDA e foarte bun, are Intel XScale la 416MHz, 320x200 TFT, Wi-Fi, Buletooth, infrarosu, Windows Mobile 5.0 preinstalat. Si-a luat un coleg de-al meu si e foarte multumit. Exista software si pentru Romania, costa 200 de euro dar hmm...se rezolva mult mai ieftin
Megane II 1.6
2005, Sedan Megane II Sedan 1.6 Privilege
FlorinZ |
#235
![]() Membru incepator Group: Members Posts: 89 Joined: 26 November 04 From: Piatra Neamt ![]() |
Stie cineva ce soft de navigatie ptr PDA are si harta Greciei? Bulgaria nu cred ca exista pe undeva .... asa ca nu mai intreb de ea
Megane Sedan
2004 MEGANE II 1.5 dCi 100 CP
Confort Privilege - Vert Cuivre - Clima - Oglinzi rabatabile electric |
Stefan_T |
#236
Membru incepator Group: Members Posts: 75 Joined: 8 June 04 From: Bucuresti ![]() |
Pentru Bulgaria si Turcia incearca TOMTOM 5.21 cu harta Europei de EST 6.08.
Pentru Grecia incearca Destinator PN. |
-------------------- Renault Clio 1.5 Dci, 65 CP
FlorinZ |
#237
Merci de info
Megane Sedan
Tudor |
#238
![]() Moderator Group: Members Posts: 1.824 Joined: 10 May 05 From: Bucuresti ![]() |
Va rog frumos care aveti, trimiteti-mi si mie pe tmoisescu@gmail.com un manual de iGO, in romana sau engleza. Adresa de pe site-ul oficial nu functioneaza, cred ca au busit-o voit. Multumesc.
Clio III
2006 1,5 dCi 80cp Dynamique 3usi Honda CR-V 2006 2,2 CDTi 140cp Executive
Radu Ganescu |
#239
![]() Membru Group: Members Posts: 101 Joined: 7 April 06 ![]() |
Salutare,
Anul acesta, ca si anul trecut de altfel, ma duc din nou in Germania. De data aceasta insa nu mai vreau sa plec fara GPS, mai ales ca voi merge prin mai multe orase (si vreau sa ajung si in Amsterdam). Am vazut in comert, mai precis la METRO un Pda Yakumo Alpha 1038103 la aprox 1000 RON. Vreau sa va intreb daca pot lua harti de pe Net ptr acest tip de GPS, daca exista variante mai ieftine, daca cineva din voi are GPS si l-a folosit atat in tara cat si in afara, ce marca are, de unde pot cumpara. |
Megane II
2005 Sedan
cibernuts |
#240
![]() Membru Group: Members Posts: 169 Joined: 5 January 06 From: Alexandria ![]() |
PDA? sau Pocket PC?,Eu unul ti-as recomanda pocket pc sau un laptop.Eu am facut toata europa cu laptopul utilizand via michelin.
Laguna 1.9 DCI
2002 Renault Laguna Authentique 1.9 DCI 107CP 2002
Renault Megane 1.5 DCI 82 CP 2004 |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 12th July 2025 - 22:21 |
