Antifonare capotă, inclusiv blană, pedalier
valerica1 |
#2011
![]() Membru Group: Members Posts: 116 Joined: 5 June 09 ![]() |
sandero
diverse
dl_dr25 |
#2012
![]() Membru autentic Group: Members Posts: 571 Joined: 4 August 07 From: Bucuresti ![]() |
![]() This post has been edited by dl_dr25: 16 Jun 2009, 21:48 |
2007 dci
- B
#2013
![]() - Group: Members Posts: 22.722 Joined: 19 April 05 From: Romania ![]() |
Apropo de insonorizare, motorizarea de 1.2 va avea insonorizant de tablier.
#2014
QUOTE(valerica1 @ 15 Jun 2009, 13:18) QUOTE(valerica1 @ 15 Jun 2009, 17:20) QUOTE(valerica1 @ 16 Jun 2009, 10:21) ![]() PS: apropo, cand zici de "acolo la voi la dacia", folosesti pluralul de majestate a persoanei intai dar pus la persoana a doua? |
valerica1 |
#2015
QUOTE(IRONICK @ 16 Jun 2009, 23:03) apropo de informatii te referi la Loganul de 1,2 sau sandero de 1,2 astea ce zici tu sunt informatii confidentiale pe care nu ai de unde sa le stii decat daca lucrezi la RTR Bucuresti ,in Pipera aproape de Nnea JIJI, |
sandero
diverse
#2016
te-ai prins, acolo lucrez
dia_ph2 |
#2017
![]() Membru autentic Group: Members Posts: 333 Joined: 29 September 08 From: Targoviste ![]() |
Sper sa nu se supere nimeni:
Si da, a izolat inclusiv aripile spate. This post has been edited by dia_ph2: 17 Jun 2009, 09:33 |
Logan ph2, 1.4mpi
2008, Laureate, Abs
GBi |
#2018
![]() Membru autentic Group: Members Posts: 264 Joined: 12 August 06 ![]() |
Daciaaa
Golan :))
KissFM 1.6 08 / ex. Laureate 1.4 04 Tot ce e bun tre' sa dispara !
loganmpi16 |
#2019
Membru autentic Group: Members Posts: 227 Joined: 31 March 09 From: Alexandria, ![]() |
Am si eu o intrebare: cum pot diminua zgomotul produs de rotile spate? Mentionez ca am dat cu pensula 3 straturi groase de vopsea antifon pe oalele rotilor, pe exterior, iar pe interior am lipit o mocheta pe suport de cauciuc.
Megane III Sport Tourer 1,5 dci 90hp
2011 Bussines
#2020
![]() fan Dacia Group: Members Posts: 21.613 Joined: 12 November 05 From: Bucuresti ![]() |
Te referi la zgomot de rulare sau la zgomotul de la denivelari?
Ca daca e primul e destul de simplu: un set de anvelope de vara mai acatari (Michelin, Pirelli Dunlop etc). |
- negru pe alb
loganmpi16 |
#2021
Ma refer la zgomotul de rulare. Am continental si pe fata si pe spate.
2011 Bussines
GBi |
#2022
QUOTE(loganmpi16 @ 17 Jun 2009, 22:56) pai si nu cumva sunt cele stock, care sunt continental all season? einstein se refera la ceva full vara ex: goodyear excellence ... Attached thumbnail(s) goodyear_excellence.1.jpg ( Size: 213.7k ) Number of downloads: 1092 |
Daciaaa
Golan :))
#2023
Nu il mai puneti mai sa isi schimbe cauciucurile ca nu asta este problema majora. O caruta de bani si efectul nu este pe masura.
dia_ph2 |
#2024
QUOTE(loganmpi16 @ 17 Jun 2009, 22:56) Incearca sa lasi pe liber la viteza de croaziera. Daca esti pe drum neted, o sa-ti ramana zgomotul anvelopelor si al vantului. Daca si asa te deranjeaza, ai gasit solutia. LE. Fasait sau huruit? Daca huruie, pot fi si rulmentii, daca fasaie, pot fi aerisirile din spatele mochetelor laterale din portbagaj (acelea pt egalizarea presiunii). This post has been edited by dia_ph2: 18 Jun 2009, 09:10 |
Logan ph2, 1.4mpi
2008, Laureate, Abs
#2025
Michelin energy mi se par ok din punct de vedere al zgomotului de rulare. Insa pretul si pretentiile sunt mai mari decat pe la conti eco contact
- negru pe alb
#2026
eu as lua michelin energy saver
dia_ph2 |
#2027
Ultimele experimentari privind pozitia batatorului/batatoarelor acustice - in curand.
Logan ph2, 1.4mpi
2008, Laureate, Abs
#2028
Apropo, dupa schimbarea distributiei s-a facut liniste in masina. Motorul nu mai este zgomotos ca inainte. Ma asteptam sa scada, dar nici chiar asa.
dia_ph2 |
#2029
Ce ulei ai acum in motor?
Referitor la batatorul acustic, trebuie montat cu precizie, abaterile de 1cm fiind deja prea mari. Trebuie doar sa refac testele, pentru a lua in considerare numai gama de 21/22/23/24/25 cm fata de catalizator. La prima vedere, 24cm favorizeaza linistea in domeniul de turatii 2000-2700rpm, in timp ce mutarea lui cu 1-2cm spre catalizator duce la linistirea rezonantelor 2700-3000, 3100-3600rpm. Mai multe date, cu mai multa certitudine, numai dupa ce refac testele. PS. Nu am reusit deocamdata sa gasesc o pozitie buna pentru al doilea batator. Intr-adevar, linisteste unele rezonante, dar amplifica altele. This post has been edited by dia_ph2: 18 Jun 2009, 11:20 |
Logan ph2, 1.4mpi
2008, Laureate, Abs
Lostboy |
#2030
Ferice de unii care le au pe ambele montate ”by default”.
#2031
acelasi ulei pe care il folosesc de mult timp, castrol 5w40
Lostboy |
#2032
Pe căldurile astea, ac-ul e la fel de silențios după schimbarea distribuției?
#2033
Cum este la mine montat, al doilea batator reduce in plaja de pana la 3000rpm. Amplifica 3000-3500rpm si pe urma reduce iar.
This post has been edited by IRONICK: 18 Jun 2009, 11:48 |
dia_ph2 |
#2034
QUOTE(Lostboy @ 18 Jun 2009, 12:38) Imi scapa ceva, sau vorbesti de unii posesori de Reno-uri? Pentru ca sunt foarte multe masini, care nu au nici un batator, dar nici rezonante atat de dubioase. QUOTE(IRONICK @ 18 Jun 2009, 12:45) Cum este la mine montat, al doilea batator reduce in plaja de pana la 3000rpm. Amplifica 3000-3500rpm si pe urma reduce iar. Cam pe unde il ai montat? La jumatatea cotului de dupa intermediara? Parca acolo am gasit eu un astfel de efect, cu toate ca intreb numai informativ. Nu mi-ar placea sa urle tocmai la 3000-3500 (stiu, urla deja acolo, dar inteleg de la tine ca se amplifica cu al doilea batator). This post has been edited by dia_ph2: 18 Jun 2009, 11:56 |
Logan ph2, 1.4mpi
2008, Laureate, Abs
#2035
L-am pus unde ai indicat tu, nu am mai stat eu sa verific. Se vede si in pozele facute.
Zgomotul nu este crescut chiar asa de mult, dar vibratia ma omoara. Imi zornaie si capacul de la cotiera daca nu tin cotul pe ea. |
Lostboy |
#2036
Am profitat de o iesire la un sat din județ și am aruncat o privire sub ...am observat că am cele 2 bătătoare montate.
@ironick - și eu am observat un zgomot deranjant (pt. mine deranjant, ceilalți nu-l aud ![]() LE de mare efect soluția oferită de ironick cu privire la ”îmbrăcatul” brăduților de la fața de ușă. This post has been edited by Lostboy: 18 Jun 2009, 12:02 |
#2037
QUOTE(Lostboy @ 18 Jun 2009, 12:43) Pe căldurile astea, ac-ul e la fel de silențios după schimbarea distribuției? Nu am auzit zgomtot de drujba anul asta cand a fost cald. Dar acum eu nu aud nici zgomotul ala de functionare cu care venea din fabrica.This post has been edited by IRONICK: 18 Jun 2009, 12:06 |
Lostboy |
#2038
Cred că o să schimba distribuția mai devreme.
#2039
Nu merita. Si oricum nu au venit inca caldurile alea nasoale.
dia_ph2 |
#2040
Logan ph2, 1.4mpi
2008, Laureate, Abs
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 16th July 2025 - 01:08 |
