29 Pages « < 7 8 9 10 11 > »
> [VAND]piese DACIA noi-REDUCERE DE PRETURI
valy051
post 16 May 2010, 18:28
Post #241
LISTA REACTUALIZATA,REPERE ADAUGATE,PRETURI REDUSE,
Alternator --------------------------------------------------190ron
Antifurt capace roti Dacia---------------------------------15ron
Anvelopa Kumho-185/65/R14 86T,1buc-NOU--------100ron/buc
Anvelope Kumho-185/65/R14 86T,4 buc(rulat 3400Km)----80ron/buc
Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc
Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc.
Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron
Bascula inf cu pivot(rebucsata Fartec)D.Papuc-------------50ron
Bascula spate -----------------------------------------------25ron
Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron
Bec 21W/5W(dublu filament) ---------------------------1ron/buc
Biele motor(set 4 buc) -------------------------------------180ron
Bieleta antiruliu Prems ---------------------------------------7ron
Bloc diode(mari) --------------------------------------------21ron
Bloc diode(mici) --------------------------------------------15ron
Borne acumulator(bronz) --------------------------------7ron/set
Brida radiator -------------------------------------------------2ron
Bucsa ax volan----------------------------------------------2.5ron
Bucsa bascula inf.(Fartec) ------------------------------------7ron
Bucsa caseta directie(teflon) ----------------------------1ron/buc
Bucsa cauciuc bascula spate -------------------------------3.5ron
Bucsa cuplaj volan(Fartec)-----------------------------------6ron
Bucsa tirant(Fartec)- ----------------------------------12ron/4buc
Burduf planetara(mare) --------------------------------------3ron
Burduf planetara(mic) ----------------------------------------3ron
Buson baie ulei -----------------------------------------------3ron
Buson radiator ------------------------------------------------2ron
Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron
Butuc roata fata Dacia(3 prezoane)---------------------------50ron
Cablu ambreiaj 1310 -----------------------------------------17ron
Cablu frana mana -------------------------------------------25ron
Cala carburator textolit -------------------------------------0.8ron
Camasi cilindru DACIA 1300 si 1400 din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set
Camere Victoria 145/155/165-13 ----------------------------5ron
Camere Victoria 175/185/195-14 ----------------------------6ron
Capac delcou Dacia -------------------------------------------4ron
Capac pompa apa Scornicesti -------------------------------55ron
Capsula vaccum ----------------------------------------------5ron
Carbuni alternator Urziceni -----------------------------------5ron
Carbuni electromotor Dacia-Oltcit ----------------------------6ron
Carburator Dacia 1400(27)(S.H.)-----------------------------65ron
Ceas presiune ulei--------------------------------------------10ron
Centuri retractabile fata -------------------------------------60ron
Cheie combinata buson ulei baie+c.v. Dacia---------------15ron
Chiulasa neechipata 1310/1410 ---------------------------400ron
Cilindrii receptori --------------------------------------------13ron
Cleste dezizolator multifunctional----------------------------2,5ron
Cleste dezizolator cablu profesional-------------------------27ron
Comutator semnal. directie 1310/1410 ----------------------9ron
Condesator delcou --------------------------------------------2ron
Cric hidraulic 2 tone -----------------------------------------30ron
Cui pontou Carfil---------------------------------------------14ron
Culbutori ---------------------------------------------------10/buc
Curea trapez.dintata GATES6213MC AVX10x825La---------13ron
Curea trapez.SUPER 9.5x950 -------------------------------11ron
Curea ventilator Fartec 10x6x1000 --------------------------5ron
Curea ventilator Fartec 10x8x1218 --------------------------9ron
Cutie Dacia Papuc 4tr.S.H ---------------------------------130ron
Cutie sigurante 10 cai ----------------------------------------8ron
Cuzineti ST R1 Dacia1310/1410 ----------------------------25ron
Diuze spalator parbriz RENAULT(+,,T''pt.cuplare furtune)---------12ron
Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron
Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron
Filtru ulei Mapco-Mann-DACIA(mare) ------------------------------13ron
Filtru ulei UAMT-DACIA(mare) ---------------------------------------6ron
Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron
Garnitura capac ppa.apa -------------------------------------2ron
Garnituri cilindrii receptori spate ----------------------------1ron
Garnituri motor 1410(set)-----------------------------------20ron
Inele sincron C.V.--------------------------------------------25ron
Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc
Motor stergator parbriz ARO 10------------------------------35ron
Oala planetara(dinspre roata) -------------------------------35ron
Oglinda ext.dreapta -----------------------------------------20ron
Patent 200mm------------------------------------------------6.5ron
Pinion delcou(Brasov) ----------------------------------------10ron
Pistol aer cu manometru(0,5-10bar)(Italia) ----------------35ron
Pistol spalat si terosonat ------------------------------------25ron
Piulite INOX prezon roata DACIA(geometrie antifurt+cheie speciala)12buc+cheie--45ron
Pistol de lipit electric 100watti--------------------------------28ron
Pivot inf. -----------------------------------------------------15ron
Platina --------------------------------------------------------4ron
Placuta protectie uzura placa presiune Dacia-------------------15ron
Prese demontat/montat bucsi bascule,cuplaj volan,planetare,etc---130ron
Presa demontat pivoti ---------------------------------------40ron
Pompa spalator parbriz Dacia---------------------------------10ron
Releu far(4pic.) ---------------------------------------------2.5ron
Releu protectie halogene 30A(Italy) -------------------------8ron
Releu semnalizare Sacele -----------------------------------10ron
Releu tensiune mecanic Bulgaria-12V ----------------------30ron
Releu tensiune mecanic Sacele(1411)12V -----------------30ron
Rotor electromotor D.Sacele --------------------------------90ron
Rotor alternator D.Sacele------------------------------------60ron
Rulment ambreiaj Fi180(39060) ---------------------------12ron
Rulment biconic Mare(35305)C.V---------------------------25ron
Rulment biconic Mic(35405)C.V.----------------------------16ron
Rulment conic302/37 -----------------------------------------7ron
Rulment roata fata 6207 -------------------------------------9ron
Rulmenti cutie viteza(5tr) -------------------------------80ron/set
Saboti frana 1310----------------------------------------50ron/set roata
Semeringuri FARTEC-----110x130x13-------------------------10ron
-------------------------80x100x10-------------------------8ron
-------------------------50x70x10--------------------------7ron
--------------------------35x50x8---------------------------5ron
--------------------------26x42x10--------------------------4ron
Set sigurante(8A-16A)---------------------------------------2ron
Semicuzineti palier+biela R1 BORGO -------------------------110ron
Set garnituri motor 1400cc ---------------------------------17ron
Set motor DACIA 1400cc SETCAR(etansare cauciuc) ----320ron
Set reparatie pompa apa ------------------------------------12ron
Set Yalle usi+portbagaj1310 --------------------------------40ron
Simering priza C.V. 17x28x7/13F ----------------------------2ron
Sonda litrometrica 5726 ------------------------------------20ron
Sonda ulei ceas ----------------------------------------------22ron
Stator alternator ---------------------------------------------55ron
Stergatoare SACA 400mm/16''(set) ------------------------10ron
Supape admisie+evacuare ---------------------------------50ron/set
Suporti motor Dacia----------------------------------------25ron
Termostat Dacia ---------------------------------------------10ron
Tija culbutori(set) -------------------------------------------24ron
Tripla Dacia 1310(stg.+drp)DSP-8 --------------------35ron/buc
Triunghi reflectorizant ---------------------------------------20ron
Valve tubeles -------------------------------------------------1ron
Voltmetru cu furca M410 3-15V(45Ah-153Ah) -------------50ron
Telef.0722.121.520
Arc_auto_L_345mm_Fi_int.105mm_Fi_ext.135mm_grosime_spira_Fi_16mm_pas_spira_50mm_.jpg_02.jpg ( Size: 55.85k ) Number of downloads: 1092
This post has been edited by valy051: 16 May 2010, 18:39
x x x - x
valy051
post 20 May 2010, 17:55
Post #242
Up!
x x x - x
bebe96
post 25 May 2010, 18:50
Post #243
buna seara.in legatura cu cilindrii receptori,nu stiti sunt cumva pentru tamburi mari?
dacia 1310 1998-berlina - b-16-ciw
valy051
post 26 May 2010, 07:44
Post #244
Aveti PM.
x x x - x
ghitza
post 26 May 2010, 18:32
Post #245
mai da ce alternator ai tu acolo la asa pret?190 roni?ce stie sa faca de atatia bani cand pe aici este la 80 de roni maxim.sunt curios .fara suparare dar e exagerat pretul
26 May 2010, 19:33:
This post has been edited by ghitza: 26 May 2010, 18:33
valy051
post 26 May 2010, 19:00
Post #246
Domnule ghitza,
Alternatorul este nou,nefolosit(nu este SH).Pretul este corect.Nimeni nu va obliga sa cumparati acest alternator.
x x x - x
valy051
post 4 Jun 2010, 18:28
Post #247
Telef.0722.121.520
x x x - x
valy051
post 16 Jun 2010, 12:48
Post #248
Up!
x x x - x
bebe96
post 18 Jun 2010, 20:42
Post #249
multumesc DL Vali pentru piese,cumparati cu incredere,om de incredere!!!!!!!!!!!!!!!!!!
dan supernova
post 1 Jul 2010, 19:37
Post #250
salut un filtru de ulei ptr dacia mar interesa si ulei daca aveti . ,cum facem sa ne intalnim ?
Dacia /Renault Supernova clima & Clio Supernova (2002) & Clio (2005) - B-902-DAN
valy051
post 12 Jul 2010, 13:08
Post #251
Aveti PM.
x x x - x
makeme
post 12 Jul 2010, 13:40
Post #252
Pibabum S.A.
aripi fata dacia model 2000
ai ?
FORD/FIAT FIESTA/SCUDO 2007/2008 WatchMoviesTime.com
valy051
post 12 Jul 2010, 13:41
Post #253
Nu am.
x x x - x
valy051
post 19 Jul 2010, 11:52
Post #254
Telef.0722.121.520
x x x - x
evolio
post 20 Jul 2010, 11:31
Post #255
Privitor melancolic al iernii
ma intereseaza jentile,sunt cele de tabla??
Dacia SuperNova Clima 2002 - PH-87-BUZ
Membru plecat cu gandul.........
valy051
post 21 Jul 2010, 16:36
Post #256
Jantele nu mai sunt de actualitate.
x x x - x
anecula_08
post 23 Jul 2010, 18:48
Post #257
Salut. Oglinda exterioara dreapta de 1310 cu reglaj din interior?
Dacia Solenza Europa cu AC - 1.4 MPI / Renault Laguna 2 Facelift - 1.6 16v / Dacia Logan Stepway - 1.0 TCE
valy051
post 23 Jul 2010, 19:39
Post #258
Nu.
x x x - x
tanel17
post 27 Jul 2010, 12:02
Post #259
jicloarele carfil D1400 sunt originale? cat costa un set? poti pune o poza cu ambalajul?
ms
Dacia 1310 1994 L - TM-??-???
valy051
post 28 Jul 2010, 17:16
Post #260
Jicloarele sunt originale Carfil,dar nu sunt la set.
x x x - x
valy051
post 2 Aug 2010, 18:45
Post #261
Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron
Telef.0722.121.520
x x x - x
G I M
post 2 Aug 2010, 23:22
Post #262
Membru cu indemanare
Poti atasa o poza cu capacul de la pompa de apa? Am mai luat cateva piese de la tine printre care si un corp de pompa de benzina care era rascopt, toate gaurile de prindere s-au rupt, nu as mai vrea sa patesc si cu asta la fel.
Una d'aia cu 5 roti
valy051
post 3 Aug 2010, 10:50
Post #263
Stimate domn,piesele pe care pretindeti ca le-ati luat de la mine au fost noi.Banuiesc ca sunteti convins ca nu le-am fabricat eu.Toate piesele pe care le-am postat au fost cumparate in timp din reteaua de magazine specializate Dacia,si sunt noi.Nu ma puteti acuza de viciile ascunse de fabricatie.(daca ele exista)Si apoi sunteti singurul cumparator care i se intampla asa ceva(am vandut 5 buc.).Imi pare rau de necazul dumneavoastra.
Capacul pompa apa este nou,fabricat la Scornicesti.
Foto pentru dl.Rusu
This post has been edited by valy051: 3 Aug 2010, 17:04
x x x - x
rusu_i
post 3 Aug 2010, 19:30
Post #264
in prima poza chiulasa are codul 509 944 - asta stiu ca-i de motor de 1.3. pentru motor de 1.4 (102-13) ar trebui sa aiba codul 597 027. ai si modelul de 1.4 ?
FORD FIESTA V 1.25 + GPL BRC SQ24.11 2008 - TM-..-...
G I M
post 3 Aug 2010, 19:37
Post #265
Corpul de benzina a fost NOU, dar prost calitativ; nu am invinovatit pe nimeni, doar am spus ce mi s-a intamplat si as vrea sa nu se mai repete. Sunt convins ca nu aveti nicio vina, nici eu nu mi-am dat seama pana nu l-am montat. O sa va dau un PM cu ce mai vreau.
3 Aug 2010, 20:35:
Valy ai PM.
This post has been edited by Neagu Ionut: 3 Aug 2010, 20:35
Una d'aia cu 5 roti
valy051
post 3 Aug 2010, 21:17
Post #266
Raspuns dlui.rusu_i,
Chiulasa are poansonat pe fata rectificata cod 102-13.
Si inca un amanunt.Sub terminatia codului 944 se afla 027.(prima poza din post)
Interesati-va la un mecanic daca este ceea ce va trebuie dumneavoastra.
x x x - x
G I M
post 4 Aug 2010, 10:30
Post #267
PM, cand ai timp sa mi le expediezi si mie. Merci
Una d'aia cu 5 roti
valy051
post 6 Aug 2010, 09:01
Post #268
Telef.0722.121.520
x x x - x
G I M
post 6 Aug 2010, 10:23
Post #269
Valy de coletul meu se mai aude ceva?
Una d'aia cu 5 roti
valy051
post 6 Aug 2010, 11:41
Post #270
Aveti PM dle.Neagu Ionut
x x x - x
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 14th July 2025 - 16:46
