[VAND]piese DACIA noi-REDUCERE DE PRETURI
valy051 |
#391
Membru autentic Group: Members Posts: 2.667 Joined: 9 April 09 From: Bucuresti ![]() |
x
x
x
- x
valy051 |
#392
Alternator Dacia---------------------------------------160ron
Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode 50A/12V-Dacia---------------------------------30ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Sacele pt.Dacia--------------------35ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron telef.0763012130 |
x
x
x
- x
valy051 |
#393
Up!
x
x
x
- x
valy051 |
#394
x
x
x
- x
pety666 |
#395
![]() Membru fidel Group: Members Posts: 167 Joined: 1 January 09 From: SJ ![]() |
salut,sunt interesat de
Set Yalle usi+portbagaj1310 --------------------------------40ron si Sonda litrometrica 5726 ------------------------------------20ron Poti pune ceva poze? Sunt fabricate de iasi? Mersi |
berlina, 1983
valy051 |
#396
Aveti PM dle.pety666
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode 50A/12V-Dacia---------------------------------30ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Sacele pt.Dacia--------------------35ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron telef.0763012130 |
x
x
x
- x
valy051 |
#397
Up!
x
x
x
- x
valy051 |
#398
Up!
x
x
x
- x
valy051 |
#399
x
x
x
- x
razvan1985 |
#400
![]() membru...unic Group: Members Posts: 2.046 Joined: 18 May 11 From: bucuresti ![]() |
salut, rulmenti dacia spate, ai?(pereche)si un pret.
Dacia/Delta
1410/1310/L/MLS
1996/1988
- B 91 RZN/B 191 RZN decat una proasta,mai bine mai multe bune...(masina)
valy051 |
#401
Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode 50A/12V-Dacia---------------------------------30ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Sacele pt.Dacia--------------------35ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti spate Dacia----------------------------------------15 ron/set Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron telef.0763012130 |
x
x
x
- x
recinalcol |
#402
![]() Membru : Amputat Group: Members Posts: 686 Joined: 19 November 09 ![]() |
Piulite INOX prezon roata antifurt(1buc/roata)+cheie speciala--25ron
Piulite INOX prezon roata(geometrie antifurt+cheie speciala)12buc+cheie--45ron Asa ceva mai ai? |
1310 Li
- VS-22-REC
valy051 |
#403
Nu mai sunt de actualitate antifurturile inox.
x
x
x
- x
valy051 |
#404
x
x
x
- x
valy051 |
#405
VAND SAU SCHIMB CU TELEFOANE MOBILE NOKIA(X7-00;N8;X6-8GB;C7;C6-01;C5-03;)CAMERE FOTO DIGITALE(Sony DSC-HX9V;NIKON COOLPIX P7000;CANON POWERSHOT S95;CANON IXUS 1100 HS.
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode 50A/12V-Dacia---------------------------------30ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Sacele pt.Dacia--------------------35ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti spate Dacia----------------------------------------15 ron/set Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron telef.0763012130 |
x
x
x
- x
valy051 |
#406
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode 50A/12V-Dacia---------------------------------30ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula superioara(Franta)--------------------------10ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant--------------- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------300ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------3ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Patent 200mm-------------------------------------------------5ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Sacele pt.Dacia--------------------35ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron/buc Rulmenti spate Dacia----------------------------------------15 ron/set/roata Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------3ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron telef.0763012130 |
x
x
x
- x
valy051 |
#407
VAND SAU SCHIMB CU TELEFOANE MOBILE NOKIA(6700 Classic;C6-01;C5-03;C5-5MP;X7-00;N8;X6-8GB;C7;C6-01;C5-03;)CAMERE FOTO DIGITALE(Sony DSC-HX9V;NIKON COOLPIX P7000;P300;CANON POWERSHOT S95;CANON IXUS 1100 HS.
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode 50A/12V-Dacia---------------------------------30ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula superioara(Franta)--------------------------10ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant--------------- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------8ron Camera Victoria 145-13---------------------------------------7ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------300ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------3ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Patent 200mm-------------------------------------------------5ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Sacele pt.Dacia--------------------35ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron/buc Rulmenti spate Dacia----------------------------------------15 ron/set/roata Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------3ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron telef.0763012130 This post has been edited by valy051: 9 Oct 2011, 15:29 |
x
x
x
- x
valy051 |
#408
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode 50A/12V-Dacia---------------------------------30ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula superioara(Franta)--------------------------10ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant--------------- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------8ron Camera Victoria 145-13---------------------------------------7ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------300ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------3ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Patent 200mm-------------------------------------------------5ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Sacele pt.Dacia--------------------35ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron/buc Rulmenti spate Dacia----------------------------------------15 ron/set/roata Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------3ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron telef.0763012130 |
x
x
x
- x
valy051 |
#409
x
x
x
- x
valy051 |
#410
x
x
x
- x
zarra68 |
#411
Membru incepator Group: Members Posts: 90 Joined: 19 January 09 From: Capitala ![]() |
Sunt interesat de ;
1.Set pompa apa,a inceput sa fluiere,si as lua si ax de inox 2.Arcuri spate preferabil de break sa fie mai tari 3.Bucsi tirant sau cum so numi,leaga bascula fata de bara de torsiune,vreau ceva calitativ. |
Dacia 1310
motor renault
1991
valy051 |
#412
Up!
x
x
x
- x
valy051 |
#413
x
x
x
- x
valy051 |
#414
x
x
x
- x
dan supernova |
#415
![]() Membru autentic Group: Members Posts: 754 Joined: 20 April 09 From: Bucuresti ![]() |
Buna ziua ,as dori un set de bucsi electromotor dacia ,si un set de carbuni dacia .
Multumesc frumos ,astept raspuns |
Dacia /Renault
Supernova clima & Clio
Supernova (2002) & Clio (2005)
- B-902-DAN
valy051 |
#416
x
x
x
- x
valy051 |
#417
x
x
x
- x
razvan1985 |
#418
termostatul,producator,tempereatura lucru?numai bine.
Dacia/Delta
1410/1310/L/MLS
1996/1988
NorbertC |
#419
![]() membru nedumerit Group: Members Posts: 110 Joined: 17 July 11 From: Timișoara ![]() |
eu aș fi interesat de ștergător plus lagăr din parte dreaptă, supernova.
Cam cât costă? Mersi anticipat! |
SupeRNova
2001 Rapsodie; Culoare: Verde Infinit
- TM 10 NUX
BZ_07_RFI |
#420
Membru autentic Group: Members Posts: 292 Joined: 25 April 11 From: Buzau/Bucuresti ![]() |
Salut, ma intereseaza carburatorul...cum este?se poate pune direct pe masina..trebuie curatat,reglat?asiguri si montaj?Ms
1310 L
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 15th July 2025 - 05:01 |
