29 Pages « < 10 11 12 13 14 > »
> [VAND]piese DACIA noi-REDUCERE DE PRETURI
valy051
post 11 Feb 2011, 21:27
Post #331
Alternator Dacia---------------------------------------160ron
Antifurt capace roti Dacia---------------------------------12ron
Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron
Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc
Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc.
Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron
Bascula inf cu pivot(rebucsata Fartec)D.Papuc-------------50ron
Bascula spate Dacia--------------------------------------25ron
Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron
Bec 21W/5W(dublu filament) ---------------------------1ron/buc
Biele motor(set 4 buc) -------------------------------------160ron
Bieleta antiruliu Prems ---------------------------------------7ron
Bloc diode(mari) --------------------------------------------20ron
Bloc diode(mici) --------------------------------------------15ron
Borne acumulator(bronz) --------------------------------7ron/set
Brida radiator -------------------------------------------------2ron
Bucsa ax volan----------------------------------------------2.5ron
Bucsa bascula inf.(Fartec) ------------------------------------7ron
Bucsa caseta directie(teflon) ----------------------------1ron/buc
Bucsa cauciuc bascula spate -------------------------------3.5ron
Bucsa cuplaj volan(Fartec)-----------------------------------6ron
Bucsa tirant(Fartec)- ----------------------------------12ron/4buc
Bucsi electromotor Dacia--------------------------------------6ron/set
Burduf planetara(mare) --------------------------------------3ron
Burduf planetara(mic) ----------------------------------------3ron
Buson baie ulei -----------------------------------------------3ron
Buson radiator ------------------------------------------------2ron
Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron
Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron
Cablu ambreiaj 1310 -----------------------------------------17ron
Cablu frana mana -------------------------------------------25ron
Cala carburator textolit -------------------------------------0.8ron
Camasi cilindru DACIA 1300 si 1400 din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set
Camere Victoria 175/185/195-14 ----------------------------6ron
Capac delcou Dacia -------------------------------------------4ron
Carbuni electromotor Dacia-Oltcit ----------------------------6ron
Carburator Dacia 1400(27)(S.H.)-----------------------------55ron
Ceas presiune ulei--------------------------------------------10ron
Centuri retractabile fata -------------------------------------60ron
Cheie combinata buson ulei baie+c.v. Dacia---------------15ron
Chiulasa neechipata 1310/1410 ---------------------------310ron
Cleste dezizolator multifunctional----------------------------2,5ron
Cleste dezizolator cablu(profesional)-------------------------27ron
Comutator semnal. directie 1310/1410 ----------------------10ron
Cui pontou Carfil---------------------------------------------12ron
Culbutori ---------------------------------------------------10/buc
Curea trapez.dintata GATES6213MC AVX10x825La---------13ron
Curea trapez.SUPER 9.5x950 -------------------------------11ron
Curea ventilator Fartec 10x6x1000 --------------------------5ron
Curea ventilator Fartec 10x8x1218 --------------------------9ron
Cutie sigurante 10 cai ----------------------------------------8ron
Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron
Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron
Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron
Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron
Filtru ulei Mapco-Mann-DACIA(mare) ------------------------------13ron
Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron
Garnituri cilindrii receptori spate ----------------------------1ron
Garnituri motor 1410(set)-----------------------------------20ron
Intrerupator lampa martor frana mana--------------------2.5ron
Inele sincron C.V.--------------------------------------------25ron
Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc
Maneta schimbare semnal directie Dacia------------------7ron/buc
Motor stergator parbriz ARO 10------------------------------35ron
Oala planetara(dinspre roata) -------------------------------35ron
Oglinda ext.dreapta -----------------------------------------15ron
Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron
Patent 200mm-------------------------------------------------5ron
Pinion delcou(Brasov) ----------------------------------------10ron
Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron
Pistol spalat si terosonat(rezervor metalic)-----------------25ron
Pistol de lipit electric 100watti--------------------------------20ron
Pivot inf. -----------------------------------------------------15ron
Platina --------------------------------------------------------4ron
Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron
Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----25ron/set
Releu far(4pic.) ---------------------------------------------2.5ron
Releu protectie halogene 30A(Italy) -------------------------8ron
Releu semnalizare Sacele -----------------------------------10ron
Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------20ron
Rotor electromotor D.Sacele --------------------------------90ron
Rotor alternator D.Sacele------------------------------------60ron
Rulment ambreiaj Fi180(39060) ---------------------------12ron
Rulment biconic Mare(35305)C.V---------------------------25ron
Rulment biconic Mic(35405)C.V.----------------------------16ron
Rulment conic302/37 -----------------------------------------7ron
Rulment roata fata 6207 -------------------------------------9ron
Rulmenti cutie viteza(5tr) -------------------------------80ron/set
Saboti frana 1310----------------------------------------50ron/set roata
Semeringuri FARTEC-----110x130x13-------------------------10ron
-------------------------80x100x10-------------------------8ron
-------------------------50x70x10--------------------------7ron
--------------------------35x50x8---------------------------5ron
--------------------------26x42x10--------------------------4ron
Set sigurante(8A-16A)---------------------------------------2ron
Set garnituri motor 1400cc ---------------------------------17ron
Set reparatie pompa apa ------------------------------------12ron
Set Yalle usi+portbagaj1310 --------------------------------40ron
Set capse ferodouri saboti spate-----------------------------3ron
Simering priza C.V. 17x28x7/13F ----------------------------2ron
Sonda litrometrica 5726 ------------------------------------20ron
Sonda ulei ceas ----------------------------------------------22ron
Stator alternator ---------------------------------------------55ron
Stergatoare SACA 400mm/16''(set) ------------------------10ron
Supapa servomecanism frana--------------------------------2.5ron
Supape admisie set ,supape evacuare set------------------40ron/set
Suporti motor Dacia----------------------------------------25ron
Stifturi planetara--------------------------------------------6ron/set
Termostat Dacia ---------------------------------------------10ron
Tija culbutori(set) -------------------------------------------24ron
Tripla Dacia 1310(stg.+drp)DSP-8 --------------------35ron/buc
Triunghi reflectorizant ---------------------------------------20ron
Valve tubeles -------------------------------------------------1ron
Telef.0722.121.520
x x x - x
valy051
post 17 Feb 2011, 20:05
Post #332
Telef.0722.121.520
x x x - x
valy051
post 28 Feb 2011, 14:52
Post #333
Telef.0722.121.520
x x x - x
razvan32
post 2 Mar 2011, 17:56
Post #334
superdaciuta
niste poze la carburator 1400?
2 Mar 2011, 17:57:
e bun carburatorul?
merge bine?
This post has been edited by razvan32: 2 Mar 2011, 17:57
DACIA 1310 1990 TX BERLINA - 6-PH-7008
andr3y_yoo
post 3 Mar 2011, 16:07
Post #335
Membru ma
un voltmetru aveti ?
Dacia Solenza 1.4 GT Turbo - B-68-BMD
Daca Ai cap Iese Altfel
Dacia 4 ever :X
valy051
post 3 Mar 2011, 20:19
Post #336
Aveti PM dle.andr3y_yoo
x x x - x
valy051
post 6 Mar 2011, 12:02
Post #337
x x x - x
valy051
post 13 Mar 2011, 20:26
Post #338
x x x - x
alinworm
post 16 Mar 2011, 22:49
Post #339
bielele de motor sunt de origine? se potrivesc la o dacia 1300'?
Dacia/Skoda 1300/Octavia 1977/2004 - BZ77UAP
DACIOARA 1310
valy051
post 18 Mar 2011, 17:54
Post #340
Releu tensiune mecanic Sacele pt.Dacia--------------------35ron
Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron
x x x - x
ncm77
post 21 Mar 2011, 19:56
Post #341
Ceasuri suplimentare eventual jaeger, daca aveti. Multumesc.
dacia 1304 2005
ghitza
post 21 Mar 2011, 21:15
Post #342
o poza cu cuplaju volan de FARTEC se poate,cea la 6roni,adica cred ca este vba de cruce volan nu?
valy051
post 22 Mar 2011, 20:39
Post #343
User ghitza si ncm77,aveti PM
This post has been edited by valy051: 22 Mar 2011, 20:41
x x x - x
HUMMER H1
post 23 Mar 2011, 23:29
Post #344
Membru cu S.U.V.
mai este as dori si eu 2 buc pt un papuc 4x4 diesel din 2005 si ce provinienta are
ms
Ro S.U.V. Double Cab 1.9d 2005 - GL-13-FHM
dorul3t
post 26 Mar 2011, 20:05
Post #345
Aviator DACIAClub
pentru ambreiaj de 200.. ai ceva?
dacia 1310 L + GPL 11.1999 - TR-21-REB
bla bla bla....
valy051
post 27 Mar 2011, 00:08
Post #346
Aveti PM user dorul3t
x x x - x
dorul3t
post 27 Mar 2011, 11:17
Post #347
Aviator DACIAClub
pune ceva poze cu
bla bla bla....
valy051
post 28 Mar 2011, 22:26
Post #348
Aveti foto:
x x x - x
mc_love
post 29 Mar 2011, 01:33
Post #349
trimiti si in tara?
29 Mar 2011, 01:38:
nu pot sa iti dau pm...
29 Mar 2011, 01:39:
ma intereseaza carburatoru daca e nou..?
This post has been edited by mc_love: 29 Mar 2011, 01:39
dacia berlina 1996
speedy82
post 31 Mar 2011, 19:34
Post #350
Mai este valabila oferta pentru proiectoare: "Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc"?
Dacia 1300 - B 19 XXX
„Aspiratorul meu magic, magnet pe patru roti, scoate orice fufa din cizme si chiloti”
valy051
post 3 Apr 2011, 00:50
Post #351
telef.0763012130
x x x - x
valy051
post 5 Apr 2011, 19:36
Post #352
telef.0763012130
x x x - x
valy051
post 7 Apr 2011, 21:14
Post #353
telef.0763012130
x x x - x
stiefani
post 8 Apr 2011, 08:06
Post #354
o poza cu
Alternator dacia -----------------------------------160ron
daca se poate?
Dacia Break 1397 2000 Li PH 50 TAX Silver Diamant cu Bi-Xenon - PH 50 TAX
kmkm
post 8 Apr 2011, 21:48
Post #355
Aveti Pm in legatura cu proiectoarele!
DACIA DOUBLE CAB 4x4 2003
novalesso
post 14 Apr 2011, 21:01
Post #356
"Piulite INOX prezon roata"
Mai sunt disponibile?
Nissan Patrol 2000 - X-XX-XXX
jubyl3r
post 15 Apr 2011, 22:35
Post #357
bucsa teflon caseta directie mai ai, se potriveste si la un megane 1 1.6 8v?
Renault Megane Coach 1996 1.6e DA0F - BT xx ADY
"Ignorance is bliss"
WGX
post 18 Apr 2011, 19:31
Post #358
Dacia 1310 Owner
Domnu valy, aveti PM
Dacia Batranul REnAult Kombi 1999/1310 CL - WGX'u
ex:Dacia 1310 CL Break, Diamond Silver ,Gasoline with Gotronic Ignition Sensor inside
now: Opel Astra G Caravan 1.6 16V 101 HP
valy051
post 19 Apr 2011, 21:37
Post #359
telef.0763012130
x x x - x
valy051
post 26 Apr 2011, 22:56
Post #360
telef.0763012130
x x x - x
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 15th July 2025 - 01:13
