[VAND]piese DACIA noi-REDUCERE DE PRETURI
valy051 |
#361
Membru autentic Group: Members Posts: 2.667 Joined: 9 April 09 From: Bucuresti ![]() |
x
x
x
- x
nelu_71 |
#362
Membru incepator Group: Members Posts: 26 Joined: 3 March 10 From: Bucuresti ![]() |
de supernova ce piese aveti ????
supernova
- B 29 FEY
buntom |
#363
![]() Membru autentic Group: Members Posts: 220 Joined: 4 May 11 From: Bucuresti,Militari ![]() |
ai cumva o nuca de Logan Prestige sau de Logan?
Scala dec. 2004 "When in doubt... C4"-Jamie Hyneman
LG Optimus G ex. Samsung Wave 723 cu Bada 2.0, |
valy051 |
#364
Alternator Dacia---------------------------------------160ron
Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode(mari) --------------------------------------------20ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300 si 1400 din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pistol spalat si terosonat(rezervor metalic)-----------------25ron Pistol de lipit electric 100watti--------------------------------20ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----25ron/set Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Sacele pt.Dacia--------------------35ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron telef.0763012130 |
x
x
x
- x
ilie71c |
#365
![]() Membru incepator Group: Members Posts: 87 Joined: 19 November 10 From: POJORATA ,SUCEAVA, BUCOVINA ![]() |
pune poze cu pistolul de lipit si cu cel de antifonat
2003 clima
valy051 |
#366
Foto solicitate:
Pistol_de_lipit_electric_100w.jpg ( Size: 64.63k ) Number of downloads: 458 Pistol_de_lipit_electric_100w.jpg_01.jpg ( Size: 56.29k ) Number of downloads: 463 Pistol_spalat_si_terosonat_01.jpg ( Size: 102.12k ) Number of downloads: 465 Pistol_spalat_si_terosonat_02.jpg ( Size: 101.69k ) Number of downloads: 474 Pistol_spalat_si_terosonat.jpg ( Size: 103.2k ) Number of downloads: 465 |
x
x
x
- x
ilie71c |
#367
le dai cu 30 lei ambele,daca sant functionale
2003 clima
valy051 |
#368
Aveti PM dle.ilie71c
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode(mari) --------------------------------------------20ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300 si 1400 din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pistol spalat si terosonat(rezervor metalic)-----------------25ron Pistol de lipit electric 100watti--------------------------------20ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----25ron/set Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Sacele pt.Dacia--------------------35ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron telef.0763012130 |
x
x
x
- x
ydaniel |
#369
aparatoare roata noroi sunt de dacia?
poze? |
Oriunde,
oricand...
Cand esti rau ,nu te uita! |
ilie71c |
#370
mai acceseaza forumul ca ti am trimis pm
2003 clima
valy051 |
#371
Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode(mari) --------------------------------------------20ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----25ron/set Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Sacele pt.Dacia--------------------35ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron telef.0763012130 This post has been edited by valy051: 20 May 2011, 15:49 |
x
x
x
- x
alexandru.ichim |
#372
Membru incepator Group: Members Posts: 11 Joined: 21 May 11 ![]() |
Salut. Nu ai si un vitezometru cu 160 + cablul care duce in cutie?
1310 TLX
- BR-06-DAS
valy051 |
#373
Nu.
x
x
x
- x
rusu_i |
#374
![]() Membru autentic Group: Members Posts: 226 Joined: 27 May 07 From: Timisoara ![]() |
pinion de delcou (de brasov) mai aveti?
FORD
FIESTA V 1.25 + GPL BRC SQ24.11
- TM-..-...
valy051 |
#375
Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode 50A/12V-Dacia---------------------------------30ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----25ron/set Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Sacele pt.Dacia--------------------35ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron telef.0763012130 |
x
x
x
- x
WGX |
#376
![]() Dacia 1310 Owner Group: Members Posts: 388 Joined: 27 August 09 From: Bucuresti ![]() |
QUOTE(valy051 @ 31 May 2011, 16:07) Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron ?? -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Nenea Valy, nu cumva pe semerigul dumitale scrie A80x100x13? ce am eu asa scrie, sau sa fie altceva , ca la nr de referinta scrie 77 03 087 035. L.E. : Multumesc musiu valy This post has been edited by WGX: 2 Jun 2011, 12:43 |
Batranul REnAult Kombi
1999/1310 CL
- WGX'u ex:Dacia 1310 CL Break, Diamond Silver ,Gasoline with Gotronic Ignition Sensor inside
now: Opel Astra G Caravan 1.6 16V 101 HP |
valy051 |
#377
Aveti PM dle.WGX
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode 50A/12V-Dacia---------------------------------30ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----25ron/set Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Sacele pt.Dacia--------------------35ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron telef.0763012130 |
x
x
x
- x
valy051 |
#378
x
x
x
- x
valy051 |
#379
SCHIMB CU TELEFON MOBIL NOKIA X7-00; HTC Desire S;
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode 50A/12V-Dacia---------------------------------30ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----25ron/set Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Sacele pt.Dacia--------------------35ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron telef.0763012130 |
x
x
x
- x
valy051 |
#380
x
x
x
- x
t@s3 |
#381
![]() Membru incepator Group: Members Posts: 41 Joined: 26 May 11 From: Bucuresti ![]() |
o poza? Merci! |
2003 Clima [COLOR=blue]Solenza Clima 2003
valy051 |
#382
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode 50A/12V-Dacia---------------------------------30ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----25ron/set Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Sacele pt.Dacia--------------------35ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron telef.0763012130 Aveti foto dle.t@s3Patent_200mm.jpg ( Size: 52.8k ) Number of downloads: 64 |
x
x
x
- x
valy051 |
#383
x
x
x
- x
valy051 |
#384
VAND,SCHIMB CU TELEFON MOBIL NOKIA X7-00; HTC Desire S;
x
x
x
- x
valy051 |
#385
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode 50A/12V-Dacia---------------------------------30ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Sacele pt.Dacia--------------------35ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron telef.0763012130 This post has been edited by valy051: 13 Jul 2011, 22:37 |
x
x
x
- x
valy051 |
#386
Membru autentic Group: Members Posts: 2.667 Joined: 9 April 09 From: Bucuresti ![]() |
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode 50A/12V-Dacia---------------------------------30ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Sacele pt.Dacia--------------------35ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------25ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron telef.0763012130 |
x
x
x
- x
valy051 |
#387
x
x
x
- x
maverick_ |
#388
![]() Membru incepator Group: Members Posts: 27 Joined: 13 October 09 ![]() |
Suport casetofon pt supernova aveti?
Supernova
cataneagoe |
#389
![]() cataneagoe Group: Members Posts: 12 Joined: 12 January 07 ![]() |
servofrana pt dacia ?
renault kangoo
kangoo
xxx.runner |
#390
![]() Membru incepator Group: Members Posts: 1 Joined: 3 July 11 ![]() |
Cateva poze daca se poate cu presele pe care la aveti...eventual si preturile fiecarora:)...
Multumesc anticipat! |
Romanian
muscle
car
- DB 44 XXX
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 15th July 2025 - 01:02 |
