26 Pages « < 5 6 7 8 9 > »
> Noul Logan Renault eco2, cu 3,8% consum
post 1 Oct 2009, 14:42
Post #181
Pentru ce discutam noi, sunt usoare.
c0rneliu
post 15 Oct 2009, 14:17
Post #182
Pana la urma a incercat cineva sa isi puna elementele aerodinamice de la sandero pe logan? Si aici ma refer la deflectoarele de pe spate, ca fusta fata am inteles ca e cam scurta. Dar deflectoare pentru rotile fata?
multumesc
dar deflectoarele de sub masina le-a pus cineva?
This post has been edited by c0rneliu: 15 Oct 2009, 14:46
dacia logan 1.4mpi - tl 02 vyu laureat 2009
c0rneliu
post 1 Nov 2009, 12:59
Post #183
http://www.dacia.ro/#/modele-si-preturi/logan-pick-up/
a vazut cineva vreun exemplar din acesta pe la dealeri?
are "cauciuc din ala" (nu stiu cum se numeste) sub bara fata ca la sandero. cred ca s-ar potrivi si la berlina ca doar este aceeasi bara.
GBi
post 1 Nov 2009, 14:53
Post #184
Daciaaa Golan :)) KissFM 1.6 08 / ex. Laureate 1.4 04
Tot ce e bun tre' sa dispara !
post 9 Nov 2009, 23:11
Post #185
Ce mai fac altii ...
This post has been edited by IRONICK: 9 Nov 2009, 23:13
c0rneliu
post 12 Nov 2009, 21:04
Post #186
foarte interesanta chestia (cred ca tot deflector se numeste) de pe stalpii din fata ...
post 13 Nov 2009, 01:44
Post #187
Eu m-as uita la roti. Zona aia conteaza 30% la drag. Si nu zic eu asta, ci un "meserias" in aerodinamica de la BMW.
Pana si Peugeot 207 Economique are capace la roti optimizate pentru aerodinamica.
0.30 > 0.274
Lowering the ride height by 5 mm
The fitment of a special flexible lower bumper trim and deeper side extensions
Optimisation of the vehicle’s air intakes
The addition of an under-tray covering either side of the exhaust system and the fuel tank
The fitment of special aerodynamic wheel trims
The introduction of a two-part rear spoiler with side extensions which wrap around the rear windscreen
To reduce the rolling resistance, Michelin 15” 185/65R15 VLRR (Very low rolling resistance) tires are fitted.
13 Nov 2009, 12:30:
Apropo de cat de bine sunt pregatiti redactorii de la revistele auto.
QUOTE(ProMotor)
Aerodinamica a fost îmbunătățită prin [...] și montarea unor spoilere modificate
This post has been edited by IRONICK: 13 Nov 2009, 12:30
post 2 Dec 2009, 11:30
Post #188
AUDI A8 2011 -
This post has been edited by IRONICK: 2 Dec 2009, 11:33
daciafan
post 7 Jan 2010, 11:31
Post #189
daca aflati ceva de montarea kitului aerodinamic si pe logan sedan nu ezitati sa postati
cred ca e una din putinele modificari ce pot fi denumite imbunatatiri
This post has been edited by daciafan: 7 Jan 2010, 11:31
post 7 Jan 2010, 11:37
Post #190
Pai ce vrei sa aflam?
This post has been edited by IRONICK: 7 Jan 2010, 11:39
YRX
post 7 Jan 2010, 11:46
Post #191
Pana la urma au pus deflectorul pe bara si la berlina? Sau numai la "export"?
A, si aparatorile la rotile spate....
Pe MCV vad ca n-au avut curaj, cred ca e totusi mai mult estetic decat functional.
This post has been edited by YRX: 7 Jan 2010, 11:48
bobo77
post 7 Jan 2010, 21:23
Post #192
This post has been edited by bobo77: 7 Jan 2010, 21:24
Dacia Logan Laureate 1,6 mpi - CT _ _ _ _ 2008 ph 2
Multa lume,putini oameni...
marksman
post 7 Jan 2010, 22:39
Post #193
Post mortem nihil est
Nick Ușor
YRX
post 8 Jan 2010, 09:45
Post #194
Au probabil si cod..... dar cred ca nu-si merita banii pe care-i cere Dacia. Merg facute artizanal foarte bine, rezultatele nu sunt spectaculoase insa, mai iau putin din turbulentele generate de rotile spate, dar nu se simte cine stie ce.
Deflectorul frontal are insa un impact mare asupra aerodinamicii masinii, e facut sa scoata aerul de sub masina si sa mascheze asperitatile de dedesubt (esapament, bascule, punti etc.). Partea proasta ca la Logan datorita garzii la sol mare trebuie sa fie si inaltimea deflectorului pe masura (exista o relatie directa intre cele doua). Asta care l-au pus ei e prea mic ca sa influenteze semnificativ curgerea pe dedesubt, cred ca mareste doar fluxul de aer prin compartimentul motorului si rezistenta la inaintare, datorita maririi suprafetei frontale a masinii.
La bara veche (de PH1) rezultatele deflectorului la consum au fost dezastruoase pentru ca a modificat in rau inclusiv curgerea pe capota si parbriz, ma intreb daca nu cumva noua bara (de PH2) a fost putin optimizata si la capitolul asta. Oricum bara PH2 este mai bine desenata la imbinarea cu capota motor si la grila superioara, mai scapa de niste turbulente.
post 8 Jan 2010, 10:29
Post #195
carenajul ala de la spate ce mai zice??
YRX
post 9 Jan 2010, 09:44
Post #196
Sa vina vara mai repede !
post 13 Jan 2010, 10:08
Post #197
Clio dCi 85 Renault eco2: 98g/km CO2
This new version of Clio dCi 85 Renault eco² produces just 98 grams of CO2 per kilometre, corresponding to combined cycle fuel consumption of just 3.7 litres/100km and a theoretical range of 1,486km.
· A series of changes to the engine and the rest of the vehicle has resulted in a significant reduction in CO2 emissions of 17g/km (a gain of 15 per cent) without any impact on the punch of the vehicle.
· This version of Clio dCi 85 Renault eco² will be available in three- and five-door form and will join the Clio line-up in March 2010.
The new version of Clio will sell at the same price as the 115g/km version, a further sign of the Renault eco² signature's bid to make ecological and economical vehicles available to as many motorists as possible.
Clio dCi 85 Renault eco² will be unveiled on January 13 at the Brussels Motor Show, Belgium, and order books will open in France on February 9.
INCORPORATION OF THE LATEST ENGINE DEVELOPMENTS
Renault's engineers focused particularly on fine-tuning the dCi 85 powerplant in order to achieve the greatest possible improvement in CO2 emissions levels without any compromise in performance.
· Longer gearing across all the transmission ratios: the torque and the flexibility of the dCi 85 allow this to be achieved without any significant impact on performance.
· Reduction of frictional losses in the engine and gearbox with the introduction of lowviscosity lubricants.
· Dedicated engine mapping focused on reducing fuel consumption and CO2 emissions.
REDUCTION OF ROLLING RESISTANCE AND DRAG
Improvements to aerodynamics:
· Flexible lip under front bumper extended by 15mm;
· Front wheel arch liner extension flaps;
· Specific underbody enclosure for rear axle.
These aerodynamics-related improvements have had no adverse effect on Clio's looks, and have notably been achieved without calling on such intrusive solutions as a rear lip spoiler or full disc wheel trims.
Reduced rolling resistance:
· Michelin 185x60 R15 low energy consumption tyres.
Taken together, these changes bring about a 5 per cent improvement in CdA, taking it from 0.725 to 0.690 and directly benefiting the vehicle’s CO2 emissions. The reduction of 17g/km has been achieved without any impact on driving pleasure, comfort or noise levels.
This post has been edited by IRONICK: 13 Jan 2010, 10:36
post 13 Jan 2010, 10:28
Post #198
Deci lipsa luminii din torpedou reduce sarcina alternatorului si deci emisiile de CO2.
Sa vedem cat de buna va fi softul asta eco al motorului, ca la K9K scot unul nou in fiecare saptamana.
post 13 Jan 2010, 10:40
Post #199
Bine, reducerea este mai mult la noxe, ca la consum scaderea este de la 3.9l/100km la 3.7l/100km. Dar la cat de putine modificari sunt, nici nu ma mira.
This post has been edited by IRONICK: 13 Jan 2010, 10:41
YRX
post 14 Jan 2010, 09:08
Post #200
Ce-mi place asta cu low viscosity oil, au inceput sa foloseasca 0w20 sau ce?
post 14 Jan 2010, 10:04
Post #201
Eu sunt curios ce au bagat in cutie.
post 14 Jan 2010, 13:41
Post #202
14 Jan 2010, 13:57:
This post has been edited by IRONICK: 14 Jan 2010, 13:57
post 14 Jan 2010, 14:05
Post #203
YRX, pe diesel nu merge acela insa 0W30 cred ca da.
YRX
post 15 Jan 2010, 08:34
Post #204
Vascozitatile uleiului de motor le-am testat eu pe toate pe masina personala. Rezultat: - zero, sau aproape de zero (respectiv insesizabil) intre 0w30, 0w40 si 5w50. Sa dea naibii daca a consumat cu 0w30 mai putin macar cu 0,1 l/100 fata de 5w50. Mai repede s-a vazut un filtru de aer nou decat uleiul.
Cat despre uleiul de cutie, am avut pe vremuri un Peugeot 309 care folosea in cutie 10w40, ulei de motor obisnuit. Cred ca este maxim-ul de "low viscosity" care se poate folosi in transmisii. A mers cutia aia impecabil vreo 20 de ani.
Unghiul beta la berlina este de 15 grade daca urmaresti conturul barii. Carenajul spate cade perfect... biggrin.gif
post 15 Jan 2010, 10:33
Post #205
Am pus si eu 5W30 Elf (ala eco, bla, bla ...). Pana acum nici o diferenta, in afara de zgomot. Mai putine tacaneli la relantiu fata de Castrol.
15 Jan 2010, 10:42:
QUOTE(YRX @ 15 Jan 2010, 08:34)
fate onlain sa iti dau ceva ...
This post has been edited by IRONICK: 15 Jan 2010, 10:42
Steel Tormentor
post 15 Jan 2010, 11:56
Post #206
care-i ala eco? evolution sxr? sau mai sunt si alte tipuri?
This post has been edited by Steel Tormentor: 15 Jan 2010, 11:57
Dacia Logan 2007 Preference 1.4MPI
post 15 Jan 2010, 12:02
Post #207
ihi, evolution sxr
membru_DC
post 16 Jan 2010, 10:24
Post #208
QUOTE(einstein1984 @ 13 Jan 2010, 10:28)
cred ca tu nu sti cum se fac testele alea de omologare de vezi consumul asa de mic prin pliantele producatorilor de masini
apropo, s-au zbatut unii prin Europa (deci nu Romania) sa vada cu dracu' au noul VW POLO si noul Ford Fiesta consum de doar 99 gr CO2 per Km... la modu' c-au achizitionat masini noi si au tras cateva teste cu ele, desigur in urma testelor au obtinut un consum de peste 110 gr CO2 per Km (teste facute cu combustibil de referinta pentru aceste teste).... numai ei (Ford si VW) stiu ce-au manarit la masini de au obtinut 99
ainstaine, unde ai vazut bre ca se fac testele cu lumina-n torpedou aprinsa? radmasa.gif eu am auzit ca fac cu toti consumatorii (faza lunga, ceata, ventilatie, AC astiv, lumina habitaclu, etc.
softu' de va fi pe noua generatie de Logan si pe celelalte doua modele ce se vor lansa (asa cum a declarat seful de la DACIA) va fi capabil sa reduca consumul, dar acesta depinde si de alti factori
de exemplu oglinzile laterale de la Duster, n-au facut decat sa creasca consumul datorita faptului ca sunt iesite cu mult (in comparatie cu cele de la MCV) in afara caroseriei...
<span class='edit'>16 Jan 2010, 10:28:</span>
QUOTE(IRONICK @ 14 Jan 2010, 10:04)
pai au schimbat niste rotite si uleiul, ce altceva puteau sa faca? tongue.gif
This post has been edited by membru_DC: 16 Jan 2010, 17:33
post 16 Jan 2010, 11:48
Post #209
QUOTE(membru_DC @ 16 Jan 2010, 10:24)
Ce spui tu este exact pe dos fata de forma si dimensiunile lor.
membru_DC
post 17 Jan 2010, 10:51
Post #210
QUOTE(IRONICK @ 16 Jan 2010, 11:48)
degeaba forma si dimensiunile lor sunt aerodinamice daca le amplasezi pe un brat la cca. 6cm de caroserie wink.gif
legat de forma acestora, o sa ne auzim mai tarziu sa dezbatem acest subiect...
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 4th August 2025 - 13:26
