26 Pages « < 18 19 20 21 > »
> Noul Logan Renault eco2, cu 3,8% consum
post 23 May 2012, 21:51
Post #551
Pe partea centrala este la nivel, dar pe laterale este mai joasa cu cativa cm decat carenajele. Poza nu este destul de edificatoare. In #529 se vede ceva, desi acolo are rotile suspendate.
This post has been edited by IRONICK: 23 May 2012, 21:53
P-A-C-O
post 29 May 2012, 19:02
Post #552
What you see is what you get!
Renault Alpine A110-50 & Carlos Tavares @ Monaco F1GP
post 30 May 2012, 07:58
Post #553
Si unde este aerodinamica la masina asta? Ca in afara de design nu este nimic de ea.
30 May 2012, 13:35:
Toyota GT 86
This post has been edited by IRONICK: 30 May 2012, 12:35
post 5 Jun 2012, 16:45
Post #554
Carenaj ("difuzor") sub portbagaj cu patru aripioare.
This post has been edited by IRONICK: 5 Jun 2012, 16:45
post 29 Jun 2012, 07:08
Post #555
Cadillac_ATS_2013
post 13 Jul 2012, 22:24
Post #556
Aerodinamica la masini:
http://media.daimler.com/dcmedia/0-921-145...-0-0-0-0-0.html
With a drag coefficient (Cd) value of 0.27, the aerodynamic experts at Mercedes-Benz succeeded in creating another masterpiece with the A-Class. And the A 180 BlueEFFICIENCY Edition due to follow later is even able to exceed this record for hatchback vehicles: thanks to a number of aerodynamic enhancements, this beacon of efficiency achieves a Cd value of 0.26.
Countless flow simulation studies on the computer and a great deal of fine tuning in the wind tunnel resulted in a clear goal: to enhance the basic shape of the A-Class design further, with a view to achieving an exceptional drag coefficient. This is no easy task, particularly for a hatchback model with a short rear overhang. But an improvement in the Cd value of just one hundredth will reduce fuel consumption by one tenth of a litre per 100 km when driving on the motorway at approx. 120 km/h. Based on NEDC figures, this corresponds to a CO2 reduction of one gram per kilometre. With a Cd value of 0.27 and a frontal area of 2.20 m2, the drag area (CdA) is less than 0.6 m2 – a benchmark figure for hatchback vehicles in this segment.
The detailed work behind this development is highlighted by the following examples:
- The distinctive side spoilers next to the rear window ("finlets") help to create a run-on design which significantly reduces the disruptive longitudinal vortices generated at the D-pillars.
- Flow losses at the front wheel arches have been reduced substantially with the aid of patented serrated wheel spoilers at front and rear, slots in the wheel arches and optimised hub caps. These measures result in improved wind flow around the wheel arches.
- The A-Class has an adjustable radiator shutter, already familiar in larger model series. The louvres behind the radiator grille are for the most part closed when there is no specific need for cooling air.
- The underbody has also been aerodynamically enhanced: the main floor panel features extensive cladding up to the rear wheel arch, followed by additional cladding of the rear axle. The rear silencer has also undergone aerodynamic optimisation.
- The new A-Class features exterior mirrors which have been optimised in terms of a number of details and already proven their excellent aerodynamic properties in large model series such as the S, E and C-Class, and also the B-Class. The position of the exterior mirror is adjusted in respect of the A-pillar in such a way that the airflow is directed along the side window without any significant interference or disruption.
The exterior mirrors and the low stepped height of the A-pillars reflect the fact that the work conducted in the wind tunnel was not just about optimising the flow conditions, but also about minimising wind noise. And in addition to aerodynamics and aeroacoustics, there is often another discipline to consider: in terms of water management too, the flow around the exterior mirrors and the A-pillars also has to be optimised in the wind tunnel in order to guarantee good visibility is maintained towards the rear and at the sides during wet weather.
More than with previous model series, in the case of the A-Class the aerodynamics experts at Mercedes-Benz made particular use of flow simulation (CFD, Computational Fluid Dynamics): each component was first improved over several cycles using flow simulation before having its aerodynamic properties put to the test in the wind tunnel.
Digital flow simulation is based on so-called finite volumes as a mathematical model. A volume net is formed from around 60 million hexahedrons, or cubes, and is based around the CAD data of the new A-Class. This enables the driving cycle to be simulated over a free area in a large virtual wind tunnel. The Mercedes engineers generate the airflow using a predetermined turbulence level.
Setting new standards in terms of Cd value and consumption: BlueEFFICIENCY Edition
Due to follow later is the A 180 CDI BlueEFFICIENCY Edition boasting even better consumption levels. It is among the most efficient vehicles of its class: thanks to a series of additional aerodynamic optimisation measures, it has been possible to reduce its Cd value from 0.27 (standard model) to 0.26.
These measures include:
- partially covering the upper part of the radiator grille
- aerodynamically shaped spring link coverings to improve the underbody airflow at the rear axle
- lowering of the suspension by 15 mm
This post has been edited by IRONICK: 13 Jul 2012, 22:32
post 30 Jul 2012, 16:33
Post #557
CFD analysis of a Saab 9-3
post 5 Aug 2012, 22:29
Post #558
This post has been edited by IRONICK: 5 Aug 2012, 22:29
Squirrel
post 8 Aug 2012, 08:35
Post #559
Captain of Black Pearl™…
Buburuza are un Cx mult mai mic (0,35 față de 0,42 la Duster) la o formă oarecum similară…Nu iau în calcul suprafața (2,0 m² față de 2,42 m²).
Sursa
Dacia Duster - RO 44 AWD 2010 1,6 16v 4Ś4 Laureaté Noir Nacré
Fire, walk with me...in 4 strokes, water cooled.
post 8 Aug 2012, 08:56
Post #560
QUOTE(Squirrel @ 8 Aug 2012, 09:35)
Dar liftul negativ nu il iei in calcul?
Squirrel
post 9 Aug 2012, 10:33
Post #561
La cum arată pe dedesubt, câteodată mă mir cum am trecut iarna ca neb1'…
LE: A fost plimbat prin nămeți peste garda la sol, ceea ce nu făceam cu berlina…Poate că spoiler-ul față și scutul motor mai presează zăpada, însă jumătatea spate are destule „puncte de ancorare”…
This post has been edited by Squirrel: 10 Aug 2012, 09:31
post 9 Aug 2012, 10:45
Post #562
Chiar ma mir cum a reusit lumea sa se descurce iarna pana a aparut Dusterul.
marius80_eugen
post 10 Aug 2012, 08:41
Post #563
"A aparut SUV-ul Duster de la Dacia si in Germania.
…Intr-un showroom doi nemti priveau jeep-ul.
Unul ii spune celuilalt…
- Romanii astia ….ar face ORICE doar sa nu-si repare drumurile…!!!! "
Iarna trecuta oamenii nici nu au iesit din casa ... au dat si al TV.
Iulikk
post 10 Aug 2012, 14:31
Post #564
Fost Membru Solenzar
Bancu' asta e aparut inainte sa iasa prafsteru...
Autoturism visiniu - CT ?? XXX cu roti
Squirrel
post 30 Aug 2012, 07:46
Post #565
Apropo de aerodinamica:
post 1 Oct 2012, 16:12
Post #566
Ampt
post 3 Oct 2012, 16:01
Post #567
Oare unde am mai văzut inserțiile de crom pe nervurile de la masca față ?
post 4 Oct 2012, 11:02
Post #568
Clio 4
post 8 Oct 2012, 10:55
Post #569
Mazda 6 Sedan
9 Oct 2012, 10:45:
9 Oct 2012, 10:50:
This post has been edited by IRONICK: 9 Oct 2012, 09:50
P-A-C-O
post 11 Oct 2012, 18:43
Post #570
Ampt
post 30 Oct 2012, 17:21
Post #571
Modificări Eco la noile generații Logan, respectiv Sandero ?
Oare s-o fi îmbunătățit Cx-ul ?
bad_hrc
post 7 Nov 2012, 22:27
Post #572
Am citit tot topicul si vad ca nu a gasit nimeni o metoda buna si sigura de a monta deflectoarele originale dacia. Eu am ph2 din 2009 si as vrea sa imi montez deflectoarele de la rotile din spate. Oare merg lipite doua tije filetate cu bison epoxy metal sau ceva asemanator pe interiorul aripii? Prelungirea aceea pentru bara se monteaza usor dar deflectoarele de la rezervor si roti trebuiesc prinse cumva si nu m-as apuca sa sudez, cu toate ca asta ar fi ce-a mai buna solutie.
Dacia Logan 2009 Laureat 1.6MPI
andreig1982
post 8 Nov 2012, 06:22
Post #573
QUOTE(IRONICK @ 29 Jun 2010, 20:50)
"Tijele alea filetate" chiar nu au legatura cu deflectorul de pe spoiler, ci cu deflectoartele de la roti.
Ele se pot monta oricand, se numesc nituri etanse (6.4mm) si se prind cu cleste de nit "doua maini". Dupa prinderea lor se da cu impresie fosfatanta si nu mai este nici o problema cu apa.
Referitor la lipitura, sunt convins ca exista cineva acolo care totusi se pricepe si ii da prin cap ca se pot prinde cu o platbanda de surubul de la punte ...
Dacia Logan Ambition - B-06-xxx 2005
bad_hrc
post 8 Nov 2012, 09:41
Post #574
Pai s-au specificat niste nituri filetate, doar ca sunt foarte scumpe la reprezentanta si nu se gasesc decat pe la ei.
post 8 Nov 2012, 10:18
Post #575
Atunci alege solutia 2, cea pe care am adoptat-o si eu.
P-A-C-O
post 26 Nov 2012, 21:23
Post #576
GBi
post 27 Nov 2012, 09:36
Post #577
super calumea inchisa blush.gif , ce brand este
Daciaaa Golan :)) KissFM 1.6 08 / ex. Laureate 1.4 04
Tot ce e bun tre' sa dispara !
andreig1982
post 27 Nov 2012, 10:25
Post #578
honda insight
a fost un fel de demo car in care au imbunatatit aeordinamica, au schimbat diverse componente cu unele facute din CFRP
post 27 Nov 2012, 10:30
Post #579
http://green.autoblog.com/2012/08/06/2013-...e-review-video/
The aero tweaks give the RAV4 EV a cD of .30, which Toyota points out is more like a sedan than your average CUV.
All of the exterior's zero-emission chrome doesn't hide the fact that this is still a RAV4, it's just that this is a significantly more aerodynamic RAV4. Those mirrors, for example, are styled after the Camry that's sold in Korea and reduce the coefficient of drag by 1.1 percent. The rear spoiler? A 2.5-percent improvement. The smoother underbody, which is possible thanks to there being a battery there instead of a lot of mufflers and whatnot? An 8.2-percent improvement. All together, the aero tweaks give the RAV4 EV a cD of .30, which Toyota points out is more like a sedan than your average CUV. When asked why these sorts of little improvements were not added to the gas-burning RAV4, Toyota's Sheldon Brown, the executive program manager in the TTC's PDO department, said that it's not so simple. The underbody panels, for example, didn't need to be designed to deal with a hot exhaust pipe and so you can't just use the same plastic and shape on the ICE RAV4. The mirrors and rear spoilers, though? Those seem easy enough to use no matter what the powertrain, so we'll keep our eyes open when the new model appears.
This post has been edited by IRONICK: 27 Nov 2012, 10:31
marian_ariciuc
post 14 Jan 2013, 21:06
Post #580
User
IRONICK....dormi?
n-am vazut poze cu deflectoarele rotilor fata care le-ai bricolat...te duci sa le pozezi?
ma gandeam sa bricolez si eu dar vreau o forma, o dimensiune...
ca sa nu mai zic ca vreau si ce e in #337...
DACIA Logan 1.6 16V E5
Vand modul inteligent de geam pentru logan 1 si 2 si alte...
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 4th August 2025 - 02:46
