Robert's DACIA 1310 <B-34-SGM>, Incredibil ! are chiar si turbina!
yknot |
#271
![]() just turbo Group: Members Posts: 226 Joined: 29 September 04 From: Braila ![]() |
volvo
480 turbo
1990 ex. owner r5 GTT
B-34-SGM |
#272
![]() Membru de partid Group: Members Posts: 1.397 Joined: 16 February 04 From: Drumul Taberei Customs ![]() |
Iar ne tinem de prostii.
Chelioasele nu sunt de vanzare ![]() Observati tabla de la ambreiaj, gaurita pt aerisirea volantei. Nu stiu daca batranii procedau la fel ![]() This post has been edited by B-34-SGM: 19 May 2006, 19:51 Attached thumbnail(s) Imag054.jpg ( Size: 79.81k ) Number of downloads: 1054 Imag051.jpg ( Size: 35.07k ) Number of downloads: 1059 Image_17_.jpg ( Size: 119.04k ) Number of downloads: 1036 Imag042a.jpg ( Size: 42.49k ) Number of downloads: 1054 Imag023g.jpg ( Size: 29.69k ) Number of downloads: 1002 |
1310 RACING
1991 full fara piele
- B 34 SGM www.prelucrariSIRA2000.ro
Ciumonk |
#273
![]() EPURUL UCIGAS Group: Members Posts: 429 Joined: 10 April 04 From: Oradea ![]() |
Sudura WIG/TIG......undeee????
Fiat 500,Fiat 600
`64 Fiat 600 VTM,
`65 VW 1200
- BH-xx-xxx;BH-xx-xxx
AAlpine1 |
#274
![]() Nothing Beats Cubic Inches !!! Group: Members Posts: 833 Joined: 7 February 04 From: Drumul Taberei Customs ![]() |
oare ce poate sa fie asta ??? o baie de ulei cum aveau batranii ??? |
. 929y
B-34-SGM |
#275
Ce baie misto! ma intreb a cui o fi? E din aia cu antival, folosita de batrani in urcarile pe coasta? Parca este si mai mare, bagi 4 litrii de ulei in loc de 3!Este incredibil!
This post has been edited by B-34-SGM: 20 May 2006, 01:59 |
1310 RACING
B-34-SGM |
#276
Multumiri LuKaS pt animatie!
Attached thumbnail(s) sgm4mn.gif ( Size: 489.6k ) Number of downloads: 846 |
1310 RACING
madmaxtata |
#277
![]() Membru autentic Group: Members Posts: 305 Joined: 26 October 05 From: focsani-bucuresti ![]() |
intrebare: de ce scrie diesel???
dacia 1310
dacia 1310
88
- vn-01-slk
Mario_b |
#278
![]() Membru Simplu Group: Members Posts: 625 Joined: 9 December 04 From: Craiova+Sibiu ![]() |
Ca facea ca dieselul mai: scotea fum mult !!
'05 Dacia
Logan 1,6
Ambition
- MBM War is peace. Freedom is Slavery. Ignorance is Strength.
--->Logan Tuning Club Craiova<--- |
B-34-SGM |
#279
Am pus cu diesel sa rad un pic de aberatiile pe care le scoteau unii "cunoscatori"
1310 RACING
madmaxtata |
#280
sal robert, mai primiti in vizita pe la atelier ca daca da ce spui de-o vizita? dar tre sa imi explici si unde si cum ajung, eu stau in regie.
dacia 1310
dacia 1310
88
- vn-01-slk
Ciumonk |
#281
Am una mica intrebare: Cam cat ai consumat tu in oras cu orizontalele(banuiesc ca erau Weber DCOE 40<sau 45>)cand era aspirat?Si cu ce venturi si ce jetari?
Fiat 500,Fiat 600
`64 Fiat 600 VTM,
`65 VW 1200
B-34-SGM |
#282
Nu am atelier, am garajul meu proprietate personala,unde imi tin si repar masina,la parter de bloc, in Dr Taberei.
0723700779 daca vrei sa faci o vizita. Sa vii imbracat de scandal, sa ma ajuti sa arunc motorul pe masina ![]() Aveam dellorto DHLA 40. consuma 10 in oras cu jetarile facute ca la carte. Valorile jetarilor nu pot sa le dau. Las teoreticienii sa te sfatuiasca, ca ei "stie" cel mai bine! This post has been edited by B-34-SGM: 22 May 2006, 18:29 |
1310 RACING
amc |
#283
![]() 2 trancane Group: Members Posts: 603 Joined: 28 November 05 From: Bucuresti ![]() |
Valorile corespunzatoare le gasesti pe net!
YUGO
Zavzta
2007/prestige
- 1-B-NU-IS--chhh
B-34-SGM |
#284
Vezi ca sunt multi parametrii care influenteaza.
Lungimea galeriei de admisie, forma galeriei de admisie, tipul axei cu came, cilindreea motorului, raportul de comprimare, avansurile aprinderii , AFR-ul. Recomand teste cu sarcina la roti, pe dinamometru cu frana. Deja am zis prea multe,pt multi care nu merita sa stie ceva. |
1310 RACING
payty |
#285
eu am un programel de pe net care indica ce jetari sa iti faci la carburatoare weber si dellorto. Banuiesc ca stii de el. Sunt ok valorile pe care le indica?
1996 1.6/2002 1.4
Ciumonk |
#286
Sau daca nu am acces la dyno le testez la turatii diferite,constante,si evaluez bujiile.Stiu,nu este o metoda stiintifica,dar atat pot sa fac deocamdata.Stiu ca nu am cum sa setez foarte bine suprapunerile jet-urilor,dar asta este.
Fiat 500,Fiat 600
`64 Fiat 600 VTM,
`65 VW 1200
#287
![]() fan Dacia Group: Members Posts: 21.667 Joined: 12 November 05 From: Bucuresti ![]() |
Exista niste baieti (unii cu dinamometru de sasiu cu frana, nu dam nume ) care vand un lambda-metru. Sau sudezi o piulita in galeria de evacuare, insurubezi un traductor de oxigen (_aka sonda lambda) si-l conectezi la un multimetru setat pe masurat voltaj. Exista un grafic care i-ti spune cum e amestecul in functie de valoarea citita pe voltmetru. Si asta poti face pe drum.
- negru pe alb
SiloS |
#288
![]() Gangester Group: Members Posts: 4.298 Joined: 23 February 04 From: Buzau ![]() |
Adica afr .
BMW
E30 325i 2003 BMW Z4
B-34-SGM |
#289
Din ce am scris,unul care se pricepe cat de cat poate citii printre randuri
![]() Repet. Cine vrea sa faca ceva, il ajut. This post has been edited by B-34-SGM: 23 May 2006, 00:49 |
1310 RACING
AAlpine1 |
#290
prog de pe net de jetat carburi e foarte bun pt un punct de plecare !!! dupa ce val iti da acolo in funct de ceea ce vrei incepi si te joci cu dif de aer , jiglere etc . (nu faceti dif de aer la strung in bataie de joc pt ca nu o sa mearga bine motoru pastrati forma originala a dif. de aer).
. 929y
AAlpine1 |
#291
1.6, axa de 280, 4 carb dellorto dhla40 (motor r5 alpine, aprindere electronica cu senzor la volanta, 5 trepte )
consum eco 11% mers in oras consum sport 15-30% mers in oras consum eco 7-8% mers afara (100-120) consum sport 10-15% mers afara (140-210) |
. 929y
B-34-SGM |
#292
1310 RACING
ydaniel |
#293
e chiar faina animatia>vreau mai mult:)
Oriunde,
oricand...
Cand esti rau ,nu te uita! |
payty |
#294
QUOTE(AAlpine1 @ 23 May 2006, 02:18) 1.6, axa de 280, 4 carb dellorto dhla40 (motor r5 alpine, aprindere electronica cu senzor la volanta, 5 trepte ) consum eco 11% mers in oras consum sport 15-30% mers in oras consum eco 7-8% mers afara (100-120) consum sport 10-15% mers afara (140-210) ce difuzoare ai la ele? |
1996 1.6/2002 1.4
ROBY 06-TFA |
#295
![]() Membru autentic Group: Members Posts: 652 Joined: 9 April 05 From: BRASOV ![]() |
QUOTE(B-34-SGM @ 23 May 2006, 02:42) Robert,sa inteleg de aici ca Stefan Vasile este un mentor pentru tine?El este unul dintre BATRANII care alergau la coasta odata si in acelasi timp un om din spatele scenei?In acea animatie apar aproape toate masinile pe care a concurat!Mai putin Sportiva lui Grigoras. |
1310tlx/Logan1.6mpi/Sport 2000
1988/2007/1986
- bv 06 tfa/bv xx ara/
B-34-SGM |
#296
e si a lui nea Nicu Grigoras, vazuta din profil. Eu i-am dat foarte multe poze lui LukaS, parese ca astea i-au placut cel mai mult. Mai lipsea nova lui nea Stefan Vasile, sa fie suita completa.
This post has been edited by B-34-SGM: 23 May 2006, 09:49 |
1310 RACING
danS22 |
#297
![]() Membru autentic Group: Members Posts: 623 Joined: 14 February 06 ![]() |
SGM ,am o intrebare pt tine,stiu ca e departe Oradea de Bucuresti ,in 4 iunie va fi un show auto organizat de 4tunning ,nu vei participa si tu?pt ca pe aici prin oradea baietii si au cam luat lumea in cap cu tunnigul auto,si ar trebui sa le cam dai niste lectii si pe pista si la mecanica....asa ca te am astepta cu mult entuziasm!!
dacia,vw scirocco
gt,kr,Li
1984,1988,2001
- bh... Dacia1300('82),Vw Scirocco Gli MK1 ('79),Vw Scirocco Gt MK2 ('84)Dacia 1410 ('01)
B-34-SGM |
#298
Imi pare rau, dar nu pot sa vin.
1310 RACING
madmaxtata |
#299
ce-ai facut robert ai pus motoru ca ai zis ca vrei sa te ajut. dar pana la motor pot sa vin sa mai trag si eu cu ochiu la putina mecanica, si-asa mai am putin si intr-un in practica. ce spui? am incercat sa iti trimit un pm dar nu merge
dacia 1310
dacia 1310
88
- vn-01-slk
ydaniel |
#300
tare mutl imi place baia de ulei cu deflector:) nu faceti si pe comanda speciala.?vb serios.dau comanda la DT customs:)
Oriunde,
oricand...
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 24th July 2025 - 01:40 |
