127 Pages « < 51 52 53 54 55 > »
> Pneuri Logan, pneu = anvelopa pentru cine nu stie
dl_dr25
post 24 May 2009, 19:26
Post #1561
Le iau de la un prieten care le "aduce" de la munca. Sunt roti de rezerva noi noute.
dacia logan 2007 dci - B
aladin79
post 26 May 2009, 10:52
Post #1562
cauciucurile care au inscriptionat pe ele M+S...sunt de iarna sau mixte??...ca mam contrazis cu unu
dacia logan laureat 2005 berlina
BoboM
post 26 May 2009, 14:37
Post #1563
Megane 1.4 16v
cris06
post 26 May 2009, 15:12
Post #1564
Mester
Te contrazic! Sunt de iarna> Iata si un argument (citat din "The car bibles"):
"Performance tyres or summer tyres
Performance tyres are designed for faster cars or for people who prefer to drive harder than the average consumer. They typically put performance and grip ahead of longevity by using a softer rubber compound. Tread block design is normally biased towards outright grip rather than the ability to pump water out of the way on a wet road. The extreme example of performance tyres are "slicks" used in motor racing, so-called because they have no tread at all.
All-round or all-season tyres
These tyres are what you'll typically find on every production car that comes out of a factory. They're designed to be a compromise between grip, performance, longevity, noise and wet-weather safety. For increased tyre life, they are made with a harder rubber compound, which sacrifices outright grip and cornering performance. For 90% of the world's drivers, this isn't an issue. The tread block design is normally a compromise between quiet running and water dispersion - the tyre should not be too noisy in normal use but should work fairly well in downpours and on wet roads. All-season tyres are neither excellent dry-weather, nor excellent wet-weather tyres, but are, at best, a compromise.
Wet-weather tyres
Rather than use an even harder rubber compound than all-season tyres, wet weather tyres actually use a softer compound than performance tyres. The rubber needs to heat up quicker in cold or wet conditions and needs to have as much mechanical grip as possible. They'll normally also have a lot more siping to try to disperse water from the contact patch. Aquachannel tyres are a subset of winter or wet-weather tyres and I have a little section on them further down the page.
Snow & mud or ice : special winter tyres
Winter tyres come at the other end of the spectrum to performance tyres, obviously. They're designed to work well in wintery conditions with snow and ice on the roads. Winter tyres typically have larger, and thus noiser tread block patterns. In extreme climates, true snow tyres have tiny metal studs fabricated into the tread for biting into the snow and ice. The downside of this is that they are incredibly noisy on dry roads and wear out both the tyre and the road surface extremely quickly if driven in the dry. Mud & snow tyres typically either have 'M&S' stamped on the tyre sidewall. Snow & Ice tyres have a snowflake symbol.
All-terrain tyres
All-terrain tyres are typically used on SUVs and light trucks. They are larger tyres with stiffer sidewalls and bigger tread block patterns. The larger tread block means the tyres are very noisy on normal roads but grip loose sand and dirt very well when you take the car or truck off-road. As well as the noise, the larger tread block pattern means less tyre surface in contact with the road. The rubber compound used in these tyres is normally middle-of-the-road - neither soft nor hard.
Mud tyres
At the extreme end of the all-terrain tyre classification are mud tyres. These have massive, super-chunky tread blocks and really shouldn't ever be driven anywhere other than loose mud and dirt. The tread sometimes doesn't even come in blocks any more but looks more like paddles built in to the tyre carcass".
Scuze de lungimea postului dar poate fi folositor.
Daewoo TF19Y Cielo Exe Plus, E3/ GPL BRC 24-11 SEQ/ 2006 - IS.06.---
madalinchiorpec
post 5 Jun 2009, 16:41
Post #1565
A avut cineva anvelope Fulda EcoControl?Am intrat pe site-ul www.tyretest.com si mi se par destul de bune,chiar mai bune decat Continental EcoContact3 si sunt si mai ieftine.Ce credeti?
Renault Clio Life Evo 2019
ciush
post 12 Jun 2009, 20:59
Post #1566
www.cauciucuridirect.ro poate ajuta
transportul e inclus in pret, se pot returna!
dacia logan 1.4 Mpi 2005 laureate - TM 10 ***
Cand ai incercat totul si nimic nu a mers, citeste instructiunile de folosire
slider2
post 12 Jun 2009, 21:50
Post #1567
doar membru si atat
nu stiu daca ai voie sa pui link-ul ala, s-ar putea considera reclama. oricum respectiva firma are niste preturi astronomice. de exemplu kleber (care stim toti cate de calitative (nu) sunt) pentru masina din semnatura mea (185/60/R15) sunt 328ron/bucata. blink.gif blink.gif blink.gif
asta in conditiile in care michelin-uri aceeasi dimensiune sunt 340ron/bucata, iar goodyear, continental, dunlop gasesti in jur de 270ron.
This post has been edited by slider2: 12 Jun 2009, 21:51
symboala neagra 2008
ciush
post 13 Jun 2009, 09:29
Post #1568
eu n-am nici o legatura cu respectivul link, am vazut ca la majoritatea cauciucurilor au teste si isi poate face lumea o idee despre calitatea pneurilor (eu sincer nici nu ma gandesc sa cumpar produse cu plata in avans)
p_alecs
post 14 Jun 2009, 11:32
Post #1569
Preturile sunt foarte mari
Dacia Logan 2006 1.5 DCI - ro-01-gem
mykissfm
post 22 Jun 2009, 12:02
Post #1570
biggrin.gif pentru einstein984 si fixxer ,michellinu-rile care le am avut eu pe masina erau fabricate in romania si asta spune tot,si ce nu va vine sa credeti ca si la case mari se fac lucruri proaste,nu sunt singurul patit,iar cat priveste ambreiajul se poate rupe si la o frana de motor asa ca problema nu este intre pedale si volan,loganul nu e prima mea masina cum este pentru alti.
asa ca aveti grija cu ambreiajul sa-l calcati cu grija.
Nissan Dacia Qashqai /Sandero
concurent
post 15 Jul 2009, 14:20
Post #1571
[quote=florinvfd,15 Dec 2008, 08:23]
Confirm ca Michelin sunt cauciucuri bune! Aveam Kormoran...care oricum se cam tocisera, iar cand am pus Michelin Energy s-a schimbat total masina. La un demaraj mai in forta...nu mai patineaza rotile asa tare, pe ploaie am MAI MULTA siguranta si bineinteles in curbe se comporta altfel, nu mai imi da senzatia ca s-ar duce in lateral.
[quote]
Poti sa-mi spui daca ai schimbat amortizoare + arcuri si numarul de km sau calitatile enuntate se pastraza cu piesele din fabrica? Zgomotul de rulare cum e?
Inca mai am kormoran cu 72 mii km si nu prea ma mai simt in siguranta decat sub 80km/h
This post has been edited by concurent: 15 Jul 2009, 14:21
Dacia Logan 1.5 DCI 2006
Kojak
post 15 Jul 2009, 14:29
Post #1572
QUOTE(concurent @ 15 Jul 2009, 15:20)
Adica ai bani de motorina, de mers jdamii de km, da' nu ai bani de niste caucioace decente care sa nu pushte la 80km/h+? excl.gif
This post has been edited by Kojak: 15 Jul 2009, 14:33
Dacia Logan 2006
TheGreatBabanu
post 15 Jul 2009, 17:32
Post #1573
subscriu la Kojak.
Dacia Sport-Sold :( Opel Corsa B - Swing 1988/1994 - IF 23 TGB / B 23 TGB
It's not about speed, It's about technique
dl_dr25
post 15 Jul 2009, 20:43
Post #1574
vreau sa pun pe masina 195/60/15
1. merg pe jentile din fabrica? (modelul 2 de aliaj )
2.la viteza de deplasare cam care ar fi direrentele?
3. cistig in stabilitate, la curbe plecari si altele ...?
4. pot aparea probleme la capete bara, caseta si restul de piesulici??
concurent
post 16 Jul 2009, 12:50
Post #1575
QUOTE(Kojak @ 15 Jul 2009, 12:29)
Nu bravez pe sosele pentru ca stiu ce dotari am. Dupa felul in care puneti problema, inseamna ca si carutele sunt periculoase din cauza cauciucurilor folosite.
Ideea e ca nu mai am incredere in materialul propriuzis (crapaturi care pot ceda) chiar daca uzura este uniforma si nu prezinta umflaturi (la propriu smile.gif )
Revin cu poze mai tarziu si vei vedea ca se mai poate merge cu profilul de rulare.
Referitor la banii de motorina: am stiut ce masina cumpar si am acceptat calitatile fara a dori sa le schimb, astfel am reusit sa folosesc difernta de bani pentru consumul de motorina.
Stii si tu foarte bina ca langa o masina scumpa, puternica si dotata, poti oricand sa pui una si mai si... Conteaza sa stii ce vrei.
Si totusi, curiozitatea ramane nesatisfacuta. Poate mai trece pe aici sa-mi raspunde.
This post has been edited by concurent: 16 Jul 2009, 12:56
post 16 Jul 2009, 12:55
Post #1576
QUOTE(dl_dr25 @ 15 Jul 2009, 21:43)
1. da
2 . VEzi AICI
3stabilitate mai mare, se tine mai bine pe viraje
4. Nu prea.
Andy_ACS
post 16 Jul 2009, 13:14
Post #1577
Yes, I'm not!
Singura problema care poate aparea este ca o sa ramai fara certificatul de inmatriculare in caz ca te prinde garcea cu ele. Si de asemenea nu treci ITP-ul cu ele.
Bafta!
vijelie
post 16 Jul 2009, 13:15
Post #1578
membru violet
Pe noul tip de certificat nu mai sunt inscrise dimensiunile anvelopelor. cool.gif
post 16 Jul 2009, 13:19
Post #1579
Da, dar scrie pe usa masinii! oricum, nu era printre intrebarile adresate mai sus, ma gandeam ca stie si el asta.
Tovarasul tau e camionagiu si transporta Fiaturi? Sau de unde ia rotile alea?
slider2
post 16 Jul 2009, 13:26
Post #1580
doar membru si atat
QUOTE(concurent @ 15 Jul 2009, 14:20)
scuza-ma dar eu cu kormorane nu m-as simti in singurata nici daca ar fi nou-noute si masina ar sta pe loc.
nici nu vreau sa ma gandesc cum arata anvelopele alea la 72000km, mai ales stiind ce calitative (nu) sunt. am avut si eu michelin-uri care au dus pe fata 60000km si 80000km pe spate (mers cu ele vara si iarna), dar alea erau michelin-uri (made in france), nu kormorane...
iar la vreo 4 ani oricata "carne" ar mai avea pe ele anvelopele e recomandat sa le schimbi pentru ca imbatraneste cauciucul, se intareste, se crapa...
ar fi culmea ca Doamne fereste maine poimaine, sa-l pupi pe unul in fund cu masina, si sa zici ca loganul are frane proaste...
This post has been edited by slider2: 16 Jul 2009, 13:29
vijelie
post 16 Jul 2009, 13:34
Post #1581
membru violet
Daca nu te simti in siguranta, mergi mai prudent, pana cand prinzi senzatia. wink.gif
concurent
post 16 Jul 2009, 16:05
Post #1582
QUOTE(Andy_ACS @ 16 Jul 2009, 11:14)
Bafta!
Garcea nu are ce sa spuna pentru ca semnul indicator este neatins la cauciucuriele din fata, care au fost pe spate pana la 60 mii km ... poate la cele de pe spate sa comenteze, sper sa nu aiba exces de zel cu mine
ITP-ul l-am facut in 2008 cand masina avea aprox 60 mii km
QUOTE(slider2 @ 16 Jul 2009, 11:26)
nici nu vreau sa ma gandesc cum arata anvelopele alea la 72000km, ... si sa zici ca loganul are frane proaste...
nici eu nu m-am simtit in siguranta la 160km/h nici cand au fost noi insa m-am simtit la 120-130km/h... acum maxim 80-90 km/h
cand a fost nou chiar am spus ca are frane proaste, mai tarziu am inteles ca la asta contribuie si calitatea cauciucului
QUOTE(vijelie @ 16 Jul 2009, 11:34)
sunt obligat s-o fac chiar si cu super cauciucuri... n-am prins ideea cu senzatia
Kojak
post 16 Jul 2009, 18:37
Post #1583
[quote=concurent]
Tati, hai sa-ti povestesc: si eu am tinut minunatiile alea de kormorane aproape 50000km, adica aprox. 1 an juma - 2, rulate la greu printre altele si la viteze constante de top biggrin.gif (160 - 170km/h). excl.gif
Si la fel ca si tine eram f. mandru de cat de multa carne mai aveau pe ele (desi erau rigide ca dreq), ce sa mai o minunatie de gume. biggrin.gif
In fine, cum ziceam pe la 50000km m-am hotarat sa le schimb (toate 4) cu niste michelinuri energy saver (made in france) cu un bujet de cca. 11mil.
Daca initial m-a intepat oleaca pipota ptr. cash-ul spart, ulterior n-am regretat si nu regret absolut deloc alegerea facuta, NU exista comparatie, parca e alta masina. smile.gif
Demaraj, silentiozitate la rulaj la viteze mari, tinuta de drum si nu in ultimul rand frane mult mai eficiente, ce sa mai alta viata, pe bune.
Intr-un cuvant: SIGURANTA (atat a ta cat si a celorlalti)
Sper ca ai prins ideea wink.gif si schimbi dreq (pana nu e prea tarziu) cirucurile alea de gume cu unele decente, pana in 10mil / toate 4buc. gasesti o gramada de marci ok.
Bafta, ca succesu-i asigurat!
This post has been edited by Kojak: 16 Jul 2009, 18:38
Dacia Logan 2006
concurent
post 17 Jul 2009, 01:02
Post #1584
[quote=Kojak,16 Jul 2009, 16:37]
[quote=concurent]
Tati, hai sa-ti povestesc: ... Demaraj, silentiozitate la rulaj la viteze mari, tinuta de drum si nu in ultimul rand frane mult mai eficiente, ce sa mai alta viata, pe bune.
[/quote]
Sa traiesti!
Asta am vrut sa citesc ca de schimbat sunt hotarat... n-am stiut ce sa aleg.
Daca ai timp, chef si placere dau o berica in Dr. Taberei (chiar si-n fuga calului).
dl_dr25
post 17 Jul 2009, 19:33
Post #1585
cu garcea o combin nu este o problema deloc.
la itp o sa ma duc cu un rind regulamentar ( al meu de iarna sau imprumutat )
dar problema mea mare este sa cistig in stabilitate, frinare si sa nu omor articulatiile ( tot o ard cu stabilitate si frinare fiindca nu am abs si lam intepat pe unul pe la cringasi in iarna happy.gif
revin cu asta care ma baga in ceata http://www.wheelsmaster.com/rt_specs.jsp imi pare mie sau latimea este mai mica la 195/60/15???
This post has been edited by dl_dr25: 17 Jul 2009, 19:36
slider2
post 17 Jul 2009, 20:20
Post #1586
doar membru si atat
185/65/R15:
- diametru total 310.75mm
- circumferinta 1952.5mm
195/60/R15
- diametru total 307.5mm
- circumferinta 1932.8mm
195/55/R16
- diametru total 310.45mm
- circumferinta 1950.61mm
eu as merge pe ultima dimensiune, fiind mult mai apropiata de cea originala, singurul impediment ar fi faptul ca trebuie sa schimbi si jantele.
dl_dr25
post 17 Jul 2009, 20:30
Post #1587
dar nici la cele alese de mine nu este o asa mare diferenta, la ce propui tu ma baga la cheltuieli mai mari. multam
fictiv2004
post 17 Jul 2009, 21:49
Post #1588
[quote=dl_dr25,15 Jul 2009, 21:43]
vreau sa pun pe masina 195/60/15.....
doua exemple, atat: 1. turist bucuros, venit la mare, filtru RAR, ramas fara talon. 2. masina burdusita cu vizitatori programati in EU, intorsi la frontiera de politia de frontiera pe motiv de caucioace... Sa vezi si sa nu crezi.. in Romania...
Si ptr. Concurent: presupun ca nu prea ai experienta la volan, altfel ai fi stiut ca toate anvelopele cu coeficient mic de uzura au in compozitie mult plastic- asa ca fugi ca dracu de tamaie cand auzi de anvelope care nu si-au facut viata la 45-50.000 km( mai sunt si cateva exceptii, da alea nu-s de buzunaru mediu obisnuit pe dacia); te sfatuiesc sa renunti la conceptiile invechite, si sa te adaptezi la actualitate... de cauciucuri de iarna banuiesc ca nici nu poate fi vorba... aaa , si zici ca Garcea nu are ce sa zica daca ai semnul de uzura in regula? iar esti copil: te anunt ca inspectorul RAR doar se uita la cauciucuri , si-ti salta talonul ptr. uzura daca vrea, legea il lasa; da-l in judecata, orice expertiza o sa-ti gaseasca fisuri-microfis.- taieturi in cauciucul tau dupa 2-3 ani.
This post has been edited by fictiv2004: 17 Jul 2009, 22:01
concurent
post 20 Jul 2009, 12:24
Post #1589
[quote=fictiv2004,17 Jul 2009, 19:49]
[/quote]
M-ai nimerit! Nu am deloc experienta in cauciucuri. Ma bucur ca au viata lunga si ma adaptez la conditii ... acum incep sa fiu interesat mult mai mult de siguranta, varsta isi spune cuvantul.
Nici la partea cu RAR nu te contrazic. E posibil orice si mai ales in Ro.
Ce parere aveti despre acest profil?
Avantaje / Dezavantaje in orice conditii
This post has been edited by concurent: 20 Jul 2009, 13:09
crising
post 20 Jul 2009, 13:56
Post #1590
Continental?
Mazda 6 2011 Combi 2.0 - TL31...
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 12th July 2025 - 15:27
