Prima revizie (1 An sau 15.000 km), informatii utile, experiente personale
juristul2000 |
#1051
![]() "Membru 20 cm record" Group: Members Posts: 793 Joined: 6 October 05 From: Oradea ![]() |
Laurate 2005
- AR-07-RZV 20% warn permanent!!!
decat sa...... mai bine nu!!!! NU, da spaga!!! |
Adrian78 |
#1052
![]() Membru autentic Group: Members Posts: 816 Joined: 24 April 06 From: Bucuresti ![]() |
Ce ulei ai luat pana la urma? Ai constatat modificari in comportamentul motorului (sunet, etc.)?
Logan Laureate
1.6
juristul2000 |
#1053
Revizia am facut-o la RND AUTO Oradea.(te lasa cu ulei,filtre de la tine).Pana la urma am luat Castrol Magnatec 5w-40 4l- 115 ron.
Revizia a costat 178 ron +20 ron la Nea mecanicu pt stimularea interesului.Atitudine ok servicii asisderea. |
Laurate 2005
danchitu86 |
#1054
![]() Membru cu BRB Group: Members Posts: 199 Joined: 24 September 05 From: Bucharest ![]() |
Am facut vinerea trecuta prima revizie la IPSO Otopeni, 270RON, multumit de cum m-au tratat.
Surprinzator azi m-au sunat pe mobil sa imi propuna un mic chestionar despre cat de satisfacut am fost de prestatia service-ului. ![]() |
Logan 1.4 MPI
Albastru Marin
2005 Laureate People's problem is not that they are mortal, but that they are suddenly mortal...
l@u |
#1055
QUOTE(juristul2000 @ 31 Oct 2006, 11:51) Revizia am facut-o la RND AUTO Oradea.(te lasa cu ulei,filtre de la tine).Pana la urma am luat Castrol Magnatec 5w-40 4l- 115 ron. Revizia a costat 178 ron +20 ron la Nea mecanicu pt stimularea interesului.Atitudine ok servicii asisderea. Salut, ai cumva DCI ptr. ca,, Magnatecu,,5W40 e ptr DCI. Ptr MPI e 10W40 ![]() |
Land Rover
Freelander
Td4, HSE
florinvfd |
#1056
![]() florinvfd Group: Members Posts: 163 Joined: 4 March 05 From: Bucuresti ![]() |
din cate stiu eu 5w40 indica anumite proprietati ale uleiului... (prima cifra indica cat e de subtire si la ce temperatura minima poate functiona motorul cu acel ulei)
http://en.wikipedia.org/wiki/Motor_oil#Multi-grade_motor_oil |
Logan 1.6 MPI
2006, Laureate bunul simt e cea mai buna regula de circulatie!
l@u |
#1057
QUOTE(florinvfd @ 8 Nov 2006, 02:15) din cate stiu eu 5w40 indica anumite proprietati ale uleiului... (prima cifra indica cat e de subtire si la ce temperatura minima poate functiona motorul cu acel ulei) http://en.wikipedia.org/wiki/Motor_oil#Multi-grade_motor_oil Ai f. mare dreptate dar Castrol Magnatec GTD 5W40 este NUMAI ptr diesel http://www.amiauto.ro/castrol/motor/gtdmpre.htm ![]() |
Land Rover
Freelander
Td4, HSE
florinvfd |
#1058
da..asa este, vad si eu.
eu am pus elf 5w40 si nu stiam ca la castrol, magnatec este doar pt diesel ![]() |
Logan 1.6 MPI
l@u |
#1059
Land Rover
Freelander
Td4, HSE
#1060
Magnatecurile GTD sunt pt diesel, iar cele GTX pentru benzina
l@u |
#1061
Land Rover
Freelander
Td4, HSE
juristul2000 |
#1062
Pai atunci inseamna ca am luat tapa si trebuie sa iau alt ulei.Da am o intrebare ce se poate intampla motorului meu cu acest ulei?A 2 intrebare cel care a facut schimbul de ulei e tampit?
PS: si 5w40 au mai bagat si altii e drept ca de la alte firme.Ce sa fac?Sa ma duc sa-l schimb iar? This post has been edited by juristul2000: 8 Nov 2006, 21:58 |
Laurate 2005
l@u |
#1063
QUOTE(juristul2000 @ 8 Nov 2006, 12:57) Pai atunci inseamna ca am luat tapa si trebuie sa iau alt ulei.Da am o intrebare ce se poate intampla motorului meu cu acest ulei?A 2 intrebare cel care a facut schimbul de ulei e tampit? PS: si 5w40 au mai bagat si altii e drept ca de la alte firme.Ce sa fac?Sa ma duc sa-l schimb iar? Salut,daca ai bagat in motor Castrol Magnatec GTD 5W40 http://www.amiauto.ro/castrol/motor/gtdmpre.htm si ai benzinar nu mai sta pe ganduri fugi repede si-l schimba!!!Daca vrei sa-ti pui tot Castrol atunci pune Castrol Magnatec GTX 10W40 dar daca vrei tot 5W40 iti recomand cam in aceeasi bani Aral High Tronic 5W40 http://www.amiauto.ro/aral/aralauto/hitrpre.htm care spre deosebire de Magnatecu 10W40 este sintetic deci mai bun. Confuzia apare datorita faptului ca alte firme (spre deosebire de Castrol)fac 5W40 si ptr. diesel si ptr. benzina Spre stiinta citeste manualele Dacia-ai sa te lamuresti si cum sta treaba cu uleiul(ce reprezinta prima cifra si a doua din denumirea uleiului).Acum catva timp nici eu nu stiam care e treaba dar deschizand un topic despre ulei am fost luat la ,,misto,,(acum imi dau seama ca mi-a prins bine)si m-am apucat de citit- manualele Dacia si acest topic care este fff. relevant in privinta tipurilor de ulei.Eu personal asa am facut si iti recomand si tie acest lucru+Aral High Tronic 5W40 pe care l-am cumparat si eu ptr. un schimb(intentionez sa schimb borsul din motor pe la 5000) ![]() |
Land Rover
Freelander
Td4, HSE
LC_TM |
#1064
Membru autentic Group: Members Posts: 269 Joined: 27 September 06 ![]() |
Revizie 10.054 km,
Locatie: AutoCardo Timisoara Costuri: -uleiul meu (Castrol Magnatec GTX3 10w40) 1.25 mil lei(Selgros,acuma e 1.36,la Real e 1.6 mil) - scuzati reclama ![]() - Filtru de ulei + "materiale auxiliare"(inca nu stiu care au fost) + manopera 850.000 lei vechi - Spaga deloc ptr ca n-am fost lasat sa stau langa masina ![]() Parere despre revizie?Omul care a facut-o a fost de treaba,dar nu si-a facut treaba prea bine,la verificari...a omis o galma in guma mea stanga fata,a fost descoperita de un angajat al unei vulcanizari,doar am luat un cui in roata.Ca urmare a drumurilor noastre bune si a socului de alaltaieri(luat o groapa mai adanca) am un cauciuc praf ![]() Tanti de la receptie s-a ratoit domnle la mine ca am intarziat,m-am uitat la ceas si apoi urat la ea si i-am zis ca sunt 10 minute intarziere,de parca e vina mea ca unu s-o rasturnat in intersectie cu camionul ![]() Destul de nemultumit pe tema cu "n-aveti voie langa masina in timpul reviziei",am stat si m-am uitat la masina de la vreo 25m distanta.....nu au facut decat strictul necesar.....nu a fost pusa la diagnosticare un pic...la verificarea parametrilor,nimic...dar banii au fost umflati!Ma mai au client 2 revizii,urmatoarele le fac eu la Lamco unde ii cunoaste tata pe mecanici si stau langa ei si nu fac ei glume cu mine.Cam de bataie de bajocura reviziile de genul asta "stati si asteptati afara pana termin". Numai bine! L. |
Nissan/ex. Dacia
Terrano II 2.7TDi/Logan
2004/2005 Ambition 1.6MPI
- TM-XX-XXX
florinmihai_73 |
#1065
Membru incepator Group: Members Posts: 8 Joined: 6 November 06 ![]() |
Azi am facut prima revizie la 1 an si 12 000 km ,practic in afara de schimbat ulei ,filtru de ulei si filtru de aer revizia a mai constat in strangerea suruburilor pe sub masina si la sugestia mea ungerea cablului de acceleratie.Recomand sa schimbati uleiul la 7500 km,eu nu am facut-o ca am mers mai mult in afara orasului dar vazand azi cu arata uleiul la 12 000 km mi-a parut rau ca nu l-am schimbat mai devreme.Unde am fost eu puteai sa ai ce ulei vrei,si la intrebarea pusa mecanicului ce ulei foloseste el raspunsul a fost castrol si il schimba la fiecare 10 000 km(avea si el tot logan )
2005 laureat
- B-07-MMF
florinmihai_73 |
#1066
Revin:manopera 65ron,si am fost lasat langa masina ,cel putin eu niciodata n-am sa accept sa nu stau langa masina.
2005 laureat
- B-07-MMF
Adrian78 |
#1067
La ce service te-au lasat langa masina?
Logan Laureate
1.6
Mich@el |
#1068
QUOTE(LC_TM @ 10 Nov 2006, 23:09) Revizie 10.054 km, Locatie: AutoCardo Timisoara Destul de nemultumit pe tema cu "n-aveti voie langa masina in timpul reviziei",am stat si m-am uitat la masina de la vreo 25m distanta....Cam de bataie de bajocura reviziile de genul asta "stati si asteptati afara pana termin". eu am facut revizia de 1 an la autocardo in luna mai si am stat chiar si sub masina cand era ridicata,nu am avut nici o problema,tipul care s-a ocupat de revizie chiar a fost amabil sa-mi explice tot ceea ce verifica pe acolo. |
Laureate 1.4
- TM-Marine Blue
LC_TM |
#1069
Ei uite ca pe mine nu m-au lasat decat 2 min sa vad ce am lovit sub ea si apoi valea ca n-ai voie langa ea,probabil arat a pustan de 18 ani si au zis ca ma expediaza ei asa repede si gata,au cam reusit,dar a 2-a oara nu se va mai intamplat,data viitoare vor sta cu usa de la garaj deschisa si eu ma voi uita de afara la ei.
Adaugare la revizie,sambata mi-am schimbat filtru de aer (MA1142) la 350.000 lei vechi,deci ca urmare toata revizia a fost 2.45 mil lei vechi,rezonabil as putea spune,dat fiind faptul ca am avut si o masina mai mica (swift) la care o revizie ma costa in jur de 5.5 mil de lei cu acelasi tip de ulei,dar mai scumpa decat la solenza la care prima revizie a fost 1.25 mil lei tot la autocardo. |
Nissan/ex. Dacia
- TM-XX-XXX
vijelie |
#1070
Revizie la Dacoserv Militari.
Desi nu am avut programare, nu a fost nici o problema. Nu am avut nimic de reclamat, da' nici ei nu au gasit ceva... Din prima m-au "invitat" langa si sub masina desi nu mi-am manifestat dorinta de a "supraveghea" operatiunile. Inlocuit filtru aer, filtru ulei, ulei (metoda gravitationala). Vaselina la suruburi (ocazie cu care au mai disparut din zgomotele "tehnologice" specifice marcii Dacia Logan), tras de roti. Total lovele: 130 RON (uleiul a fost "al meu", absolut nici o problema din partea lor) Total timp: 1h si 30min cu tot cu facturare, stampila etc. Pozitiv: dialog permanent tehnician-client, deloc zgarciti la vorba. Negativ: canci tehnologie necesara testarii CB, doar mecanica si inspectare vizuala sub elevator. Una peste alta, m-a lasat rece. |
Duster
2011 Laureate dCi
dunn |
#1071
Membru incepator Group: Members Posts: 12 Joined: 18 November 05 ![]() |
revizie 1 an si 13.300 km
auto cobalcescu ulei elf escelium 5w40 filtru ulei filtru aer completat antigel lichid parbriz nu au pus ca l-am umplut eu ![]() in masina am gasit filtru aer, filtru ulei, un rest de ulei, rest de la antigel 330 ron gata in 1h30min |
laureate 1.6
- b-xx-jex
GoGu |
#1072
Revizie de aproape un an si 12000km, Caremil Iasi
Nu se sta in service, se sta la un fel de terasa, la o cafea (iti dau o fisa, doua pt. automat, de la ei). Se poate urmari ce se intampla cu masina pe un televizor conectat la camerele din service. Din pacate masina mea era intr-un colt, ii vedeam doar jumatatea dreapta, din spate. Am vazut doar niste mogaldete ce apareau si dispareau pe acolo si ca au ridicat-o de 2 ori pe elevator. Ce am cerut: revizie, reglaj frana mana si reparatie lumina marsarier, plus sa se uite la puntea fata ca -sanchi- am auzit niste zgomote. cost total: 231,3 ron cu tva preturi fara tva: - ulei daciaoil 5w30 - bidon 4l - 84,33 ron - mi-au lasat bidonul cu ceva ulei pe fund, ce-i drept... - filtru ulei - 23.31 ron - filtru aer - 45.14 ron - pe ala vechi mi l-au dat inapoi - contactor marsarier - moca, garantie - manopera - 40.59 ron Mi-au reglat frana de mana, mi-au schimbat pe garantie contactorul marsarier, au zis ca puntile sunt ok. Mi-au mai zis ca placutele mai au carne 6mm si ca sa vin sa le schimb peste 5000 km. Yeah, right, sa dea altu' 300 ron pe un schimb de placute (asa sunt de proaste ca s-au dus in 12000 km? Ca cine ma stie numai de mers sportiv nu ma suspecteaza. Nu mai bine pun ferodo la 60 ron, huh?) ![]() Timp efectiv de lucru ~ 1h. |
Scenic 1.5dCi
recolta 2012
bassfreak |
#1073
pai daca mai au 6mm carne, te mai tin 15000 km cel putin. parca trebuie sa aiba minim 6mm cu tot cu suport - asa zicea cineva pe aici.
ale mele la 32000km mai aveau carne pe ele jumatate fata de cele noi ferodo pe care le cumparasem, deci puteam sa le las cu succes pana la 50mii cel putin. LE: a, si am facut majoritatea km in bucuresti! This post has been edited by bassfreak: 15 Nov 2006, 21:26 |
Cr3ativ3 |
#1074
![]() Ma-nvart pe-aici...fac cercuri Group: Members Posts: 264 Joined: 19 December 04 From: PITESTI ![]() |
Am si eu 2-3 intebari pt ca maine ma duc in service pt revisia de 2 ani! Am 20.867 KM! Revizia o fac la IATSA Stefanesti Arges!
1 Trebuie sa imi schimbe bujiile?(in carte scrie 30.000 dar............) 2 Trebuie sa dea jos placutele de frana pt a le verifica? 3 5W40 sau 10W40 ca unii au bagat ba una ba alta! Ce e mai bun? Ce marca recomandati? 4 La ce ar trebuie sa fiu atent si ce sa cer mecanicilor? Multumesc anticipat This post has been edited by Cr3ativ3: 15 Nov 2006, 23:26 |
Ambition 2004 Nu stiu sa ma semnez :P !
l@u |
#1075
QUOTE(Cr3ativ3 @ 15 Nov 2006, 15:25) Am si eu 2-3 intebari pt ca maine ma duc in service pt revisia de 2 ani! Am 20.867 KM! Revizia o fac la IATSA Stefanesti Arges! 1 Trebuie sa imi schimbe bujiile?(in carte scrie 30.000 dar............) 2 Trebuie sa dea jos placutele de frana pt a le verifica? 3 5W40 sau 10W40 ca unii au bagat ba una ba alta! Ce e mai bun? Ce marca recomandati? 4 La ce ar trebuie sa fiu atent si ce sa cer mecanicilor? Multumesc anticipat 1-NU 2-DA 3-5W40 4-Citeste in manualul de intretinere+ceea ce crezi tu ca functioneaza anormal Parerea mea!!! ![]() |
Land Rover
Freelander
Td4, HSE
Cr3ativ3 |
#1076
OK! Am mers am facut revizia! Pret-187.12 lei la IATSA Stefanesti
Ulei motor DaciaOil 5W30 4ll-62.75 lei Filtru de aer 30.58 Filtru de ulei 11.60 Total manopera 48.52lei Placutele erau ok! Antigelul garantat pana la -25. Au conectat-o la PC si au gasit o valoare care era ajustata ce calculatorul masinii in functie de stilul de condus mai mare, dar nu stiu ce valoare(ceva cu imbogatirea nu stiu cui) Normala era de 128 si era la 171! Au sters-o si au pus valoare normala! Are ceva daca au bagat W30?Care e diferenta dintre W40 si W30! This post has been edited by Cr3ativ3: 16 Nov 2006, 11:55 |
gdan12 |
#1077
mr Group: Members Posts: 42 Joined: 23 March 05 From: Bucuresti ![]() |
Am facut revizia de 1 an, 7500 km, la Dacoserv Militari:
-ulei motor, Elf Excellium LDX 5W40 din Metro, 119 RON -filtru de aer si de ulei 65 RON (de la magazinul din curte) -manopera 65 RON -bonus mecanic 15 RON Operatii: inlocuire filtre, ulei, verificat antigel, strans suruburi sub masina, pus vaselina la schimbator de viteza si undeva in spate, verificare pe pc. Antigel mai completasem eu, cumparat cu 2 sapt. inainte tot de la ei (19 ron bidonul de 1 l). Am stat tot timpul linga mecanic si nu a fost nici o problema ca am adus uleiul. |
2005, 1.4 LAUREATE
l@u |
#1078
[quote=Cr3ativ3,16 Nov 2006, 03:47]
Care e diferenta dintre W40 si W30! W40 o sa faca fata mai bine decat W30 la vara cand o sa fie cald ![]() This post has been edited by lau0678: 16 Nov 2006, 15:27 |
Land Rover
Freelander
Td4, HSE
simedi |
#1079
![]() Membru ! Group: Members Posts: 25 Joined: 13 November 06 ![]() |
Salut
Dupa prima revizie facuta la Bogyo-Sf.Gheorghe (1 an-cca. 5100 km cost 185 ron) am ramas cu o nelamurire: nu mi-au schimbat filtrul de aer !!! Poate din cauza numarului mic de kilometri? Si ce inseamna ibenol ? Stiu ca trebuia sa-i intreb pe ei cand am platit factura dar eram foarte grabit si mai era si in perioada lansarii MCV, drive-teste...nebunie mare. In rest tratament ok, nu am stat langa masina, dar puteam sa stau la 5 m, dupa un perete de sticla. |
Laureate 1.4 Mpi - 2005
l@u |
#1080
Ibemol-ul este carpa aceea cu care se sterg mecanicii -sper ca nu te-au pus sa o platesti ptr. ca maine s-ar putea sa-ti ceara sa le platesti si salopetele ca doar la masina ta le-au murdarit
Land Rover
Freelander
Td4, HSE
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 22nd July 2025 - 14:59 |
