Mici intrebari - mai tehnice, Ca si celalalt, dar diferit
#481
![]() - Group: Members Posts: 22.548 Joined: 19 April 05 From: Romania ![]() |
#482
![]() fan Dacia Group: Members Posts: 21.389 Joined: 12 November 05 From: Bucuresti ![]() |
au venit inginerii si au inventata camionul de 40 de tone, eh?
- negru pe alb
wolfin |
#483
![]() Haha Group: Members Posts: 8.799 Joined: 2 December 05 From: Bucuresti ![]() |
nu...dar cu avizul inginerului s a furat la bitum.
pegas
3120
#484
Ihi, si pe vremea romailor treceau sute de mii de carute pe zi pe drumul ala.
- negru pe alb
wolfin |
#485
de aceea in Japonia era interzisa roata pe drumurile pietruite
pegas
3120
bion |
#486
Pietruite sau pavate? Fraierii de romani le pavau.Rezista si azi. In zone cu trafic mare se mai faceau sleauri.Vezi la Bombei.
orezarii,The 5 major routes of Japan were at the very least covered by 3cm of gravel and sand and local villages were required to maintain the road to ensure no pot holes landed a samurai in the mud. Important sections of the roads and dangerous sections of the roads were paved with large stones – similar to Roman roads. Dar baza era caratul in carca sau pe cai. This post has been edited by bion: 2 Sep 2022, 09:44 |
SLZ Scala
Agrig |
#487
Membru autentic Group: Members Posts: 3.067 Joined: 13 February 04 From: Jimbolia/Timisoara mai rar. ![]() |
Mai nou loganila a inceput sa porneasca precum televizoul pe lampi, nu pleaca ii trageai un pumn in punctul nevralgic, asa si asta, dau sa-l pornesc i se filfiie antidemarajul, ii trag o palma linga butucul cheii citeva saptamini n-are taine.
![]() Azi am desfacut capacele si am scos bobina, strins contactele in cupla mama, cam de 2 bani conectorul ala, bagat preventiv ceva spray contact si mai vedem, daca mai face pun Portasol-ul pe el! |
Megane IV 1,33Tce
Nelson Mandela |
Merced |
#488
![]() No fear. No limit. No equal. Group: Members Posts: 8.277 Joined: 24 June 07 ![]() |
Aveti doua minute sa discutam despre bateriile termostatate?
Dupa ce am avut la resedinta din mediul rural ani de zile o baterie de cada modelul antic, cu comanda separata pe apa rece si apa calda, cu "obertain"-uri care se gasesc din ce in ce mai greu si de calitate din ce in ce mai indoielnica, prin vara am facut pasul spre o tehnologie pe care o stiam de ceva vreme, pe care o folosisem pe vapoare, o baterie termostatata. Alegerea a fost foarte logica, mai ales ca aici, din cauza sistemului cu hidrofor, si daca apucai sa reglezi o temperatura ok, in momentul pornirii pompei se modifica putin. Plus ca la un dus, abia iti reglai temperatura cat de cat si apoi daca voiai sa faci o economie, cum e la moda la mine aici, nu pentru ca e apa scumpa, ci pentru ca umpli fosa si vidanjarea e scumpa... trebuia sa o iei de la capat. Nu stiu de ce am asteptat atata timp, ca de cel putin doi ani urmaream sa cumpar de la Lidl, dar nu prea am prins cand au mai fost oferte, dar in fine, am luat si sunt FOARTE multumit. Face fix ce vreau sa faca, acum pornesc jucaria, opresc cand vreau, repornesc si se regeleaza imediat la cat trebuie. Am ajuns sa fac un dus cu ~10 l de apa. Fosa imi multumeste! Acum si intrebarea. Am citit prin instructiunile ei ceva la un moment dat ca temperatura maxima a apei calde ar fi 60 de grade. Si nu am inteles daca se refera la temperatura maxima pe care o poate furniza, caz care ar fi ok, ca eu oricum o tin la 38 sau cat zice ca are ea din fabrica, rar o dau mai sus, sau se refera la apa calda care intra in ea. De ce intreb? Pentru ca pentru vara viitoare intentionez sa montez si un panou solar pentru apa calda pe casa. Si apa din ala e vara pe la 80-90 de grade din ce am vazut la matusa-mea care are de vreo trei ani montat un sistem de genul asta. Asa ca intrebarea este: Mai mixeaza corect bateria termostatata sa imi dea 38 de grade cu apa calda de 90 de grade? Sau este peste puterile ei? A testat careva treaba asta? Am tot amanat momentul montarii unui panou ca nu mi s-a parut ca se amortizeaza suficient de repede. Dar la cum se scumpeste curentul... De exemplu in ultima luna am avut aici consum 190Kwh, tinand cont ca apa calda o fac cu un boiler Ariston de 80l cu rezistenta de 1800W(pe care-l tin pe la jumate din termostatul lui) si apa din fantana o scot cu o pompa care parca are tot cam 1800W. Cred ca boilerul merge cam o ora pe zi, depinde de cati suntem pe aici si de consum. Oricum 190kwh este chiar rezonabil si daca ramaneau preturile la curent cat au fost acum 2 ani, sincer nici nu-mi mai bateam capul. Probabil economia ar fi de 80-90kwh pe luna, timp de ~5 luni. Deci la preturile de pe vremuri, 0.4 lei per kwh, amortizam o investitie din asta in ... 10 ani... Acum lucrurile nu par sa mai fie chiar asa. |
Ka
Victorine |
#489
O vană de amestec sub boiler nu face același lucru? Întreb. Pentru că am impresia că sunt mai solide și mai fiabile, plus că cred că acoperă un interval mai mare de temperatură (mă refer la cât suportă, ca să nu-ți mai pui problema asta) decât o baterie termostatată. Și pui una singură, nu duș, lavoar baie, chiuvetă bucătărie, etc.
Un panou solar cu tuburi vidate și rezervor de acumulare nepresurizat a devenit foarte accesibil din câte am văzut la Leroy, mă bătea și pe mine gândul pentru socrii care folosesc boiler. https://www.leroymerlin.ro/produse/search/Panou%20solar Și vezi că la Hidroelectrica e 0.25 lei kWh. ![]() This post has been edited by Victorine: 17 Sep 2022, 07:49 |
Toyota
Auris Touring Sports HSD
2014
Merced |
#490
Aici e o incurcatura mare facuta cu mult timp inaintea mea. Pe vremea cand a facut taica-meu casa asta, a considerat decat sa mai traga fire pe deasupra curtii de la stalp, si sa faca cu ocazia asta bransament propriu, ca e mai simplu sa traga de pe casa bunicului lui, casa care acum a sarit de 100 de ani si care este la vreo 10 metri de a noastra. Ca oricum el se platea facturile acolo, asa l-a invatat pe el un consatean care lucra pe vremea aia la "electrica".
Taica-meu nu mai e printre noi din 1999, intre timp la casa aia batraneasca unde multi ani a venit factura pe numele bunicului lui/strabunicului meu, mort din 1970 btw(am gasit eu facturi/chitante de curent din 1997 si curentul venea pe numele lui), rezolvase o matusa sa treaca pe numele ei. La casa aia sunt 'nspe mii de mostenitori, unii de care nu mai dai, teoretic cred ca am si eu ceva cota parte de pe acolo, desi parca taica-meu la un moment dat a cam renuntat benevol la partile lui(nu stiu daca si aici, nu prea e clar daca a fost la notar, in fine... aiurelile de pe vremea aia nu le mai pot controla). Anul asta a murit si matusa. Probabil o sa mai vina inca 25 de ani factura pe numele ei. Am analizat si sa imi fac bransament propriu. Mi se pare ca o sa ma coste mult prea mult si pentru un beneficiu prea mic. Si daca-l fac eu cu un prieten, partea din curte de la mine, ca tocmai ce l-am ajutat si eu vara asta sa isi faca la el la tara, materialele, bataia de cap, nu stiu daca merita. Legal oricum ar trebui sa prezint o instalatie electrica la nivel de 2022, ceea ce eu nu am aici. Nici impamantare nu am. Am trase doua fire de impamantare la doua prize, cea de langa baie si cea din bucatarie. Fire care nu se duc nicaieri. Mi-am dat seama la un moment dat ca sunt scoase pe exteriorul casei si acolo stau degeaba de cand s-a facut casa. Nu s-a tras platbanda, nu s-au pus tarusi. Probabil daca se ducea pana la capat, ar fi fost un tarus la misto batut si o sarma legata de acolo. Dar aia nu prea e impamantare. Ce am putut face eu impreuna cu amicul care e pasionat de asa ceva si se califica si ca electrician in perioada asta, a fost sa montam un panou electric nou in casa batraneasca, iar spre mine am pus o diferentiala de la ETI, mai exact KZS-1M C25. In caz de ceva, macar sper sa isi faca aia treaba. Cum am stat noi asa pana acum, sper sa nu fie cazul vreodata sa vad daca merge acea diferentiala. Sa ma mai apuc acum sa schimb firele din pereti... Sa pun cupru, ca am aluminiu, cam exclud. Am avut un gand la un moment dat sa incerc sa trag prin tuburile vechi, dar nu am incredere ca o sa mearga. Partea buna e ca n-am avut vreo problema pe aici prin casa pe partea electrica. Toate prizele si intrerupatoarele sunt inlocuite de mine, cablurile desi de aluminiu, sunt destul de groase, in casa am un panou antic cu fuzibile de care nu m-am atins niciodata. Pe unde am mai modificat in ultimii ani, gen tras o noua doza in anexa in care am pus centrala, am folosit cleme wago, am luat o seringa de Aluplus si am bagat peste tot unde am bagat in clema conductorul de aluminiu, ce am mai putut face sa ma asigur ca macar acum cat de cat corect, am facut. Probabil o sa incerc sa fac ceva cu impamantarea aia macar pentru prizele pentru care s-a tras conductorul ala si sa trag si din anexa centralei si de la hidrofor, sa am macar aceste dispozitive conectate la o impamantare. Ca n-o sa reusesc eu sa o fac nici pe aia 100% corecta, dar macar sa fie ceva. In fond nici la bloc nu am impamantare in dormitoare/sufragerie... Daca apuc vreodata sa-mi fac o casa de la 0, o sa fie show. Pe de alta parte nu pot acum nici sa-l acuz pe taica-meu pentru ca la nivelul anilor aia, a facut si el cam ce a putut. Dar nici eu nu ma apuc sa daram peretii, unii dintre ei gletuiti de mana mea de "meserias", ca sa fac acum de la 0 instalatia. |
Ka
marksman |
#491
Post mortem nihil est Group: Members Posts: 7.679 Joined: 1 November 04 From: sat ![]() |
Ce naiba, toți pun în rezidențial diferențiale pe curba C? Nici eu n-am mai citit normativul I7 de ani buni, dar rețin că în rezidențial mori până declanșează o diferențială pe curba C. Oricum, așa am și eu pus, am căutat pe B, tot ce găsești în magazinele de bricolaj sunt pe C, B doar în anumite magazine care aduc la comandă, pe motiv "păi lumea tot de astea pune, boss, alea pă B declanșează și dacă bagi ștecheru-n priză". Evident, la cum se fac legăturile în doze.
Opel / Mazda
Crossland X / CX-30
2019 / 2020 Charlie Foxtrot: Massively vote Charlie Golf for President!
Agrig |
#492
Este vorba de apa calda pe intrare sa nu fie mai mare de 60C, cel putin din ce stiu de la un amic, fix cu asta s-a confruntat la o casa de vacanta, a pus incalzire solara si cind este foarte calda apa scoate prea fierbinte, domeniul de reglaj al termostatului este limitat. La mine la centrala apa este pe la 45-50C reglata deci n-am treaba cu domeniul de reglaj.
Instalatia din Al daca este bine dimensionata este foarte buna, problemele apar doar la legaturile de la prize in general. La bloc tot asa am si daca a fost sa schimb o priza preventiv am pus mai demult cleme cu surub si prelungire de Cu dar acum citiva ani le-am schimbat cu mufe de sertizare si pina acum nu am avut nici o alta problema. La ora asta sint mufe din Cu-Al insa doar de la 10mmp in sus precum si saibe binetalice. Disjunctoarele magneto termice care au curba C admit curentul instantaneu maxim mai mare decit cele cu B, este util daca ai prin casa ceva motoare electrice mai marisoare. In fapt lucreaza pe 2 principii diferite, pentru scurt decupleaza partea magnetica care este rapida, 10ms daca mai tin minte este cerinta iar pentru suprasarcina decupeaza partea termica, aia reglata fin. Diferentialele n-au treaba sa decupleza pe curba C daca apare curent de scurgere spre pamint, doar acolo protejaza la curentare, faza-pamint, faca te curentezi intre faza si nul te trateaza ca pe un consumator. ![]() La detectia scurgerii spre pamint deconecteaza instant, max 30ms cred. This post has been edited by Agrig: 17 Sep 2022, 09:50 |
Megane IV 1,33Tce
Nelson Mandela |
Merced |
#493
Am greșit eu când am scris C25, asta era să o ia din greșeală inițial apoi a comandat B25. Am vrut să pun poza dar la cum e forumul acum, nu mă lasa. Este mai exact un rcbo eti KZS-1M-DN 1p+N A B25/0.03 6kA .
Și așa a stricat una că a alimentat-o aiurea... Așa a învățat pe pielea mea să știe să nu mai greșească pe viitor. Și celelalte siguranțe sunt tot B. Și el are fixul asta ca în magazine de găsesc mai mult C. Mulțumesc pentru informații, deci daca pun panoul solar musai o sa pun și o vana de amestec. Mai vedem și cu soarele, că nu prea mai sunt pe stoc nicăieri. Cel puțin nu la aprox 1500 lei, cat erau cu un an și ceva in urma . |
Ka
bucatzel |
#494
![]() Membru plictisit Group: Moderatori Posts: 6.465 Joined: 19 May 08 From: Timisoara ![]() |
Intrebare pentru "uleiosii" forumului. Cat de diferite sunt T90 si 80W90? Ce s-a scris pe vremuri pe la 13xx, ambele se bagau in cutia de Dacie, al doilea fiind mai bine vazut decat primul. La mine nu prea conteaza comportamentul iarna, i-am luat doar caucioace de vara, dar fiind cutia cu etansare cu semeringuri de pasla, daca e uleiul prea subtire, o sa mi se scurga.
1981
Marty |
#495
T90 e monograd, alalaltu-i multigrad. As zice ca vascozitatea-i aceeasi in stare normala, difera doar temperaturile la care se transforma-n marmelada/pishwasser.
Gillette
De unica folosinta
2011
tatabobu |
#496
Nu, e invers. Vascozitatea la temperatura de lucru e aproximativ aceeasi, dar 80w90-ul ar trebui sa fie mai subtire la temperaturi scazute, si e mai probabil sa se prelinga.
Marty |
#497
La temperaturi joase, uleiul se-ngroasa; la temperaturi ridicate, se subtiaza.
Gillette
De unica folosinta
2011
#498
daca e monograd, da.
- negru pe alb
Marty |
#499
Si, daca-i multigrad, e invers? La cald se-ngroasa si la rece se subtiaza?
Gillette
De unica folosinta
2011
#500
Nu fata de vascozitatea20C, dar va rezista mai mult tendintei de ingrosare la rece respectiv subtiere la cald.
This post has been edited by einstein1984: 25 Oct 2022, 12:47 |
- negru pe alb
Marty |
#501
Si io ce plm am zis?
Gillette
De unica folosinta
2011
georgstelsib |
#502
Membru Group: Members Posts: 136 Joined: 17 May 15 ![]() |
QUOTE(bucatzel @ 24 Oct 2022, 19:50) Intrebare pentru "uleiosii" forumului. Cat de diferite sunt T90 si 80W90? Ce s-a scris pe vremuri pe la 13xx, ambele se bagau in cutia de Dacie, al doilea fiind mai bine vazut decat primul. La mine nu prea conteaza comportamentul iarna, i-am luat doar caucioace de vara, dar fiind cutia cu etansare cu semeringuri de pasla, daca e uleiul prea subtire, o sa mi se scurga. T90 va fi mai gros la temperaturi negative decat 80W90 . La temperaturi ridicate si normale va avea cam aceeasi vascozitate . De preferat cel multigrad, fiindca usureaza pornirea si reduce consumul la pornirea la rece . La cel monograd , T90 , este indicat sa apesi ambreiajul la prima pornire a zilei si la temperaturi negative , pentru a decupla cutia de viteze si a nu se mai roti trenul fix in uleiul ingrosat . |
bmwh548 |
#503
QUOTE(marksman @ 17 Sep 2022, 10:27) Ce naiba, toți pun în rezidențial diferențiale pe curba C? Nici eu n-am mai citit normativul I7 de ani buni, dar rețin că în rezidențial mori până declanșează o diferențială pe curba C. Oricum, așa am și eu pus, am căutat pe B, tot ce găsești în magazinele de bricolaj sunt pe C, B doar în anumite magazine care aduc la comandă, pe motiv "păi lumea tot de astea pune, boss, alea pă B declanșează și dacă bagi ștecheru-n priză". Evident, la cum se fac legăturile în doze. Te protejeaza si C-ul. Eram in apa pana la gat, daca nu ar fi fost suficient de rapid nu mai butonam azi. |
Marty |
#504
Din experientele voastre, care-i cea mai eficienta modalitate de a polisha un far, de fapt, care-i cea mai eficienta/sigura metoda de a proteja farul respectiv:
- smirghel + polish + protectie lichida; - smirghel + polish + lacuire; - smirghel + polishare + folie transparenta; - smirghel + polimerizare ? This post has been edited by Marty: 1 Nov 2022, 14:12 |
Gillette
De unica folosinta
2011
psychoo |
#505
![]() Membru Group: Members Posts: 3.685 Joined: 23 August 07 From: Timisoara ![]() |
Am facut eu experimente si am descoperit ca polimerizarea este doar diluant, nu ofera protectie UV ceea ce inseamna ca farul se va ingalbeni in maxim 12 luni de la reconditionare
Polish nu se face pe o suprafata deteriorata, doar pe o suprafata care are lacul suficient de bun pentru a fi polisat. Deci raspunsul este: curatat lacul vechi de pe faruri cu smirghel P500-P600 Grija mare sa se curete tot lacul, altfel se va vedea sub noul strat Dupa P500 se slefuieste cu P1200-1500 ca sa matuiesti cu zgarieturi fine Se degreseaza cu alcool tehnic si carpa care sa nu lase scame Se foloseste lac BICOMPONENT! Exista si la spray cu un capacel rosu care activeaza intaritorul si se poate utiliza in maxim 48 ore de la activare (unii zic ca si mai mult daca il tii la frigider) Se da primul strat subtire, altfel curge si o iei de la capat Daca vezi ca se albeste farul cand dai urmatoarele straturi NU TE PANICA, se va face transparent cand se usuca. Maxim 3 straturi, ce e peste va fi prea gros si risca sa se ciobeasca la lovituri de pietre. Minim 5 minute intre straturi, maxim 15. Poti verifica pe banda de mascare apasand cu degetul. Trebuie sa simti ca si cum ai atinge lipiciul unei benzi adezive: nu e ud, e lipicios Grija mare mai ales pe vremea asta cu roua. Minim 24 ore e recomandat sa nu se ude suprafata. Daca lacuiesti la pranz cand ai soare si te prinde umezeala de seara o sa se albeasca lacul. Mai bine il dai jos si il bagi in casa peste noapte Dupa 1-2 zile daca ai imperfectiuni si praf le poti polisa. Smirghelit cu P2000 ca sa elimini imperfectiunile, smirghelesti cu P3000-P5000 zona retusata, apoi pasta de polish si burete, neaparat cu un dispozitiv care are minim 10.000RPM. La mana nu vei putea sa faci transparent. Se curata farul cu apa, se sterge ca sa fie uscat, apoi se poate polisa cu disc cu lana sau pasla Durabilitatea este data de calitatea lacului, deci pentru a nu reface periodic operatiunea dai un ban (eu am dat 100 lei pe un tub dar nu stiu sa zic inca daca e "ce trebuie") This post has been edited by psychoo: 1 Nov 2022, 14:28 Attached thumbnail(s) Screenshot_20221101_142354_Gallery.jpg ( Size: 1.77mb ) Number of downloads: 247 Screenshot_20221101_142408_Gallery.jpg ( Size: 1.83mb ) Number of downloads: 250 Screenshot_20221101_142505_Gallery.jpg ( Size: 1.56mb ) Number of downloads: 248 Screenshot_20221101_142446_Gallery.jpg ( Size: 1.79mb ) Number of downloads: 248 |
Focus
YRX |
#506
![]() Membru autentic Group: Members Posts: 5.050 Joined: 6 July 06 From: Bucuresti ![]() |
Psychoo... 10.000 rpm??? Ala e flex, nu masina de polishat, topesti si farul, nu numai lacul.
2005 Ambition 1.6 MPI
psychoo |
#507
Doar daca apesi tare pe el...
Eu am un orbital de la dexter care are 13000 rpm in gol. Nu i.am dat chiar la maxim, dar mai mult de jumatate si nu s.a topit nimic ![]() |
Focus
volint |
#508
![]() membru miserupist Group: Members Posts: 317 Joined: 7 September 04 From: Bucuresti (44.45682;26.13879) ![]() |
Dacia / Mitzu
Nova GTI / hautlandăr
2000 / 2011
YRX |
#509
paul_damian |
#510
Nu sunt electrician, asa ca... ajutor!
Un convertizor de frecventa se programeaza cu cateva date ale motorului. Tensiune, putere, curent, bobinaje, din astea. Dar mai e un parametru numit "rated slip" si se cere un rpm. Ce aghiuta e asta, ca goagal nu ma ajuta? |
Sandero
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 14th May 2025 - 01:57 |
