dacia injectie, exclusiv sistemul de injectie (berlina/nova)
vespukci |
#4231
vespukci Group: Members Posts: 230 Joined: 15 June 10 ![]() |
2000
adriano94 |
#4232
![]() Membru autentic Group: Members Posts: 279 Joined: 30 May 09 ![]() |
e cam exagerat 10 min, cum se creeaza presiune la voi??tine-ti vasu strans la maxim??eu stiam ca se lasa slab :|
This post has been edited by adriano94: 11 Jan 2011, 20:44 |
2002 Li
- XX 11 NED
vladpop |
#4233
![]() Membru incepator Group: Members Posts: 28 Joined: 28 March 10 From: Medias ![]() |
1310 CLi Break
- SB-05-HJD
adriano94 |
#4234
Si iti merge rotund motorul la relanti?
Perfect! |
2002 Li
- XX 11 NED
ghitza |
#4235
asa sta si la mine pe ceas la 500 acuma nush cat arata pe tester dar o sa ma uit cand ma duc cu ea si sta bine nu tremura
Dacia/BMW 316i an 99
1310 li
2003 Berlina
- Ar-07-GIB/BG
vladpop |
#4236
interesant...
1310 CLi Break
- SB-05-HJD
Crisescu |
#4237
![]() Membru incepator Group: Members Posts: 50 Joined: 21 April 06 ![]() |
La 500 de ture
![]() ghita,poate ma ajuti cu poza aia mai buna! Thx! |
Dacia 1310LI
BREAK
- PH62ABG
Andyno |
#4238
![]() Membru autentic Group: Members Posts: 1.435 Joined: 9 June 09 From: Bucuresti. ![]() |
500 ture? aveti ceasuri de logan? numai la logan turometrul are liniuta de 500 ture..eu asa am vazut.
la mine statea cu o liniuta sub 1000 ture...dar acum nu stiu dece numai coboara sub 1000. la voi acum ca-i mai cald afara, cat de repede urca acul la temeperatura? sau cand era mai frig...la mine dupa 10 km se ridica 1 cm si am carton. This post has been edited by Andyno: 12 Jan 2011, 10:12 |
Dacia 1310, an 99'.
Toyota Hilux D4D 170 CP 2007.
Dacia 1310, an 20' injectata.
mrkiry |
#4239
![]() Din tara unde nici apocalipsa nu ajunge... Group: Members Posts: 1.818 Joined: 2 December 10 From: Bucuresti ![]() |
Daca ceasul arata 500 de ture si motorul merge rotund,ceva este in neregula...Mersul normal este de 850+/- 50 rot/min.
![]() Si apropo de logan,nici la ala pe motorina nu sta la 500 de ture.Poate doar la autobuze ![]() This post has been edited by mrkiry: 12 Jan 2011, 13:11 |
Megane2
2004 Lux Privilege
- GR85KYR Renault Megane 2,1.6 16v,113 cp,an 2004
vladpop |
#4240
1310 CLi Break
- SB-05-HJD
madal8n |
#4241
Membru incepator Group: Members Posts: 10 Joined: 4 January 11 ![]() |
si la mine e la fel sta sub liniuta de 900 dupa ce se-ncalzeste , dar din cand in cand mai sare spre 1000 , nu stiu ce o avea , o fi de la bujii ma gandesc sa le schimb cu bosch wr8bc , acum am eyquem !
1310i
2000
- ph-97-min
vladpop |
#4242
QUOTE(madal8n @ 12 Jan 2011, 14:13) si la mine e la fel sta sub liniuta de 900 dupa ce se-ncalzeste , dar din cand in cand mai sare spre 1000 , nu stiu ce o avea , o fi de la bujii ma gandesc sa le schimb cu bosch wr8bc , acum am eyquem ! Si la mine sare asa o fractiune de secunda, cred ca sunt curenti vagabonzi, nu cred ca bujiile sunt de vina, si cand pornesc ventilatorul cateodata oscileaza excelent pana la 3000rpm ![]() This post has been edited by vladpop: 12 Jan 2011, 14:26 |
1310 CLi Break
- SB-05-HJD
Andyno |
#4243
mda...azi dupa ce am mers vro 40 km prin oras, am obs ca limba de la temperatura s a ridicat 2 cm, dar inca nu a ajuns la jumate..char si cu carton.
turatia statea perfect la 900 rpm...cred ca termostatul nu mai functioneaza bine. |
Dacia 1310, an 99'.
CGDBZ |
#4244
Membru autentic Group: Members Posts: 2.487 Joined: 8 July 09 From: BZ ![]() |
Ce bine e de mine ca nu am turometru si nici ceas pentru temperatura apei
Andyno |
#4245
da...ai decat vitezometru si indicator bezina...ma mir le a pus si pastea
Dacia 1310, an 99'.
adriano94 |
#4246
Daca ceasul arata 500 de ture si motorul merge rotund,ceva este in neregula...Mersul normal este de 850+/- 50 rot/min. biggrin.gif
Si apropo de logan,nici la ala pe motorina nu sta la 500 de ture.Poate doar la autobuze laugh.gif arata-mi si mie unde scrie??cand o sa o pun pe tester o sa ii fac o poza sa va arat,dar mai dureaza..... |
2002 Li
- XX 11 NED
ghitza |
#4247
CRISESCU:nu inteleg ce e asa de greu daca am zis un surubel micut cu cap de imbus aflat in dreapta corpului clapeta(inspre radiator) pe care se sprijina clapeta,care este impinsa de jos de motorasu de relanti,sus sta pe acest surubel care il poti strange sau destrange,logic daca il strangi urca turatia ,uite ti-am tras o poza explicata cat de cat ,sper sa te ajute
Attached thumbnail(s) SDC11241_surubel.JPG ( Size: 309.03k ) Number of downloads: 430 |
1310 li
2003 Berlina
- Ar-07-GIB/BG
Crisescu |
#4248
Multumesc mult ghita,acum m-am lamurit.La mine,nici cu relantiul la 750 acel surubel nu se atinge de nimic...mai raman vreo 2 mm de cursa...si asa e din fabrica,de-aia nu-mi dadeam seama de care surub e vorba.Inca are vopseaua de sigil pe el.Asa ca sunt cam in dubiu...dar cred ca o sa incerc si varianta ta si-o sa umblu la el.
Dacia 1310LI
BREAK
- PH62ABG
ghitza |
#4249
nu strici nimic daca umbli la el fi fara griji,daca nu e bine il dai innapoi si gata
1310 li
2003 Berlina
- Ar-07-GIB/BG
nyky |
#4250
![]() Membru Group: Members Posts: 114 Joined: 17 March 10 From: Tm ![]() |
Si la mine tot pe la 600 sta, verificat cand am facut itp, da nu tremura sau altceva. Vara sta acul la temperatura aproape de rosu la mine, chiar mai si trece putin peste, sistemul e aerisit si curatat iar antigelul e nou. inca nu am avut probleme, poate asa face ea.
Fiat/ Alfa Romeo
STILO/ 159
2002 . 1.2 16volti , 80 de cai./ 2.4 jtdm
adriano94 |
#4251
nu iti indica bine,trebuia sa te uiti si la temperatura sa vezi
2002 Li
- XX 11 NED
Paulorossi |
#4252
Salut prieteni.Revin cu problema mea legata de termostat,azi am masurat iar rezistenta senzorului de temperatura ECU dupa un drum de aprox 20 km.Mentionez ca am pe jumatea radiatorului carton iar temperatura mediului exterior a fost undeva la 6 grade.Valoarea rezistentei senzorului de temperatura a fost de 350 ohm,din graficul manualului de injectie corespunzatoare unei temperaturi de aprox 79 grade.
Rog pe cineva daca poate sa masoare la cald rezistenta sondei de temperatura(cealalta) care are un singur fir si care este folosita de indicatorul de temp al masinii. Se masoara intre papuc si masa motorului.Stiu ca la masuratoarea efectuata de mine am inregistrat valoarea de 700 ohm,valoare la care acul indicator statea intre linia de mijloc si partea de jos.Asa voi sti daca e decalibrata sonda ECU/sonda de temp de la ceas sau e partial blocat pe deschis termostatul.Mentionez ca masina da caldura dar am sesizat ca se incalzeste intr-un timp mai lung. Multumesc anticipat. This post has been edited by Paulorossi: 12 Jan 2011, 18:18 |
1310Li
adriano94 |
#4253
Paulorossi: cred ca e de la termostat daca zici ca se incalzeste mai greu
2002 Li
- XX 11 NED
Andyno |
#4254
ghitza: am umblat si eu la surubelul ala ptr turatie...la mine este de forma...nu face nimic ptr ca nu atinge de nimic.
este spatiu de 1 cm intre el. |
Dacia 1310, an 99'.
ghitza |
#4255
asa mare?
1310 li
2003 Berlina
- Ar-07-GIB/BG
Andyno |
#4256
e puii si cu tine...asta nu stiu
![]() am pornit masina si ma m uitat la surubelul ala...am obs ca nu se poate regla nimic de acolo... cand se incalzeste este posibil sa se mai lase clapeta sau ce? |
Dacia 1310, an 99'.
ghitza |
#4257
pai la cald se face nu la rece ,caci la rece asa e cum ai zis mai sus pentru ca nu scade relantiu motorasu fiindca e rece motoru,las-o sa ajunga la temperatura de lucru (89-90)si atunci umbli acoloo si il faci mai mare
1310 li
2003 Berlina
- Ar-07-GIB/BG
Andyno |
#4258
azi am schimbat termostatul !
motorul ziua se incalzeste in 1 km...acul sta la linia alba de sus. sta perfect la relanti la 800 rpm..si la 700 rpm si a scazut si consumul !!...bine nu de la relanti. ![]() This post has been edited by Andyno: 15 Jan 2011, 00:40 |
Dacia 1310, an 99'.
adriano94 |
#4259
uitati relantiul meu de la masina
![]() Attached thumbnail(s) 15_01_11_0925.jpg ( Size: 29.88k ) Number of downloads: 286 |
2002 Li
- XX 11 NED
tazman887 |
#4260
Membru incepator Group: Members Posts: 14 Joined: 15 January 11 ![]() |
Am o dacie break pe injectie din 2000 si cateodata incepe sa o ia razna in mers si o las la relanti.... se tureza singur motorul ... se duce pana la 2000 turatii iar la 0 iar la 2000 si tot asa pana il opresc si il pornesc din nou... din aceeasi cauza...(variatia turatiei de relanti) raman si fara frane in mersdeoarece cred eu presiunea de vacuum la frane nu mai este constanta... ce e de facut?!
This post has been edited by tazman887: 15 Jan 2011, 17:54 |
break
2000
- GJ 62 BDM
DaciaClub - Reno Bot |
![]() Mesaj automat ![]() |
Pentru celelalte probleme, sunt deja topicuri dedicate pe aria comună CLT si Nova... |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 8th June 2025 - 16:46 |
